C6747使用K9K2G16ABA,利用test程序可以读出ID号,想烧写.bin文件,修改REL_LSP_02_20_00_07下的nand_writer程序,将
DEVICE_BusWidth DEVICE_emifBusWidth( void ) [ return DEVICE_BUSWIDTH_8BIT; ] 修改为 DEVICE_BusWidth DEVICE_emifBusWidth( void ) [ return DEVICE_BUSWIDTH_16BIT; ] 初始化设置时将EMIFA的CS3设置也改为16bit,但跑到NAND_readPage这个程序的ECC校验时,会return E_FALL,查看这时候的src和dest的值,发现dest会间隔1个或2个或四个数的值为0,这是什么原因?? |
6 个讨论
对照一下手册看K9K2G16ABA是事满足下面所说的条件:
20.2.5.6.8 Interfacing to a Non-CE Don't Care NAND Flash As explained in Section 20.2.5.6.4, the EMIFA does not support NAND Flash devices that require the chip select signal to remain low during the tR time for a read. One way to work around this limitation is to use a GPIO pin to drive the CE signal of the NAND Flash device. If this work around is implemented, software will configure the selected GPIO to be low, then begin the NAND Flash operation, starting with the command phase. Once the http://processors.wiki.ti.com/index.php/Main_Page Think Over Before Asking. http://www.catb.org/~esr/faqs/smart-questions.html#goal |
lifei639156 发表于 2018-7-25 06:48 您好,我看了数据手册,MT29F2G16 read page和program page 都是with CE# don't care,而且ID为0xCA在支持的列表中 |
终于找到问题的原因了,现在可以烧写程序了,总结一下,供参考
1、NAND_open()->ASYNC_MEM_Open()->DEVICE_AsyncMemInit()->DEVICE_pinmuxControl(15,0xFFFFFFFF,0x11888888); 将管脚设置为8位,注释掉函数中的所有管脚定义 2、(*hAsyncMemInfo->hDeviceInfo->fxnInit)(hAsyncMemInfo); 调用了DEVICE_ASYNC_MEM_Init() ABCR[hAsyncMemInfo->chipSelectNum] = 0x3FFFFFFC | ((hAsyncMemInfo->busWidth == DEVICE_BUSWIDTH_8BIT)? 0 : 1);修改了寄存器CE3CFG的值,注释掉即可。 |
832 浏览 1 评论
1071 浏览 0 评论
620 浏览 1 评论
469 浏览 1 评论
663 浏览 2 评论
265浏览 29评论
1228浏览 23评论
360浏览 20评论
337浏览 14评论
204浏览 13评论
GMT+8, 2025-3-7 00:24 , Processed in 1.155810 second(s), Total 83, Slave 67 queries .
