描述
This reference design uses the TPS54218 in a synchronous buck-boost configuration to generate a negative 0.5V output from a 3.3V input. Switching at 1MHz, the total solution size is extremely compact. An external LM4040 reference provides a precision pull-up voltage and is necessary to regulate the (...)
5116 浏览 0 评论
自己设计的Arduino UNO R3主控板原理图+PCB源文件(可直接打样)
5099 浏览 0 评论
63462 浏览 1 评论
2869 浏览 2 评论
7159 浏览 0 评论
基于峰岹的FU6813L波轮洗衣机控制方案(原理图+PCB+源程序
93059浏览 4评论
2872浏览 2评论
5154浏览 1评论
63522浏览 1评论
7161浏览 0评论
GMT+8, 2025-1-1 19:13 , Processed in 0.966472 second(s), Total 77, Slave 55 queries .
