在iodefine.h 文件中,对IO寄存器进行了定义,例如对port0的定义: struct st_port0 { union { unsigned char BYTE; struct { unsigned char :5; unsigned char B2:1; unsigned char B1:1; unsigned char B0:1; } BIT; } PDR; char wk0[31]; union { unsigned char BYTE; struct { unsigned char :5; unsigned char B2:1; unsigned char B1:1; unsigned char B0:1; } BIT; } PODR; char wk1[31]; union { unsigned char BYTE; struct { unsigned char :5; unsigned char B2:1; unsigned char B1:1; unsigned char B0:1; } BIT; } PIDR; char wk2[31]; union { unsigned char BYTE; struct { unsigned char :5; unsigned char B2:1; unsigned char B1:1; unsigned char B0:1; } BIT; } PMR; char wk3[31]; union { unsigned char BYTE; struct { unsigned char :3; unsigned char B4:1; unsigned char :1; unsigned char B2:1; unsigned char :1; unsigned char B0:1; } BIT; } ODR0; char wk4[63]; union { unsigned char BYTE; struct { unsigned char :5; unsigned char B2:1; unsigned char B1:1; unsigned char B0:1; } BIT; } PCR; char wk5[31]; union { unsigned char BYTE; struct { unsigned char :5; unsigned char B2:1; unsigned char B1:1; unsigned char B0:1; } BIT; } DSCR; }; 其中的char wk0[31]; char wk1[31];等是表示什么意思(功能)? |
4个回答
你好!你的问题我们已经收到,会尽快答复,请随时关注Rulz新消息! |
wk这个变量是用来占用两个寄存器地址之间的空白位置的,比如PORT0.PDR的地址为0008 C000h,中间通过32长度的数组wk[31],进行空间占位,那么下一个寄存器PORT0.PODR地址为0008 C020h。后续所有的wk的数组都是用来对空间进行占位的。这个数组变量在编程的时候不能使用。 |
明白了,谢谢 |
In reply to Seven Sun: 明白了,谢谢 |
请问一个迭代法图形二值化的程序代码把宽改成240之后整个屏幕不显示是什么原因?
2701 浏览 0 评论
2693 浏览 1 评论
1927 浏览 1 评论
2081 浏览 2 评论
2652 浏览 2 评论
791浏览 0评论
GMT+8, 2025-2-3 07:20 , Processed in 0.490621 second(s), Total 56, Slave 47 queries .
