扫一扫,分享给好友
4个回答
我用串口数据打印时间看了一下,是1秒钟。
是的,一秒钟 ,可以设置, Watchdog_setReload(watchdogHandle, 3*1500000); // 3s, per 1500000= 1sec |
Watchdog_Params_init(¶ms);params.callbackFxn = (Watchdog_Callback)watchdogCallback;params.resetMode = Watchdog_RESET_ON;watchdogHandle = Watchdog_open(Board_WATCHDOG0, ¶ms);Watchdog_setReload(watchdogHandle,1500000);//1sec (WDT runs always at 48MHz/32) 仔细看参数请勿重复发帖,谢谢。 |
the WDT can be configured to generate an interrupt to the microcontroller (MCU) on its first time-out and
to generate a reset signal on its second time-out. 也就是说,两倍设定时间不喂狗才触发复位。第一次计时到只会触发中断,不会触发复位。 |
586 浏览 1 评论
425 浏览 1 评论
619 浏览 2 评论
909 浏览 3 评论
709 浏览 1 评论
191浏览 29评论
1152浏览 23评论
323浏览 20评论
286浏览 14评论
135浏览 13评论
GMT+8, 2025-2-2 19:34 , Processed in 0.731760 second(s), Total 52, Slave 46 queries .
