扫一扫,分享给好友
如题:
在SPI通讯中,需要用到修改SPI频率,使用 SPIConfigSetExpClk()修改,导致出错,有单独修改的API?或者修改需要怎么设置?谢谢 void SPI_BATE_SET(unsigned long rate) [ MAP_SPIReset(SPI_BASE); // // Configure SPI interface // MAP_SPIConfigSetExpClk(SPI_BASE,MAP_PRCMPeripheralClockGet(SPI_PRCM), rate,SPI_MODE_MASTER,SPI_SUB_MODE_0, (SPI_HW_CTRL_CS | SPI_4PIN_MODE | SPI_TURBO_OFF | SPI_CS_ACtiVELOW | SPI_WL_8)); // // Enable SPI for communication // MAP_SPIEnable(SPI_BASE); ] 邮件中提到需要通过修改SPI频率: After reset, wait for DREQ to be high, set your SPI to around 1.7MHz (12.288/7 = 1.755), then write 0xe000 to SCI_CLOCKF (5.0x 12.288MHz). The CLOCKF value sets 61.44MHz clock, and when DREQ is high again, then you can use 8.5Mbit/sec for SCI reads. (61.44/7 = 8.77) |
邮件中提到需要要修改SPI频率
340 浏览 1 评论
533 浏览 2 评论
777 浏览 3 评论
653 浏览 1 评论
1132 浏览 1 评论
63浏览 29评论
164浏览 23评论
253浏览 20评论
203浏览 14评论
60浏览 13评论
GMT+8, 2024-12-24 01:45 , Processed in 0.393429 second(s), Total 44, Slave 39 queries .
