扫一扫,分享给好友
在rdk3.5下,nfs挂载下
root@DM8127_IPNC:~# passwd root Changing password for root Enter the new password (minimum of 5, maximum of 8 characters) Please use a combination of upper and lower case letters and numbers. Enter new password: Bad password: too short. Warning: weak password (continuing). Re-enter new password: passwd: An error occurred updating the password file. 在nfs下passwd 更改密码不成功?在nand下,可以passwd更改成功,请问这是什么原因? |
3个回答
Lu Xinjian,
你使用的是默认带的nfs文件系统么?我这里尝试在IPNC RDK 3.5下nfs可以修改密码 (我修改的时候应用程序没有起来) : root@DM8127_IPNC:/opt/ipnc# passwd root Changing password for root Enter the new password (minimum of 5, maximum of 8 characters) Please use a combination of upper and lower case letters and numbers. Enter new password: Bad password: too simple. Warning: weak password (continuing). Password changed. |
物是人非aaa 发表于 2018-6-23 01:15 你好! 我确认是nfs挂载的根文件出现的问题 root@DM8127_IPNC:/etc# passwd root Changing password for root Enter the new password (minimum of 5, maximum of 8 characters) Please use a combination of upper and lower case letters and numbers. Enter new password: Bad password: too simple. Warning: weak password (continuing). Re-enter new password: passwd: An error occurred updating the password file. 用flash启动是可以更改 |
Lu Xinjian, 我已经使用IPNC RDK3.5包自带的文件系统,通过nfs启动,修改root密码成功。你能否尝试一下IPNC RDK3.5包自带的文件系统? 请问你使用的nfs文件系统是否基于软件包自带的文件系统修改过什么,导致了问题? |
595 浏览 1 评论
447 浏览 1 评论
633 浏览 2 评论
937 浏览 3 评论
716 浏览 1 评论
213浏览 29评论
1175浏览 23评论
336浏览 20评论
300浏览 14评论
155浏览 13评论
GMT+8, 2025-2-12 14:59 , Processed in 0.796478 second(s), Total 47, Slave 42 queries .
