扫一扫,分享给好友
参考论坛上的《Ubifs文件系统的制作和启动.pdf》制作镜像文件,之前的步骤都正常。生成镜像时:
mkfs.ubifs -F -q -r /home/usr/rootfs_2_0_1 -m 2048 -e 126976 -c 2047 -o ubifs.img 此时提示-F选项无法使用。此时的打印如下 mkfs.ubifs: invalid option -- 'F' Usage: mkfs.ubifs [OPTIONS] target Make a UBIFS file system image from an existing directory tree Examples: Build file system from directory /opt/img, writting the result in the ubifs.img file mkfs.ubifs -m 512 -e 128KiB -c 100 -r /opt/img ubifs.img The same, but writting directly to an UBI volume mkfs.ubifs -r /opt/img /dev/ubi0_0 Creating an empty UBIFS filesystem on an UBI volume mkfs.ubifs /dev/ubi0_0 Options: -r, -d, --root=DIR build file system from directory DIR -m, --min-io-size=SIZE minimum I/O unit size -e, --leb-size=SIZE logical erase block size -c, --max-leb-cnt=COUNT maximum logical erase block count -o, --output=FILE output to FILE -j, --jrn-size=SIZE journal size -R, --reserved=SIZE how much space should be reserved for the super-user -x, --compr=TYPE compression type - "lzo", "favor_lzo", "zlib" or "none" (default: "lzo") -X, --favor-percent may only be used with favor LZO compression and defines how many percent better zlib should compress to make mkfs.ubifs use zlib instead of LZO (default 20%) -f, --fanout=NUM fanout NUM (default: 8) -k, --keyhash=TYPE key hash type - "r5" or "test" (default: "r5") -p, --orph-lebs=COUNT count of erase blocks for orphans (default: 1) -D, --devtable=FILE use device table FILE -U, --squash-uids squash owners making all files owned by root -l, --log-lebs=COUNT count of erase blocks for the log (used only for debugging) -v, --verbose verbose operation -V, --version display version information -g, --debug=LEVEL display debug information (0 - none, 1 - statistics, 2 - files, 3 - more details) -h, --help display this help text 将-F参数去掉的话,会继续提示-q参数不可用。将上述两个参数都去掉才能生成镜像。对于8168,这样的镜像是否可用? 参考http://www.360doc.com/content/14/1015/18/18578054_417224516.shtml,使用了最新版本的mtd-utils,结果还是一样 参考http://www.qiyangtech.com/news/ARM-development-board-faq2-c0eji0c9yhybra01.html,检查了mkfs.ubifs工具和文件系统的路径,未发现异常。 mtd-utils的版本:mtd-utils-1.5.2 库版本分别是e2fsprogs-1.42.13,zlib-1.2.8,lzo-2.06 ubuntu版本:10.04 LTS ubuntu内核版本是2.6.32 |
4个回答
你好,
你使用的是文档里面链接里面最新的工具,还是就是文档里面使用的工具版本?会否是版本匹配问题。 ubuntu10.04应该是没有问题的。现在的问题和你使用的芯片也没有直接关系。 |
物是人非aaa 发表于 2018-6-22 05:50 谢谢关注! 论坛pdf资料里提到的链接,并没有一个确定的版本号。自己找的另外一个链接,也就是主贴提到的那个网址。版本号号称是1.5.2 |
物是人非aaa 发表于 2018-6-22 05:50 更换了一下版本 zlib-1.2.5 lzo-2.06 e2fsprogs-1.42 mtd-utils-1.5.1 不过问题依旧 |
问题找到了:mkfs.ubifs和ubinize用法不对。之前没有加"./",这样使用的就是本机的mkfs.ubifs和ubinize。加上"./"后,问题解决
使用的命令参数如下 ./mkfs.ubifs -F -q -r /home/cx/DVRRDK_04.00.00.03/target/rootfs_2_0_1 -m 2048 -e 126976 -c 2047 -o ubifs.img ./ubinize -o ubi.img -m 2048 -p 128KiB ubinize.cfg 可以用-V参数来确认mkfs.ubifs的版本 本机版本:mkfs.ubifs -V Version 1.3 要使用的版本:./mkfs.ubifs -V mkfs.ubifs 1.5.2 |
813 浏览 1 评论
1066 浏览 0 评论
615 浏览 1 评论
465 浏览 1 评论
658 浏览 2 评论
261浏览 29评论
1223浏览 23评论
354浏览 20评论
333浏览 14评论
197浏览 13评论
GMT+8, 2025-3-4 21:14 , Processed in 0.747030 second(s), Total 49, Slave 44 queries .
