我采用XDS100v2 USB Emulator在CCSV5下调试DM365开发板。不知为什么在run下执行debug后,总是出现以下错误信息: ARM9: GEL Output: DM365EVM ARM Startup Sequence ARM9: GEL Output: Disable IRQ/FIQ ARM9: GEL Output: Flush Cache ARM9: GEL Output: Disable MMU ARM9: GEL Output: Disable IRQ/FIQ ARM9: GEL Output: Flush Cache ARM9: GEL Output: Disable MMU ARM9: GEL Output: Setup Power Modules (All on)...ARM9: GEL Output: [Done] ARM9: GEL Output: Setup PinMux...ARM9: GEL Output: [Done] ARM9: GEL Output: Setup PLL0...ARM9: GEL: Error while executing OnTargetConnect(): Target failed to write memory at 0x01C40900 at (*(pll_ctl)&=~(0x0001)) [evmdm365.gel:500] at Setup_PLL1() [evmdm365.gel:124] at OnTargetConnect() . ARM9: Error: (Error -1029 @ 0x2B5F) Invalid data read from ICECrusher register. Reset the device, and retry the operation. If error persists, confirm configuration, power-cycle the board, and/or try more reliable JTAG settings (e.g. lower TCLK). (Emulation package 5.0.872.0) ARM9: Failed Software Reset ARM9: Error: (Error -1029 @ 0x2B5F) Invalid data read from ICECrusher register. Reset the device, and retry the operation. If error persists, confirm configuration, power-cycle the board, and/or try more reliable JTAG settings (e.g. lower TCLK). (Emulation package 5.0.872.0) ARM9: Unable to determine target status after 20 attempts ARM9: Failed to remove the debug state from the target before disconnecting. There may still be breakpoint op-codes embedded in program memory. It is recommended that you reset the emulator before you connect and reload your program before you continue debugging 检查.GEL文件,没有发现什么问题。在targetConfigs下检查EVMDM365.ccxml, 设置没有什么问题, 可是连接测试出错。请问这是什么原因啊。谢了! |
这个问题,请将 XDS100v2仿真器的JTAG TCLK设置为:adaptive with user specified limit 。
如果我的回复解决了您的问题,请点击下面的标签“是”。 |
kingnet_52004 发表于 2018-6-22 04:39 Titan, 谢谢!正如你说的,问题解决了! |
586 浏览 1 评论
427 浏览 1 评论
620 浏览 2 评论
910 浏览 3 评论
709 浏览 1 评论
193浏览 29评论
1157浏览 23评论
323浏览 20评论
286浏览 14评论
135浏览 13评论
GMT+8, 2025-2-4 11:01 , Processed in 0.894857 second(s), Total 47, Slave 42 queries .
