扫一扫,分享给好友
DM8127上cache默认配置如下(FC_RMAN_IRES_c6xdsp.cfg):
/* Disable caching for HWspinlock addresses */Cache.MAR0_31 = 0x00000000; /* 0x00000000 - 0x1FFFFFFF --> NOT CACHEABLE */Cache.MAR32_63 = 0x00000000; /* 0x20000000 - 0x3FFFFFFF --> NOT CACHEABLE *//* Config/EDMA registers cache disabled */Cache.MAR64_95 = 0x00000000; /* 0x40000000 - 0x5FFFFFFF --> NOT CACHEABLE */Cache.MAR96_127 = 0x00000000; /* 0x60000000 - 0x7FFFFFFF --> NOT CACHEABLE *//* cache settings for 1st 512MB DDR */Cache.MAR128_159 = 0x0000FF00; /* 0x80000000 - 0x87FFFFFF --> NOT CACHEABLE */ /* 0x88000000 - 0x8FFFFFFF --> CACHEABLE */ /* 0x90000000 - 0x9FFFFFFF --> NOT CACHEABLE *//* cache settings for 2nd 512MB DDR */Cache.MAR160_191 = 0x0FFF0000; /* 0xA0000000 - 0xAFFFFFFF --> NOT CACHEABLE */ /* 0xB0000000 - 0xBBFFFFFF --> CACHEABLE */ /* 0xBC000000 - 0xBFFFFFFF --> NOT CACHEABLE *//* cache settings for 3rd 512MB DDR */Cache.MAR192_223 = 0x00000000; /* 0xC0000000 - 0xDFFFFFFF --> NOT CACHEABLE *//* cache settings for 4th 512MB DDR */Cache.MAR224_255 = 0x00000000; /* 0xE0000000 - 0xFFFFFFFF --> NOT CACHEABLE */而在config_512M.bld中 var KB=1024;var MB=KB*KB;var GB=KB*KB*KB;var DDR3_ADDR = 0x80000000;var DDR3_SIZE = 1 * GB;var DDR3_ADDR_256_REG0_START = 0x80000000;var DDR3_ADDR_256_REG0_END = 0x90000000;var DDR3_ADDR_256_REG1_START = 0xB0000000;var DDR3_ADDR_256_REG1_END = 0xC0000000;var OCMC0_ADDR = 0x40300000;var OCMC1_ADDR = 0x40400000;var OCMC_SIZE = 256*KB;/* first 256MB */var LINUX_SIZE = 80*MB;var CMEM_SIZE = 64*MB var SR1_SIZE = 60*MB;var VIDEO_M3_CODE_SIZE = 3*MB;var VIDEO_M3_DATA_SIZE = 14*MB;var DSS_M3_CODE_SIZE = 2*MB;var DSS_M3_DATA_SIZE = 22*MB;var DSP_CODE_SIZE = 1*MB;var DSP_DATA_SIZE = 10*MB;/* second 256MB */var TILER_SIZE = 128*MB; /* Reducing this to fix Vid Frame Alloc failures. Need to fix */ /* MUST be aligned on 128MB boundary */var SR2_FRAME_BUFFER_SIZE = 105*MB; var SR0_SIZE = 16*MB;var HDVPSS_DESC_SIZE = 2*MB;var HDVPSS_SHARED_SIZE = 2*MB;var NOTIFY_SHARED_SIZE = 2*MB;var REMOTE_DEBUG_SIZE = 1*MB;根据cache配置 Cache.MAR128_159 = 0x0000FF00; Cache.MAR160_191 = 0x0FFF0000; 512M内存中CMEM中有16MB是cacheable,SR1、VIDEO_M3_CODE、VIDEO_M3_DATA、DSS_M3_CODE、DSS_M3_DATA、DSP_CODE、DSP_DATA、TILER全部 cacheable,SR2_FRAME_BUFFER中有64MB是cacheable。 我的疑惑: 1. cacheable是不是只用配置DSP_CODE、DSP_DATA即可?毕竟FC_RMAN_IRES_c6xdsp.cfg是在配置DSP上的CACHE。 2. 默认配置为什么要设置 部分CMEM、SR1、VIDEO_M3_CODE、VIDEO_M3_DATA、DSS_M3_CODE、DSS_M3_DATA、TILER和部分SR2_FRAME_BUFFER cacheable? |
你好,
你看的是哪个版本的IPNC RDK?IPNC RDK 3.8里面的配置和你写的不一样。 除了dsp的code,data段外,DSP会运算处理的数据可以配置为cache,这样能提高运算速度。但要注意cache一致性。 |
物是人非aaa 发表于 2018-6-21 08:46 我的IPNC RDK版本是3.5。 |
876 浏览 1 评论
1092 浏览 0 评论
631 浏览 1 评论
495 浏览 1 评论
675 浏览 2 评论
286浏览 29评论
1246浏览 23评论
373浏览 20评论
362浏览 14评论
236浏览 13评论
GMT+8, 2025-3-18 19:04 , Processed in 0.977346 second(s), Total 78, Slave 62 queries .
