扫一扫,分享给好友
To connect an external 16bits memory with BLE/BHE for 8bits accesses, please follow this recommandation: EMIFADD[16:0] to SRAM_ADD[17:1] EMIFBADD1 to SRAM_ADD[0] EMIFDQM0 to SRAM_BLE EMIFDQM1 to SRAM_BHE The EMIF has to be programmed as following: Select Strobe = 0 Enhanced Wait = 0 Memory Size = 16 SETUP Cycle Config = Slave Dependent HOLD Cycle Config = Slave Dependent Strobe Cycle Config = Slave Dependent In the TRM, the EMIF is described as 8 bits. This is not correct. The EMIF on TMS570LS series is 16bits data. |
潘涛12345 发表于 2018-6-21 10:48 Select Strobe = 0 Enhanced Wait = 0 Memory Size = 16 SETUP Cycle Config = Slave Dependent HOLD Cycle Config = Slave Dependent Strobe Cycle Config = Slave Dependent 是只需要设置这几个就好了吗?在HAL里还有其他的参数,那些不用管? 还有我是通过CPLD来控制SRAM的,因为当时设计的时候发现控制信号数量与SRAM控制线数量不符,所以用了CPLD来中转控制,那我需要怎么设置呢? |
580 浏览 1 评论
418 浏览 1 评论
611 浏览 2 评论
894 浏览 3 评论
704 浏览 1 评论
180浏览 29评论
1144浏览 23评论
316浏览 20评论
277浏览 14评论
127浏览 13评论
GMT+8, 2025-1-31 21:44 , Processed in 0.395043 second(s), Total 47, Slave 42 queries .
