扫一扫,分享给好友
各位:
我安装ccs5.4不成功,系统是win7 64位的 。卸载了杀毒软件,关闭了防火墙, 还是出现附件中的错误和log信息,请遇到过的高手指点下。谢谢! log信息如下: --------------------------------------- ------ ccs_setup_5.4.0.00091 Installation ------------- --------------------------------------- 08/07/2013 17:27:27PM - 08/07/2013 17:27:27PM - 08/07/2013 17:27:27PM - InstallID : D94AFFCE-50ED-4AD8-819A-B184987CD7F8 08/07/2013 17:27:27PM - Installer : F:downloadCCS5.4.0.00091_win32ccs_setup_5.4.0.00091.exe 08/07/2013 17:27:27PM - BuildName : ccs_setup_5.4.0.00091.exe 08/07/2013 17:27:27PM - Install version: 5.4.0.00091 08/07/2013 17:27:27PM - Install source : F:downloadCCS5.4.0.00091_win32 08/07/2013 17:27:27PM - OS : Windows 08/07/2013 17:27:27PM - UserName : asus 08/07/2013 17:27:27PM - Update? : 0 08/07/2013 17:27:27PM - testmode : <%testmode%> 08/07/2013 17:27:27PM - testurl : <%testurl%> 08/07/2013 17:27:27PM - http info : -accept */* -proxyfilter http::ProxyRequired -proxyhost [] -proxyport [] -urlencoding utf-8 -useragent [Tcl http client package 2.5.3] 08/07/2013 17:27:27PM - tmp dir : C:/Users/asus/AppData/Local/Temp/ijtmp_EDACDD11-B33D-4D43-806D-6BD0DBD8D818 08/07/2013 17:27:27PM - InstallURL : <%InstallURL%> 08/07/2013 17:27:27PM - Command line : /installkitvfs/main.tcl 0 08/07/2013 17:27:27PM - 08/07/2013 17:27:27PM - Checking conditions for B64D3D93-67B0-4BD9-9B1B-4264B8023A45 - Set Temp value - Before Action is Executed 08/07/2013 17:27:27PM - Checking condition 5401F86C-FE5E-4FF7-A77A-C4CBD8D576EB - Execute Script Condition 08/07/2013 17:27:27PM - Condition passed 08/07/2013 17:27:27PM - Executing action B64D3D93-67B0-4BD9-9B1B-4264B8023A45 - Set Temp value 08/07/2013 17:27:27PM - Executing action A2728FBB-5A26-4329-BFBE-DE6C9E246501 - Check Temp/Installsource value 08/07/2013 17:27:27PM - Checking conditions for 3A18DFFF-E127-407E-987E-23B777277223 - Check for McAfee - Before Action is Executed 08/07/2013 17:27:27PM - Checking condition 60C48044-51FA-4487-BFBF-5E5276E11AA6 - Platform Condition 08/07/2013 17:27:27PM - Checking to see if <%Platform%> is Windows 08/07/2013 17:27:27PM - ** Checking to see if Windows is Windows 08/07/2013 17:27:27PM - Condition passed 08/07/2013 17:27:27PM - Executing action 3A18DFFF-E127-407E-987E-23B777277223 - Check for McAfee 08/07/2013 17:27:27PM - Registry key HKEY_LOCAL_MACHINESOFTWAREMcAfee does not exist unable to open key: 系统找不到指定的文件。 08/07/2013 17:27:27PM - Checking conditions for 123EF823-0459-4F01-ABF1-BE12CCBD883C - Check for junctions (Windows) - Before Action is Executed 08/07/2013 17:27:27PM - Checking condition 9DA2DCAC-C1A2-4FA9-A505-21437A8B0431 - Platform Condition 08/07/2013 17:27:27PM - Checking to see if <%Platform%> is Windows 08/07/2013 17:27:27PM - ** Checking to see if Windows is Windows 08/07/2013 17:27:27PM - Condition passed 08/07/2013 17:27:27PM - Executing action 123EF823-0459-4F01-ABF1-BE12CCBD883C - Check for junctions (Windows) 08/07/2013 17:27:27PM - checking C:/Users/asus/AppData/Local/Temp/ijtmp_EDACDD11-B33D-4D43-806D-6BD0DBD8D818 for links 08/07/2013 17:27:28PM - Checking conditions for 6D910536-6D94-48FC-9FB6-DEC5FBC0E6B9 - Set Update variables if needed - Before Action is Executed 08/07/2013 17:27:28PM - Checking condition A2DF4B22-7FD5-40DD-A8C7-744CDD290075 - String Equal Condition 08/07/2013 17:27:28PM - Checking to see if <%InstallPrefix%> equals ccs_update 08/07/2013 17:27:28PM - ** Checking to see if ccs_setup equals ccs_update 08/07/2013 17:27:28PM - Condition failed 08/07/2013 17:27:28PM - Skipping action 6D910536-6D94-48FC-9FB6-DEC5FBC0E6B9 - Set Update variables if needed - conditions failed 08/07/2013 17:27:28PM - Checking conditions for FD9BA738-0681-4F8C-A99E-D9630FE9317A - Get InstallDir - Before Action is Executed 08/07/2013 17:27:28PM - Checking condition 96501BA3-2DAB-4133-BEAD-86FCA44BFE84 - String Is Condition 08/07/2013 17:27:28PM - Checking to see if <%UpdateMode%> is true 08/07/2013 17:27:28PM - ** Checking to see if 0 is true 08/07/2013 17:27:28PM - Condition failed 08/07/2013 17:27:28PM - Skipping action FD9BA738-0681-4F8C-A99E-D9630FE9317A - Get InstallDir - conditions failed 08/07/2013 17:27:28PM - Checking conditions for 5A908E3F-6B9A-4311-B8CA-15578F03CEC9 - Set Native_Eclipse_Selected - Before Action is Executed 08/07/2013 17:27:28PM - Checking condition A2036039-9CCB-492A-8247-6D07128AEE2F - Command Line Test Condition 08/07/2013 17:27:28PM - Checking to see if eclipseprefix was passed on the command line 08/07/2013 17:27:28PM - Condition failed 08/07/2013 17:27:28PM - Skipping action 5A908E3F-6B9A-4311-B8CA-15578F03CEC9 - Set Native_Eclipse_Selected - conditions failed 08/07/2013 17:27:28PM - Checking conditions for 99A470ED-DD5C-4D41-BA90-A04A061322EB - Set Native Eclipse Variable - Before Action is Executed 08/07/2013 17:27:28PM - Checking condition DF6C1A44-866A-4053-A6D4-D810A1260FFA - String Is Condition 08/07/2013 17:27:28PM - Checking to see if <%UpdateMode%> is true 08/07/2013 17:27:28PM - ** Checking to see if 0 is true 08/07/2013 17:27:28PM - Condition failed 08/07/2013 17:27:28PM - Skipping action 99A470ED-DD5C-4D41-BA90-A04A061322EB - Set Native Eclipse Variable - conditions failed 08/07/2013 17:27:28PM - Checking conditions for 0E76BDFA-AE33-4D11-80D4-021EEE28FADA - Set Valid Eclipse Variable - Before Action is Executed 08/07/2013 17:27:28PM - Checking condition A0F1E771-08C1-4655-89F3-A760BAE68E12 - String Is Condition 08/07/2013 17:27:28PM - Checking to see if <%UpdateMode%> is true 08/07/2013 17:27:28PM - ** Checking to see if 0 is true 08/07/2013 17:27:28PM - Condition failed 08/07/2013 17:27:28PM - Skipping action 0E76BDFA-AE33-4D11-80D4-021EEE28FADA - Set Valid Eclipse Variable - conditions failed 08/07/2013 17:27:28PM - Checking conditions for F0A046CD-8A59-4F7D-B025-7ED78FD8C0F3 - Execute Response File Action - Before Action is Executed 08/07/2013 17:27:28PM - Checking condition C434E3F3-C405-466D-9713-A8F99B3BCC12 - Command Line Test Condition 08/07/2013 17:27:28PM - Checking to see if response-file was passed on the command line 08/07/2013 17:27:28PM - Condition failed 08/07/2013 17:27:28PM - Skipping action F0A046CD-8A59-4F7D-B025-7ED78FD8C0F3 - Execute Response File Action - conditions failed 08/07/2013 17:27:28PM - Checking conditions for 73286838-ADC5-44C6-9BF4-3D00C32317F7 - Set Windows information - Before Action is Executed 08/07/2013 17:27:28PM - Checking condition DDEDDBE3-895A-4F08-B242-B5CEB39360F2 - Platform Condition 08/07/2013 17:27:28PM - Checking to see if <%Platform%> is Windows 08/07/2013 17:27:28PM - ** Checking to see if Windows is Windows 08/07/2013 17:27:28PM - Condition passed 08/07/2013 17:27:28PM - Executing action 73286838-ADC5-44C6-9BF4-3D00C32317F7 - Set Windows information 08/07/2013 17:27:28PM - Checking System Info... 08/07/2013 17:27:28PM - Registry key WindowsCSDVersionString does not exist 08/07/2013 17:27:28PM - Windows 7 Ultimate matched .*s*Windows 7.* 08/07/2013 17:27:28PM - WindowsProductName= Windows 7 Ultimate WindowsCurrentVersion= 6.1 WindowsCSDVersionString= - WindowsCSDVersionDWord= 256 WindowsPlatform= Windows7 08/07/2013 17:27:28PM - Executing action 1409F691-5623-49F1-99EB-D4ED15870571 - Set BuildName (default) 08/07/2013 17:27:29PM - Setting active setup type to New Setup Type (B6E0CE8C-4E6F-4885-953A-32946A051105). 08/07/2013 17:27:29PM - Activating component D253A697-7480-46F3-AF71-AB63991129FD 08/07/2013 17:27:29PM - Executing actions A0AAD47D-43D9-43F8-9439-47A03F6F4E2B - Startup Actions 08/07/2013 17:27:29PM - Executing action 13EDEC6E-8DA0-4447-BDEA-CA07B2E6C024 - Run Common Startup Actions 08/07/2013 17:27:29PM - Executing actions 0C7AA01C-904A-49D5-A05B-E0AE9CC22448 - Common Startup Actions 08/07/2013 17:27:29PM - Checking conditions for 22F60A3C-BD94-46EA-A08B-8DE1A6DE012D - - Before Action is Executed 08/07/2013 17:27:29PM - Checking condition 4759E3D6-FA8F-4285-8B95-F54DBEA3EEC5 - Platform Condition 08/07/2013 17:27:29PM - Checking to see if <%Platform%> is Windows 08/07/2013 17:27:29PM - ** Checking to see if Windows is Windows 08/07/2013 17:27:29PM - Condition passed 08/07/2013 17:27:29PM - Executing action 22F60A3C-BD94-46EA-A08B-8DE1A6DE012D - Check For Reboots (Windows) 08/07/2013 17:27:29PM - Executing actions C5310624-D7B0-49EA-8FC1-2DF23B182604 - Check For Reboots 08/07/2013 17:27:29PM - Executing action E5553D24-EE8E-4F1E-9135-8F2D646360AC - Run reg.exe 1 08/07/2013 17:27:29PM - Executing Command Line: reg.exe query [HKEY_LOCAL_MACHINESYSTEMCurrentControlSetControlSession Manager] /v PendingFileRenameOperations 08/07/2013 17:27:29PM - Error while executing: ´íÎó: ϵͳÕҲ»µ½ָ¶¨µÄע²á±íÏî»òֵ¡£ 08/07/2013 17:27:29PM - Executing action 3BEBA945-EC03-49BA-923B-4462C8B0014B - Write reg text 1 08/07/2013 17:27:29PM - Executing action 40ECEE20-4593-482C-A807-3446FE6334DE - Check registry keys 08/07/2013 17:27:29PM - Checking for reboots ... 08/07/2013 17:27:29PM - Registry key UpdateExeVolatile does not exist unable to open key: 系统找不到指定的文件。 08/07/2013 17:27:29PM - Registry key rebootrequired does not exist unable to open key: 系统找不到指定的文件。 08/07/2013 17:27:29PM - Checking conditions for 177AA845-805E-424B-A48A-6E2BFD6C9CD6 - - Before Action is Executed 08/07/2013 17:27:29PM - Checking condition 05370712-1717-4B2A-A7F9-359FCCA2E57B - String Is Condition 08/07/2013 17:27:29PM - Checking to see if <%GuiMode%> is true 08/07/2013 17:27:29PM - ** Checking to see if 1 is true 08/07/2013 17:27:29PM - Condition passed 08/07/2013 17:27:29PM - Checking condition 0459569F-EDC5-4A4D-93EE-0FB7BE84B4C9 - String Is Condition 08/07/2013 17:27:29PM - Checking to see if <%UpdateMode%> is false 08/07/2013 17:27:29PM - ** Checking to see if 0 is false 08/07/2013 17:27:29PM - Condition passed 08/07/2013 17:27:29PM - Checking condition 50A21EBD-54A7-45F4-8988-7791D76EC6A3 - String Is Condition 08/07/2013 17:27:29PM - Checking to see if <%FoundReboot%> is true 08/07/2013 17:27:29PM - ** Checking to see if false is true 08/07/2013 17:27:29PM - Condition failed 08/07/2013 17:27:29PM - Skipping action 177AA845-805E-424B-A48A-6E2BFD6C9CD6 - Reboot Message - conditions failed 08/07/2013 17:27:29PM - Checking conditions for E52C2017-2ED3-4B74-BBE2-86BB2E723383 - - Before Action is Executed 08/07/2013 17:27:29PM - Checking condition 0FAA39B6-E52E-4D19-B9EC-7071A6697A0C - String Is Condition 08/07/2013 17:27:29PM - Checking to see if <%GuiMode%> is false 08/07/2013 17:27:29PM - ** Checking to see if 1 is false 08/07/2013 17:27:29PM - Condition failed 08/07/2013 17:27:29PM - Skipping action E52C2017-2ED3-4B74-BBE2-86BB2E723383 - Reboot Message - conditions failed 08/07/2013 17:27:29PM - Checking conditions for CC5D72E4-5258-41C5-9C78-AB886C2F8673 - - Before Action is Executed 08/07/2013 17:27:29PM - Checking condition 9D5BB820-1691-42D3-8ADE-0DC2304F9BCD - String Equal Condition 08/07/2013 17:27:29PM - Checking to see if <%Answer%> equals No 08/07/2013 17:27:29PM - Condition failed 08/07/2013 17:27:29PM - Skipping action CC5D72E4-5258-41C5-9C78-AB886C2F8673 - Exit - conditions failed 08/07/2013 17:27:29PM - Executing action 1C82CB44-08EC-4BAE-BCF7-719902E9C236 - Execute Windows Startup 08/07/2013 17:27:29PM - Checking conditions for AED7E1E0-3E40-41B5-A471-FAAFD73529F8 - Windows Startup Action - Before Action is Executed 08/07/2013 17:27:29PM - Checking condition BDCBFA61-EF65-4DF4-A4C3-1CD5758BDD79 - Platform Condition 08/07/2013 17:27:29PM - Checking to see if <%Platform%> is Windows 08/07/2013 17:27:29PM - ** Checking to see if Windows is Windows 08/07/2013 17:27:29PM - Condition passed 08/07/2013 17:27:29PM - Executing actions AED7E1E0-3E40-41B5-A471-FAAFD73529F8 - Windows Startup Action 08/07/2013 17:27:29PM - Executing action C4D1AB2C-8D0E-4AF0-BA43-2DF6CA3D3A1C - Check Memory 08/07/2013 17:27:29PM - Checking Memory... 08/07/2013 17:27:29PM - Checking conditions for 98FB6613-1F73-4BCB-8DDB-B431EBD71496 - - Before Action is Executed 08/07/2013 17:27:29PM - Checking condition 17D28D55-F95F-4DD0-AC94-EF4CDE6400D2 - Execute Script Condition 08/07/2013 17:27:29PM - C:/Users/asus/AppData/Local/Temp is writable ? 1 or 1 08/07/2013 17:27:29PM - C:/Users/asus/AppData/Local/Temp/ijtmp_EDACDD11-B33D-4D43-806D-6BD0DBD8D818 exists? 1 08/07/2013 17:27:29PM - C:/Users/asus/AppData/Local/Temp/ijtmp_EDACDD11-B33D-4D43-806D-6BD0DBD8D818 is writable ? 1 08/07/2013 17:27:29PM - making C:/Users/asus/AppData/Local/Temp/ijtmp_EDACDD11-B33D-4D43-806D-6BD0DBD8D818/baserepo 08/07/2013 17:27:29PM - Condition failed 08/07/2013 17:27:29PM - Skipping action 98FB6613-1F73-4BCB-8DDB-B431EBD71496 - Exit if no access to Temp dir - conditions failed 08/07/2013 17:27:29PM - Checking conditions for B6872AE1-0E02-431F-B454-399EF4DB3A9F - - Before Action is Executed 08/07/2013 17:27:29PM - Checking condition 0747C492-B4C3-420E-B891-6A9F93C6AA21 - Command Line Test Condition 08/07/2013 17:27:29PM - Checking to see if prefix was passed on the command line 08/07/2013 17:27:29PM - Condition failed 08/07/2013 17:27:29PM - Skipping action B6872AE1-0E02-431F-B454-399EF4DB3A9F - Check InstallDir parameter - conditions failed 08/07/2013 17:27:29PM - Checking conditions for 1514399D-CAAF-4087-9E82-A65109B675F8 - - Before Action is Executed 08/07/2013 17:27:29PM - Checking condition 245ABF90-7270-43B9-A0A7-17F7DAAB3466 - Command Line Test Condition 08/07/2013 17:27:29PM - Checking to see if eclipseprefix was passed on the command line 08/07/2013 17:27:29PM - Condition failed 08/07/2013 17:27:29PM - Skipping action 1514399D-CAAF-4087-9E82-A65109B675F8 - Execute Look for EclipseDir - conditions failed 08/07/2013 17:27:29PM - Executing action 7A1CB0AB-04A3-41C0-8655-22F6AE6A972A - Full CCS or Component install test 08/07/2013 17:27:29PM - .*_setup_5.4.* 08/07/2013 17:27:29PM - full installer 08/07/2013 17:27:29PM - Checking conditions for 390AFA53-7D35-4C26-A453-27B7CEBB834E - - Before Action is Executed 08/07/2013 17:27:29PM - Checking condition AB402A5E-1927-4722-B563-CAF54B6E53AA - Platform Condition 08/07/2013 17:27:29PM - Checking to see if <%Platform%> is Windows 08/07/2013 17:27:29PM - ** Checking to see if Windows is Windows 08/07/2013 17:27:29PM - Condition passed 08/07/2013 17:27:29PM - Executing action 390AFA53-7D35-4C26-A453-27B7CEBB834E - Unpack Setup xml file 08/07/2013 17:27:29PM - Unpacking C:/Users/asus/AppData/Local/Temp/ijtmp_EDACDD11-B33D-4D43-806D-6BD0DBD8D818/ccs_installini.xml 08/07/2013 17:27:29PM - Checking conditions for F4C790E5-5B05-43B4-ABC4-B4B9C1C01A59 - - Before Action is Executed 08/07/2013 17:27:29PM - Checking condition D1A276F0-17F4-498A-B707-E9B7CDAF7109 - Platform Condition 08/07/2013 17:27:29PM - Checking to see if <%Platform%> is Linux-x86 08/07/2013 17:27:29PM - ** Checking to see if Windows is Linux-x86 08/07/2013 17:27:29PM - Condition failed 08/07/2013 17:27:29PM - Skipping action F4C790E5-5B05-43B4-ABC4-B4B9C1C01A59 - Unpack Setup xml file - conditions failed 08/07/2013 17:27:29PM - Executing action 1FDA0E1A-FA6B-40B5-934E-553F9ABDC49B - Set InstallIni file name 08/07/2013 17:27:29PM - InstallSource = F:/download/CCS5.4.0.00091_win32 08/07/2013 17:27:29PM - InstallIni file = C:/Users/asus/AppData/Local/Temp/ijtmp_EDACDD11-B33D-4D43-806D-6BD0DBD8D818/ccs_installini.xml C:/Users/asus/AppData/Local/Temp/ijtmp_EDACDD11-B33D-4D43-806D-6BD0DBD8D818/ccs_installini.xml 08/07/2013 17:27:29PM - Executing action C325767C-1961-4AB1-8037-7C19CB4BA543 - Get Setup Types 08/07/2013 17:27:29PM - Executing action D6E650CF-E79A-4C23-86E7-FE0AF5BB288C - Set USERPROFILE variable 08/07/2013 17:27:29PM - userprofile = C:Usersasus 08/07/2013 17:27:30PM - looking for * in C:Usersasus/ti 08/07/2013 17:27:30PM - Checking conditions for DCC432F6-3409-4694-A45A-ADE2F727D197 - Run Main Startup Actions - Before Action is Executed 08/07/2013 17:27:30PM - Checking condition 811E0FCC-5436-4EF1-B100-38D48AEDAEDB - String Is Condition 08/07/2013 17:27:30PM - Checking to see if <%UpdateMode%> is false 08/07/2013 17:27:30PM - ** Checking to see if 0 is false 08/07/2013 17:27:30PM - Condition passed 08/07/2013 17:27:30PM - Executing action DCC432F6-3409-4694-A45A-ADE2F727D197 - Run Main Startup Actions 08/07/2013 17:27:30PM - Executing actions 4BA19292-8FFD-40DE-8CA5-B8FC9CDD9A15 - Main Startup Actions 08/07/2013 17:27:30PM - Executing action 164527E4-7D70-4D17-BBF9-D2D79EA6EC93 - Run Manifest File Actions 08/07/2013 17:27:30PM - Executing actions 2E15C1E1-4FB2-4D3F-8401-2D82FB9F0AF6 - Manifest File Actions 08/07/2013 17:27:30PM - Checking conditions for 25BA989D-274D-4302-A91E-48B8454834E4 - - Before Action is Executed 08/07/2013 17:27:30PM - Checking condition 45766827-6E1C-43A5-AE55-3EDC12383C2C - Platform Condition 08/07/2013 17:27:30PM - Checking to see if <%Platform%> is Linux-x86 08/07/2013 17:27:30PM - ** Checking to see if Windows is Linux-x86 08/07/2013 17:27:30PM - Condition failed 08/07/2013 17:27:30PM - Skipping action 25BA989D-274D-4302-A91E-48B8454834E4 - Unpack Manifest xml file - conditions failed 08/07/2013 17:27:30PM - Checking conditions for 1C65743D-E0A5-4787-B152-3A21723C2002 - - Before Action is Executed 08/07/2013 17:27:30PM - Checking condition 9B003E01-3775-4A7C-ABAD-252F786C62F6 - Platform Condition 08/07/2013 17:27:30PM - Checking to see if <%Platform%> is Windows 08/07/2013 17:27:30PM - ** Checking to see if Windows is Windows 08/07/2013 17:27:30PM - Condition passed 08/07/2013 17:27:30PM - Executing action 1C65743D-E0A5-4787-B152-3A21723C2002 - Unpack Manifest xml file 08/07/2013 17:27:30PM - Unpacking C:/Users/asus/AppData/Local/Temp/ijtmp_EDACDD11-B33D-4D43-806D-6BD0DBD8D818/ccs_manifest.xml 08/07/2013 17:27:31PM - Checking conditions for 64C32BE4-E5A9-49DE-B300-99E89DCD537B - - Before Action is Executed 08/07/2013 17:27:31PM - Checking condition 6CB61E0B-777D-4323-B690-2D6B7EC21739 - String Is Condition 08/07/2013 17:27:31PM - Checking to see if <%ComponentInstaller%> is false 08/07/2013 17:27:31PM - ** Checking to see if false is false 08/07/2013 17:27:31PM - Condition passed 08/07/2013 17:27:31PM - Executing action 64C32BE4-E5A9-49DE-B300-99E89DCD537B - Set Manifest file name (Main) 08/07/2013 17:27:31PM - InstallIni file = C:/Users/asus/AppData/Local/Temp/ijtmp_EDACDD11-B33D-4D43-806D-6BD0DBD8D818/ccs_manifest.xml C:/Users/asus/AppData/Local/Temp/ijtmp_EDACDD11-B33D-4D43-806D-6BD0DBD8D818/ccs_manifest.xml 08/07/2013 17:27:31PM - Checking conditions for 2237DB6B-9676-4FDA-8BBB-9CD0741C175B - - Before Action is Executed 08/07/2013 17:27:31PM - Checking condition 15FF209F-7BBD-4D5E-BDC0-36EE302F2496 - String Is Condition 08/07/2013 17:27:31PM - Checking to see if <%ComponentInstaller%> is true 08/07/2013 17:27:31PM - ** Checking to see if false is true 08/07/2013 17:27:31PM - Condition failed 08/07/2013 17:27:31PM - Skipping action 2237DB6B-9676-4FDA-8BBB-9CD0741C175B - Set Manifest file name (Component) - conditions failed 08/07/2013 17:27:31PM - Checking conditions for CB39A277-9A24-430C-8680-A15529B595BE - - Before Action is Executed 08/07/2013 17:27:31PM - Checking condition 016B1F93-7184-4FC3-8688-0A1889957CA9 - String Is Condition 08/07/2013 17:27:31PM - Checking to see if <%ComponentInstaller%> is true 08/07/2013 17:27:31PM - ** Checking to see if false is true 08/07/2013 17:27:31PM - Condition failed 08/07/2013 17:27:31PM - Skipping action CB39A277-9A24-430C-8680-A15529B595BE - Exit - conditions failed 08/07/2013 17:27:31PM - Executing action 02082184-215D-4D0A-9DA8-3288BFC36931 - Run Get URL Name 08/07/2013 17:27:31PM - Executing actions C6771919-CB79-4C4F-A842-7560C1B039E5 - Get URL Name 08/07/2013 17:27:31PM - Executing action C6771919-CB79-4C4F-A842-7560C1B039E5 - Get URL Name 08/07/2013 17:27:31PM - P2version = 08/07/2013 17:27:31PM - Reading manifest file C:/Users/asus/AppData/Local/Temp/ijtmp_EDACDD11-B33D-4D43-806D-6BD0DBD8D818/ccs_manifest.xml 08/07/2013 17:27:31PM - tsvar = domNode025586C0 08/07/2013 17:27:31PM - found at least one product update, setting product install eq true 08/07/2013 17:27:31PM - urlname = |Code Composer Studio v5 Updates| 08/07/2013 17:27:31PM - repotype = multiple 08/07/2013 17:27:31PM - ts = 20130502111513 08/07/2013 17:27:31PM - setlocal = true 08/07/2013 17:27:31PM - Executing action 618B18B2-BF4D-45A2-819F-E7339E124226 - Run Look for Local Repository 08/07/2013 17:27:31PM - Executing actions C3322C75-C36B-4CAA-99B6-D10C70E75CED - Look for Local Respository 08/07/2013 17:27:31PM - Executing action C3322C75-C36B-4CAA-99B6-D10C70E75CED - Look for Local Respository 08/07/2013 17:27:31PM - updaterepo = 08/07/2013 17:27:31PM - local repo = F:downloadCCS5.4.0.00091_win32/featurerepo 08/07/2013 17:27:31PM - localbaserepo = F:downloadCCS5.4.0.00091_win32/baserepo 08/07/2013 17:27:31PM - localrepo = F:downloadCCS5.4.0.00091_win32/featurerepo 08/07/2013 17:27:31PM - setlocal = true 08/07/2013 17:27:31PM - setting CCSlocal values F:downloadCCS5.4.0.00091_win32/featurerepo F:downloadCCS5.4.0.00091_win32/baserepo F:downloadCCS5.4.0.00091_win32 08/07/2013 17:27:31PM - Executing action 23557737-FFE9-4727-A3B7-022578B08DFC - Run Read Manifest file 08/07/2013 17:27:31PM - Executing actions 0606F3A6-B4B3-430D-BF58-90FD8DC7E9D0 - Read Manifest file 08/07/2013 17:27:31PM - Executing action 0606F3A6-B4B3-430D-BF58-90FD8DC7E9D0 - Read Manifest file 08/07/2013 17:27:31PM - LocalRepository_Exists = 1 08/07/2013 17:27:31PM - Reading manifest file C:/Users/asus/AppData/Local/Temp/ijtmp_EDACDD11-B33D-4D43-806D-6BD0DBD8D818/ccs_manifest.xml 08/07/2013 17:27:31PM - alternate url info not given on commandline 08/07/2013 17:27:31PM - Component url ARM_CGT_HELP = F:/download/CCS5.4.0.00091_win32/baserepo 08/07/2013 17:27:31PM - Component url C2000_CGT_HELP = F:/download/CCS5.4.0.00091_win32/baserepo 08/07/2013 17:27:31PM - Component url C5500_CGT_HELP = F:/download/CCS5.4.0.00091_win32/baserepo 08/07/2013 17:27:31PM - Component url C6000_CGT_HELP = F:/download/CCS5.4.0.00091_win32/baserepo 08/07/2013 17:27:31PM - Component url CCSINIT = F:/download/CCS5.4.0.00091_win32/featurerepo 08/07/2013 17:27:31PM - Component url CGT_DEFAULTLIBS_C2800 = F:/download/CCS5.4.0.00091_win32/featurerepo 08/07/2013 17:27:31PM - Component url CGT_DEFAULTLIBS_C5400 = F:/download/CCS5.4.0.00091_win32/featurerepo 08/07/2013 17:27:31PM - Component url CGT_DEFAULTLIBS_C5500 = F:/download/CCS5.4.0.00091_win32/featurerepo 08/07/2013 17:27:31PM - Component url CGT_DEFAULTLIBS_C6000 = F:/download/CCS5.4.0.00091_win32/featurerepo 08/07/2013 17:27:31PM - Component url CGT_DEFAULTLIBS_MSP430 = F:/download/CCS5.4.0.00091_win32/featurerepo 08/07/2013 17:27:31PM - Component url CGT_DEFAULTLIBS_TMS470 = F:/download/CCS5.4.0.00091_win32/featurerepo 08/07/2013 17:27:31PM - Component url DEV_SUPPORT_C54XX = F:/download/CCS5.4.0.00091_win32/featurerepo 08/07/2013 17:27:31PM - Component url DEV_SUPPORT_C55XX = F:/download/CCS5.4.0.00091_win32/featurerepo 08/07/2013 17:27:31PM - Component url DEV_SUPPORT_C6000 = F:/download/CCS5.4.0.00091_win32/featurerepo 08/07/2013 17:27:31PM - Component url DEV_SUPPORT_C6000MC = F:/download/CCS5.4.0.00091_win32/featurerepo 08/07/2013 17:27:31PM - Component url DEV_SUPPORT_CC2538 = F:/download/CCS5.4.0.00091_win32/featurerepo 08/07/2013 17:27:31PM - Component url DEV_SUPPORT_DAVINCI = F:/download/CCS5.4.0.00091_win32/featurerepo 08/07/2013 17:27:31PM - Component url DEV_SUPPORT_INTEGRA = F:/download/CCS5.4.0.00091_win32/featurerepo 08/07/2013 17:27:31PM - Component url DEV_SUPPORT_OMAP = F:/download/CCS5.4.0.00091_win32/featurerepo 08/07/2013 17:27:31PM - Component url DEV_SUPPORT_SHARED = F:/download/CCS5.4.0.00091_win32/featurerepo 08/07/2013 17:27:31PM - Component url DEV_SUPPORT_SITARA = F:/download/CCS5.4.0.00091_win32/featurerepo 08/07/2013 17:27:31PM - Component url DMED = F:/download/CCS5.4.0.00091_win32/featurerepo 08/07/2013 17:27:31PM - Component url DS = F:/download/CCS5.4.0.00091_win32/featurerepo 08/07/2013 17:27:31PM - Component url DVT_COMMON = F:/download/CCS5.4.0.00091_win32/baserepo 08/07/2013 17:27:31PM - Component url DVT_TRACE = F:/download/CCS5.4.0.00091_win32/baserepo 08/07/2013 17:27:31PM - Component url DVT_UIA = F:/download/CCS5.4.0.00091_win32/baserepo 08/07/2013 17:27:31PM - Component url DVT_VIA_CCS = F:/download/CCS5.4.0.00091_win32/baserepo 08/07/2013 17:27:31PM - Component url DVT_ENERGYTRACE = F:/download/CCS5.4.0.00091_win32/baserepo 08/07/2013 17:27:31PM - Component url ECLIPSECORE = F:/download/CCS5.4.0.00091_win32/baserepo 08/07/2013 17:27:31PM - Component url ECLIPSE = F:/download/CCS5.4.0.00091_win32/baserepo 08/07/2013 17:27:31PM - Component url EMU_BH = F:/download/CCS5.4.0.00091_win32/featurerepo 08/07/2013 17:27:31PM - Component url EMU_C2000 = F:/download/CCS5.4.0.00091_win32/featurerepo 08/07/2013 17:27:31PM - Component url EMU_C2000_FLASH = F:/download/CCS5.4.0.00091_win32/featurerepo 08/07/2013 17:27:31PM - Component url EMU_HERCULES = F:/download/CCS5.4.0.00091_win32/featurerepo 08/07/2013 17:27:31PM - Component url EMU_MSP430 = F:/download/CCS5.4.0.00091_win32/featurerepo 08/07/2013 17:27:31PM - Component url EMU_SD = F:/download/CCS5.4.0.00091_win32/featurerepo 08/07/2013 17:27:31PM - Component url EMU_STELLARIS = F:/download/CCS5.4.0.00091_win32/featurerepo 08/07/2013 17:27:31PM - Component url EMU_TI = F:/download/CCS5.4.0.00091_win32/featurerepo 08/07/2013 17:27:31PM - Component url GCC_ARM_COMPILER = F:/download/CCS5.4.0.00091_win32/featurerepo 08/07/2013 17:27:31PM - Component url GMF = F:/download/CCS5.4.0.00091_win32/baserepo 08/07/2013 17:27:31PM - Component url GRACE = F:/download/CCS5.4.0.00091_win32/featurerepo 08/07/2013 17:27:31PM - Component url IDE_MAIN = F:/download/CCS5.4.0.00091_win32/baserepo 08/07/2013 17:27:31PM - Component url IDE_WORKFLOW = F:/download/CCS5.4.0.00091_win32/baserepo 08/07/2013 17:27:31PM - Component url IDE_ARM = F:/download/CCS5.4.0.00091_win32/baserepo 08/07/2013 17:27:31PM - Component url IDE_MSP430 = F:/download/CCS5.4.0.00091_win32/baserepo 08/07/2013 17:27:31PM - Component url IDE_C2000 = F:/download/CCS5.4.0.00091_win32/baserepo 08/07/2013 17:27:31PM - Component url IDE_C5400 = F:/download/CCS5.4.0.00091_win32/baserepo 08/07/2013 17:27:31PM - Component url IDE_C5500 = F:/download/CCS5.4.0.00091_win32/baserepo 08/07/2013 17:27:31PM - Component url IDE_C6000 = F:/download/CCS5.4.0.00091_win32/baserepo 08/07/2013 17:27:31PM - Component url JRE = F:/download/CCS5.4.0.00091_win32/baserepo 08/07/2013 17:27:31PM - Component url KEYSTONE1 = F:/download/CCS5.4.0.00091_win32/featurerepo 08/07/2013 17:27:31PM - Component url KEYSTONE2 = F:/download/CCS5.4.0.00091_win32/featurerepo 08/07/2013 17:27:31PM - Component url MSP430ware = F:/download/CCS5.4.0.00091_win32/featurerepo 08/07/2013 17:27:31PM - Component url MSP430_CGT_HELP = F:/download/CCS5.4.0.00091_win32/baserepo 08/07/2013 17:27:31PM - Component url MSVC2008 = F:/download/CCS5.4.0.00091_win32/baserepo 08/07/2013 17:27:31PM - Component url MSVC2012 = F:/download/CCS5.4.0.00091_win32/baserepo 08/07/2013 17:27:31PM - Component url MSVC80 = F:/download/CCS5.4.0.00091_win32/baserepo 08/07/2013 17:27:31PM - Component url P2TOOLS = F:/download/CCS5.4.0.00091_win32/baserepo 08/07/2013 17:27:31PM - Component url SIM_TI = F:/download/CCS5.4.0.00091_win32/featurerepo 08/07/2013 17:27:31PM - Component url TC_ARM_BIOS6 = F:/download/CCS5.4.0.00091_win32/featurerepo 08/07/2013 17:27:31PM - Component url TC_ARM_XDCTOOLS = F:/download/CCS5.4.0.00091_win32/featurerepo 08/07/2013 17:27:31PM - Component url TC_BIOS5 = F:/download/CCS5.4.0.00091_win32/featurerepo 08/07/2013 17:27:31PM - Component url TC_BIOS6 = F:/download/CCS5.4.0.00091_win32/featurerepo 08/07/2013 17:27:31PM - Component url TC_C2000_BIOS6 = F:/download/CCS5.4.0.00091_win32/featurerepo 08/07/2013 17:27:31PM - Component url TC_C2000_XDCTOOLS = F:/download/CCS5.4.0.00091_win32/featurerepo 08/07/2013 17:27:31PM - Component url TC_C6000_BIOS6 = F:/download/CCS5.4.0.00091_win32/featurerepo 08/07/2013 17:27:31PM - Component url TC_C6000_XDCTOOLS = F:/download/CCS5.4.0.00091_win32/featurerepo 08/07/2013 17:27:31PM - Component url TC_MSP430_BIOS6 = F:/download/CCS5.4.0.00091_win32/featurerepo 08/07/2013 17:27:31PM - Component url TC_MSP430_XDCTOOLS = F:/download/CCS5.4.0.00091_win32/featurerepo 08/07/2013 17:27:31PM - Component url TC_XDAIS = F:/download/CCS5.4.0.00091_win32/featurerepo 08/07/2013 17:27:31PM - Component url TC_XDAIS_BIOS5 = F:/download/CCS5.4.0.00091_win32/featurerepo 08/07/2013 17:27:31PM - Component url TC_XDCTOOLS = F:/download/CCS5.4.0.00091_win32/featurerepo 08/07/2013 17:27:31PM - Component url TC_XDCTOOLS_BIOS5 = F:/download/CCS5.4.0.00091_win32/featurerepo 08/07/2013 17:27:31PM - Component url TIVA_TM4C = F:/download/CCS5.4.0.00091_win32/featurerepo 08/07/2013 17:27:31PM - Component url TIVA_TM4E = F:/download/CCS5.4.0.00091_win32/featurerepo 08/07/2013 17:27:31PM - Component url UIA = F:/download/CCS5.4.0.00091_win32/featurerepo 08/07/2013 17:27:31PM - Component url XULRUNNER = F:/download/CCS5.4.0.00091_win32/featurerepo 08/07/2013 17:27:31PM - Component url INSTALLER = F:/download/CCS5.4.0.00091_win32/featurerepo 08/07/2013 17:27:31PM - baseurl = http://go-bradley.am.dhcp.ti.com/CCS5.4.0.00091_win32 08/07/2013 17:27:31PM - Executing action 064CDB88-8721-4CDA-B246-37D052A32298 - Debug information 08/07/2013 17:27:31PM - Manifest file: C:/Users/asus/AppData/Local/Temp/ijtmp_EDACDD11-B33D-4D43-806D-6BD0DBD8D818/ccs_manifest.xml 08/07/2013 17:27:31PM - Setup file : C:/Users/asus/AppData/Local/Temp/ijtmp_EDACDD11-B33D-4D43-806D-6BD0DBD8D818/ccs_installini.xml 08/07/2013 17:27:31PM - Installer: ccs_setup_5.4.0.00091.exe 08/07/2013 17:27:31PM - ccs_setup_5.4.0.00091.exe 08/07/2013 17:27:31PM - C:Usersasus 08/07/2013 17:27:31PM - Checking conditions for 8F539122-507F-4B01-8ABD-1443E5E641D6 - - Before Action is Executed 08/07/2013 17:27:31PM - Checking condition ECCFACBA-E04C-48D6-9BD9-2BA9B3C509E1 - String Is Condition 08/07/2013 17:27:31PM - Checking to see if <%ShowSetupPane%> is false 08/07/2013 17:27:31PM - ** Checking to see if true is false 08/07/2013 17:27:31PM - Condition failed 08/07/2013 17:27:31PM - Skipping action 8F539122-507F-4B01-8ABD-1443E5E641D6 - Execute Get Edition Details - conditions failed 08/07/2013 17:27:31PM - Checking conditions for A0354A16-79FB-457B-9363-CED6124ADDCA - - Before Action is Executed 08/07/2013 17:27:31PM - Checking condition C483848C-C11F-41BC-AB86-7D4A0C24A5BA - String Is Condition 08/07/2013 17:27:31PM - Checking to see if <%ShowSetupPane%> is false 08/07/2013 17:27:31PM - ** Checking to see if true is false 08/07/2013 17:27:31PM - Condition failed 08/07/2013 17:27:31PM - Skipping action A0354A16-79FB-457B-9363-CED6124ADDCA - Execute Setup Panes to Display - conditions failed 08/07/2013 17:27:31PM - Checking conditions for EECE82E1-6B6F-468C-A6BA-5AB21E7F19E8 - - Before Action is Executed 08/07/2013 17:27:31PM - Checking condition 2660F337-EF5C-4F78-92FA-E0B8EE28FC23 - Platform Condition 08/07/2013 17:27:31PM - Checking to see if <%Platform%> is Linux-x86 08/07/2013 17:27:31PM - ** Checking to see if Windows is Linux-x86 08/07/2013 17:27:31PM - Condition failed 08/07/2013 17:27:31PM - Skipping action EECE82E1-6B6F-468C-A6BA-5AB21E7F19E8 - Non-admin Message (linux) - conditions failed 08/07/2013 17:27:31PM - Checking conditions for 1EEDE33F-FA96-434E-A408-3A858B0CFE41 - - Before Action is Executed 08/07/2013 17:27:31PM - Checking condition B2E179AA-7558-48D7-8D00-0E27D34F3026 - Platform Condition 08/07/2013 17:27:31PM - Checking to see if <%Platform%> is Linux-x86 08/07/2013 17:27:31PM - ** Checking to see if Windows is Linux-x86 08/07/2013 17:27:31PM - Condition failed 08/07/2013 17:27:31PM - Skipping action 1EEDE33F-FA96-434E-A408-3A858B0CFE41 - Non-admin Message (linux) - conditions failed 08/07/2013 17:27:31PM - Checking conditions for AABD8C8E-3C88-4987-B89C-D6747C9394D5 - - Before Action is Executed 08/07/2013 17:27:31PM - Checking condition 474FB0CF-0071-4661-AC05-9DBF4E4BFED2 - Platform Condition 08/07/2013 17:27:31PM - Checking to see if <%Platform%> is Linux-x86 08/07/2013 17:27:31PM - ** Checking to see if Windows is Linux-x86 08/07/2013 17:27:31PM - Condition failed 08/07/2013 17:27:31PM - Skipping action AABD8C8E-3C88-4987-B89C-D6747C9394D5 - Exit - conditions failed 08/07/2013 17:27:31PM - Checking conditions for 17AAAD6D-433F-4CC7-A9E2-5EB0008F5832 - - Before Action is Executed 08/07/2013 17:27:31PM - Checking condition C00CA713-8588-4B43-A8C7-ECE74CDF01E6 - String Is Condition 08/07/2013 17:27:31PM - Checking to see if <%ComponentInstaller%> is false 08/07/2013 17:27:31PM - ** Checking to see if false is false 08/07/2013 17:27:31PM - Condition passed 08/07/2013 17:27:31PM - Executing action 17AAAD6D-433F-4CC7-A9E2-5EB0008F5832 - Set ARM MPU BU flag 08/07/2013 17:27:31PM - F:downloadCCS5.4.0.00091_win32/baserepo/arm_mpu.txt doesn't exist 08/07/2013 17:27:31PM - Checking conditions for 356EAA68-888B-4347-A851-EE731133C133 - - Before Action is Executed 08/07/2013 17:27:31PM - Checking condition A0D7DD06-8F87-416C-8B34-062A99D6C77A - String Is Condition 08/07/2013 17:27:31PM - Checking to see if <%arm_mpu%> is true 08/07/2013 17:27:31PM - ** Checking to see if 0 is true 08/07/2013 17:27:31PM - Condition failed 08/07/2013 17:27:31PM - Skipping action 356EAA68-888B-4347-A851-EE731133C133 - Set ARM ISA on (for ARM MPU) - conditions failed 08/07/2013 17:27:31PM - Checking conditions for 1D9048C0-D833-4B2F-9801-9E63F248B79D - Run Update Startup Actions - Before Action is Executed 08/07/2013 17:27:31PM - Checking condition 7AFBBD9A-9EE6-4541-95BB-F8B8D6EDBDC3 - String Is Condition 08/07/2013 17:27:31PM - Checking to see if <%UpdateMode%> is true 08/07/2013 17:27:31PM - ** Checking to see if 0 is true 08/07/2013 17:27:31PM - Condition failed 08/07/2013 17:27:31PM - Skipping action 1D9048C0-D833-4B2F-9801-9E63F248B79D - Run Update Startup Actions - conditions failed 08/07/2013 17:27:31PM - Executing action 161F5BA9-3D23-4365-A8B8-ADFFE05E9A98 - Create Install Panes 08/07/2013 17:27:31PM - description = Select this option if you wish to customize the individual features that are installed. 08/07/2013 17:27:31PM - activating Custom 08/07/2013 17:27:31PM - Checking conditions for A11790D2-A8D6-4BF2-B0AC-FD735A88B2B6 - License Agreement - Before Pane is Displayed 08/07/2013 17:27:31PM - Checking condition 5AD62789-2677-4DA5-84E1-739D4AAFA825 - Command Line Test Condition 08/07/2013 17:27:31PM - Checking to see if test was not passed on the command line 08/07/2013 17:27:31PM - Condition passed 08/07/2013 17:27:31PM - Executing actions A11790D2-A8D6-4BF2-B0AC-FD735A88B2B6 - License Agreement - Before Pane is Displayed 08/07/2013 17:27:31PM - Checking conditions for 8D4321BA-CBFE-487B-978A-6F8856E82BDF - Disable Next Button - Before Action is Executed 08/07/2013 17:27:31PM - Checking condition B9385049-E34B-4149-BEEA-19848C59FB8F - String Is Condition 08/07/2013 17:27:31PM - Checking to see if <%Property <%CurrentPane%> UserMustAcceptLicense%> is true 08/07/2013 17:27:31PM - ** Checking to see if Yes is true 08/07/2013 17:27:31PM - Condition passed 08/07/2013 17:27:31PM - Checking condition 695C91E5-69F9-4B0B-8F89-C78D8E2C348F - String Is Condition 08/07/2013 17:27:31PM - Checking to see if <%LicenseAccepted%> is false 08/07/2013 17:27:31PM - ** Checking to see if No is false 08/07/2013 17:27:31PM - Condition passed 08/07/2013 17:27:31PM - Executing action 8D4321BA-CBFE-487B-978A-6F8856E82BDF - Disable Next Button 08/07/2013 17:27:31PM - Displaying pane A11790D2-A8D6-4BF2-B0AC-FD735A88B2B6 - License Agreement 08/07/2013 17:27:31PM - Executing actions A11790D2-A8D6-4BF2-B0AC-FD735A88B2B6 - License Agreement - After Pane is Displayed 08/07/2013 17:27:31PM - Executing action DECD8C88-32C8-495F-B29B-39B0AB07DC86 - Add Print Button 08/07/2013 17:27:43PM - Executing actions A11790D2-A8D6-4BF2-B0AC-FD735A88B2B6 - License Agreement - Before Next Pane is Displayed 08/07/2013 17:27:43PM - Executing actions F47FFD38-C9F1-4896-B0C5-A870FBD8CDE7 - Select Destination - Before Pane is Displayed 08/07/2013 17:27:43PM - Checking conditions for 572E4601-A7D6-49BD-A9FB-30C5DA9AAB1E - Add checkbox for Eclipse location - Before Action is Executed 08/07/2013 17:27:43PM - Checking condition AD8384AE-E702-459F-A993-B485AC309184 - String Equal Condition 08/07/2013 17:27:43PM - Checking to see if <%ShortName%> does not equal UniFlash 08/07/2013 17:27:43PM - ** Checking to see if CCS does not equal UniFlash 08/07/2013 17:27:43PM - Condition passed 08/07/2013 17:27:43PM - Executing action 572E4601-A7D6-49BD-A9FB-30C5DA9AAB1E - Add checkbox for Eclipse location 08/07/2013 17:27:43PM - Checking conditions for 7615A7D4-FB57-4CD7-9D01-345765DF42DE - Execute Look for EclipseDir - Before Action is Executed 08/07/2013 17:27:43PM - Checking condition A94F968A-97A1-4C75-BC27-CB9BA3F14E66 - String Is Condition 08/07/2013 17:27:43PM - Checking to see if <%EclipseDir%> is not empty 08/07/2013 17:27:43PM - ** Checking to see if is not empty 08/07/2013 17:27:43PM - Condition failed 08/07/2013 17:27:43PM - Skipping action 7615A7D4-FB57-4CD7-9D01-345765DF42DE - Execute Look for EclipseDir - conditions failed 08/07/2013 17:27:43PM - Displaying pane F47FFD38-C9F1-4896-B0C5-A870FBD8CDE7 - Select Destination 08/07/2013 17:27:43PM - Executing actions F47FFD38-C9F1-4896-B0C5-A870FBD8CDE7 - Select Destination - After Pane is Displayed 08/07/2013 17:27:43PM - Checking conditions for DF3D9494-F760-448B-915E-A23D94B7FE9C - Initialize EclipseDir - Before Action is Executed 08/07/2013 17:27:43PM - Checking condition 541443C2-AE4D-4C32-891F-76BA4174C31A - String Is Condition 08/07/2013 17:27:43PM - Checking to see if <%Native_Eclipse_Selected%> is false 08/07/2013 17:27:43PM - ** Checking to see if 0 is false 08/07/2013 17:27:43PM - Condition passed 08/07/2013 17:27:43PM - Executing action DF3D9494-F760-448B-915E-A23D94B7FE9C - Initialize EclipseDir 08/07/2013 17:27:43PM - Executing action 76B72CC4-6A46-43FF-ACAD-88E10B96E4AA - Initialize Variables 08/07/2013 17:27:43PM - checking installedfbinary 08/07/2013 17:27:43PM - Executing action 7AE21CEE-B823-4A59-988A-CF452F9E8811 - Set ReRun (false) 08/07/2013 17:27:43PM - Executing action DAE3C4E4-3CE4-4A7F-A60B-9F332F4021CE - Set Update_Eclipse (true) 08/07/2013 17:27:43PM - Executing action B9E1016C-6068-4C82-8137-F472851CD25C - DestinationFrame 08/07/2013 17:27:43PM - Executing action B9CB2CE2-E2E9-45F1-B7B3-0FEDD1A31099 - DestinationLabel 08/07/2013 17:27:43PM - Executing action B000C96C-0BDA-43F2-BA4B-E0E15B1700AE - DestinationBrowseButton 08/07/2013 17:27:43PM - Executing action B4E4526D-A3DB-486D-A7BF-39320D74CB7F - Adjust Layout 08/07/2013 17:27:43PM - Checking conditions for D948D911-691E-4BBA-A789-FD437E15C553 - Set EclipseDir Checkbox - Before Action is Executed 08/07/2013 17:27:43PM - Checking condition 723CA04D-2EF9-4B6A-8FDD-97A01E04A617 - String Is Condition 08/07/2013 17:27:43PM - Checking to see if <%Valid_Eclipse_Found%> is true 08/07/2013 17:27:43PM - ** Checking to see if false is true 08/07/2013 17:27:43PM - Condition failed 08/07/2013 17:27:43PM - Skipping action D948D911-691E-4BBA-A789-FD437E15C553 - Set EclipseDir Checkbox - conditions failed 08/07/2013 17:27:43PM - Checking conditions for 1D063DD9-A021-42A2-B1F5-EDF53B08EEB4 - Execute EclipseDir Action - Before Action is Executed 08/07/2013 17:27:43PM - Checking condition 4C64020A-A19F-460B-A4AD-43A59BE69C48 - String Equal Condition 08/07/2013 17:27:43PM - Checking to see if <%ShortName%> does not equal UniFlash 08/07/2013 17:27:43PM - ** Checking to see if CCS does not equal UniFlash 08/07/2013 17:27:43PM - Condition passed 08/07/2013 17:27:43PM - Executing action 1D063DD9-A021-42A2-B1F5-EDF53B08EEB4 - Execute EclipseDir Action 08/07/2013 17:27:43PM - Executing actions B520BD41-3AB6-4D4B-91B3-8C28D0C214D2 - EclipseDir Action 08/07/2013 17:27:43PM - Checking conditions for 7D9E88F0-5467-4E6D-A430-29312184ACD8 - - Before Action is Executed 08/07/2013 17:27:43PM - Checking condition 9A5D877C-FFC1-4225-BD05-980C8F0532FE - String Is Condition 08/07/2013 17:27:43PM - Checking to see if <%Native_Eclipse_Selected%> is false 08/07/2013 17:27:43PM - ** Checking to see if 0 is false 08/07/2013 17:27:43PM - Condition passed 08/07/2013 17:27:43PM - Executing action 7D9E88F0-5467-4E6D-A430-29312184ACD8 - Execute Destroy Eclipse Location Action 08/07/2013 17:27:43PM - Executing actions 251DB6BC-DFA4-45BE-8ECE-D72CBE1E87D4 - Destroy Eclipse Location Action 08/07/2013 17:27:43PM - Checking conditions for F6D36286-ED6F-40D0-AD99-2F8450E51081 - - Before Action is Executed 08/07/2013 17:27:43PM - Checking condition 8BBD9C89-EFBB-457A-B7B8-36C27F8C2D93 - Execute Script Condition 08/07/2013 17:27:43PM - aWidget = CDBAD941-00B7-4B5F-B3C8-74CF9FE03269 08/07/2013 17:27:43PM - Condition passed 08/07/2013 17:27:43PM - Executing action F6D36286-ED6F-40D0-AD99-2F8450E51081 - Delete Browse Button 08/07/2013 17:27:43PM - Checking conditions for AC055342-233D-4DBE-A388-8D459C788420 - - Before Action is Executed 08/07/2013 17:27:43PM - Checking condition 552C5F74-33ED-4D6B-8386-8AEE0F861479 - Execute Script Condition 08/07/2013 17:27:43PM - aWidget = 355B175A-3A7D-43F2-BB48-483CE773678A 08/07/2013 17:27:43PM - Condition passed 08/07/2013 17:27:43PM - Executing action AC055342-233D-4DBE-A388-8D459C788420 - Delete Eclipse Label 08/07/2013 17:27:43PM - Checking conditions for 9061C5E1-8C4A-4BAC-ADB0-7FE93901F568 - - Before Action is Executed 08/07/2013 17:27:43PM - Checking condition 42DFCE80-B1CF-4341-BCA6-0DEE4C97BB0E - Execute Script Condition 08/07/2013 17:27:43PM - aWidget = 8C353761-A7C4-487F-8DED-7B6CEAFCC7F3 08/07/2013 17:27:43PM - Condition passed 08/07/2013 17:27:43PM - Executing action 9061C5E1-8C4A-4BAC-ADB0-7FE93901F568 - Delete Eclipse Frame 08/07/2013 17:27:43PM - Executing action 7D140CC9-056A-46F3-9402-6200A6DD0179 - Enable Next Button 3 08/07/2013 17:27:43PM - Checking conditions for C3BBD85E-CF2E-4D18-830E-706680E62295 - - Before Action is Executed 08/07/2013 17:27:43PM - Checking condition 21D3B6B1-8945-4630-B44A-6E752CCC6393 - String Is Condition 08/07/2013 17:27:43PM - Checking to see if <%Native_Eclipse_Selected%> is true 08/07/2013 17:27:43PM - ** Checking to see if 0 is true 08/07/2013 17:27:43PM - Condition failed 08/07/2013 17:27:43PM - Skipping action C3BBD85E-CF2E-4D18-830E-706680E62295 - Execute Create Eclipse Location Action - conditions failed 08/07/2013 17:27:46PM - Checking conditions for F47FFD38-C9F1-4896-B0C5-A870FBD8CDE7 - Select Destination - Before Next Pane is Displayed 08/07/2013 17:27:46PM - Checking condition 9988A480-90AF-4403-9780-1C5A957E2445 - File Permission Condition 08/07/2013 17:27:46PM - Checking to see if we can create <%InstallDir%> 08/07/2013 17:27:46PM - ** Checking to see if we can create C:ti 08/07/2013 17:27:46PM - Condition passed 08/07/2013 17:27:46PM - Executing actions F47FFD38-C9F1-4896-B0C5-A870FBD8CDE7 - Select Destination - Before Next Pane is Displayed 08/07/2013 17:27:46PM - Executing action 00881923-FC71-43A3-9FC0-801A9E6C35B6 - Execute Look for Previous Installs 08/07/2013 17:27:46PM - Executing actions C72174AD-964D-449B-9E81-13CED09097C5 - Look for Previous Installs 08/07/2013 17:27:46PM - Executing action C72174AD-964D-449B-9E81-13CED09097C5 - Look for Previous Installs 08/07/2013 17:27:46PM - CCSDIR = C:ti/ccsv5 false 0 08/07/2013 17:27:46PM - C:ti C:ti/ccsv5 C:ti/ccsv5/eclipse C:ti/ccsv5/eclipse/ccs_config.xml 08/07/2013 17:27:46PM - dir content C:/ti/ccsv5 = 08/07/2013 17:27:46PM - file exists 0 08/07/2013 17:27:46PM - no ccsdir or it's empty 08/07/2013 17:27:46PM - Checking conditions for A59224D3-9CA8-4944-9C35-A0C72BAE5D71 - Previous Install Found - Before Pane is Displayed 08/07/2013 17:27:46PM - Checking condition BEB51ECD-539D-4EB0-9BBD-70325303A603 - String Is Condition 08/07/2013 17:27:46PM - Checking to see if <%ReRun%> is true 08/07/2013 17:27:46PM - ** Checking to see if 0 is true 08/07/2013 17:27:46PM - Condition failed 08/07/2013 17:27:46PM - Skipping pane A59224D3-9CA8-4944-9C35-A0C72BAE5D71 - Previous Install Found - conditions failed 08/07/2013 17:27:46PM - Checking conditions for F6FCB570-82DE-4640-AEF0-5CD6A221E0EB - Custom Setup Type - Before Pane is Displayed 08/07/2013 17:27:46PM - Checking condition 60512861-E5AE-4FDD-8E7C-C982DD1A4B6C - String Is Condition 08/07/2013 17:27:46PM - Checking to see if <%ReRun%> is false 08/07/2013 17:27:46PM - ** Checking to see if 0 is false 08/07/2013 17:27:46PM - Condition passed 08/07/2013 17:27:46PM - Checking condition 49610746-5157-47D5-BD44-A52DADA4E885 - String Is Condition 08/07/2013 17:27:46PM - Checking to see if <%ShowSetupPane%> is true 08/07/2013 17:27:46PM - ** Checking to see if true is true 08/07/2013 17:27:46PM - Condition passed 08/07/2013 17:27:46PM - Executing actions F6FCB570-82DE-4640-AEF0-5CD6A221E0EB - Custom Setup Type - Before Pane is Displayed 08/07/2013 17:27:46PM - Displaying pane F6FCB570-82DE-4640-AEF0-5CD6A221E0EB - Custom Setup Type 08/07/2013 17:27:47PM - Executing actions F6FCB570-82DE-4640-AEF0-5CD6A221E0EB - Custom Setup Type - After Pane is Displayed 08/07/2013 17:27:49PM - Executing actions F6FCB570-82DE-4640-AEF0-5CD6A221E0EB - Custom Setup Type - Before Next Pane is Displayed 08/07/2013 17:27:49PM - Executing action 39084E99-5AFB-45DA-AFD1-8ACD3A936F53 - Disable Next 08/07/2013 17:27:49PM - Executing action 4CF4BB8E-1853-46E0-AB50-25BA2172B119 - Execute Get Edition Details 08/07/2013 17:27:49PM - Executing actions 214CDC31-6FF9-4C65-B874-265447EB94E3 - Get Edition Details 08/07/2013 17:27:49PM - Executing action 64877C38-51BE-4D33-8849-6C8852694A01 - Parse XML Input 08/07/2013 17:27:49PM - Executing action E065533E-1E05-44C3-BB4D-F4D3CB0F8713 - Execute Setup Panes to Display 08/07/2013 17:27:49PM - Executing actions 3835C529-654B-4A82-B84B-B3A7CBEA79AB - Set Panes to Display 08/07/2013 17:27:49PM - Checking conditions for 3835C529-654B-4A82-B84B-B3A7CBEA79AB - - Before Action is Executed 08/07/2013 17:27:49PM - Checking condition 15BC7606-F1AD-4573-8AA7-21FFCA15D5DB - String Is Condition 08/07/2013 17:27:49PM - Checking to see if <%UpdateMode%> is false 08/07/2013 17:27:49PM - ** Checking to see if 0 is false 08/07/2013 17:27:49PM - Condition passed 08/07/2013 17:27:49PM - Executing action 3835C529-654B-4A82-B84B-B3A7CBEA79AB - Set Panes to Display 08/07/2013 17:27:49PM - In Add Components: 08/07/2013 17:27:49PM - installed features = 08/07/2013 17:27:49PM - products installed: 08/07/2013 17:27:49PM - products installed: 08/07/2013 17:27:49PM - edition pane now: ISA,FEATURE,EMU 08/07/2013 17:27:49PM - Edition: Custom ISA,FEATURE,EMU 08/07/2013 17:27:49PM - ISAs: true 08/07/2013 17:27:49PM - Features: true 08/07/2013 17:27:49PM - Emus: true 08/07/2013 17:27:49PM - Checking conditions for E72C84B4-EC31-4A8F-9380-31452E3AB764 - Choose ISAs - Before Pane is Displayed 08/07/2013 17:27:49PM - Checking condition B6C81A68-D44A-4C50-9EFE-31283C4A5DA2 - String Is Condition 08/07/2013 17:27:49PM - Checking to see if <%ShowISAs%> is true 08/07/2013 17:27:49PM - ** Checking to see if true is true 08/07/2013 17:27:49PM - Condition passed 08/07/2013 17:27:49PM - Executing actions E72C84B4-EC31-4A8F-9380-31452E3AB764 - Choose ISAs - Before Pane is Displayed 08/07/2013 17:27:49PM - Executing action 5F503179-A182-4759-8CBD-71D018F72B92 - Disable Next 08/07/2013 17:27:49PM - Executing action FF47D51D-DCFF-4ADD-9EC5-F70146A0EBBF - Add ISAs 08/07/2013 17:27:49PM - products installed: 08/07/2013 17:27:49PM - products installed: 08/07/2013 17:27:49PM - Displaying pane E72C84B4-EC31-4A8F-9380-31452E3AB764 - Choose ISAs 08/07/2013 17:27:49PM - Executing actions E72C84B4-EC31-4A8F-9380-31452E3AB764 - Choose ISAs - After Pane is Displayed 08/07/2013 17:27:49PM - Executing action A7B822CD-1782-40B1-B1A2-CAF6D83668A0 - Reset download size msg 08/07/2013 17:27:53PM - Adding TC_BIOS5 91193648: new total 91193648.0 08/07/2013 17:27:53PM - Adding TC_C6000_BIOS6 14578054: new total 105771702.0 08/07/2013 17:27:53PM - Adding TC_BIOS6 24089799: new total 129861501.0 08/07/2013 17:27:53PM - Adding SIM_TI 47448879: new total 177310380.0 08/07/2013 17:27:53PM - Adding EMU_SD 27888672: new total 205199052.0 08/07/2013 17:27:53PM - Adding IDE_MAIN 85556996: new total 290756048.0 08/07/2013 17:27:53PM - Adding TC_XDCTOOLS_BIOS5 88411834: new total 379167882.0 08/07/2013 17:27:53PM - Adding KEYSTONE1 1590496: new total 380758378.0 08/07/2013 17:27:53PM - Adding EMU_TI 35739725: new total 416498103.0 08/07/2013 17:27:53PM - Adding KEYSTONE2 1380354: new total 417878457.0 08/07/2013 17:27:53PM - Adding CGT_DEFAULTLIBS_C6000 69766516: new total 487644973.0 08/07/2013 17:27:53PM - Adding DVT_UIA 36713918: new total 524358891.0 08/07/2013 17:27:53PM - Adding DEV_SUPPORT_SHARED 4047699: new total 528406590.0 08/07/2013 17:27:53PM - Adding DEV_SUPPORT_C6000MC 170789: new total 528577379.0 08/07/2013 17:27:53PM - Adding TC_C6000_XDCTOOLS 28065809: new total 556643188.0 08/07/2013 17:27:53PM - Adding C6000_CGT_HELP 3197575: new total 559840763.0 08/07/2013 17:27:53PM - Adding TC_XDAIS 8492292: new total 568333055.0 08/07/2013 17:27:53PM - Adding EMU_BH 45370003: new total 613703058.0 08/07/2013 17:27:53PM - Adding DMED 1611418: new total 615314476.0 08/07/2013 17:27:53PM - Adding GMF 12342547: new total 627657023.0 08/07/2013 17:27:53PM - Adding XULRUNNER 16596408: new total 644253431.0 08/07/2013 17:27:53PM - Adding CCSINIT 1331118: new total 645584549.0 08/07/2013 17:27:53PM - Adding UIA 23110255: new total 668694804.0 08/07/2013 17:27:53PM - Adding DS 16259318: new total 684954122.0 08/07/2013 17:27:53PM - adding JRE 716318928.0 08/07/2013 17:27:53PM - adding ECLIPSE 808309175.0 08/07/2013 17:27:53PM - adding ECLIPSECORE 861206412.0 08/07/2013 17:27:53PM - adding P2TOOLS 861227168.0 08/07/2013 17:27:53PM - adding MSVC80 863934520.0 08/07/2013 17:27:53PM - adding MSVC2008 868151360.0 08/07/2013 17:27:53PM - adding MSVC2012 874711448.0 08/07/2013 17:27:53PM - adding INSTALLER 874711943.0 08/07/2013 17:27:53PM - 834.190314293 08/07/2013 17:27:53PM - ==================== Install size: 2502.57 MB. s=1 08/07/2013 17:27:58PM - Executing actions E72C84B4-EC31-4A8F-9380-31452E3AB764 - Choose ISAs - Before Next Pane is Displayed 08/07/2013 17:27:58PM - Checking conditions for 0FF2C23D-509B-496F-9DED-C0FE5D001E3A - Custom Choose Components - Before Pane is Displayed 08/07/2013 17:27:58PM - Checking condition 78EC68E8-BDC8-4E8E-998E-339FA70D366A - String Is Condition 08/07/2013 17:27:58PM - Checking to see if <%ShowFEATUREs%> is true 08/07/2013 17:27:58PM - ** Checking to see if true is true 08/07/2013 17:27:58PM - Condition passed 08/07/2013 17:27:58PM - Executing actions 0FF2C23D-509B-496F-9DED-C0FE5D001E3A - Custom Choose Components - Before Pane is Displayed 08/07/2013 17:27:58PM - Executing action 20F6E982-FCA8-4DA7-865F-66836D1A486B - Add Components 08/07/2013 17:27:58PM - In Add Components: 08/07/2013 17:27:58PM - compmessagewidget .wizard.steps.f0FF2C23D-509B-496F-9DED-C0FE5D001E3A.message 08/07/2013 17:27:58PM - installed features = 08/07/2013 17:27:58PM - Displaying feature list: 08/07/2013 17:27:58PM - addgroup=0:addsub=1:level=0 08/07/2013 17:27:58PM - initializing showcomps for Compiler Tools 0 08/07/2013 17:27:58PM - initializing showcomps for Compiler Tools 0 08/07/2013 17:27:58PM - initializing showcomps for Compiler Tools 0 08/07/2013 17:27:58PM - initializing showcomps for Compiler Tools 0 08/07/2013 17:27:58PM - 1 Component CGT_DEFAULTLIBS_C6000 is offered 08/07/2013 17:27:58PM - 1 Component CGT_DEFAULTLIBS_C6000 is selected 08/07/2013 17:27:58PM - adding group Compiler_Tools 08/07/2013 17:27:58PM - level = 0 1 08/07/2013 17:27:58PM - showcomps for Compiler Tools 1 08/07/2013 17:27:58PM - initializing showcomps for Compiler Tools 0 08/07/2013 17:27:58PM - initializing showcomps for Compiler Tools 0 08/07/2013 17:27:58PM - initializing showcomps for Compiler Tools 0 08/07/2013 17:27:58PM - all components in Compiler Tools are now being selected. 08/07/2013 17:27:58PM - showcomps: 0 Compiler_Tools: 1 08/07/2013 17:27:58PM - in click_componentsubgroup Compiler Tools 08/07/2013 17:27:58PM - Checking subgroup Compiler Tools 08/07/2013 17:27:58PM - Checking subgroup Compiler Tools 08/07/2013 17:27:58PM - Checking subgroup Compiler Tools 08/07/2013 17:27:58PM - Checking subgroup Compiler Tools 08/07/2013 17:27:58PM - CGT_DEFAULTLIBS_C6000 has no additional options 08/07/2013 17:27:58PM - Checking CGT_DEFAULTLIBS_C6000 08/07/2013 17:27:58PM - Adding TC_BIOS5 91193648: new total 91193648.0 08/07/2013 17:27:58PM - Adding TC_C6000_BIOS6 14578054: new total 105771702.0 08/07/2013 17:27:58PM - Adding TC_BIOS6 24089799: new total 129861501.0 08/07/2013 17:27:58PM - Adding SIM_TI 47448879: new total 177310380.0 08/07/2013 17:27:58PM - Adding EMU_SD 27888672: new total 205199052.0 08/07/2013 17:27:58PM - Adding IDE_MAIN 85556996: new total 290756048.0 08/07/2013 17:27:58PM - Adding TC_XDCTOOLS_BIOS5 88411834: new total 379167882.0 08/07/2013 17:27:58PM - Adding KEYSTONE1 1590496: new total 380758378.0 08/07/2013 17:27:58PM - Adding EMU_TI 35739725: new total 416498103.0 08/07/2013 17:27:58PM - Adding KEYSTONE2 1380354: new total 417878457.0 08/07/2013 17:27:58PM - Adding CGT_DEFAULTLIBS_C6000 69766516: new total 487644973.0 08/07/2013 17:27:58PM - Adding DVT_UIA 36713918: new total 524358891.0 08/07/2013 17:27:58PM - Adding DEV_SUPPORT_SHARED 4047699: new total 528406590.0 08/07/2013 17:27:58PM - Adding DEV_SUPPORT_C6000MC 170789: new total 528577379.0 08/07/2013 17:27:58PM - Adding TC_C6000_XDCTOOLS 28065809: new total 556643188.0 08/07/2013 17:27:58PM - Adding C6000_CGT_HELP 3197575: new total 559840763.0 08/07/2013 17:27:58PM - Adding TC_XDAIS 8492292: new total 568333055.0 08/07/2013 17:27:58PM - Adding EMU_BH 45370003: new total 613703058.0 08/07/2013 17:27:58PM - Adding DMED 1611418: new total 615314476.0 08/07/2013 17:27:58PM - Adding GMF 12342547: new total 627657023.0 08/07/2013 17:27:58PM - Adding XULRUNNER 16596408: new total 644253431.0 08/07/2013 17:27:58PM - Adding CCSINIT 1331118: new total 645584549.0 08/07/2013 17:27:58PM - Adding UIA 23110255: new total 668694804.0 08/07/2013 17:27:58PM - Adding DS 16259318: new total 684954122.0 08/07/2013 17:27:58PM - adding JRE 31364806 new size: 716318928.0 08/07/2013 17:27:58PM - adding ECLIPSE 91990247 new size: 808309175.0 08/07/2013 17:27:58PM - adding ECLIPSECORE 52897237 new size: 861206412.0 08/07/2013 17:27:58PM - adding P2TOOLS 20756 new size: 861227168.0 08/07/2013 17:27:58PM - adding MSVC80 2707352 new size: 863934520.0 08/07/2013 17:27:58PM - adding MSVC2008 4216840 new size: 868151360.0 08/07/2013 17:27:58PM - adding MSVC2012 6560088 new size: 874711448.0 08/07/2013 17:27:58PM - adding INSTALLER 495 new size: 874711943.0 08/07/2013 17:27:58PM - size = 874711943.0 08/07/2013 17:27:58PM - ==================== Install size: 2502.57 MB. 08/07/2013 17:27:58PM - setting CGT_DEFAULTLIBS_C6000 on 1 08/07/2013 17:27:58PM - Checking subgroup Compiler Tools 08/07/2013 17:27:58PM - Checking subgroup Compiler Tools 08/07/2013 17:27:58PM - Checking subgroup Compiler Tools 08/07/2013 17:27:58PM - addgroup=1:addsub=0:level=1 08/07/2013 17:27:58PM - initializing showcomps for TI Documentation 0 08/07/2013 17:27:58PM - initializing showcomps for TI Documentation 0 08/07/2013 17:27:58PM - initializing showcomps for TI Documentation 0 08/07/2013 17:27:58PM - 1 Component C6000_CGT_HELP is offered 08/07/2013 17:27:58PM - 1 Component C6000_CGT_HELP is selected 08/07/2013 17:27:58PM - 1 Adding subgroup: TI Documentation 08/07/2013 17:27:58PM - level = 1 1 08/07/2013 17:27:58PM - showcomps for TI Documentation 0 08/07/2013 17:27:58PM - initializing showcomps for TI Documentation 0 08/07/2013 17:27:58PM - initializing showcomps for TI Documentation 0 08/07/2013 17:27:58PM - 1 Component DMED is offered 08/07/2013 17:27:58PM - 1 Component DMED is selected 08/07/2013 17:27:58PM - level = 1 1 08/07/2013 17:27:58PM - showcomps for TI Documentation 0 08/07/2013 17:27:58PM - initializing showcomps for TI Documentation 0 08/07/2013 17:27:58PM - all components in TI Documentation are now being selected. 08/07/2013 17:27:58PM - showcomps: 0 TI_Documentation: 1 08/07/2013 17:27:58PM - in click_componentsubgroup TI Documentation 08/07/2013 17:27:58PM - Checking subgroup TI Documentation 08/07/2013 17:27:58PM - Checking subgroup TI Documentation 08/07/2013 17:27:58PM - Checking subgroup TI Documentation 08/07/2013 17:27:58PM - C6000_CGT_HELP has no additional options 08/07/2013 17:27:58PM - Checking C6000_CGT_HELP 08/07/2013 17:27:58PM - Adding TC_BIOS5 91193648: new total 91193648.0 08/07/2013 17:27:58PM - Adding TC_C6000_BIOS6 14578054: new total 105771702.0 08/07/2013 17:27:58PM - Adding TC_BIOS6 24089799: new total 129861501.0 08/07/2013 17:27:58PM - Adding SIM_TI 47448879: new total 177310380.0 08/07/2013 17:27:58PM - Adding EMU_SD 27888672: new total 205199052.0 08/07/2013 17:27:58PM - Adding IDE_MAIN 85556996: new total 290756048.0 08/07/2013 17:27:58PM - Adding TC_XDCTOOLS_BIOS5 88411834: new total 379167882.0 08/07/2013 17:27:58PM - Adding KEYSTONE1 1590496: new total 380758378.0 08/07/2013 17:27:58PM - Adding EMU_TI 35739725: new total 416498103.0 08/07/2013 17:27:58PM - Adding KEYSTONE2 1380354: new total 417878457.0 08/07/2013 17:27:58PM - Adding CGT_DEFAULTLIBS_C6000 69766516: new total 487644973.0 08/07/2013 17:27:58PM - Adding DVT_UIA 36713918: new total 524358891.0 08/07/2013 17:27:58PM - Adding DEV_SUPPORT_SHARED 4047699: new total 528406590.0 08/07/2013 17:27:58PM - Adding DEV_SUPPORT_C6000MC 170789: new total 528577379.0 08/07/2013 17:27:58PM - Adding TC_C6000_XDCTOOLS 28065809: new total 556643188.0 08/07/2013 17:27:58PM - Adding C6000_CGT_HELP 3197575: new total 559840763.0 08/07/2013 17:27:58PM - Adding TC_XDAIS 8492292: new total 568333055.0 08/07/2013 17:27:58PM - Adding EMU_BH 45370003: new total 613703058.0 08/07/2013 17:27:58PM - Adding DMED 1611418: new total 615314476.0 08/07/2013 17:27:58PM - Adding GMF 12342547: new total 627657023.0 08/07/2013 17:27:58PM - Adding XULRUNNER 16596408: new total 644253431.0 08/07/2013 17:27:58PM - Adding CCSINIT 1331118: new total 645584549.0 08/07/2013 17:27:58PM - Adding UIA 23110255: new total 668694804.0 08/07/2013 17:27:58PM - Adding DS 16259318: new total 684954122.0 08/07/2013 17:27:58PM - adding JRE 31364806 new size: 716318928.0 08/07/2013 17:27:58PM - adding ECLIPSE 91990247 new size: 808309175.0 08/07/2013 17:27:58PM - adding ECLIPSECORE 52897237 new size: 861206412.0 08/07/2013 17:27:58PM - adding P2TOOLS 20756 new size: 861227168.0 08/07/2013 17:27:58PM - adding MSVC80 2707352 new size: 863934520.0 08/07/2013 17:27:58PM - adding MSVC2008 4216840 new size: 868151360.0 08/07/2013 17:27:58PM - adding MSVC2012 6560088 new size: 874711448.0 08/07/2013 17:27:58PM - adding INSTALLER 495 new size: 874711943.0 08/07/2013 17:27:58PM - size = 874711943.0 08/07/2013 17:27:58PM - ==================== Install size: 2502.57 MB. 08/07/2013 17:27:58PM - setting C6000_CGT_HELP on 1 08/07/2013 17:27:58PM - Checking subgroup TI Documentation 08/07/2013 17:27:58PM - Checking subgroup TI Documentation 08/07/2013 17:27:58PM - DMED has no additional options 08/07/2013 17:27:58PM - Checking DMED 08/07/2013 17:27:58PM - Adding TC_BIOS5 91193648: new total 91193648.0 08/07/2013 17:27:58PM - Adding TC_C6000_BIOS6 14578054: new total 105771702.0 08/07/2013 17:27:58PM - Adding TC_BIOS6 24089799: new total 129861501.0 08/07/2013 17:27:58PM - Adding SIM_TI 47448879: new total 177310380.0 08/07/2013 17:27:58PM - Adding EMU_SD 27888672: new total 205199052.0 08/07/2013 17:27:58PM - Adding IDE_MAIN 85556996: new total 290756048.0 08/07/2013 17:27:58PM - Adding TC_XDCTOOLS_BIOS5 88411834: new total 379167882.0 08/07/2013 17:27:58PM - Adding KEYSTONE1 1590496: new total 380758378.0 08/07/2013 17:27:58PM - Adding EMU_TI 35739725: new total 416498103.0 08/07/2013 17:27:58PM - Adding KEYSTONE2 1380354: new total 417878457.0 08/07/2013 17:27:58PM - Adding CGT_DEFAULTLIBS_C6000 69766516: new total 487644973.0 08/07/2013 17:27:58PM - Adding DVT_UIA 36713918: new total 524358891.0 08/07/2013 17:27:58PM - Adding DEV_SUPPORT_SHARED 4047699: new total 528406590.0 08/07/2013 17:27:58PM - Adding DEV_SUPPORT_C6000MC 170789: new total 528577379.0 08/07/2013 17:27:58PM - Adding TC_C6000_XDCTOOLS 28065809: new total 556643188.0 08/07/2013 17:27:58PM - Adding C6000_CGT_HELP 3197575: new total 559840763.0 08/07/2013 17:27:58PM - Adding TC_XDAIS 8492292: new total 568333055.0 08/07/2013 17:27:58PM - Adding EMU_BH 45370003: new total 613703058.0 08/07/2013 17:27:58PM - Adding DMED 1611418: new total 615314476.0 08/07/2013 17:27:58PM - Adding GMF 12342547: new total 627657023.0 08/07/2013 17:27:58PM - Adding XULRUNNER 16596408: new total 644253431.0 08/07/2013 17:27:58PM - Adding CCSINIT 1331118: new total 645584549.0 08/07/2013 17:27:58PM - Adding UIA 23110255: new total 668694804.0 08/07/2013 17:27:58PM - Adding DS 16259318: new total 684954122.0 08/07/2013 17:27:58PM - adding JRE 31364806 new size: 716318928.0 08/07/2013 17:27:58PM - adding ECLIPSE 91990247 new size: 808309175.0 08/07/2013 17:27:58PM - adding ECLIPSECORE 52897237 new size: 861206412.0 08/07/2013 17:27:58PM - adding P2TOOLS 20756 new size: 861227168.0 08/07/2013 17:27:58PM - adding MSVC80 2707352 new size: 863934520.0 08/07/2013 17:27:58PM - adding MSVC2008 4216840 new size: 868151360.0 08/07/2013 17:27:58PM - adding MSVC2012 6560088 new size: 874711448.0 08/07/2013 17:27:58PM - adding INSTALLER 495 new size: 874711943.0 08/07/2013 17:27:58PM - size = 874711943.0 08/07/2013 17:27:58PM - ==================== Install size: 2502.57 MB. 08/07/2013 17:27:58PM - setting DMED on 1 08/07/2013 17:27:58PM - Checking subgroup TI Documentation 08/07/2013 17:27:58PM - addgroup=0:addsub=0:level=1 08/07/2013 17:27:58PM - initializing showcomps for MSP430ware only 0 08/07/2013 17:27:58PM - addgroup=0:addsub=0:level=1 08/07/2013 17:27:58PM - initializing showcomps for Grace (includes MSP430ware) 0 08/07/2013 17:27:58PM - addgroup=0:addsub=0:level=1 08/07/2013 17:27:58PM - initializing showcomps for DSP/BIOS v5 0 08/07/2013 17:27:58PM - 1 Component TC_XDCTOOLS_BIOS5 is offered 08/07/2013 17:27:58PM - 1 Component TC_XDCTOOLS_BIOS5 is selected 08/07/2013 17:27:58PM - adding group Device_Software 08/07/2013 17:27:58PM - 1 Adding subgroup: DSP/BIOS v5 08/07/2013 17:27:58PM - level = 1 1 08/07/2013 17:27:58PM - showcomps for DSP/BIOS v5 0 08/07/2013 17:27:58PM - initializing showcomps for DSP/BIOS v5 0 08/07/2013 17:27:58PM - 1 Component TC_XDAIS_BIOS5 is offered 08/07/2013 17:27:58PM - 1 Component TC_XDAIS_BIOS5 is selected 08/07/2013 17:27:58PM - level = 1 1 08/07/2013 17:27:58PM - showcomps for DSP/BIOS v5 0 08/07/2013 17:27:58PM - initializing showcomps for DSP/BIOS v5 0 08/07/2013 17:27:58PM - 1 Component TC_BIOS5 is offered 08/07/2013 17:27:58PM - 1 Component TC_BIOS5 is selected 08/07/2013 17:27:58PM - level = 1 1 08/07/2013 17:27:58PM - showcomps for DSP/BIOS v5 0 08/07/2013 17:27:58PM - all components in DSP/BIOS v5 are now being selected. 08/07/2013 17:27:58PM - showcomps: 0 DSP/BIOS_v5: 1 08/07/2013 17:27:58PM - in click_componentsubgroup DSP/BIOS v5 08/07/2013 17:27:58PM - Checking subgroup DSP/BIOS v5 08/07/2013 17:27:58PM - TC_XDCTOOLS_BIOS5 has no additional options 08/07/2013 17:27:58PM - Checking TC_XDCTOOLS_BIOS5 08/07/2013 17:27:58PM - Adding TC_BIOS5 91193648: new total 91193648.0 08/07/2013 17:27:58PM - Adding TC_C6000_BIOS6 14578054: new total 105771702.0 08/07/2013 17:27:58PM - Adding TC_BIOS6 24089799: new total 129861501.0 08/07/2013 17:27:58PM - Adding SIM_TI 47448879: new total 177310380.0 08/07/2013 17:27:58PM - Adding EMU_SD 27888672: new total 205199052.0 08/07/2013 17:27:58PM - Adding IDE_MAIN 85556996: new total 290756048.0 08/07/2013 17:27:58PM - Adding TC_XDCTOOLS_BIOS5 88411834: new total 379167882.0 08/07/2013 17:27:58PM - Adding KEYSTONE1 1590496: new total 380758378.0 08/07/2013 17:27:58PM - Adding EMU_TI 35739725: new total 416498103.0 08/07/2013 17:27:58PM - Adding KEYSTONE2 1380354: new total 417878457.0 08/07/2013 17:27:58PM - Adding CGT_DEFAULTLIBS_C6000 69766516: new total 487644973.0 08/07/2013 17:27:58PM - Adding DVT_UIA 36713918: new total 524358891.0 08/07/2013 17:27:58PM - Adding DEV_SUPPORT_SHARED 4047699: new total 528406590.0 08/07/2013 17:27:58PM - Adding DEV_SUPPORT_C6000MC 170789: new total 528577379.0 08/07/2013 17:27:58PM - Adding TC_C6000_XDCTOOLS 28065809: new total 556643188.0 08/07/2013 17:27:58PM - Adding C6000_CGT_HELP 3197575: new total 559840763.0 08/07/2013 17:27:58PM - Adding TC_XDAIS 8492292: new total 568333055.0 08/07/2013 17:27:58PM - Adding EMU_BH 45370003: new total 613703058.0 08/07/2013 17:27:58PM - Adding DMED 1611418: new total 615314476.0 08/07/2013 17:27:58PM - Adding GMF 12342547: new total 627657023.0 08/07/2013 17:27:58PM - Adding XULRUNNER 16596408: new total 644253431.0 08/07/2013 17:27:58PM - Adding CCSINIT 1331118: new total 645584549.0 08/07/2013 17:27:58PM - Adding UIA 23110255: new total 668694804.0 08/07/2013 17:27:58PM - Adding DS 16259318: new total 684954122.0 08/07/2013 17:27:58PM - adding JRE 31364806 new size: 716318928.0 08/07/2013 17:27:58PM - adding ECLIPSE 91990247 new size: 808309175.0 08/07/2013 17:27:58PM - adding ECLIPSECORE 52897237 new size: 861206412.0 08/07/2013 17:27:58PM - adding P2TOOLS 20756 new size: 861227168.0 08/07/2013 17:27:58PM - adding MSVC80 2707352 new size: 863934520.0 08/07/2013 17:27:58PM - adding MSVC2008 4216840 new size: 868151360.0 08/07/2013 17:27:58PM - adding MSVC2012 6560088 new size: 874711448.0 08/07/2013 17:27:58PM - adding INSTALLER 495 new size: 874711943.0 08/07/2013 17:27:58PM - size = 874711943.0 08/07/2013 17:27:58PM - ==================== Install size: 2502.57 MB. 08/07/2013 17:27:58PM - setting TC_XDCTOOLS_BIOS5 on 1 08/07/2013 17:27:58PM - Checking subgroup DSP/BIOS v5 08/07/2013 17:27:58PM - TC_XDAIS_BIOS5 has no additional options 08/07/2013 17:27:58PM - Checking TC_XDAIS_BIOS5 08/07/2013 17:27:58PM - Adding TC_BIOS5 91193648: new total 91193648.0 08/07/2013 17:27:58PM - Adding TC_C6000_BIOS6 14578054: new total 105771702.0 08/07/2013 17:27:58PM - Adding TC_BIOS6 24089799: new total 129861501.0 08/07/2013 17:27:58PM - Adding SIM_TI 47448879: new total 177310380.0 08/07/2013 17:27:58PM - Adding EMU_SD 27888672: new total 205199052.0 08/07/2013 17:27:58PM - Adding IDE_MAIN 85556996: new total 290756048.0 08/07/2013 17:27:58PM - Adding TC_XDCTOOLS_BIOS5 88411834: new total 379167882.0 08/07/2013 17:27:58PM - Adding KEYSTONE1 1590496: new total 380758378.0 08/07/2013 17:27:58PM - Adding EMU_TI 35739725: new total 416498103.0 08/07/2013 17:27:58PM - Adding KEYSTONE2 1380354: new total 417878457.0 08/07/2013 17:27:58PM - Adding CGT_DEFAULTLIBS_C6000 69766516: new total 487644973.0 08/07/2013 17:27:58PM - Adding DVT_UIA 36713918: new total 524358891.0 08/07/2013 17:27:58PM - Adding DEV_SUPPORT_SHARED 4047699: new total 528406590.0 08/07/2013 17:27:58PM - Adding DEV_SUPPORT_C6000MC 170789: new total 528577379.0 08/07/2013 17:27:58PM - Adding TC_C6000_XDCTOOLS 28065809: new total 556643188.0 08/07/2013 17:27:58PM - Adding C6000_CGT_HELP 3197575: new total 559840763.0 08/07/2013 17:27:58PM - Adding TC_XDAIS 8492292: new total 568333055.0 08/07/2013 17:27:58PM - Adding EMU_BH 45370003: new total 613703058.0 08/07/2013 17:27:58PM - Adding DMED 1611418: new total 615314476.0 08/07/2013 17:27:58PM - Adding GMF 12342547: new total 627657023.0 08/07/2013 17:27:58PM - Adding XULRUNNER 16596408: new total 644253431.0 08/07/2013 17:27:58PM - Adding CCSINIT 1331118: new total 645584549.0 08/07/2013 17:27:58PM - Adding UIA 23110255: new total 668694804.0 08/07/2013 17:27:58PM - Adding DS 16259318: new total 684954122.0 08/07/2013 17:27:58PM - adding JRE 31364806 new size: 716318928.0 08/07/2013 17:27:58PM - adding ECLIPSE 91990247 new size: 808309175.0 08/07/2013 17:27:58PM - adding ECLIPSECORE 52897237 new size: 861206412.0 08/07/2013 17:27:58PM - adding P2TOOLS 20756 new size: 861227168.0 08/07/2013 17:27:58PM - adding MSVC80 2707352 new size: 863934520.0 08/07/2013 17:27:58PM - adding MSVC2008 4216840 new size: 868151360.0 08/07/2013 17:27:58PM - adding MSVC2012 6560088 new size: 874711448.0 08/07/2013 17:27:58PM - adding INSTALLER 495 new size: 874711943.0 08/07/2013 17:27:58PM - size = 874711943.0 08/07/2013 17:27:58PM - ==================== Install size: 2502.57 MB. 08/07/2013 17:27:58PM - setting TC_XDAIS_BIOS5 on 1 08/07/2013 17:27:58PM - Checking subgroup DSP/BIOS v5 08/07/2013 17:27:58PM - TC_BIOS5 has no additional options 08/07/2013 17:27:58PM - Checking TC_BIOS5 08/07/2013 17:27:58PM - Adding TC_BIOS5 91193648: new total 91193648.0 08/07/2013 17:27:58PM - Adding TC_C6000_BIOS6 14578054: new total 105771702.0 08/07/2013 17:27:58PM - Adding TC_BIOS6 24089799: new total 129861501.0 08/07/2013 17:27:58PM - Adding SIM_TI 47448879: new total 177310380.0 08/07/2013 17:27:58PM - Adding EMU_SD 27888672: new total 205199052.0 08/07/2013 17:27:58PM - Adding IDE_MAIN 85556996: new total 290756048.0 08/07/2013 17:27:58PM - Adding TC_XDCTOOLS_BIOS5 88411834: new total 379167882.0 08/07/2013 17:27:58PM - Adding KEYSTONE1 1590496: new total 380758378.0 08/07/2013 17:27:58PM - Adding EMU_TI 35739725: new total 416498103.0 08/07/2013 17:27:58PM - Adding KEYSTONE2 1380354: new total 417878457.0 08/07/2013 17:27:58PM - Adding CGT_DEFAULTLIBS_C6000 69766516: new total 487644973.0 08/07/2013 17:27:58PM - Adding DVT_UIA 36713918: new total 524358891.0 08/07/2013 17:27:58PM - Adding DEV_SUPPORT_SHARED 4047699: new total 528406590.0 08/07/2013 17:27:58PM - Adding DEV_SUPPORT_C6000MC 170789: new total 528577379.0 08/07/2013 17:27:58PM - Adding TC_C6000_XDCTOOLS 28065809: new total 556643188.0 08/07/2013 17:27:58PM - Adding C6000_CGT_HELP 3197575: new total 559840763.0 08/07/2013 17:27:58PM - Adding TC_XDAIS 8492292: new total 568333055.0 08/07/2013 17:27:58PM - Adding EMU_BH 45370003: new total 613703058.0 08/07/2013 17:27:58PM - Adding DMED 1611418: new total 615314476.0 08/07/2013 17:27:58PM - Adding GMF 12342547: new total 627657023.0 08/07/2013 17:27:58PM - Adding XULRUNNER 16596408: new total 644253431.0 08/07/2013 17:27:58PM - Adding CCSINIT 1331118: new total 645584549.0 08/07/2013 17:27:58PM - Adding UIA 23110255: new total 668694804.0 08/07/2013 17:27:58PM - Adding DS 16259318: new total 684954122.0 08/07/2013 17:27:58PM - adding JRE 31364806 new size: 716318928.0 08/07/2013 17:27:58PM - adding ECLIPSE 91990247 new size: 808309175.0 08/07/2013 17:27:58PM - adding ECLIPSECORE 52897237 new size: 861206412.0 08/07/2013 17:27:58PM - adding P2TOOLS 20756 new size: 861227168.0 08/07/2013 17:27:58PM - adding MSVC80 2707352 new size: 863934520.0 08/07/2013 17:27:58PM - adding MSVC2008 4216840 new size: 868151360.0 08/07/2013 17:27:58PM - adding MSVC2012 6560088 new size: 874711448.0 08/07/2013 17:27:58PM - adding INSTALLER 495 new size: 874711943.0 08/07/2013 17:27:58PM - size = 874711943.0 08/07/2013 17:27:58PM - ==================== Install size: 2502.57 MB. 08/07/2013 17:27:58PM - setting TC_BIOS5 on 1 08/07/2013 17:27:58PM - addgroup=1:addsub=0:level=1 08/07/2013 17:27:58PM - initializing showcomps for SYS/BIOS v6 0 08/07/2013 17:27:58PM - initializing showcomps for SYS/BIOS v6 0 08/07/2013 17:27:58PM - 1 Component TC_XDCTOOLS is offered 08/07/2013 17:27:58PM - 1 Component TC_XDCTOOLS is selected 08/07/2013 17:27:58PM - 1 Adding subgroup: SYS/BIOS v6 08/07/2013 17:27:58PM - level = 1 1 08/07/2013 17:27:58PM - showcomps for SYS/BIOS v6 0 08/07/2013 17:27:58PM - initializing showcomps for SYS/BIOS v6 0 08/07/2013 17:27:58PM - 1 Component TC_C6000_XDCTOOLS is offered 08/07/2013 17:27:58PM - 1 Component TC_C6000_XDCTOOLS is selected 08/07/2013 17:27:58PM - level = 1 1 08/07/2013 17:27:58PM - showcomps for SYS/BIOS v6 0 08/07/2013 17:27:58PM - initializing showcomps for SYS/BIOS v6 0 08/07/2013 17:27:58PM - initializing showcomps for SYS/BIOS v6 0 08/07/2013 17:27:58PM - initializing showcomps for SYS/BIOS v6 0 08/07/2013 17:27:58PM - initializing showcomps for SYS/BIOS v6 0 08/07/2013 17:27:58PM - 1 Component TC_XDAIS is offered 08/07/2013 17:27:58PM - 1 Component TC_XDAIS is selected 08/07/2013 17:27:58PM - level = 1 1 08/07/2013 17:27:58PM - showcomps for SYS/BIOS v6 0 08/07/2013 17:27:58PM - initializing showcomps for SYS/BIOS v6 0 08/07/2013 17:27:58PM - 1 Component UIA is offered 08/07/2013 17:27:58PM - 1 Component UIA is selected 08/07/2013 17:27:58PM - level = 1 1 08/07/2013 17:27:58PM - showcomps for SYS/BIOS v6 0 08/07/2013 17:27:58PM - initializing showcomps for SYS/BIOS v6 0 08/07/2013 17:27:58PM - initializing showcomps for SYS/BIOS v6 0 08/07/2013 17:27:58PM - 1 Component TC_BIOS6 is offered 08/07/2013 17:27:58PM - 1 Component TC_BIOS6 is selected 08/07/2013 17:27:58PM - level = 1 1 08/07/2013 17:27:58PM - showcomps for SYS/BIOS v6 0 08/07/2013 17:27:58PM - initializing showcomps for SYS/BIOS v6 0 08/07/2013 17:27:58PM - 1 Component TC_C6000_BIOS6 is offered 08/07/2013 17:27:58PM - 1 Component TC_C6000_BIOS6 is selected 08/07/2013 17:27:58PM - level = 1 1 08/07/2013 17:27:58PM - showcomps for SYS/BIOS v6 0 08/07/2013 17:27:58PM - initializing showcomps for SYS/BIOS v6 0 08/07/2013 17:27:58PM - all components in SYS/BIOS v6 are now being selected. 08/07/2013 17:27:58PM - showcomps: 0 SYS/BIOS_v6: 1 08/07/2013 17:27:58PM - in click_componentsubgroup SYS/BIOS v6 08/07/2013 17:27:58PM - Checking subgroup SYS/BIOS v6 08/07/2013 17:27:58PM - Checking subgroup SYS/BIOS v6 08/07/2013 17:27:58PM - TC_XDCTOOLS has no additional options 08/07/2013 17:27:58PM - Checking TC_XDCTOOLS 08/07/2013 17:27:58PM - Adding TC_BIOS5 91193648: new total 91193648.0 08/07/2013 17:27:58PM - Adding TC_C6000_BIOS6 14578054: new total 105771702.0 08/07/2013 17:27:58PM - Adding TC_BIOS6 24089799: new total 129861501.0 08/07/2013 17:27:58PM - Adding SIM_TI 47448879: new total 177310380.0 08/07/2013 17:27:58PM - Adding EMU_SD 27888672: new total 205199052.0 08/07/2013 17:27:58PM - Adding IDE_MAIN 85556996: new total 290756048.0 08/07/2013 17:27:58PM - Adding TC_XDCTOOLS_BIOS5 88411834: new total 379167882.0 08/07/2013 17:27:58PM - Adding KEYSTONE1 1590496: new total 380758378.0 08/07/2013 17:27:58PM - Adding EMU_TI 35739725: new total 416498103.0 08/07/2013 17:27:58PM - Adding KEYSTONE2 1380354: new total 417878457.0 08/07/2013 17:27:58PM - Adding CGT_DEFAULTLIBS_C6000 69766516: new total 487644973.0 08/07/2013 17:27:58PM - Adding DVT_UIA 36713918: new total 524358891.0 08/07/2013 17:27:58PM - Adding DEV_SUPPORT_SHARED 4047699: new total 528406590.0 08/07/2013 17:27:58PM - Adding DEV_SUPPORT_C6000MC 170789: new total 528577379.0 08/07/2013 17:27:58PM - Adding TC_C6000_XDCTOOLS 28065809: new total 556643188.0 08/07/2013 17:27:58PM - Adding C6000_CGT_HELP 3197575: new total 559840763.0 08/07/2013 17:27:58PM - Adding TC_XDAIS 8492292: new total 568333055.0 08/07/2013 17:27:58PM - Adding EMU_BH 45370003: new total 613703058.0 08/07/2013 17:27:58PM - Adding DMED 1611418: new total 615314476.0 08/07/2013 17:27:58PM - Adding GMF 12342547: new total 627657023.0 08/07/2013 17:27:58PM - Adding XULRUNNER 16596408: new total 644253431.0 08/07/2013 17:27:58PM - Adding CCSINIT 1331118: new total 645584549.0 08/07/2013 17:27:58PM - Adding UIA 23110255: new total 668694804.0 08/07/2013 17:27:58PM - Adding DS 16259318: new total 684954122.0 08/07/2013 17:27:58PM - adding JRE 31364806 new size: 716318928.0 08/07/2013 17:27:58PM - adding ECLIPSE 91990247 new size: 808309175.0 08/07/2013 17:27:58PM - adding ECLIPSECORE 52897237 new size: 861206412.0 08/07/2013 17:27:58PM - adding P2TOOLS 20756 new size: 861227168.0 08/07/2013 17:27:58PM - adding MSVC80 2707352 new size: 863934520.0 08/07/2013 17:27:58PM - adding MSVC2008 4216840 new size: 868151360.0 08/07/2013 17:27:58PM - adding MSVC2012 6560088 new size: 874711448.0 08/07/2013 17:27:58PM - adding INSTALLER 495 new size: 874711943.0 08/07/2013 17:27:58PM - size = 874711943.0 08/07/2013 17:27:58PM - ==================== Install size: 2502.57 MB. 08/07/2013 17:27:58PM - setting TC_XDCTOOLS on 1 08/07/2013 17:27:58PM - Checking subgroup SYS/BIOS v6 08/07/2013 17:27:58PM - TC_C6000_XDCTOOLS has no additional options 08/07/2013 17:27:58PM - Checking TC_C6000_XDCTOOLS 08/07/2013 17:27:58PM - Adding TC_BIOS5 91193648: new total 91193648.0 08/07/2013 17:27:58PM - Adding TC_C6000_BIOS6 14578054: new total 105771702.0 08/07/2013 17:27:58PM - Adding TC_BIOS6 24089799: new total 129861501.0 08/07/2013 17:27:58PM - Adding SIM_TI 47448879: new total 177310380.0 08/07/2013 17:27:58PM - Adding EMU_SD 27888672: new total 205199052.0 08/07/2013 17:27:58PM - Adding IDE_MAIN 85556996: new total 290756048.0 08/07/2013 17:27:58PM - Adding TC_XDCTOOLS_BIOS5 88411834: new total 379167882.0 08/07/2013 17:27:58PM - Adding KEYSTONE1 1590496: new total 380758378.0 08/07/2013 17:27:58PM - Adding EMU_TI 35739725: new total 416498103.0 08/07/2013 17:27:58PM - Adding KEYSTONE2 1380354: new total 417878457.0 08/07/2013 17:27:58PM - Adding CGT_DEFAULTLIBS_C6000 69766516: new total 487644973.0 08/07/2013 17:27:58PM - Adding DVT_UIA 36713918: new total 524358891.0 08/07/2013 17:27:58PM - Adding DEV_SUPPORT_SHARED 4047699: new total 528406590.0 08/07/2013 17:27:58PM - Adding DEV_SUPPORT_C6000MC 170789: new total 528577379.0 08/07/2013 17:27:58PM - Adding TC_C6000_XDCTOOLS 28065809: new total 556643188.0 08/07/2013 17:27:58PM - Adding C6000_CGT_HELP 3197575: new total 559840763.0 08/07/2013 17:27:58PM - Adding TC_XDAIS 8492292: new total 568333055.0 08/07/2013 17:27:58PM - Adding EMU_BH 45370003: new total 613703058.0 08/07/2013 17:27:58PM - Adding DMED 1611418: new total 615314476.0 08/07/2013 17:27:58PM - Adding GMF 12342547: new total 627657023.0 08/07/2013 17:27:58PM - Adding XULRUNNER 16596408: new total 644253431.0 08/07/2013 17:27:58PM - Adding CCSINIT 1331118: new total 645584549.0 08/07/2013 17:27:58PM - Adding UIA 23110255: new total 668694804.0 08/07/2013 17:27:58PM - Adding DS 16259318: new total 684954122.0 08/07/2013 17:27:58PM - adding JRE 31364806 new size: 716318928.0 08/07/2013 17:27:58PM - adding ECLIPSE 91990247 new size: 808309175.0 08/07/2013 17:27:58PM - adding ECLIPSECORE 52897237 new size: 861206412.0 08/07/2013 17:27:58PM - adding P2TOOLS 20756 new size: 861227168.0 08/07/2013 17:27:58PM - adding MSVC80 2707352 new size: 863934520.0 08/07/2013 17:27:58PM - adding MSVC2008 4216840 new size: 868151360.0 08/07/2013 17:27:58PM - adding MSVC2012 6560088 new size: 874711448.0 08/07/2013 17:27:58PM - adding INSTALLER 495 new size: 874711943.0 08/07/2013 17:27:58PM - size = 874711943.0 08/07/2013 17:27:58PM - ==================== Install size: 2502.57 MB. 08/07/2013 17:27:58PM - setting TC_C6000_XDCTOOLS on 1 08/07/2013 17:27:58PM - Checking subgroup SYS/BIOS v6 08/07/2013 17:27:58PM - Checking subgroup SYS/BIOS v6 08/07/2013 17:27:58PM - Checking subgroup SYS/BIOS v6 08/07/2013 17:27:58PM - Checking subgroup SYS/BIOS v6 08/07/2013 17:27:58PM - TC_XDAIS has no additional options 08/07/2013 17:27:58PM - Checking TC_XDAIS 08/07/2013 17:27:58PM - Adding TC_BIOS5 91193648: new total 91193648.0 08/07/2013 17:27:58PM - Adding TC_C6000_BIOS6 14578054: new total 105771702.0 08/07/2013 17:27:58PM - Adding TC_BIOS6 24089799: new total 129861501.0 08/07/2013 17:27:58PM - Adding SIM_TI 47448879: new total 177310380.0 08/07/2013 17:27:58PM - Adding EMU_SD 27888672: new total 205199052.0 08/07/2013 17:27:58PM - Adding IDE_MAIN 85556996: new total 290756048.0 08/07/2013 17:27:58PM - Adding TC_XDCTOOLS_BIOS5 88411834: new total 379167882.0 08/07/2013 17:27:58PM - Adding KEYSTONE1 1590496: new total 380758378.0 08/07/2013 17:27:58PM - Adding EMU_TI 35739725: new total 416498103.0 08/07/2013 17:27:58PM - Adding KEYSTONE2 1380354: new total 417878457.0 08/07/2013 17:27:58PM - Adding CGT_DEFAULTLIBS_C6000 69766516: new total 487644973.0 08/07/2013 17:27:58PM - Adding DVT_UIA 36713918: new total 524358891.0 08/07/2013 17:27:58PM - Adding DEV_SUPPORT_SHARED 4047699: new total 528406590.0 08/07/2013 17:27:58PM - Adding DEV_SUPPORT_C6000MC 170789: new total 528577379.0 08/07/2013 17:27:58PM - Adding TC_C6000_XDCTOOLS 28065809: new total 556643188.0 08/07/2013 17:27:58PM - Adding C6000_CGT_HELP 3197575: new total 559840763.0 08/07/2013 17:27:58PM - Adding TC_XDAIS 8492292: new total 568333055.0 08/07/2013 17:27:58PM - Adding EMU_BH 45370003: new total 613703058.0 08/07/2013 17:27:58PM - Adding DMED 1611418: new total 615314476.0 08/07/2013 17:27:58PM - Adding GMF 12342547: new total 627657023.0 08/07/2013 17:27:58PM - Adding XULRUNNER 16596408: new total 644253431.0 08/07/2013 17:27:58PM - Adding CCSINIT 1331118: new total 645584549.0 08/07/2013 17:27:58PM - Adding UIA 23110255: new total 668694804.0 08/07/2013 17:27:58PM - Adding DS 16259318: new total 684954122.0 08/07/2013 17:27:58PM - adding JRE 31364806 new size: 716318928.0 08/07/2013 17:27:58PM - adding ECLIPSE 91990247 new size: 808309175.0 08/07/2013 17:27:58PM - adding ECLIPSECORE 52897237 new size: 861206412.0 08/07/2013 17:27:58PM - adding P2TOOLS 20756 new size: 861227168.0 08/07/2013 17:27:58PM - adding MSVC80 2707352 new size: 863934520.0 08/07/2013 17:27:58PM - adding MSVC2008 4216840 new size: 868151360.0 08/07/2013 17:27:58PM - adding MSVC2012 6560088 new size: 874711448.0 08/07/2013 17:27:58PM - adding INSTALLER 495 new size: 874711943.0 08/07/2013 17:27:58PM - size = 874711943.0 08/07/2013 17:27:58PM - ==================== Install size: 2502.57 MB. 08/07/2013 17:27:58PM - setting TC_XDAIS on 1 08/07/2013 17:27:58PM - Checking subgroup SYS/BIOS v6 08/07/2013 17:27:58PM - UIA has no additional options 08/07/2013 17:27:58PM - Checking UIA 08/07/2013 17:27:58PM - Adding TC_BIOS5 91193648: new total 91193648.0 08/07/2013 17:27:58PM - Adding TC_C6000_BIOS6 14578054: new total 105771702.0 08/07/2013 17:27:58PM - Adding TC_BIOS6 24089799: new total 129861501.0 08/07/2013 17:27:58PM - Adding SIM_TI 47448879: new total 177310380.0 08/07/2013 17:27:58PM - Adding EMU_SD 27888672: new total 205199052.0 08/07/2013 17:27:58PM - Adding IDE_MAIN 85556996: new total 290756048.0 08/07/2013 17:27:58PM - Adding TC_XDCTOOLS_BIOS5 88411834: new total 379167882.0 08/07/2013 17:27:58PM - Adding KEYSTONE1 1590496: new total 380758378.0 08/07/2013 17:27:58PM - Adding EMU_TI 35739725: new total 416498103.0 08/07/2013 17:27:58PM - Adding KEYSTONE2 1380354: new total 417878457.0 08/07/2013 17:27:58PM - Adding CGT_DEFAULTLIBS_C6000 69766516: new total 487644973.0 08/07/2013 17:27:58PM - Adding DVT_UIA 36713918: new total 524358891.0 08/07/2013 17:27:58PM - Adding DEV_SUPPORT_SHARED 4047699: new total 528406590.0 08/07/2013 17:27:58PM - Adding DEV_SUPPORT_C6000MC 170789: new total 528577379.0 08/07/2013 17:27:58PM - Adding TC_C6000_XDCTOOLS 28065809: new total 556643188.0 08/07/2013 17:27:58PM - Adding C6000_CGT_HELP 3197575: new total 559840763.0 08/07/2013 17:27:58PM - Adding TC_XDAIS 8492292: new total 568333055.0 08/07/2013 17:27:58PM - Adding EMU_BH 45370003: new total 613703058.0 08/07/2013 17:27:58PM - Adding DMED 1611418: new total 615314476.0 08/07/2013 17:27:58PM - Adding GMF 12342547: new total 627657023.0 08/07/2013 17:27:58PM - Adding XULRUNNER 16596408: new total 644253431.0 08/07/2013 17:27:58PM - Adding CCSINIT 1331118: new total 645584549.0 08/07/2013 17:27:58PM - Adding UIA 23110255: new total 668694804.0 08/07/2013 17:27:58PM - Adding DS 16259318: new total 684954122.0 08/07/2013 17:27:58PM - adding JRE 31364806 new size: 716318928.0 08/07/2013 17:27:58PM - adding ECLIPSE 91990247 new size: 808309175.0 08/07/2013 17:27:58PM - adding ECLIPSECORE 52897237 new size: 861206412.0 08/07/2013 17:27:58PM - adding P2TOOLS 20756 new size: 861227168.0 08/07/2013 17:27:58PM - adding MSVC80 2707352 new size: 863934520.0 08/07/2013 17:27:58PM - adding MSVC2008 4216840 new size: 868151360.0 08/07/2013 17:27:58PM - adding MSVC2012 6560088 new size: 874711448.0 08/07/2013 17:27:58PM - adding INSTALLER 495 new size: 874711943.0 08/07/2013 17:27:58PM - size = 874711943.0 08/07/2013 17:27:58PM - ==================== Install size: 2502.57 MB. 08/07/2013 17:27:58PM - setting UIA on 1 08/07/2013 17:27:58PM - Checking subgroup SYS/BIOS v6 08/07/2013 17:27:58PM - Checking subgroup SYS/BIOS v6 08/07/2013 17:27:58PM - TC_BIOS6 has no additional options 08/07/2013 17:27:58PM - Checking TC_BIOS6 08/07/2013 17:27:58PM - Adding TC_BIOS5 91193648: new total 91193648.0 08/07/2013 17:27:58PM - Adding TC_C6000_BIOS6 14578054: new total 105771702.0 08/07/2013 17:27:58PM - Adding TC_BIOS6 24089799: new total 129861501.0 08/07/2013 17:27:58PM - Adding SIM_TI 47448879: new total 177310380.0 08/07/2013 17:27:58PM - Adding EMU_SD 27888672: new total 205199052.0 08/07/2013 17:27:58PM - Adding IDE_MAIN 85556996: new total 290756048.0 08/07/2013 17:27:58PM - Adding TC_XDCTOOLS_BIOS5 88411834: new total 379167882.0 08/07/2013 17:27:58PM - Adding KEYSTONE1 1590496: new total 380758378.0 08/07/2013 17:27:58PM - Adding EMU_TI 35739725: new total 416498103.0 08/07/2013 17:27:58PM - Adding KEYSTONE2 1380354: new total 417878457.0 08/07/2013 17:27:58PM - Adding CGT_DEFAULTLIBS_C6000 69766516: new total 487644973.0 08/07/2013 17:27:58PM - Adding DVT_UIA 36713918: new total 524358891.0 08/07/2013 17:27:58PM - Adding DEV_SUPPORT_SHARED 4047699: new total 528406590.0 08/07/2013 17:27:58PM - Adding DEV_SUPPORT_C6000MC 170789: new total 528577379.0 08/07/2013 17:27:58PM - Adding TC_C6000_XDCTOOLS 28065809: new total 556643188.0 08/07/2013 17:27:58PM - Adding C6000_CGT_HELP 3197575: new total 559840763.0 08/07/2013 17:27:58PM - Adding TC_XDAIS 8492292: new total 568333055.0 08/07/2013 17:27:58PM - Adding EMU_BH 45370003: new total 613703058.0 08/07/2013 17:27:58PM - Adding DMED 1611418: new total 615314476.0 08/07/2013 17:27:58PM - Adding GMF 12342547: new total 627657023.0 08/07/2013 17:27:58PM - Adding XULRUNNER 16596408: new total 644253431.0 08/07/2013 17:27:58PM - Adding CCSINIT 1331118: new total 645584549.0 08/07/2013 17:27:58PM - Adding UIA 23110255: new total 668694804.0 08/07/2013 17:27:58PM - Adding DS 16259318: new total 684954122.0 08/07/2013 17:27:58PM - adding JRE 31364806 new size: 716318928.0 08/07/2013 17:27:58PM - adding ECLIPSE 91990247 new size: 808309175.0 08/07/2013 17:27:58PM - adding ECLIPSECORE 52897237 new size: 861206412.0 08/07/2013 17:27:58PM - adding P2TOOLS 20756 new size: 861227168.0 08/07/2013 17:27:58PM - adding MSVC80 2707352 new size: 863934520.0 08/07/2013 17:27:58PM - adding MSVC2008 4216840 new size: 868151360.0 08/07/2013 17:27:58PM - adding MSVC2012 6560088 new size: 874711448.0 08/07/2013 17:27:58PM - adding INSTALLER 495 new size: 874711943.0 08/07/2013 17:27:58PM - size = 874711943.0 08/07/2013 17:27:58PM - ==================== Install size: 2502.57 MB. 08/07/2013 17:27:58PM - setting TC_BIOS6 on 1 08/07/2013 17:27:58PM - Checking subgroup SYS/BIOS v6 08/07/2013 17:27:58PM - TC_C6000_BIOS6 has no additional options 08/07/2013 17:27:58PM - Checking TC_C6000_BIOS6 08/07/2013 17:27:58PM - Adding TC_BIOS5 91193648: new total 91193648.0 08/07/2013 17:27:58PM - Adding TC_C6000_BIOS6 14578054: new total 105771702.0 08/07/2013 17:27:58PM - Adding TC_BIOS6 24089799: new total 129861501.0 08/07/2013 17:27:58PM - Adding SIM_TI 47448879: new total 177310380.0 08/07/2013 17:27:58PM - Adding EMU_SD 27888672: new total 205199052.0 08/07/2013 17:27:58PM - Adding IDE_MAIN 85556996: new total 290756048.0 08/07/2013 17:27:58PM - Adding TC_XDCTOOLS_BIOS5 88411834: new total 379167882.0 08/07/2013 17:27:58PM - Adding KEYSTONE1 1590496: new total 380758378.0 08/07/2013 17:27:58PM - Adding EMU_TI 35739725: new total 416498103.0 08/07/2013 17:27:58PM - Adding KEYSTONE2 1380354: new total 417878457.0 08/07/2013 17:27:58PM - Adding CGT_DEFAULTLIBS_C6000 69766516: new total 487644973.0 08/07/2013 17:27:58PM - Adding DVT_UIA 36713918: new total 524358891.0 08/07/2013 17:27:58PM - Adding DEV_SUPPORT_SHARED 4047699: new total 528406590.0 08/07/2013 17:27:58PM - Adding DEV_SUPPORT_C6000MC 170789: new total 528577379.0 08/07/2013 17:27:58PM - Adding TC_C6000_XDCTOOLS 28065809: new total 556643188.0 08/07/2013 17:27:58PM - Adding C6000_CGT_HELP 3197575: new total 559840763.0 08/07/2013 17:27:58PM - Adding TC_XDAIS 8492292: new total 568333055.0 08/07/2013 17:27:58PM - Adding EMU_BH 45370003: new total 613703058.0 08/07/2013 17:27:58PM - Adding DMED 1611418: new total 615314476.0 08/07/2013 17:27:58PM - Adding GMF 12342547: new total 627657023.0 08/07/2013 17:27:58PM - Adding XULRUNNER 16596408: new total 644253431.0 08/07/2013 17:27:58PM - Adding CCSINIT 1331118: new total 645584549.0 08/07/2013 17:27:58PM - Adding UIA 23110255: new total 668694804.0 08/07/2013 17:27:58PM - Adding DS 16259318: new total 684954122.0 08/07/2013 17:27:58PM - adding JRE 31364806 new size: 716318928.0 08/07/2013 17:27:58PM - adding ECLIPSE 91990247 new size: 808309175.0 08/07/2013 17:27:58PM - adding ECLIPSECORE 52897237 new size: 861206412.0 08/07/2013 17:27:58PM - adding P2TOOLS 20756 new size: 861227168.0 08/07/2013 17:27:58PM - adding MSVC80 2707352 new size: 863934520.0 08/07/2013 17:27:58PM - adding MSVC2008 4216840 new size: 868151360.0 08/07/2013 17:27:58PM - adding MSVC2012 6560088 new size: 874711448.0 08/07/2013 17:27:58PM - adding INSTALLER 495 new size: 874711943.0 08/07/2013 17:27:58PM - size = 874711943.0 08/07/2013 17:27:58PM - ==================== Install size: 2502.57 MB. 08/07/2013 17:27:58PM - setting TC_C6000_BIOS6 on 1 08/07/2013 17:27:58PM - Checking subgroup SYS/BIOS v6 08/07/2013 17:27:58PM - addgroup=0:addsub=1:level=0 08/07/2013 17:27:58PM - initializing showcomps for Simulators 0 08/07/2013 17:27:58PM - 1 Component SIM_TI is offered 08/07/2013 17:27:58PM - 1 Component SIM_TI is selected 08/07/2013 17:27:58PM - adding group Simulators 08/07/2013 17:27:58PM - level = 0 1 08/07/2013 17:27:58PM - showcomps for Simulators 1 08/07/2013 17:27:58PM - addgroup=0:addsub=1:level=0 08/07/2013 17:27:58PM - initializing showcomps for Base Installation 0 08/07/2013 17:27:58PM - 1 Component DS is offered 08/07/2013 17:27:58PM - 1 Component DS is selected 08/07/2013 17:27:58PM - 1 Component DS is mandatory 08/07/2013 17:27:58PM - initializing showcomps for Base Installation 0 08/07/2013 17:27:58PM - initializing showcomps for Base Installation 0 08/07/2013 17:27:58PM - initializing showcomps for Base Installation 0 08/07/2013 17:27:58PM - initializing showcomps for Base Installation 0 08/07/2013 17:27:58PM - 1 Component IDE_C6000 is offered 08/07/2013 17:27:58PM - 1 Component IDE_C6000 is selected 08/07/2013 17:27:58PM - 1 Component IDE_C6000 is mandatory 08/07/2013 17:27:58PM - initializing showcomps for Base Installation 0 08/07/2013 17:27:58PM - initializing showcomps for Base Installation 0 08/07/2013 17:27:58PM - initializing showcomps for Base Installation 0 08/07/2013 17:27:58PM - 1 Component DEV_SUPPORT_SHARED is offered 08/07/2013 17:27:58PM - 1 Component DEV_SUPPORT_SHARED is selected 08/07/2013 17:27:58PM - 1 Component DEV_SUPPORT_SHARED is mandatory 08/07/2013 17:27:58PM - initializing showcomps for Base Installation 0 08/07/2013 17:27:58PM - 1 Component IDE_WORKFLOW is offered 08/07/2013 17:27:58PM - 1 Component IDE_WORKFLOW is selected 08/07/2013 17:27:58PM - 1 Component IDE_WORKFLOW is mandatory 08/07/2013 17:27:58PM - initializing showcomps for Base Installation 0 08/07/2013 17:27:58PM - 1 Component DVT_TRACE is offered 08/07/2013 17:27:58PM - 1 Component DVT_TRACE is selected 08/07/2013 17:27:58PM - 1 Component DVT_TRACE is mandatory 08/07/2013 17:27:58PM - initializing showcomps for Base Installation 0 08/07/2013 17:27:58PM - initializing showcomps for Base Installation 0 08/07/2013 17:27:58PM - initializing showcomps for Base Installation 0 08/07/2013 17:27:58PM - initializing showcomps for Base Installation 0 08/07/2013 17:27:58PM - initializing showcomps for Base Installation 0 08/07/2013 17:27:58PM - 1 Component KEYSTONE1 is offered 08/07/2013 17:27:58PM - 1 Component KEYSTONE1 is selected 08/07/2013 17:27:58PM - 1 Component KEYSTONE1 is mandatory 08/07/2013 17:27:58PM - initializing showcomps for Base Installation 0 08/07/2013 17:27:58PM - initializing showcomps for Base Installation 0 08/07/2013 17:27:58PM - 1 Component DVT_VIA_CCS is offered 08/07/2013 17:27:58PM - 1 Component DVT_VIA_CCS is selected 08/07/2013 17:27:58PM - 1 Component DVT_VIA_CCS is mandatory 08/07/2013 17:27:58PM - initializing showcomps for Base Installation 0 08/07/2013 17:27:58PM - 1 Component CCSINIT is offered 08/07/2013 17:27:58PM - 1 Component CCSINIT is selected 08/07/2013 17:27:58PM - 1 Component CCSINIT is mandatory 08/07/2013 17:27:58PM - initializing showcomps for Base Installation 0 08/07/2013 17:27:58PM - initializing showcomps for Base Installation 0 08/07/2013 17:27:58PM - initializing showcomps for Base Installation 0 08/07/2013 17:27:58PM - initializing showcomps for Base Installation 0 08/07/2013 17:27:58PM - initializing showcomps for Base Installation 0 08/07/2013 17:27:58PM - 1 Component GMF is offered 08/07/2013 17:27:58PM - 1 Component GMF is selected 08/07/2013 17:27:58PM - 1 Component GMF is mandatory 08/07/2013 17:27:58PM - initializing showcomps for Base Installation 0 08/07/2013 17:27:58PM - initializing showcomps for Base Installation 0 08/07/2013 17:27:58PM - 1 Component KEYSTONE2 is offered 08/07/2013 17:27:58PM - 1 Component KEYSTONE2 is selected 08/07/2013 17:27:58PM - 1 Component KEYSTONE2 is mandatory 08/07/2013 17:27:58PM - initializing showcomps for Base Installation 0 08/07/2013 17:27:58PM - initializing showcomps for Base Installation 0 08/07/2013 17:27:58PM - initializing showcomps for Base Installation 0 08/07/2013 17:27:58PM - initializing showcomps for Base Installation 0 08/07/2013 17:27:58PM - initializing showcomps for Base Installation 0 08/07/2013 17:27:58PM - 1 Component DEV_SUPPORT_C6000MC is offered 08/07/2013 17:27:58PM - 1 Component DEV_SUPPORT_C6000MC is selected 08/07/2013 17:27:58PM - 1 Component DEV_SUPPORT_C6000MC is mandatory 08/07/2013 17:27:58PM - initializing showcomps for Base Installation 0 08/07/2013 17:27:58PM - initializing showcomps for Base Installation 0 08/07/2013 17:27:58PM - 1 Component DVT_UIA is offered 08/07/2013 17:27:58PM - 1 Component DVT_UIA is selected 08/07/2013 17:27:58PM - 1 Component DVT_UIA is mandatory 08/07/2013 17:27:58PM - initializing showcomps for Base Installation 0 08/07/2013 17:27:58PM - initializing showcomps for Base Installation 0 08/07/2013 17:27:58PM - 1 Component DVT_COMMON is offered 08/07/2013 17:27:58PM - 1 Component DVT_COMMON is selected 08/07/2013 17:27:58PM - 1 Component DVT_COMMON is mandatory 08/07/2013 17:27:58PM - initializing showcomps for Base Installation 0 08/07/2013 17:27:58PM - initializing showcomps for Base Installation 0 08/07/2013 17:27:58PM - initializing showcomps for Base Installation 0 08/07/2013 17:27:58PM - 1 Component XULRUNNER is offered 08/07/2013 17:27:58PM - 1 Component XULRUNNER is selected 08/07/2013 17:27:58PM - 1 Component XULRUNNER is mandatory 08/07/2013 17:27:58PM - initializing showcomps for Base Installation 0 08/07/2013 17:27:58PM - initializing showcomps for Base Installation 0 08/07/2013 17:27:58PM - 1 Component IDE_MAIN is offered 08/07/2013 17:27:58PM - 1 Component IDE_MAIN is selected 08/07/2013 17:27:58PM - 1 Component IDE_MAIN is mandatory 08/07/2013 17:27:58PM - all components in Base Installation are now being selected. 08/07/2013 17:27:58PM - showcomps: 0 Base_Installation: 1 08/07/2013 17:27:58PM - in click_componentsubgroup Base Installation 08/07/2013 17:27:58PM - Checking subgroup Base Installation 08/07/2013 17:27:58PM - DS has no additional options 08/07/2013 17:27:58PM - skipping DS, it's madatory 08/07/2013 17:27:58PM - Checking subgroup Base Installation 08/07/2013 17:27:58PM - Checking subgroup Base Installation 08/07/2013 17:27:58PM - Checking subgroup Base Installation 08/07/2013 17:27:58PM - Checking subgroup Base Installation 08/07/2013 17:27:58PM - IDE_C6000 has no additional options 08/07/2013 17:27:58PM - skipping IDE_C6000, it's madatory 08/07/2013 17:27:58PM - Checking subgroup Base Installation 08/07/2013 17:27:58PM - Checking subgroup Base Installation 08/07/2013 17:27:58PM - Checking subgroup Base Installation 08/07/2013 17:27:58PM - DEV_SUPPORT_SHARED has no additional options 08/07/2013 17:27:58PM - skipping DEV_SUPPORT_SHARED, it's madatory 08/07/2013 17:27:58PM - Checking subgroup Base Installation 08/07/2013 17:27:58PM - IDE_WORKFLOW has no additional options 08/07/2013 17:27:58PM - skipping IDE_WORKFLOW, it's madatory 08/07/2013 17:27:58PM - Checking subgroup Base Installation 08/07/2013 17:27:58PM - DVT_TRACE has no additional options 08/07/2013 17:27:58PM - skipping DVT_TRACE, it's madatory 08/07/2013 17:27:58PM - Checking subgroup Base Installation 08/07/2013 17:27:58PM - Checking subgroup Base Installation 08/07/2013 17:27:58PM - Checking subgroup Base Installation 08/07/2013 17:27:58PM - Checking subgroup Base Installation 08/07/2013 17:27:58PM - Checking subgroup Base Installation 08/07/2013 17:27:58PM - KEYSTONE1 has no additional options 08/07/2013 17:27:58PM - skipping KEYSTONE1, it's madatory 08/07/2013 17:27:58PM - Checking subgroup Base Installation 08/07/2013 17:27:58PM - Checking subgroup Base Installation 08/07/2013 17:27:58PM - DVT_VIA_CCS has no additional options 08/07/2013 17:27:58PM - skipping DVT_VIA_CCS, it's madatory 08/07/2013 17:27:58PM - Checking subgroup Base Installation 08/07/2013 17:27:58PM - CCSINIT has no additional options 08/07/2013 17:27:58PM - skipping CCSINIT, it's madatory 08/07/2013 17:27:58PM - Checking subgroup Base Installation 08/07/2013 17:27:58PM - Checking subgroup Base Installation 08/07/2013 17:27:58PM - Checking subgroup Base Installation 08/07/2013 17:27:58PM - Checking subgroup Base Installation 08/07/2013 17:27:58PM - Checking subgroup Base Installation 08/07/2013 17:27:58PM - GMF has no additional options 08/07/2013 17:27:58PM - skipping GMF, it's madatory 08/07/2013 17:27:58PM - Checking subgroup Base Installation 08/07/2013 17:27:58PM - Checking subgroup Base Installation 08/07/2013 17:27:58PM - KEYSTONE2 has no additional options 08/07/2013 17:27:58PM - skipping KEYSTONE2, it's madatory 08/07/2013 17:27:58PM - Checking subgroup Base Installation 08/07/2013 17:27:58PM - Checking subgroup Base Installation 08/07/2013 17:27:58PM - Checking subgroup Base Installation 08/07/2013 17:27:58PM - Checking subgroup Base Installation 08/07/2013 17:27:58PM - Checking subgroup Base Installation 08/07/2013 17:27:58PM - DEV_SUPPORT_C6000MC has no additional options 08/07/2013 17:27:58PM - skipping DEV_SUPPORT_C6000MC, it's madatory 08/07/2013 17:27:58PM - Checking subgroup Base Installation 08/07/2013 17:27:58PM - Checking subgroup Base Installation 08/07/2013 17:27:58PM - DVT_UIA has no additional options 08/07/2013 17:27:58PM - skipping DVT_UIA, it's madatory 08/07/2013 17:27:58PM - Checking subgroup Base Installation 08/07/2013 17:27:58PM - Checking subgroup Base Installation 08/07/2013 17:27:58PM - DVT_COMMON has no additional options 08/07/2013 17:27:58PM - skipping DVT_COMMON, it's madatory 08/07/2013 17:27:58PM - Checking subgroup Base Installation 08/07/2013 17:27:58PM - Checking subgroup Base Installation 08/07/2013 17:27:58PM - Checking subgroup Base Installation 08/07/2013 17:27:58PM - XULRUNNER has no additional options 08/07/2013 17:27:58PM - skipping XULRUNNER, it's madatory 08/07/2013 17:27:58PM - Checking subgroup Base Installation 08/07/2013 17:27:58PM - Checking subgroup Base Installation 08/07/2013 17:27:58PM - IDE_MAIN has no additional options 08/07/2013 17:27:58PM - skipping IDE_MAIN, it's madatory 08/07/2013 17:27:58PM - Displaying pane 0FF2C23D-509B-496F-9DED-C0FE5D001E3A - Custom Choose Components 08/07/2013 17:27:58PM - Executing actions 0FF2C23D-509B-496F-9DED-C0FE5D001E3A - Custom Choose Components - After Pane is Displayed 08/07/2013 17:27:58PM - Checking conditions for CFB4CAC7-37EE-4FF6-AE3B-B128AA009E91 - SpecialLabel - Before Action is Executed 08/07/2013 17:27:58PM - Checking condition 21CB69A4-8E86-4E6C-8C0C-AF7F21D47827 - String Equal Condition 08/07/2013 17:27:58PM - Checking to see if yes equals <%allowrestricted%> 08/07/2013 17:27:58PM - ** Checking to see if yes equals yes 08/07/2013 17:27:58PM - Condition passed 08/07/2013 17:27:58PM - Executing action CFB4CAC7-37EE-4FF6-AE3B-B128AA009E91 - SpecialLabel 08/07/2013 17:27:58PM - Checking conditions for 61274498-7290-431F-9098-ED970DFAE549 - RestrictedTextBox - Before Action is Executed 08/07/2013 17:27:58PM - Checking condition D0403FE3-D835-48CF-9E66-5B5FCDF034E1 - String Equal Condition 08/07/2013 17:27:58PM - Checking to see if yes equals <%allowrestricted%> 08/07/2013 17:27:58PM - ** Checking to see if yes equals yes 08/07/2013 17:27:58PM - Condition passed 08/07/2013 17:27:58PM - Executing action 61274498-7290-431F-9098-ED970DFAE549 - RestrictedTextBox 08/07/2013 17:28:00PM - Executing actions 0FF2C23D-509B-496F-9DED-C0FE5D001E3A - Custom Choose Components - Before Next Pane is Displayed 08/07/2013 17:28:00PM - Checking conditions for 138B95D0-F89F-46BD-861F-A7465C02821B - Custom Choose Emulators - Before Pane is Displayed 08/07/2013 17:28:00PM - Checking condition 86672030-011E-487C-9422-A4E318ACDB1E - String Is Condition 08/07/2013 17:28:00PM - Checking to see if <%ShowEMUs%> is true 08/07/2013 17:28:00PM - ** Checking to see if true is true 08/07/2013 17:28:00PM - Condition passed 08/07/2013 17:28:00PM - Executing actions 138B95D0-F89F-46BD-861F-A7465C02821B - Custom Choose Emulators - Before Pane is Displayed 08/07/2013 17:28:00PM - Executing action 04EEB113-B28D-40F7-A356-0543BA36271F - Add Emulators 08/07/2013 17:28:00PM - In Add Emulators: 08/07/2013 17:28:00PM - emulatormessagewidget .wizard.steps.f138B95D0-F89F-46BD-861F-A7465C02821B.message 08/07/2013 17:28:00PM - installed features = 08/07/2013 17:28:01PM - Displaying feature list: 08/07/2013 17:28:01PM - JTAG Emulator Support description is JTAG Emulator Support 08/07/2013 17:28:01PM - caught delete JTAG_Emulator_Support 08/07/2013 17:28:01PM - [JTAG Emulator Support] [JTAG Emulator Support] 08/07/2013 17:28:01PM - JTAG Emulator Support JTAG Emulator Support 08/07/2013 17:28:01PM - addgroup=0:addsub=1:level=0 08/07/2013 17:28:01PM - caught delete JTAG_Emulator_Support 08/07/2013 17:28:01PM - c: TIVA_TM4C,JTAG Emulator Support JTAG Emulator Support 08/07/2013 17:28:01PM - 1setting showcomps to 0 08/07/2013 17:28:01PM - initializing showcomps for JTAG Emulator Support 0 08/07/2013 17:28:01PM - c: EMU_BH,JTAG Emulator Support JTAG Emulator Support 08/07/2013 17:28:01PM - 1setting showcomps to 0 08/07/2013 17:28:01PM - initializing showcomps for JTAG Emulator Support 0 08/07/2013 17:28:01PM - 1 Component EMU_BH is offered 08/07/2013 17:28:01PM - caught delete EMU_BH 08/07/2013 17:28:01PM - 1 Component EMU_BH is selected 08/07/2013 17:28:01PM - adding group JTAG_Emulator_Support 08/07/2013 17:28:01PM - level = 0 1 08/07/2013 17:28:01PM - 2setting showcomps to 1 08/07/2013 17:28:01PM - showcomps for JTAG Emulator Support 1 08/07/2013 17:28:01PM - c: EMU_SD,JTAG Emulator Support JTAG Emulator Support 08/07/2013 17:28:01PM - 1setting showcomps to 0 08/07/2013 17:28:01PM - initializing showcomps for JTAG Emulator Support 0 08/07/2013 17:28:01PM - 1 Component EMU_SD is offered 08/07/2013 17:28:01PM - caught delete EMU_SD 08/07/2013 17:28:01PM - 1 Component EMU_SD is selected 08/07/2013 17:28:01PM - level = 0 1 08/07/2013 17:28:01PM - 2setting showcomps to 1 08/07/2013 17:28:01PM - showcomps for JTAG Emulator Support 1 08/07/2013 17:28:01PM - c: EMU_STELLARIS,JTAG Emulator Support JTAG Emulator Support 08/07/2013 17:28:01PM - 1setting showcomps to 0 08/07/2013 17:28:01PM - initializing showcomps for JTAG Emulator Support 0 08/07/2013 17:28:01PM - c: EMU_MSP430,JTAG Emulator Support JTAG Emulator Support 08/07/2013 17:28:01PM - 1setting showcomps to 0 08/07/2013 17:28:01PM - initializing showcomps for JTAG Emulator Support 0 08/07/2013 17:28:01PM - c: TIVA_TM4E,JTAG Emulator Support JTAG Emulator Support 08/07/2013 17:28:01PM - 1setting showcomps to 0 08/07/2013 17:28:01PM - initializing showcomps for JTAG Emulator Support 0 08/07/2013 17:28:01PM - c: EMU_TI,JTAG Emulator Support JTAG Emulator Support 08/07/2013 17:28:01PM - 1setting showcomps to 0 08/07/2013 17:28:01PM - initializing showcomps for JTAG Emulator Support 0 08/07/2013 17:28:01PM - 1 Component EMU_TI is offered 08/07/2013 17:28:01PM - caught delete EMU_TI 08/07/2013 17:28:01PM - 1 Component EMU_TI is selected 08/07/2013 17:28:01PM - level = 0 1 08/07/2013 17:28:01PM - 2setting showcomps to 1 08/07/2013 17:28:01PM - 1 Component EMU_TI is mandatory 08/07/2013 17:28:01PM - showcomps for JTAG Emulator Support 1 08/07/2013 17:28:01PM - 1 Found additionoptions for EMU_TI 08/07/2013 17:28:01PM - caught delete XDS100_Class_Emulator_Support 08/07/2013 17:28:01PM - level = 0 1 08/07/2013 17:28:01PM - 4setting showcomps to 1 08/07/2013 17:28:01PM - showcomps for JTAG Emulator Support 1 08/07/2013 17:28:01PM - caught delete TI_XDS560_PCI_Emulator 08/07/2013 17:28:01PM - level = 0 1 08/07/2013 17:28:01PM - 4setting showcomps to 1 08/07/2013 17:28:01PM - showcomps for JTAG Emulator Support 1 08/07/2013 17:28:01PM - in calculate_sizes from emulators 08/07/2013 17:28:01PM - BIOS 5 TC_BIOS5 08/07/2013 17:28:01PM - Adding TC_BIOS5 91193648: new total 91193648.0 08/07/2013 17:28:01PM - TI C2800 Compiler Tools CGT_DEFAULTLIBS_C2800 08/07/2013 17:28:01PM - C6000 BIOS6 TC_C6000_BIOS6 08/07/2013 17:28:01PM - Adding TC_C6000_BIOS6 14578054: new total 105771702.0 08/07/2013 17:28:01PM - BIOS 6 TC_BIOS6 08/07/2013 17:28:01PM - Adding TC_BIOS6 24089799: new total 129861501.0 08/07/2013 17:28:01PM - TI MSP430 Compiler Tools CGT_DEFAULTLIBS_MSP430 08/07/2013 17:28:01PM - C6000 Device Support DEV_SUPPORT_C6000 08/07/2013 17:28:01PM - TI Simulators SIM_TI 08/07/2013 17:28:01PM - Adding SIM_TI 47448879: new total 177310380.0 08/07/2013 17:28:01PM - Spectrum Digital Emulators EMU_SD 08/07/2013 17:28:01PM - Adding EMU_SD 27888672: new total 205199052.0 08/07/2013 17:28:01PM - Code Composer Plugins IDE_MAIN 08/07/2013 17:28:01PM - Adding IDE_MAIN 85556996: new total 290756048.0 08/07/2013 17:28:01PM - XDCTools TC_XDCTOOLS_BIOS5 08/07/2013 17:28:01PM - Adding TC_XDCTOOLS_BIOS5 88411834: new total 379167882.0 08/07/2013 17:28:01PM - TI C5400 Compiler Tools CGT_DEFAULTLIBS_C5400 08/07/2013 17:28:01PM - MSVC 2005 MSVC80 08/07/2013 17:28:01PM - Stellaris Emulators EMU_STELLARIS 08/07/2013 17:28:01PM - Code Composer Plugins IDE_ARM 08/07/2013 17:28:01PM - TI ARM Compiler Tools CGT_DEFAULTLIBS_TMS470 08/07/2013 17:28:01PM - C5500 Compiler Help C5500_CGT_HELP 08/07/2013 17:28:01PM - Integra Device Support DEV_SUPPORT_INTEGRA 08/07/2013 17:28:01PM - ARM XDCTools TC_ARM_XDCTOOLS 08/07/2013 17:28:01PM - Code Composer Plugins IDE_C5500 08/07/2013 17:28:01PM - C55xx Device Support DEV_SUPPORT_C55XX 08/07/2013 17:28:01PM - JRE JRE 08/07/2013 17:28:01PM - Hercules Emulation EMU_HERCULES 08/07/2013 17:28:01PM - Code Composer Plugins IDE_C6000 08/07/2013 17:28:01PM - Keystone1 KEYSTONE1 08/07/2013 17:28:01PM - Adding KEYSTONE1 1590496: new total 380758378.0 08/07/2013 17:28:01PM - TI Emulators EMU_TI 08/07/2013 17:28:01PM - Adding EMU_TI 35739725: new total 416498103.0 08/07/2013 17:28:01PM - Keystone2 KEYSTONE2 08/07/2013 17:28:01PM - Adding KEYSTONE2 1380354: new total 417878457.0 08/07/2013 17:28:01PM - LWInstaller INSTALLER 08/07/2013 17:28:01PM - GCC ARM Compiler Tools GCC_ARM_COMPILER 08/07/2013 17:28:01PM - TI C5500 Compiler Tools CGT_DEFAULTLIBS_C5500 08/07/2013 17:28:01PM - Grace GRACE 08/07/2013 17:28:01PM - Tiva C Series ARM MCUs TIVA_TM4C 08/07/2013 17:28:01PM - Eclipse P2 Extensions P2TOOLS 08/07/2013 17:28:01PM - MSP430 XDCTools TC_MSP430_XDCTOOLS 08/07/2013 17:28:01PM - TI C6000 Compiler Tools CGT_DEFAULTLIBS_C6000 08/07/2013 17:28:01PM - Adding CGT_DEFAULTLIBS_C6000 69766516: new total 487644973.0 08/07/2013 17:28:01PM - DVT DVT_UIA 08/07/2013 17:28:01PM - Adding DVT_UIA 36713918: new total 524358891.0 08/07/2013 17:28:01PM - Tiva E Series ARM MCUs TIVA_TM4E 08/07/2013 17:28:01PM - C2000 BIOS6 TC_C2000_BIOS6 08/07/2013 17:28:01PM - Eclipse ECLIPSE 08/07/2013 17:28:01PM - MSP430 Emulators EMU_MSP430 08/07/2013 17:28:01PM - MSP430ware MSP430ware 08/07/2013 17:28:01PM - DVT DVT_ENERGYTRACE 08/07/2013 17:28:01PM - MSP430 BIOS6 TC_MSP430_BIOS6 08/07/2013 17:28:01PM - DaVinci Device Support DEV_SUPPORT_DAVINCI 08/07/2013 17:28:01PM - CC2538 Device Support DEV_SUPPORT_CC2538 08/07/2013 17:28:01PM - OMAP Device Support DEV_SUPPORT_OMAP 08/07/2013 17:28:01PM - Code Composer Plugins IDE_MSP430 08/07/2013 17:28:01PM - Shared Device Support DEV_SUPPORT_SHARED 08/07/2013 17:28:01PM - Adding DEV_SUPPORT_SHARED 4047699: new total 528406590.0 08/07/2013 17:28:01PM - C2000 XDCTools TC_C2000_XDCTOOLS 08/07/2013 17:28:01PM - C2000 Compiler Help C2000_CGT_HELP 08/07/2013 17:28:01PM - MSVC 2008 MSVC2008 08/07/2013 17:28:01PM - C6000 Multicore Device Support DEV_SUPPORT_C6000MC 08/07/2013 17:28:01PM - Adding DEV_SUPPORT_C6000MC 170789: new total 528577379.0 08/07/2013 17:28:01PM - MSP430 Compiler Help MSP430_CGT_HELP 08/07/2013 17:28:01PM - ARM Compiler Help ARM_CGT_HELP 08/07/2013 17:28:01PM - XDCTools TC_XDCTOOLS 08/07/2013 17:28:01PM - C6000 XDCTools TC_C6000_XDCTOOLS 08/07/2013 17:28:01PM - Adding TC_C6000_XDCTOOLS 28065809: new total 556643188.0 08/07/2013 17:28:01PM - MSVC 2012 MSVC2012 08/07/2013 17:28:01PM - C6000 Compiler Help C6000_CGT_HELP 08/07/2013 17:28:01PM - Adding C6000_CGT_HELP 3197575: new total 559840763.0 08/07/2013 17:28:01PM - Eclipse Core ECLIPSECORE 08/07/2013 17:28:01PM - Code Composer Plugins IDE_C2000 08/07/2013 17:28:01PM - XDAIS TC_XDAIS 08/07/2013 17:28:01PM - Adding TC_XDAIS 8492292: new total 568333055.0 08/07/2013 17:28:01PM - Blackhawk Emulators EMU_BH 08/07/2013 17:28:01PM - Adding EMU_BH 45370003: new total 613703058.0 08/07/2013 17:28:01PM - Compiler Tools On-line Documentation DMED 08/07/2013 17:28:01PM - Adding DMED 1611418: new total 615314476.0 08/07/2013 17:28:01PM - Graphical Modeling Framework GMF 08/07/2013 17:28:01PM - Adding GMF 12342547: new total 627657023.0 08/07/2013 17:28:01PM - Xulrunner XULRUNNER 08/07/2013 17:28:01PM - Adding XULRUNNER 16596408: new total 644253431.0 08/07/2013 17:28:01PM - CCSINIT CCSINIT 08/07/2013 17:28:01PM - Adding CCSINIT 1331118: new total 645584549.0 08/07/2013 17:28:01PM - DVT DVT_VIA_CCS 08/07/2013 17:28:01PM - Sitara Device Support DEV_SUPPORT_SITARA 08/07/2013 17:28:01PM - UIA UIA 08/07/2013 17:28:01PM - Adding UIA 23110255: new total 668694804.0 08/07/2013 17:28:01PM - Debug Server DS 08/07/2013 17:28:01PM - Adding DS 16259318: new total 684954122.0 08/07/2013 17:28:01PM - XDAIS TC_XDAIS_BIOS5 08/07/2013 17:28:01PM - ARM BIOS6 TC_ARM_BIOS6 08/07/2013 17:28:01PM - C2000 Emulation Flash EMU_C2000_FLASH 08/07/2013 17:28:01PM - C2000 Device Support EMU_C2000 08/07/2013 17:28:01PM - DVT DVT_TRACE 08/07/2013 17:28:01PM - Code Composer Plugins IDE_WORKFLOW 08/07/2013 17:28:01PM - Code Composer Plugins IDE_C5400 08/07/2013 17:28:01PM - C54xx Device Support DEV_SUPPORT_C54XX 08/07/2013 17:28:01PM - DVT DVT_COMMON 08/07/2013 17:28:01PM - adding JRE size 08/07/2013 17:28:01PM - adding ECLIPSE size 08/07/2013 17:28:01PM - adding ECLIPSECORE size 08/07/2013 17:28:01PM - adding P2TOOLS size 08/07/2013 17:28:01PM - adding MSVC80 size 08/07/2013 17:28:01PM - adding MSVC2008 size 08/07/2013 17:28:01PM - adding MSVC2012 size 08/07/2013 17:28:01PM - adding INSTALLER size 08/07/2013 17:28:01PM - ==================== Install size: 2502.57 MB. 08/07/2013 17:28:01PM - Displaying pane 138B95D0-F89F-46BD-861F-A7465C02821B - Custom Choose Emulators 08/07/2013 17:28:01PM - Executing actions 138B95D0-F89F-46BD-861F-A7465C02821B - Custom Choose Emulators - After Pane is Displayed 08/07/2013 17:28:05PM - Executing actions 138B95D0-F89F-46BD-861F-A7465C02821B - Custom Choose Emulators - Before Next Pane is Displayed 08/07/2013 17:28:05PM - Checking conditions for 3538E466-B89F-4088-8A88-A91EE6BA44B7 - GCC licensing pane - Before Pane is Displayed 08/07/2013 17:28:05PM - Checking condition 3E6FB704-879E-4154-9843-07F224A8A2C0 - Execute Script Condition 08/07/2013 17:28:05PM - Condition failed 08/07/2013 17:28:05PM - Skipping pane 3538E466-B89F-4088-8A88-A91EE6BA44B7 - GCC licensing pane - conditions failed 08/07/2013 17:28:05PM - Executing actions 970555AE-BBCE-498A-BB1F-05C2F50D8552 - Start Copying Files - Before Pane is Displayed 08/07/2013 17:28:05PM - Executing action C4EC8154-C66E-4DC2-B476-02CB1D52201E - Display Installation Information 08/07/2013 17:28:05PM - Installdir = C:ti 08/07/2013 17:28:05PM - Space required: 2562631.68 08/07/2013 17:28:05PM - Space available: 30540926976 08/07/2013 17:28:05PM - Disk Space Detection: Prefered 2.44 MB ; Available 28.44 GB 08/07/2013 17:28:05PM - adding JRE size 08/07/2013 17:28:05PM - adding ECLIPSE size 08/07/2013 17:28:05PM - adding ECLIPSECORE size 08/07/2013 17:28:05PM - adding P2TOOLS size 08/07/2013 17:28:05PM - adding MSVC80 size 08/07/2013 17:28:05PM - adding MSVC2008 size 08/07/2013 17:28:05PM - adding MSVC2012 size 08/07/2013 17:28:05PM - adding INSTALLER size 08/07/2013 17:28:05PM - TC_ARM_XDCTOOLS,SYS/BIOS v6 SYS/BIOS v6 08/07/2013 17:28:05PM - Component nodename TC_ARM_XDCTOOLS 08/07/2013 17:28:05PM - DS,Base Installation Base Installation 08/07/2013 17:28:05PM - Component nodename DS 08/07/2013 17:28:05PM - DS is selected 08/07/2013 17:28:05PM - DS has a binary ti_dspack_ibsetup_5.4.0.279.exe 08/07/2013 17:28:05PM - adding Debug Server to the list 08/07/2013 17:28:05PM - TC_XDCTOOLS_BIOS5,DSP/BIOS v5 DSP/BIOS v5 08/07/2013 17:28:05PM - Component nodename TC_XDCTOOLS_BIOS5 08/07/2013 17:28:05PM - TC_XDCTOOLS,SYS/BIOS v6 SYS/BIOS v6 08/07/2013 17:28:05PM - Component nodename TC_XDCTOOLS 08/07/2013 17:28:05PM - TC_XDCTOOLS is selected 08/07/2013 17:28:05PM - TC_XDCTOOLS has a binary xdctools_3_25_00_48_base_windows.zip 08/07/2013 17:28:05PM - adding XDCTools to the list 08/07/2013 17:28:05PM - TC_C6000_XDCTOOLS,SYS/BIOS v6 SYS/BIOS v6 08/07/2013 17:28:05PM - Component nodename TC_C6000_XDCTOOLS 08/07/2013 17:28:05PM - TC_C6000_XDCTOOLS is selected 08/07/2013 17:28:05PM - TC_C6000_XDCTOOLS has a binary xdctools_3_25_00_48_c6000.zip 08/07/2013 17:28:05PM - adding C6000 XDCTools to the list 08/07/2013 17:28:05PM - IDE_MSP430,Base Installation Base Installation 08/07/2013 17:28:05PM - Component nodename IDE_MSP430 08/07/2013 17:28:05PM - MSP430ware,MSP430ware only MSP430ware only 08/07/2013 17:28:05PM - Component nodename MSP430ware 08/07/2013 17:28:05PM - TIVA_TM4C,JTAG Emulator Support JTAG Emulator Support 08/07/2013 17:28:05PM - Component nodename TIVA_TM4C 08/07/2013 17:28:05PM - EMU_C2000,Base Installation Base Installation 08/07/2013 17:28:05PM - Component nodename EMU_C2000 08/07/2013 17:28:05PM - GCC_ARM_COMPILER,Compiler Tools Compiler Tools 08/07/2013 17:28:05PM - Component nodename GCC_ARM_COMPILER 08/07/2013 17:28:05PM - IDE_C5500,Base Installation Base Installation 08/07/2013 17:28:05PM - Component nodename IDE_C5500 08/07/2013 17:28:05PM - EMU_BH,JTAG Emulator Support JTAG Emulator Support 08/07/2013 17:28:05PM - Component nodename EMU_BH 08/07/2013 17:28:05PM - EMU_BH is selected 08/07/2013 17:28:05PM - EMU_BH has a binary bh_emupack_setup_5.3.0.208.exe 08/07/2013 17:28:05PM - adding Blackhawk Emulators to the list 08/07/2013 17:28:05PM - ARM_CGT_HELP,TI Documentation TI Documentation 08/07/2013 17:28:05PM - Component nodename ARM_CGT_HELP 08/07/2013 17:28:05PM - TC_ARM_BIOS6,SYS/BIOS v6 SYS/BIOS v6 08/07/2013 17:28:05PM - Component nodename TC_ARM_BIOS6 08/07/2013 17:28:05PM - IDE_C6000,Base Installation Base Installation 08/07/2013 17:28:05PM - Component nodename IDE_C6000 08/07/2013 17:28:05PM - IDE_C6000 is selected 08/07/2013 17:28:05PM - IDE_C6000 has a binary idebuildRepo.zip 08/07/2013 17:28:05PM - adding Code Composer Plugins to the list 08/07/2013 17:28:05PM - DEV_SUPPORT_C6000,Base Installation Base Installation 08/07/2013 17:28:05PM - Component nodename DEV_SUPPORT_C6000 08/07/2013 17:28:05PM - EMU_SD,JTAG Emulator Support JTAG Emulator Support 08/07/2013 17:28:05PM - Component nodename EMU_SD 08/07/2013 17:28:05PM - EMU_SD is selected 08/07/2013 17:28:05PM - EMU_SD has a binary sd_emupack_setup_5.2.0.07.exe 08/07/2013 17:28:05PM - adding Spectrum Digital Emulators to the list 08/07/2013 17:28:05PM - C5500_CGT_HELP,TI Documentation TI Documentation 08/07/2013 17:28:05PM - Component nodename C5500_CGT_HELP 08/07/2013 17:28:05PM - TC_C2000_BIOS6,SYS/BIOS v6 SYS/BIOS v6 08/07/2013 17:28:05PM - Component nodename TC_C2000_BIOS6 08/07/2013 17:28:05PM - EMU_STELLARIS,JTAG Emulator Support JTAG Emulator Support 08/07/2013 17:28:05PM - Component nodename EMU_STELLARIS 08/07/2013 17:28:05PM - EMU_C2000_FLASH,Base Installation Base Installation 08/07/2013 17:28:05PM - Component nodename EMU_C2000_FLASH 08/07/2013 17:28:05PM - C6000_CGT_HELP,TI Documentation TI Documentation 08/07/2013 17:28:05PM - Component nodename C6000_CGT_HELP 08/07/2013 17:28:05PM - C6000_CGT_HELP is selected 08/07/2013 17:28:05PM - C6000_CGT_HELP has a binary c6000helprepo.zip 08/07/2013 17:28:05PM - adding C6000 Compiler Help to the list 08/07/2013 17:28:05PM - DEV_SUPPORT_SHARED,Base Installation Base Installation 08/07/2013 17:28:05PM - Component nodename DEV_SUPPORT_SHARED 08/07/2013 17:28:05PM - DEV_SUPPORT_SHARED is selected 08/07/2013 17:28:05PM - DEV_SUPPORT_SHARED has a binary shared_device_support_1.0.6.zip 08/07/2013 17:28:05PM - adding Shared Device Support to the list 08/07/2013 17:28:05PM - CGT_DEFAULTLIBS_MSP430,Compiler Tools Compiler Tools 08/07/2013 17:28:05PM - Component nodename CGT_DEFAULTLIBS_MSP430 08/07/2013 17:28:05PM - TC_XDAIS_BIOS5,DSP/BIOS v5 DSP/BIOS v5 08/07/2013 17:28:05PM - Component nodename TC_XDAIS_BIOS5 08/07/2013 17:28:05PM - TC_MSP430_BIOS6,SYS/BIOS v6 SYS/BIOS v6 08/07/2013 17:28:05PM - Component nodename TC_MSP430_BIOS6 08/07/2013 17:28:05PM - IDE_WORKFLOW,Base Installation Base Installation 08/07/2013 17:28:05PM - Component nodename IDE_WORKFLOW 08/07/2013 17:28:05PM - IDE_WORKFLOW is selected 08/07/2013 17:28:05PM - IDE_WORKFLOW has a binary idebuildRepo.zip 08/07/2013 17:28:05PM - IDE_WORKFLOW failed some test here 08/07/2013 17:28:05PM - DVT_TRACE,Base Installation Base Installation 08/07/2013 17:28:05PM - Component nodename DVT_TRACE 08/07/2013 17:28:05PM - DVT_TRACE is selected 08/07/2013 17:28:05PM - DVT_TRACE has a binary dvtRepo.zip 08/07/2013 17:28:05PM - adding DVT to the list 08/07/2013 17:28:05PM - DVT_ENERGYTRACE,Base Installation Base Installation 08/07/2013 17:28:05PM - Component nodename DVT_ENERGYTRACE 08/07/2013 17:28:05PM - DEV_SUPPORT_C55XX,Base Installation Base Installation 08/07/2013 17:28:05PM - Component nodename DEV_SUPPORT_C55XX 08/07/2013 17:28:05PM - CGT_DEFAULTLIBS_TMS470,Compiler Tools Compiler Tools 08/07/2013 17:28:05PM - Component nodename CGT_DEFAULTLIBS_TMS470 08/07/2013 17:28:05PM - TC_BIOS5,DSP/BIOS v5 DSP/BIOS v5 08/07/2013 17:28:05PM - Component nodename TC_BIOS5 08/07/2013 17:28:05PM - TC_BIOS5 is selected 08/07/2013 17:28:05PM - TC_BIOS5 has a binary bios_setupwin32_5_42_01_09.exe 08/07/2013 17:28:05PM - adding BIOS 5 to the list 08/07/2013 17:28:05PM - DEV_SUPPORT_CC2538,Base Installation Base Installation 08/07/2013 17:28:05PM - Component nodename DEV_SUPPORT_CC2538 08/07/2013 17:28:05PM - DEV_SUPPORT_OMAPNDA,Base Installation Base Installation 08/07/2013 17:28:05PM - Component nodename DEV_SUPPORT_OMAPNDA 08/07/2013 17:28:05PM - KEYSTONE1,Base Installation Base Installation 08/07/2013 17:28:05PM - Component nodename KEYSTONE1 08/07/2013 17:28:05PM - KEYSTONE1 is selected 08/07/2013 17:28:05PM - KEYSTONE1 has a binary ti_emupack_keystone1_setup_1.0.6.0.exe 08/07/2013 17:28:05PM - adding Keystone1 to the list 08/07/2013 17:28:05PM - CGT_DEFAULTLIBS_EVE,Base Installation Base Installation 08/07/2013 17:28:05PM - Component nodename CGT_DEFAULTLIBS_EVE 08/07/2013 17:28:05PM - CGT_DEFAULTLIBS_C6000,Compiler Tools Compiler Tools 08/07/2013 17:28:05PM - Component nodename CGT_DEFAULTLIBS_C6000 08/07/2013 17:28:05PM - CGT_DEFAULTLIBS_C6000 is selected 08/07/2013 17:28:05PM - CGT_DEFAULTLIBS_C6000 has a binary ti_cgt_c6000_7.4.2_setup_win32.exe 08/07/2013 17:28:05PM - adding TI C6000 Compiler Tools to the list 08/07/2013 17:28:05PM - SIM_TI,Simulators Simulators 08/07/2013 17:28:05PM - Component nodename SIM_TI 08/07/2013 17:28:05PM - SIM_TI is selected 08/07/2013 17:28:05PM - SIM_TI has a binary ti_simpack_setup_5.4.0.4.exe 08/07/2013 17:28:05PM - adding TI Simulators to the list 08/07/2013 17:28:05PM - DVT_VIA_CCS,Base Installation Base Installation 08/07/2013 17:28:05PM - Component nodename DVT_VIA_CCS 08/07/2013 17:28:05PM - DVT_VIA_CCS is selected 08/07/2013 17:28:05PM - DVT_VIA_CCS has a binary dvtRepo.zip 08/07/2013 17:28:05PM - DVT_VIA_CCS failed some test here 08/07/2013 17:28:05PM - CCSINIT,Base Installation Base Installation 08/07/2013 17:28:05PM - Component nodename CCSINIT 08/07/2013 17:28:05PM - CCSINIT is selected 08/07/2013 17:28:05PM - CCSINIT has a binary ccsinit_setup_5.1.0.0.exe 08/07/2013 17:28:05PM - adding CCSINIT to the list 08/07/2013 17:28:05PM - CGT_DEFAULTLIBS_C2800,Compiler Tools Compiler Tools 08/07/2013 17:28:05PM - Component nodename CGT_DEFAULTLIBS_C2800 08/07/2013 17:28:05PM - TC_XDAIS,SYS/BIOS v6 SYS/BIOS v6 08/07/2013 17:28:05PM - Component nodename TC_XDAIS 08/07/2013 17:28:05PM - TC_XDAIS is selected 08/07/2013 17:28:05PM - TC_XDAIS has a binary xdais_7_21_01_07.zip 08/07/2013 17:28:05PM - adding XDAIS to the list 08/07/2013 17:28:05PM - EMU_MSP430,JTAG Emulator Support JTAG Emulator Support 08/07/2013 17:28:05PM - Component nodename EMU_MSP430 08/07/2013 17:28:05PM - TIVA_TM4E,JTAG Emulator Support JTAG Emulator Support 08/07/2013 17:28:05PM - Component nodename TIVA_TM4E 08/07/2013 17:28:05PM - DEV_SUPPORT_INTEGRA,Base Installation Base Installation 08/07/2013 17:28:05PM - Component nodename DEV_SUPPORT_INTEGRA 08/07/2013 17:28:05PM - GRACE,Grace (includes MSP430ware) Grace (includes MSP430ware) 08/07/2013 17:28:05PM - Component nodename GRACE 08/07/2013 17:28:05PM - IDE_C5400,Base Installation Base Installation 08/07/2013 17:28:05PM - Component nodename IDE_C5400 08/07/2013 17:28:05PM - IDE_C2000,Base Installation Base Installation 08/07/2013 17:28:05PM - Component nodename IDE_C2000 08/07/2013 17:28:05PM - EMU_MSP432,Base Installation Base Installation 08/07/2013 17:28:05PM - Component nodename EMU_MSP432 08/07/2013 17:28:05PM - UIA,SYS/BIOS v6 SYS/BIOS v6 08/07/2013 17:28:05PM - Component nodename UIA 08/07/2013 17:28:05PM - UIA is selected 08/07/2013 17:28:05PM - UIA has a binary uia_1_03_00_02.zip 08/07/2013 17:28:05PM - adding UIA to the list 08/07/2013 17:28:05PM - GMF,Base Installation Base Installation 08/07/2013 17:28:05PM - Component nodename GMF 08/07/2013 17:28:05PM - GMF is selected 08/07/2013 17:28:05PM - GMF has a binary gmfRepo.zip 08/07/2013 17:28:05PM - adding Graphical Modeling Framework to the list 08/07/2013 17:28:05PM - DEV_SUPPORT_VAYUNDA1,Base Installation Base Installation 08/07/2013 17:28:05PM - Component nodename DEV_SUPPORT_VAYUNDA1 08/07/2013 17:28:05PM - KEYSTONE2,Base Installation Base Installation 08/07/2013 17:28:05PM - Component nodename KEYSTONE2 08/07/2013 17:28:05PM - KEYSTONE2 is selected 08/07/2013 17:28:05PM - KEYSTONE2 has a binary ti_emupack_keystone2_setup_1.0.0.3.exe 08/07/2013 17:28:05PM - adding Keystone2 to the list 08/07/2013 17:28:05PM - EVE_SIM_TI,Base Installation Base Installation 08/07/2013 17:28:05PM - Component nodename EVE_SIM_TI 08/07/2013 17:28:05PM - C2000_CGT_HELP,TI Documentation TI Documentation 08/07/2013 17:28:05PM - Component nodename C2000_CGT_HELP 08/07/2013 17:28:05PM - DEV_SUPPORT_SITARA,Base Installation Base Installation 08/07/2013 17:28:05PM - Component nodename DEV_SUPPORT_SITARA 08/07/2013 17:28:05PM - CGT_DEFAULTLIBS_C5400,Compiler Tools Compiler Tools 08/07/2013 17:28:05PM - Component nodename CGT_DEFAULTLIBS_C5400 08/07/2013 17:28:05PM - TC_MSP430_XDCTOOLS,SYS/BIOS v6 SYS/BIOS v6 08/07/2013 17:28:05PM - Component nodename TC_MSP430_XDCTOOLS 08/07/2013 17:28:05PM - DEV_SUPPORT_OMAP,Base Installation Base Installation 08/07/2013 17:28:05PM - Component nodename DEV_SUPPORT_OMAP 08/07/2013 17:28:05PM - IDE_ARM,Base Installation Base Installation 08/07/2013 17:28:05PM - Component nodename IDE_ARM 08/07/2013 17:28:05PM - DEV_SUPPORT_C6000MC,Base Installation Base Installation 08/07/2013 17:28:05PM - Component nodename DEV_SUPPORT_C6000MC 08/07/2013 17:28:05PM - DEV_SUPPORT_C6000MC is selected 08/07/2013 17:28:05PM - DEV_SUPPORT_C6000MC has a binary c6000multicore_device_support_1.0.4.zip 08/07/2013 17:28:05PM - adding C6000 Multicore Device Support to the list 08/07/2013 17:28:05PM - GREE_C2000_SUPPORT,Base Installation Base Installation 08/07/2013 17:28:05PM - Component nodename GREE_C2000_SUPPORT 08/07/2013 17:28:05PM - TC_BIOS6,SYS/BIOS v6 SYS/BIOS v6 08/07/2013 17:28:05PM - Component nodename TC_BIOS6 08/07/2013 17:28:05PM - TC_BIOS6 is selected 08/07/2013 17:28:05PM - TC_BIOS6 has a binary bios_6_35_01_29_base.zip 08/07/2013 17:28:05PM - adding BIOS 6 to the list 08/07/2013 17:28:05PM - TC_C6000_BIOS6,SYS/BIOS v6 SYS/BIOS v6 08/07/2013 17:28:05PM - Component nodename TC_C6000_BIOS6 08/07/2013 17:28:05PM - TC_C6000_BIOS6 is selected 08/07/2013 17:28:05PM - TC_C6000_BIOS6 has a binary bios_6_35_01_29_c6000.zip 08/07/2013 17:28:05PM - adding C6000 BIOS6 to the list 08/07/2013 17:28:05PM - DMED,TI Documentation TI Documentation 08/07/2013 17:28:05PM - Component nodename DMED 08/07/2013 17:28:05PM - DMED is selected 08/07/2013 17:28:05PM - DMED has a binary ti_cgt_dmed_setup_1.1.2.0.exe 08/07/2013 17:28:05PM - adding Compiler Tools On-line Documentation to the list 08/07/2013 17:28:05PM - DVT_UIA,Base Installation Base Installation 08/07/2013 17:28:05PM - Component nodename DVT_UIA 08/07/2013 17:28:05PM - DVT_UIA is selected 08/07/2013 17:28:05PM - DVT_UIA has a binary dvtRepo.zip 08/07/2013 17:28:05PM - DVT_UIA failed some test here 08/07/2013 17:28:05PM - DEV_SUPPORT_C54XX,Base Installation Base Installation 08/07/2013 17:28:05PM - Component nodename DEV_SUPPORT_C54XX 08/07/2013 17:28:05PM - DVT_COMMON,Base Installation Base Installation 08/07/2013 17:28:05PM - Component nodename DVT_COMMON 08/07/2013 17:28:05PM - DVT_COMMON is selected 08/07/2013 17:28:05PM - DVT_COMMON has a binary dvtRepo.zip 08/07/2013 17:28:05PM - DVT_COMMON failed some test here 08/07/2013 17:28:05PM - CGT_DEFAULTLIBS_C5500,Compiler Tools Compiler Tools 08/07/2013 17:28:05PM - Component nodename CGT_DEFAULTLIBS_C5500 08/07/2013 17:28:05PM - DEV_SUPPORT_DAVINCI,Base Installation Base Installation 08/07/2013 17:28:05PM - Component nodename DEV_SUPPORT_DAVINCI 08/07/2013 17:28:05PM - EMU_HERCULES,Base Installation Base Installation 08/07/2013 17:28:05PM - Component nodename EMU_HERCULES 08/07/2013 17:28:05PM - EMU_TI,JTAG Emulator Support JTAG Emulator Support 08/07/2013 17:28:05PM - Component nodename EMU_TI 08/07/2013 17:28:05PM - EMU_TI is selected 08/07/2013 17:28:05PM - EMU_TI has a binary ti_emupack_setup_5.1.73.0.exe 08/07/2013 17:28:05PM - adding TI Emulators to the list 08/07/2013 17:28:05PM - XULRUNNER,Base Installation Base Installation 08/07/2013 17:28:05PM - Component nodename XULRUNNER 08/07/2013 17:28:05PM - XULRUNNER is selected 08/07/2013 17:28:05PM - XULRUNNER has a binary xulrunner_10.4.0.zip 08/07/2013 17:28:05PM - adding Xulrunner to the list 08/07/2013 17:28:05PM - DEV_SUPPORT_VAYUNDA2,Base Installation Base Installation 08/07/2013 17:28:05PM - Component nodename DEV_SUPPORT_VAYUNDA2 08/07/2013 17:28:05PM - TC_C2000_XDCTOOLS,SYS/BIOS v6 SYS/BIOS v6 08/07/2013 17:28:05PM - Component nodename TC_C2000_XDCTOOLS 08/07/2013 17:28:05PM - MSP430_CGT_HELP,TI Documentation TI Documentation 08/07/2013 17:28:05PM - Component nodename MSP430_CGT_HELP 08/07/2013 17:28:05PM - IDE_MAIN,Base Installation Base Installation 08/07/2013 17:28:05PM - Component nodename IDE_MAIN 08/07/2013 17:28:05PM - IDE_MAIN is selected 08/07/2013 17:28:05PM - IDE_MAIN has a binary idebuildRepo.zip 08/07/2013 17:28:05PM - IDE_MAIN failed some test here 08/07/2013 17:28:05PM - Install Directory: C:ti/ccsv5 Setup Type: Custom Product Families selected: C6000 Multi Core DSPs Components to be installed: JRE Eclipse Eclipse Core Eclipse P2 Extensions MSVC 2005 MSVC 2008 MSVC 2012 LWInstaller BIOS 5 BIOS 6 Blackhawk Emulators C6000 BIOS6 C6000 Compiler Help C6000 Multicore Device Support C6000 XDCTools CCSINIT Code Composer Plugins Compiler Tools On-line Documentation DVT Debug Server Graphical Modeling Framework Keystone1 Keystone2 Shared Device Support Spectrum Digital Emulators TI C6000 Compiler Tools TI Emulators TI Simulators UIA XDAIS XDCTools XDS100 Class Emulator Support Xulrunner 08/07/2013 17:28:05PM - Displaying pane 970555AE-BBCE-498A-BB1F-05C2F50D8552 - Start Copying Files 08/07/2013 17:28:05PM - Executing actions 970555AE-BBCE-498A-BB1F-05C2F50D8552 - Start Copying Files - After Pane is Displayed 08/07/2013 17:28:05PM - Executing actions 970555AE-BBCE-498A-BB1F-05C2F50D8552 - Start Copying Files - Before Next Pane is Displayed 08/07/2013 17:28:05PM - Executing actions 52C7C2BC-1F41-4249-9F63-446012A9932F - Custom Copying Files - Before Pane is Displayed 08/07/2013 17:28:05PM - Executing action 91C1A8F5-F64C-49A5-B36F-13A27CBC2B2B - Disable Buttons 08/07/2013 17:28:05PM - Displaying pane 52C7C2BC-1F41-4249-9F63-446012A9932F - Custom Copying Files 08/07/2013 17:28:05PM - Executing actions 52C7C2BC-1F41-4249-9F63-446012A9932F - Custom Copying Files - After Pane is Displayed 08/07/2013 17:28:05PM - Executing action A632D499-CB7C-4DF1-9094-2ED4D938D047 - Set widget values 08/07/2013 17:28:05PM - .wizard.steps.f52C7C2BC-1F41-4249-9F63-446012A9932F 08/07/2013 17:28:05PM - Executing action 597A14A8-9842-4C6F-A081-5DB914701168 - Install Everything 08/07/2013 17:28:05PM - Executing actions B51DE951-D209-4A30-820D-F4333DC0F757 - Install Actions 08/07/2013 17:28:05PM - Executing action B61916A4-E55E-433E-AD86-CA546CB82EBA - debug info 08/07/2013 17:28:05PM - InstallDir C:ti 08/07/2013 17:28:05PM - CCSDIR C:ti/ccsv5 08/07/2013 17:28:05PM - EclipseDir C:ti/ccsv5/eclipse 08/07/2013 17:28:05PM - features previously installed: 08/07/2013 17:28:05PM - previously allowed (not installed) binaries: 08/07/2013 17:28:05PM - eclipse? 08/07/2013 17:28:05PM - checking eclipse in 08/07/2013 17:28:05PM - checking eclipse in 08/07/2013 17:28:05PM - installwidget from install stuff .wizard.steps.f52C7C2BC-1F41-4249-9F63-446012A9932F 08/07/2013 17:28:05PM - http info : -accept */* -proxyfilter http::ProxyRequired -proxyhost [] -proxyport [] -urlencoding utf-8 -useragent [Tcl http client package 2.5.3] 08/07/2013 17:28:05PM - system encoding: identity 08/07/2013 17:28:05PM - update java? : true 08/07/2013 17:28:05PM - Executing action 67D2E6D4-918E-4E69-9F6E-96FDC5BA98DD - Check for non-ascii characters 08/07/2013 17:28:05PM - Executing action 5BF85883-9AAD-42FF-8B0C-F73656A132E9 - Execute Check for InstallDir junction (Windows) 08/07/2013 17:28:05PM - Executing actions 3C59A104-A461-45AB-BFF8-54BA60E868EF - Check for InstallDir junction (Windows) 08/07/2013 17:28:05PM - Checking conditions for 3C59A104-A461-45AB-BFF8-54BA60E868EF - - Before Action is Executed 08/07/2013 17:28:05PM - Checking condition 368AE49A-5EEE-4DBC-8DE3-5D0DAE06CED9 - Platform Condition 08/07/2013 17:28:05PM - Checking to see if <%Platform%> is Windows 08/07/2013 17:28:05PM - ** Checking to see if Windows is Windows 08/07/2013 17:28:05PM - Condition passed 08/07/2013 17:28:05PM - Executing action 3C59A104-A461-45AB-BFF8-54BA60E868EF - Check for InstallDir junction (Windows) 08/07/2013 17:28:05PM - checking C:/ti for links 08/07/2013 17:28:05PM - dir parameter = C:/ti 08/07/2013 17:28:05PM - checking C:/ti... 08/07/2013 17:28:06PM - dir now C:/ 08/07/2013 17:28:06PM - dir parameter = C:/ 08/07/2013 17:28:06PM - checking C:/... 08/07/2013 17:28:06PM - dir now C:/ 08/07/2013 17:28:06PM - C:/ eq C:/ 08/07/2013 17:28:06PM - checking C:/ti/ccsv5/eclipse for links 08/07/2013 17:28:06PM - dir parameter = C:/ti/ccsv5/eclipse 08/07/2013 17:28:06PM - C:/ti/ccsv5/eclipse doesn't exist, continuing 08/07/2013 17:28:06PM - dir now C:/ti/ccsv5 08/07/2013 17:28:06PM - dir parameter = C:/ti/ccsv5 08/07/2013 17:28:06PM - C:/ti/ccsv5 doesn't exist, continuing 08/07/2013 17:28:06PM - dir now C:/ti 08/07/2013 17:28:06PM - dir parameter = C:/ti 08/07/2013 17:28:06PM - checking C:/ti... 08/07/2013 17:28:07PM - dir now C:/ 08/07/2013 17:28:07PM - dir parameter = C:/ 08/07/2013 17:28:07PM - checking C:/... 08/07/2013 17:28:07PM - dir now C:/ 08/07/2013 17:28:07PM - C:/ eq C:/ 08/07/2013 17:28:07PM - Checking conditions for 03FF910C-9C82-4954-A8BC-A581EB12B363 - - Before Action is Executed 08/07/2013 17:28:07PM - Checking condition DCD08B1C-7318-4679-95A7-1C67E8B34D55 - Platform Condition 08/07/2013 17:28:07PM - Checking to see if <%Platform%> is Linux-x86 08/07/2013 17:28:07PM - ** Checking to see if Windows is Linux-x86 08/07/2013 17:28:07PM - Condition failed 08/07/2013 17:28:07PM - Skipping action 03FF910C-9C82-4954-A8BC-A581EB12B363 - Check user for eclipse (Linux) - conditions failed 08/07/2013 17:28:07PM - Checking conditions for B1610F21-7223-463C-A20F-63B86E7540BD - - Before Action is Executed 08/07/2013 17:28:07PM - Checking condition FBAD1A6A-8C68-453C-88CD-C706E984ED33 - File Exists Condition 08/07/2013 17:28:07PM - Checking to see if <%EclipseDir%>/ccs.properties exists 08/07/2013 17:28:07PM - ** Checking to see if C:ti/ccsv5/eclipse/ccs.properties exists 08/07/2013 17:28:07PM - Condition failed 08/07/2013 17:28:07PM - Skipping action B1610F21-7223-463C-A20F-63B86E7540BD - Set CCS Version - conditions failed 08/07/2013 17:28:07PM - Executing action CFB47EDB-83E9-4996-8950-F56A34D99856 - Set Shortcut AppName Value 08/07/2013 17:28:07PM - Texas Instruments/Code Composer Studio 5.4.0 Code Composer Studio 5.4.0 08/07/2013 17:28:07PM - Checking conditions for 3F13C524-F0A9-43CD-A1E3-30CC0BA6A8CE - - Before Action is Executed 08/07/2013 17:28:07PM - Checking condition CEB9BB47-3E97-4C7F-BC8C-1083D203955F - String Is Condition 08/07/2013 17:28:07PM - Checking to see if <%ComponentInstaller%> is false 08/07/2013 17:28:07PM - ** Checking to see if false is false 08/07/2013 17:28:07PM - Condition passed 08/07/2013 17:28:07PM - Checking condition 079494D0-01E9-4974-AE48-039212CCFA85 - Command Line Test Condition 08/07/2013 17:28:07PM - Checking to see if test was passed on the command line 08/07/2013 17:28:07PM - Condition failed 08/07/2013 17:28:07PM - Skipping action 3F13C524-F0A9-43CD-A1E3-30CC0BA6A8CE - Write ccs.properties - conditions failed 08/07/2013 17:28:07PM - Executing action ED594D8A-F0DB-4A5A-B795-708DF2A90A0B - Set executable name 08/07/2013 17:28:07PM - false 0 08/07/2013 17:28:07PM - New Executable name: C:ti/ccsv5/eclipseccstudio.exe 08/07/2013 17:28:07PM - Executing action 0D989427-0F69-485D-BE72-F2E935B73E52 - Set OS Specific Environment 08/07/2013 17:28:07PM - Executing action D8E2B8AA-EB63-47FE-82AA-45EFA802BD78 - Check URL 08/07/2013 17:28:07PM - -accept */* -proxyfilter http::ProxyRequired -proxyhost [] -proxyport [] -urlencoding utf-8 -useragent [Tcl http client package 2.5.3] 08/07/2013 17:28:07PM - C:/Users/asus/AppData/Local/Temp/ijtmp_EDACDD11-B33D-4D43-806D-6BD0DBD8D818/tmpfile 08/07/2013 17:28:07PM - Checking conditions for F42ABA50-C9D7-4771-920C-0FEBABED0FB0 - - Before Action is Executed 08/07/2013 17:28:07PM - Checking condition 26BBE798-0872-4727-A392-CC2E02FCE122 - String Is Condition 08/07/2013 17:28:07PM - Checking to see if <%ValidURL%> is false 08/07/2013 17:28:07PM - ** Checking to see if 1 is false 08/07/2013 17:28:07PM - Condition failed 08/07/2013 17:28:07PM - Skipping action F42ABA50-C9D7-4771-920C-0FEBABED0FB0 - Invalid URL message - conditions failed 08/07/2013 17:28:07PM - Checking conditions for A74CD224-6F8B-4D98-A7F0-1B0F834CAD19 - - Before Action is Executed 08/07/2013 17:28:07PM - Checking condition D6D6ECF6-266D-4C54-8440-A632093FECFC - String Is Condition 08/07/2013 17:28:07PM - Checking to see if <%ValidURL%> is false 08/07/2013 17:28:07PM - ** Checking to see if 1 is false 08/07/2013 17:28:07PM - Condition failed 08/07/2013 17:28:07PM - Skipping action A74CD224-6F8B-4D98-A7F0-1B0F834CAD19 - Invalid URL message - conditions failed 08/07/2013 17:28:07PM - Checking conditions for F747BBA6-DCBA-4CDE-B57B-EF8FD7E27CB5 - - Before Action is Executed 08/07/2013 17:28:07PM - Checking condition A7E1D8E2-DBB1-48E9-A360-E5D12D6AADEE - String Is Condition 08/07/2013 17:28:07PM - Checking to see if <%ValidURL%> is false 08/07/2013 17:28:07PM - ** Checking to see if 1 is false 08/07/2013 17:28:07PM - Condition failed 08/07/2013 17:28:07PM - Skipping action F747BBA6-DCBA-4CDE-B57B-EF8FD7E27CB5 - Exit - conditions failed 08/07/2013 17:28:07PM - Executing action 6EC1F21D-0682-41CB-9A41-4D8B8CDA8EEE - Set JavaFound 08/07/2013 17:28:07PM - Found existing java in C:ti/ccsv5/eclipse/jre/bin/java.exe 08/07/2013 17:28:07PM - Executing action E40D7DAD-4686-4F93-B2CD-887A95143B07 - Progress Bar Setup 08/07/2013 17:28:07PM - msvc2005 component exists 08/07/2013 17:28:07PM - JRE size = 31364806 08/07/2013 17:28:07PM - progress bar setup: ECLIPSE 3.8.0.SR1 08/07/2013 17:28:07PM - progress bar setup: 08/07/2013 17:28:07PM - installing eclipse, components don't match ECLIPSE 3.8.0.SR1 or update not installed yet 08/07/2013 17:28:07PM - Update_Eclipse true Native_Eclipse_Selected 0 08/07/2013 17:28:07PM - Eclipse size = 91990247 08/07/2013 17:28:07PM - Checking conditions for CB835508-B3C7-4C6D-86FB-A5722D1B4066 - - Before Action is Executed 08/07/2013 17:28:07PM - Checking condition F9DA4F2D-C63D-42EE-BD4E-C8F42BBD36FD - Command Line Test Condition 08/07/2013 17:28:07PM - Checking to see if test was passed on the command line 08/07/2013 17:28:07PM - Condition failed 08/07/2013 17:28:07PM - Skipping action CB835508-B3C7-4C6D-86FB-A5722D1B4066 - Run Test Actions - conditions failed 08/07/2013 17:28:07PM - Checking conditions for 866CB3CE-38C7-4316-9DA4-F23C328C8081 - - Before Action is Executed 08/07/2013 17:28:07PM - Checking condition 73F4C949-9A6C-4AF3-938E-AE9FCD484172 - Platform Condition 08/07/2013 17:28:07PM - Checking to see if <%Platform%> is Windows 08/07/2013 17:28:07PM - ** Checking to see if Windows is Windows 08/07/2013 17:28:07PM - Condition passed 08/07/2013 17:28:07PM - Executing action 866CB3CE-38C7-4316-9DA4-F23C328C8081 - Unpack unzip.exe 08/07/2013 17:28:07PM - Unpacking C:/Users/asus/AppData/Local/Temp/ijtmp_EDACDD11-B33D-4D43-806D-6BD0DBD8D818/unzip.exe 08/07/2013 17:28:07PM - Executing action B464AEA4-609E-4D3E-A86C-8A98A43D4275 - Unpack p2.app 08/07/2013 17:28:07PM - Unpacking C:/Users/asus/AppData/Local/Temp/ijtmp_EDACDD11-B33D-4D43-806D-6BD0DBD8D818/p2.app.zip 08/07/2013 17:28:07PM - Executing action 7DF319D5-D5F8-4FC6-87DC-887D4BBAAB08 - Unzip p2.app 08/07/2013 17:28:08PM - Checking conditions for A313FF31-91FB-47AB-A9D4-C81E1B2DA8C1 - - Before Action is Executed 08/07/2013 17:28:08PM - Checking condition 28013E47-E25A-45BE-A17E-6012E53D9AD5 - Command Line Test Condition 08/07/2013 17:28:08PM - Checking to see if test was not passed on the command line 08/07/2013 17:28:08PM - Condition passed 08/07/2013 17:28:08PM - Executing action A313FF31-91FB-47AB-A9D4-C81E1B2DA8C1 - Run Production Actions 08/07/2013 17:28:08PM - Executing actions E9AEA672-9CC4-4620-91F0-031A4399B5D9 - Production Actions 08/07/2013 17:28:08PM - Executing action D9F9FA6D-0618-449A-AA37-A3C5BEC8F40C - Setup GUI information 08/07/2013 17:28:08PM - setting text widget 08/07/2013 17:28:08PM - text widget??? - .wizard.steps.f52C7C2BC-1F41-4249-9F63-446012A9932F.clientarea.frame.text 08/07/2013 17:28:08PM - percent now 1 08/07/2013 17:28:08PM - Executing action 7A1E3C13-A600-4DA9-B47D-319A28BD244B - Remove ccs_update executables and scripts 08/07/2013 17:28:08PM - Checking conditions for C51982FE-9BDA-48CD-95BF-A6B70A993729 - - Before Action is Executed 08/07/2013 17:28:08PM - Checking condition 11E9FD2B-B3DE-49F8-9D69-853C25E16B47 - String Is Condition 08/07/2013 17:28:08PM - Checking to see if <%ComponentInstaller%> is true 08/07/2013 17:28:08PM - ** Checking to see if false is true 08/07/2013 17:28:08PM - Condition failed 08/07/2013 17:28:08PM - Skipping action C51982FE-9BDA-48CD-95BF-A6B70A993729 - Execute Write ComponentInstaller config file - conditions failed 08/07/2013 17:28:08PM - Checking conditions for 6D4C31EA-783A-4805-8548-6089DBCF461E - - Before Action is Executed 08/07/2013 17:28:08PM - Checking condition ED229D09-4C22-4629-A526-48481FFDBEDB - String Is Condition 08/07/2013 17:28:08PM - Checking to see if <%ComponentInstaller%> is false 08/07/2013 17:28:08PM - ** Checking to see if false is false 08/07/2013 17:28:08PM - Condition passed 08/07/2013 17:28:08PM - Checking condition 2088C495-5B3A-4B8C-9895-5CE2432A91BE - String Is Condition 08/07/2013 17:28:08PM - Checking to see if <%UpdateMode%> is false 08/07/2013 17:28:08PM - ** Checking to see if 0 is false 08/07/2013 17:28:08PM - Condition passed 08/07/2013 17:28:08PM - Executing action 6D4C31EA-783A-4805-8548-6089DBCF461E - Execute Write CCS Config File 08/07/2013 17:28:08PM - Executing actions A085CE76-4DD6-4499-9194-CA7BF3E1B747 - Write ccs_config.xml File 08/07/2013 17:28:08PM - Executing action A085CE76-4DD6-4499-9194-CA7BF3E1B747 - Write ccs_config.xml File 08/07/2013 17:28:08PM - ccs_config: Installedfeatures 08/07/2013 17:28:08PM - mcomp = JRE ECLIPSE ECLIPSECORE P2TOOLS MSVC80 MSVC2008 MSVC2012 INSTALLER 08/07/2013 17:28:08PM - not skipping C6000 Multi Core DSPs 08/07/2013 17:28:08PM - Looking for c6000 08/07/2013 17:28:08PM - /noc2400 /noc2800 /noc5400 /noc5500 /noarm /noomap /nodavinci 08/07/2013 17:28:08PM - writing ccs_config file: JRE 08/07/2013 17:28:08PM - writing ccs_config file: ECLIPSE 08/07/2013 17:28:08PM - writing ccs_config file: ECLIPSECORE 08/07/2013 17:28:08PM - writing ccs_config file: P2TOOLS 08/07/2013 17:28:08PM - writing ccs_config file: MSVC80 08/07/2013 17:28:08PM - writing ccs_config file: MSVC2008 08/07/2013 17:28:08PM - writing ccs_config file: MSVC2012 08/07/2013 17:28:08PM - writing ccs_config file: INSTALLER 08/07/2013 17:28:08PM - sorted index list: DS CGT_DEFAULTLIBS_C2800 CGT_DEFAULTLIBS_C5400 CGT_DEFAULTLIBS_C5500 CGT_DEFAULTLIBS_C6000 CGT_DEFAULTLIBS_MSP430 CGT_DEFAULTLIBS_TMS470 IDE_MAIN IDE_WORKFLOW IDE_ARM IDE_MSP430 IDE_C2000 IDE_C5500 IDE_C6000 IDE_C5400 DVT_COMMON DVT_TRACE DVT_VIA_CCS DVT_UIA DVT_ENERGYTRACE GMF TC_XDCTOOLS TC_XDCTOOLS_BIOS5 TC_ARM_XDCTOOLS TC_C2000_XDCTOOLS TC_C6000_XDCTOOLS TC_MSP430_XDCTOOLS TC_BIOS5 TC_BIOS6 TC_ARM_BIOS6 TC_C2000_BIOS6 TC_C6000_BIOS6 TC_MSP430_BIOS6 TC_XDAIS TC_XDAIS_BIOS5 GRACE UIA MSP430ware CCSINIT SIM_TI EMU_BH EMU_TI EMU_STELLARIS EMU_HERCULES EMU_SD EMU_C2000 EMU_C2000_FLASH EMU_MSP430 KEYSTONE1 KEYSTONE2 DMED MSP430_CGT_HELP C6000_CGT_HELP ARM_CGT_HELP C2000_CGT_HELP C5500_CGT_HELP DEV_SUPPORT_SHARED DEV_SUPPORT_SITARA DEV_SUPPORT_C55XX DEV_SUPPORT_C54XX DEV_SUPPORT_C6000 DEV_SUPPORT_C6000MC DEV_SUPPORT_DAVINCI DEV_SUPPORT_INTEGRA DEV_SUPPORT_OMAP DEV_SUPPORT_CC2538 XULRUNNER GCC_ARM_COMPILER TIVA_TM4C TIVA_TM4E CGT_DEFAULTLIBS_EVE EVE_SIM_TI EMU_MSP432 DEV_SUPPORT_OMAPNDA DEV_SUPPORT_VAYUNDA1 DEV_SUPPORT_VAYUNDA2 GREE_C2000_SUPPORT 08/07/2013 17:28:08PM - writing ccs_config file: DS 08/07/2013 17:28:08PM - IB installer for DS 08/07/2013 17:28:08PM - ccs_config: searching for DS in 08/07/2013 17:28:08PM - DS is new 08/07/2013 17:28:08PM - DS is selected 08/07/2013 17:28:08PM - adding size 15 08/07/2013 17:28:08PM - binary = ti_dspack_ibsetup_5.4.0.279.exe initial 08/07/2013 17:28:08PM - adding DS to JRE ECLIPSE ECLIPSECORE P2TOOLS MSVC80 MSVC2008 MSVC2012 INSTALLER 08/07/2013 17:28:08PM - writing ccs_config file: CGT_DEFAULTLIBS_C2800 08/07/2013 17:28:08PM - ccs_config: searching for CGT_DEFAULTLIBS_C2800 in 08/07/2013 17:28:08PM - CGT_DEFAULTLIBS_C2800 is new 08/07/2013 17:28:08PM - CGT_DEFAULTLIBS_C2800 is not selected 08/07/2013 17:28:08PM - binary = ti_cgt_c2000_6.1.3_setup_win32.exe do not install 08/07/2013 17:28:08PM - writing ccs_config file: CGT_DEFAULTLIBS_C5400 08/07/2013 17:28:08PM - ccs_config: searching for CGT_DEFAULTLIBS_C5400 in 08/07/2013 17:28:08PM - CGT_DEFAULTLIBS_C5400 is new 08/07/2013 17:28:08PM - CGT_DEFAULTLIBS_C5400 is not selected 08/07/2013 17:28:08PM - binary = ld_4_2_0.zip do not install 08/07/2013 17:28:08PM - writing ccs_config file: CGT_DEFAULTLIBS_C5500 08/07/2013 17:28:08PM - ccs_config: searching for CGT_DEFAULTLIBS_C5500 in 08/07/2013 17:28:08PM - CGT_DEFAULTLIBS_C5500 is new 08/07/2013 17:28:08PM - CGT_DEFAULTLIBS_C5500 is not selected 08/07/2013 17:28:08PM - binary = ti_cgt_c5500_4.4.1_setup_win32.exe do not install 08/07/2013 17:28:08PM - writing ccs_config file: CGT_DEFAULTLIBS_C6000 08/07/2013 17:28:08PM - ccs_config: searching for CGT_DEFAULTLIBS_C6000 in 08/07/2013 17:28:08PM - CGT_DEFAULTLIBS_C6000 is new 08/07/2013 17:28:08PM - CGT_DEFAULTLIBS_C6000 is selected 08/07/2013 17:28:08PM - adding size 66 08/07/2013 17:28:08PM - binary = ti_cgt_c6000_7.4.2_setup_win32.exe initial 08/07/2013 17:28:08PM - adding CGT_DEFAULTLIBS_C6000 to JRE ECLIPSE ECLIPSECORE P2TOOLS MSVC80 MSVC2008 MSVC2012 INSTALLER DS 08/07/2013 17:28:08PM - writing ccs_config file: CGT_DEFAULTLIBS_MSP430 08/07/2013 17:28:08PM - ccs_config: searching for CGT_DEFAULTLIBS_MSP430 in 08/07/2013 17:28:08PM - CGT_DEFAULTLIBS_MSP430 is new 08/07/2013 17:28:08PM - CGT_DEFAULTLIBS_MSP430 is not selected 08/07/2013 17:28:08PM - binary = ti_cgt_msp430_4.1.5_setup_win32.exe do not install 08/07/2013 17:28:08PM - writing ccs_config file: CGT_DEFAULTLIBS_TMS470 08/07/2013 17:28:08PM - ccs_config: searching for CGT_DEFAULTLIBS_TMS470 in 08/07/2013 17:28:08PM - CGT_DEFAULTLIBS_TMS470 is new 08/07/2013 17:28:08PM - CGT_DEFAULTLIBS_TMS470 is not selected 08/07/2013 17:28:08PM - binary = ti_cgt_tms470_5.0.4_setup_win32.exe do not install 08/07/2013 17:28:08PM - writing ccs_config file: IDE_MAIN 08/07/2013 17:28:08PM - ccs_config: searching for IDE_MAIN in 08/07/2013 17:28:08PM - IDE_MAIN is new 08/07/2013 17:28:08PM - IDE_MAIN is selected 08/07/2013 17:28:08PM - adding size 81 08/07/2013 17:28:08PM - binary = idebuildRepo.zip initial 08/07/2013 17:28:08PM - adding IDE_MAIN to JRE ECLIPSE ECLIPSECORE P2TOOLS MSVC80 MSVC2008 MSVC2012 INSTALLER DS CGT_DEFAULTLIBS_C6000 08/07/2013 17:28:08PM - writing ccs_config file: IDE_WORKFLOW 08/07/2013 17:28:08PM - ccs_config: searching for IDE_WORKFLOW in 08/07/2013 17:28:08PM - IDE_WORKFLOW is new 08/07/2013 17:28:08PM - IDE_WORKFLOW is selected 08/07/2013 17:28:08PM - adding size 81 08/07/2013 17:28:08PM - binary = idebuildRepo.zip initial 08/07/2013 17:28:08PM - adding IDE_WORKFLOW to JRE ECLIPSE ECLIPSECORE P2TOOLS MSVC80 MSVC2008 MSVC2012 INSTALLER DS CGT_DEFAULTLIBS_C6000 IDE_MAIN 08/07/2013 17:28:08PM - writing ccs_config file: IDE_ARM 08/07/2013 17:28:08PM - ccs_config: searching for IDE_ARM in 08/07/2013 17:28:08PM - IDE_ARM is new 08/07/2013 17:28:08PM - IDE_ARM is not selected 08/07/2013 17:28:08PM - binary = idebuildRepo.zip do not install 08/07/2013 17:28:08PM - writing ccs_config file: IDE_MSP430 08/07/2013 17:28:08PM - ccs_config: searching for IDE_MSP430 in 08/07/2013 17:28:08PM - IDE_MSP430 is new 08/07/2013 17:28:08PM - IDE_MSP430 is not selected 08/07/2013 17:28:08PM - binary = idebuildRepo.zip do not install 08/07/2013 17:28:08PM - writing ccs_config file: IDE_C2000 08/07/2013 17:28:08PM - ccs_config: searching for IDE_C2000 in 08/07/2013 17:28:08PM - IDE_C2000 is new 08/07/2013 17:28:08PM - IDE_C2000 is not selected 08/07/2013 17:28:08PM - binary = idebuildRepo.zip do not install 08/07/2013 17:28:08PM - writing ccs_config file: IDE_C5500 08/07/2013 17:28:08PM - ccs_config: searching for IDE_C5500 in 08/07/2013 17:28:08PM - IDE_C5500 is new 08/07/2013 17:28:08PM - IDE_C5500 is not selected 08/07/2013 17:28:08PM - binary = idebuildRepo.zip do not install 08/07/2013 17:28:08PM - writing ccs_config file: IDE_C6000 08/07/2013 17:28:08PM - ccs_config: searching for IDE_C6000 in 08/07/2013 17:28:08PM - IDE_C6000 is new 08/07/2013 17:28:08PM - IDE_C6000 is selected 08/07/2013 17:28:08PM - adding size 81 08/07/2013 17:28:08PM - binary = idebuildRepo.zip initial 08/07/2013 17:28:08PM - adding IDE_C6000 to JRE ECLIPSE ECLIPSECORE P2TOOLS MSVC80 MSVC2008 MSVC2012 INSTALLER DS CGT_DEFAULTLIBS_C6000 IDE_MAIN IDE_WORKFLOW 08/07/2013 17:28:08PM - writing ccs_config file: IDE_C5400 08/07/2013 17:28:08PM - ccs_config: searching for IDE_C5400 in 08/07/2013 17:28:08PM - IDE_C5400 is new 08/07/2013 17:28:08PM - IDE_C5400 is not selected 08/07/2013 17:28:08PM - binary = idebuildRepo.zip do not install 08/07/2013 17:28:08PM - writing ccs_config file: DVT_COMMON 08/07/2013 17:28:08PM - ccs_config: searching for DVT_COMMON in 08/07/2013 17:28:08PM - DVT_COMMON is new 08/07/2013 17:28:08PM - DVT_COMMON is selected 08/07/2013 17:28:08PM - adding size 35 08/07/2013 17:28:08PM - binary = dvtRepo.zip initial 08/07/2013 17:28:08PM - adding DVT_COMMON to JRE ECLIPSE ECLIPSECORE P2TOOLS MSVC80 MSVC2008 MSVC2012 INSTALLER DS CGT_DEFAULTLIBS_C6000 IDE_MAIN IDE_WORKFLOW IDE_C6000 08/07/2013 17:28:08PM - writing ccs_config file: DVT_TRACE 08/07/2013 17:28:08PM - ccs_config: searching for DVT_TRACE in 08/07/2013 17:28:08PM - DVT_TRACE is new 08/07/2013 17:28:08PM - DVT_TRACE is selected 08/07/2013 17:28:08PM - adding size 35 08/07/2013 17:28:08PM - binary = dvtRepo.zip initial 08/07/2013 17:28:08PM - adding DVT_TRACE to JRE ECLIPSE ECLIPSECORE P2TOOLS MSVC80 MSVC2008 MSVC2012 INSTALLER DS CGT_DEFAULTLIBS_C6000 IDE_MAIN IDE_WORKFLOW IDE_C6000 DVT_COMMON 08/07/2013 17:28:08PM - writing ccs_config file: DVT_VIA_CCS 08/07/2013 17:28:08PM - ccs_config: searching for DVT_VIA_CCS in 08/07/2013 17:28:08PM - DVT_VIA_CCS is new 08/07/2013 17:28:08PM - DVT_VIA_CCS is selected 08/07/2013 17:28:08PM - adding size 35 08/07/2013 17:28:08PM - binary = dvtRepo.zip initial 08/07/2013 17:28:08PM - adding DVT_VIA_CCS to JRE ECLIPSE ECLIPSECORE P2TOOLS MSVC80 MSVC2008 MSVC2012 INSTALLER DS CGT_DEFAULTLIBS_C6000 IDE_MAIN IDE_WORKFLOW IDE_C6000 DVT_COMMON DVT_TRACE 08/07/2013 17:28:08PM - writing ccs_config file: DVT_UIA 08/07/2013 17:28:08PM - ccs_config: searching for DVT_UIA in 08/07/2013 17:28:08PM - DVT_UIA is new 08/07/2013 17:28:08PM - DVT_UIA is selected 08/07/2013 17:28:08PM - adding size 35 08/07/2013 17:28:08PM - binary = dvtRepo.zip initial 08/07/2013 17:28:08PM - adding DVT_UIA to JRE ECLIPSE ECLIPSECORE P2TOOLS MSVC80 MSVC2008 MSVC2012 INSTALLER DS CGT_DEFAULTLIBS_C6000 IDE_MAIN IDE_WORKFLOW IDE_C6000 DVT_COMMON DVT_TRACE DVT_VIA_CCS 08/07/2013 17:28:08PM - writing ccs_config file: DVT_ENERGYTRACE 08/07/2013 17:28:08PM - ccs_config: searching for DVT_ENERGYTRACE in 08/07/2013 17:28:08PM - DVT_ENERGYTRACE is new 08/07/2013 17:28:08PM - DVT_ENERGYTRACE is not selected 08/07/2013 17:28:08PM - binary = dvtRepo.zip do not install 08/07/2013 17:28:08PM - writing ccs_config file: GMF 08/07/2013 17:28:08PM - ccs_config: searching for GMF in 08/07/2013 17:28:08PM - GMF is new 08/07/2013 17:28:08PM - GMF is selected 08/07/2013 17:28:08PM - adding size 11 08/07/2013 17:28:08PM - binary = gmfRepo.zip initial 08/07/2013 17:28:08PM - adding GMF to JRE ECLIPSE ECLIPSECORE P2TOOLS MSVC80 MSVC2008 MSVC2012 INSTALLER DS CGT_DEFAULTLIBS_C6000 IDE_MAIN IDE_WORKFLOW IDE_C6000 DVT_COMMON DVT_TRACE DVT_VIA_CCS DVT_UIA 08/07/2013 17:28:08PM - writing ccs_config file: TC_XDCTOOLS 08/07/2013 17:28:08PM - ccs_config: searching for TC_XDCTOOLS in 08/07/2013 17:28:08PM - TC_XDCTOOLS is new 08/07/2013 17:28:08PM - TC_XDCTOOLS is selected 08/07/2013 17:28:08PM - adding size 84 08/07/2013 17:28:08PM - binary = xdctools_3_25_00_48_base_windows.zip initial 08/07/2013 17:28:08PM - adding TC_XDCTOOLS to JRE ECLIPSE ECLIPSECORE P2TOOLS MSVC80 MSVC2008 MSVC2012 INSTALLER DS CGT_DEFAULTLIBS_C6000 IDE_MAIN IDE_WORKFLOW IDE_C6000 DVT_COMMON DVT_TRACE DVT_VIA_CCS DVT_UIA GMF 08/07/2013 17:28:08PM - writing ccs_config file: TC_ARM_XDCTOOLS 08/07/2013 17:28:08PM - ccs_config: searching for TC_ARM_XDCTOOLS in 08/07/2013 17:28:08PM - TC_ARM_XDCTOOLS is new 08/07/2013 17:28:08PM - TC_ARM_XDCTOOLS is not selected 08/07/2013 17:28:08PM - binary = xdctools_3_25_00_48_arm.zip do not install 08/07/2013 17:28:08PM - writing ccs_config file: TC_C2000_XDCTOOLS 08/07/2013 17:28:08PM - ccs_config: searching for TC_C2000_XDCTOOLS in 08/07/2013 17:28:08PM - TC_C2000_XDCTOOLS is new 08/07/2013 17:28:08PM - TC_C2000_XDCTOOLS is not selected 08/07/2013 17:28:08PM - binary = xdctools_3_25_00_48_c2000.zip do not install 08/07/2013 17:28:08PM - writing ccs_config file: TC_C6000_XDCTOOLS 08/07/2013 17:28:08PM - ccs_config: searching for TC_C6000_XDCTOOLS in 08/07/2013 17:28:08PM - TC_C6000_XDCTOOLS is new 08/07/2013 17:28:08PM - TC_C6000_XDCTOOLS is selected 08/07/2013 17:28:08PM - adding size 26 08/07/2013 17:28:08PM - binary = xdctools_3_25_00_48_c6000.zip initial 08/07/2013 17:28:08PM - adding TC_C6000_XDCTOOLS to JRE ECLIPSE ECLIPSECORE P2TOOLS MSVC80 MSVC2008 MSVC2012 INSTALLER DS CGT_DEFAULTLIBS_C6000 IDE_MAIN IDE_WORKFLOW IDE_C6000 DVT_COMMON DVT_TRACE DVT_VIA_CCS DVT_UIA GMF TC_XDCTOOLS 08/07/2013 17:28:08PM - writing ccs_config file: TC_MSP430_XDCTOOLS 08/07/2013 17:28:08PM - ccs_config: searching for TC_MSP430_XDCTOOLS in 08/07/2013 17:28:08PM - TC_MSP430_XDCTOOLS is new 08/07/2013 17:28:08PM - TC_MSP430_XDCTOOLS is not selected 08/07/2013 17:28:08PM - binary = xdctools_3_25_00_48_msp430.zip do not install 08/07/2013 17:28:08PM - writing ccs_config file: TC_BIOS5 08/07/2013 17:28:08PM - ccs_config: searching for TC_BIOS5 in 08/07/2013 17:28:08PM - TC_BIOS5 is new 08/07/2013 17:28:08PM - TC_BIOS5 is selected 08/07/2013 17:28:08PM - adding size 86 08/07/2013 17:28:08PM - binary = bios_setupwin32_5_42_01_09.exe initial 08/07/2013 17:28:08PM - adding TC_BIOS5 to JRE ECLIPSE ECLIPSECORE P2TOOLS MSVC80 MSVC2008 MSVC2012 INSTALLER DS CGT_DEFAULTLIBS_C6000 IDE_MAIN IDE_WORKFLOW IDE_C6000 DVT_COMMON DVT_TRACE DVT_VIA_CCS DVT_UIA GMF TC_XDCTOOLS TC_C6000_XDCTOOLS 08/07/2013 17:28:08PM - writing ccs_config file: TC_BIOS6 08/07/2013 17:28:08PM - ccs_config: searching for TC_BIOS6 in 08/07/2013 17:28:08PM - TC_BIOS6 is new 08/07/2013 17:28:08PM - TC_BIOS6 is selected 08/07/2013 17:28:08PM - adding size 22 08/07/2013 17:28:08PM - binary = bios_6_35_01_29_base.zip initial 08/07/2013 17:28:08PM - adding TC_BIOS6 to JRE ECLIPSE ECLIPSECORE P2TOOLS MSVC80 MSVC2008 MSVC2012 INSTALLER DS CGT_DEFAULTLIBS_C6000 IDE_MAIN IDE_WORKFLOW IDE_C6000 DVT_COMMON DVT_TRACE DVT_VIA_CCS DVT_UIA GMF TC_XDCTOOLS TC_C6000_XDCTOOLS TC_BIOS5 08/07/2013 17:28:08PM - writing ccs_config file: TC_ARM_BIOS6 08/07/2013 17:28:08PM - ccs_config: searching for TC_ARM_BIOS6 in 08/07/2013 17:28:08PM - TC_ARM_BIOS6 is new 08/07/2013 17:28:08PM - TC_ARM_BIOS6 is not selected 08/07/2013 17:28:08PM - binary = bios_6_35_01_29_arm.zip do not install 08/07/2013 17:28:08PM - writing ccs_config file: TC_C2000_BIOS6 08/07/2013 17:28:08PM - ccs_config: searching for TC_C2000_BIOS6 in 08/07/2013 17:28:08PM - TC_C2000_BIOS6 is new 08/07/2013 17:28:08PM - TC_C2000_BIOS6 is not selected 08/07/2013 17:28:08PM - binary = bios_6_35_01_29_c2000.zip do not install 08/07/2013 17:28:08PM - writing ccs_config file: TC_C6000_BIOS6 08/07/2013 17:28:08PM - ccs_config: searching for TC_C6000_BIOS6 in 08/07/2013 17:28:08PM - TC_C6000_BIOS6 is new 08/07/2013 17:28:08PM - TC_C6000_BIOS6 is selected 08/07/2013 17:28:08PM - adding size 13 08/07/2013 17:28:08PM - binary = bios_6_35_01_29_c6000.zip initial 08/07/2013 17:28:08PM - adding TC_C6000_BIOS6 to JRE ECLIPSE ECLIPSECORE P2TOOLS MSVC80 MSVC2008 MSVC2012 INSTALLER DS CGT_DEFAULTLIBS_C6000 IDE_MAIN IDE_WORKFLOW IDE_C6000 DVT_COMMON DVT_TRACE DVT_VIA_CCS DVT_UIA GMF TC_XDCTOOLS TC_C6000_XDCTOOLS TC_BIOS5 TC_BIOS6 08/07/2013 17:28:08PM - writing ccs_config file: TC_MSP430_BIOS6 08/07/2013 17:28:08PM - ccs_config: searching for TC_MSP430_BIOS6 in 08/07/2013 17:28:08PM - TC_MSP430_BIOS6 is new 08/07/2013 17:28:08PM - TC_MSP430_BIOS6 is not selected 08/07/2013 17:28:08PM - binary = bios_6_35_01_29_msp430.zip do not install 08/07/2013 17:28:08PM - writing ccs_config file: TC_XDAIS 08/07/2013 17:28:08PM - ccs_config: searching for TC_XDAIS in 08/07/2013 17:28:08PM - TC_XDAIS is new 08/07/2013 17:28:08PM - TC_XDAIS is selected 08/07/2013 17:28:08PM - adding size 8 08/07/2013 17:28:08PM - binary = xdais_7_21_01_07.zip initial 08/07/2013 17:28:08PM - adding TC_XDAIS to JRE ECLIPSE ECLIPSECORE P2TOOLS MSVC80 MSVC2008 MSVC2012 INSTALLER DS CGT_DEFAULTLIBS_C6000 IDE_MAIN IDE_WORKFLOW IDE_C6000 DVT_COMMON DVT_TRACE DVT_VIA_CCS DVT_UIA GMF TC_XDCTOOLS TC_C6000_XDCTOOLS TC_BIOS5 TC_BIOS6 TC_C6000_BIOS6 08/07/2013 17:28:08PM - writing ccs_config file: GRACE 08/07/2013 17:28:08PM - ccs_config: searching for GRACE in 08/07/2013 17:28:08PM - GRACE is new 08/07/2013 17:28:08PM - GRACE is not selected 08/07/2013 17:28:08PM - binary = grace_2_10_00_78.zip do not install 08/07/2013 17:28:08PM - writing ccs_config file: UIA 08/07/2013 17:28:08PM - ccs_config: searching for UIA in 08/07/2013 17:28:08PM - UIA is new 08/07/2013 17:28:08PM - UIA is selected 08/07/2013 17:28:08PM - adding size 22 08/07/2013 17:28:08PM - binary = uia_1_03_00_02.zip initial 08/07/2013 17:28:08PM - adding UIA to JRE ECLIPSE ECLIPSECORE P2TOOLS MSVC80 MSVC2008 MSVC2012 INSTALLER DS CGT_DEFAULTLIBS_C6000 IDE_MAIN IDE_WORKFLOW IDE_C6000 DVT_COMMON DVT_TRACE DVT_VIA_CCS DVT_UIA GMF TC_XDCTOOLS TC_C6000_XDCTOOLS TC_BIOS5 TC_BIOS6 TC_C6000_BIOS6 TC_XDAIS 08/07/2013 17:28:08PM - writing ccs_config file: MSP430ware 08/07/2013 17:28:08PM - ccs_config: searching for MSP430ware in 08/07/2013 17:28:08PM - MSP430ware is new 08/07/2013 17:28:08PM - MSP430ware is not selected 08/07/2013 17:28:08PM - binary = msp430ware_1_40_00_26.zip do not install 08/07/2013 17:28:08PM - writing ccs_config file: CCSINIT 08/07/2013 17:28:08PM - ccs_config: searching for CCSINIT in 08/07/2013 17:28:08PM - CCSINIT is new 08/07/2013 17:28:08PM - CCSINIT is selected 08/07/2013 17:28:08PM - adding size 1 08/07/2013 17:28:08PM - binary = ccsinit_setup_5.1.0.0.exe initial 08/07/2013 17:28:08PM - adding CCSINIT to JRE ECLIPSE ECLIPSECORE P2TOOLS MSVC80 MSVC2008 MSVC2012 INSTALLER DS CGT_DEFAULTLIBS_C6000 IDE_MAIN IDE_WORKFLOW IDE_C6000 DVT_COMMON DVT_TRACE DVT_VIA_CCS DVT_UIA GMF TC_XDCTOOLS TC_C6000_XDCTOOLS TC_BIOS5 TC_BIOS6 TC_C6000_BIOS6 TC_XDAIS UIA 08/07/2013 17:28:08PM - writing ccs_config file: SIM_TI 08/07/2013 17:28:08PM - ccs_config: searching for SIM_TI in 08/07/2013 17:28:08PM - SIM_TI is new 08/07/2013 17:28:08PM - SIM_TI is selected 08/07/2013 17:28:08PM - adding size 45 08/07/2013 17:28:08PM - binary = ti_simpack_setup_5.4.0.4.exe initial 08/07/2013 17:28:08PM - adding SIM_TI to JRE ECLIPSE ECLIPSECORE P2TOOLS MSVC80 MSVC2008 MSVC2012 INSTALLER DS CGT_DEFAULTLIBS_C6000 IDE_MAIN IDE_WORKFLOW IDE_C6000 DVT_COMMON DVT_TRACE DVT_VIA_CCS DVT_UIA GMF TC_XDCTOOLS TC_C6000_XDCTOOLS TC_BIOS5 TC_BIOS6 TC_C6000_BIOS6 TC_XDAIS UIA CCSINIT 08/07/2013 17:28:08PM - writing ccs_config file: EMU_BH 08/07/2013 17:28:08PM - ccs_config: searching for EMU_BH in 08/07/2013 17:28:08PM - EMU_BH is new 08/07/2013 17:28:08PM - EMU_BH is selected 08/07/2013 17:28:08PM - adding size 43 08/07/2013 17:28:08PM - binary = bh_emupack_setup_5.3.0.208.exe initial 08/07/2013 17:28:08PM - adding EMU_BH to JRE ECLIPSE ECLIPSECORE P2TOOLS MSVC80 MSVC2008 MSVC2012 INSTALLER DS CGT_DEFAULTLIBS_C6000 IDE_MAIN IDE_WORKFLOW IDE_C6000 DVT_COMMON DVT_TRACE DVT_VIA_CCS DVT_UIA GMF TC_XDCTOOLS TC_C6000_XDCTOOLS TC_BIOS5 TC_BIOS6 TC_C6000_BIOS6 TC_XDAIS UIA CCSINIT SIM_TI 08/07/2013 17:28:08PM - writing ccs_config file: EMU_TI 08/07/2013 17:28:08PM - XDS100_Class_Emulator_Support selected 08/07/2013 17:28:08PM - ccs_config: searching for EMU_TI in 08/07/2013 17:28:08PM - EMU_TI is new 08/07/2013 17:28:08PM - EMU_TI is selected 08/07/2013 17:28:08PM - adding size 34 08/07/2013 17:28:08PM - binary = ti_emupack_setup_5.1.73.0.exe initial 08/07/2013 17:28:08PM - adding EMU_TI to JRE ECLIPSE ECLIPSECORE P2TOOLS MSVC80 MSVC2008 MSVC2012 INSTALLER DS CGT_DEFAULTLIBS_C6000 IDE_MAIN IDE_WORKFLOW IDE_C6000 DVT_COMMON DVT_TRACE DVT_VIA_CCS DVT_UIA GMF TC_XDCTOOLS TC_C6000_XDCTOOLS TC_BIOS5 TC_BIOS6 TC_C6000_BIOS6 TC_XDAIS UIA CCSINIT SIM_TI EMU_BH 08/07/2013 17:28:08PM - writing ccs_config file: EMU_STELLARIS 08/07/2013 17:28:08PM - ccs_config: searching for EMU_STELLARIS in 08/07/2013 17:28:08PM - EMU_STELLARIS is new 08/07/2013 17:28:08PM - EMU_STELLARIS is not selected 08/07/2013 17:28:08PM - binary = ti_stellaris_setup-10114.exe do not install 08/07/2013 17:28:08PM - writing ccs_config file: EMU_HERCULES 08/07/2013 17:28:08PM - IB installer for EMU_HERCULES 08/07/2013 17:28:08PM - ccs_config: searching for EMU_HERCULES in 08/07/2013 17:28:08PM - EMU_HERCULES is new 08/07/2013 17:28:08PM - EMU_HERCULES is not selected 08/07/2013 17:28:08PM - binary = ti_hercules_setup_5.4.0.3.exe do not install 08/07/2013 17:28:08PM - writing ccs_config file: EMU_SD 08/07/2013 17:28:08PM - ccs_config: searching for EMU_SD in 08/07/2013 17:28:08PM - EMU_SD is new 08/07/2013 17:28:08PM - EMU_SD is selected 08/07/2013 17:28:08PM - adding size 26 08/07/2013 17:28:08PM - binary = sd_emupack_setup_5.2.0.07.exe initial 08/07/2013 17:28:08PM - adding EMU_SD to JRE ECLIPSE ECLIPSECORE P2TOOLS MSVC80 MSVC2008 MSVC2012 INSTALLER DS CGT_DEFAULTLIBS_C6000 IDE_MAIN IDE_WORKFLOW IDE_C6000 DVT_COMMON DVT_TRACE DVT_VIA_CCS DVT_UIA GMF TC_XDCTOOLS TC_C6000_XDCTOOLS TC_BIOS5 TC_BIOS6 TC_C6000_BIOS6 TC_XDAIS UIA CCSINIT SIM_TI EMU_BH EMU_TI EMU_TI_XDS100 08/07/2013 17:28:08PM - writing ccs_config file: EMU_C2000 08/07/2013 17:28:08PM - ccs_config: searching for EMU_C2000 in 08/07/2013 17:28:08PM - EMU_C2000 is new 08/07/2013 17:28:08PM - EMU_C2000 is not selected 08/07/2013 17:28:08PM - binary = ti_c2000support_setup_4.1.0.3.exe do not install 08/07/2013 17:28:08PM - writing ccs_config file: EMU_C2000_FLASH 08/07/2013 17:28:08PM - ccs_config: searching for EMU_C2000_FLASH in 08/07/2013 17:28:08PM - EMU_C2000_FLASH is new 08/07/2013 17:28:08PM - EMU_C2000_FLASH is not selected 08/07/2013 17:28:08PM - binary = ti_c2000_flash_setup_1.0.0.2.exe do not install 08/07/2013 17:28:08PM - writing ccs_config file: EMU_MSP430 08/07/2013 17:28:08PM - ccs_config: searching for EMU_MSP430 in 08/07/2013 17:28:08PM - EMU_MSP430 is new 08/07/2013 17:28:08PM - EMU_MSP430 is not selected 08/07/2013 17:28:08PM - binary = ti_msp430pack_setup_5.4.0.5.exe do not install 08/07/2013 17:28:08PM - writing ccs_config file: KEYSTONE1 08/07/2013 17:28:08PM - ccs_config: searching for KEYSTONE1 in 08/07/2013 17:28:08PM - KEYSTONE1 is new 08/07/2013 17:28:08PM - KEYSTONE1 is selected 08/07/2013 17:28:08PM - adding size 1 08/07/2013 17:28:08PM - binary = ti_emupack_keystone1_setup_1.0.6.0.exe initial 08/07/2013 17:28:08PM - adding KEYSTONE1 to JRE ECLIPSE ECLIPSECORE P2TOOLS MSVC80 MSVC2008 MSVC2012 INSTALLER DS CGT_DEFAULTLIBS_C6000 IDE_MAIN IDE_WORKFLOW IDE_C6000 DVT_COMMON DVT_TRACE DVT_VIA_CCS DVT_UIA GMF TC_XDCTOOLS TC_C6000_XDCTOOLS TC_BIOS5 TC_BIOS6 TC_C6000_BIOS6 TC_XDAIS UIA CCSINIT SIM_TI EMU_BH EMU_TI EMU_TI_XDS100 EMU_SD 08/07/2013 17:28:08PM - writing ccs_config file: KEYSTONE2 08/07/2013 17:28:08PM - ccs_config: searching for KEYSTONE2 in 08/07/2013 17:28:08PM - KEYSTONE2 is new 08/07/2013 17:28:08PM - KEYSTONE2 is selected 08/07/2013 17:28:08PM - adding size 1 08/07/2013 17:28:08PM - binary = ti_emupack_keystone2_setup_1.0.0.3.exe initial 08/07/2013 17:28:08PM - adding KEYSTONE2 to JRE ECLIPSE ECLIPSECORE P2TOOLS MSVC80 MSVC2008 MSVC2012 INSTALLER DS CGT_DEFAULTLIBS_C6000 IDE_MAIN IDE_WORKFLOW IDE_C6000 DVT_COMMON DVT_TRACE DVT_VIA_CCS DVT_UIA GMF TC_XDCTOOLS TC_C6000_XDCTOOLS TC_BIOS5 TC_BIOS6 TC_C6000_BIOS6 TC_XDAIS UIA CCSINIT SIM_TI EMU_BH EMU_TI EMU_TI_XDS100 EMU_SD KEYSTONE1 08/07/2013 17:28:08PM - writing ccs_config file: DMED 08/07/2013 17:28:08PM - ccs_config: searching for DMED in 08/07/2013 17:28:08PM - DMED is new 08/07/2013 17:28:08PM - DMED is selected 08/07/2013 17:28:08PM - adding size 1 08/07/2013 17:28:08PM - binary = ti_cgt_dmed_setup_1.1.2.0.exe initial 08/07/2013 17:28:08PM - adding DMED to JRE ECLIPSE ECLIPSECORE P2TOOLS MSVC80 MSVC2008 MSVC2012 INSTALLER DS CGT_DEFAULTLIBS_C6000 IDE_MAIN IDE_WORKFLOW IDE_C6000 DVT_COMMON DVT_TRACE DVT_VIA_CCS DVT_UIA GMF TC_XDCTOOLS TC_C6000_XDCTOOLS TC_BIOS5 TC_BIOS6 TC_C6000_BIOS6 TC_XDAIS UIA CCSINIT SIM_TI EMU_BH EMU_TI EMU_TI_XDS100 EMU_SD KEYSTONE1 KEYSTONE2 08/07/2013 17:28:08PM - writing ccs_config file: MSP430_CGT_HELP 08/07/2013 17:28:08PM - ccs_config: searching for MSP430_CGT_HELP in 08/07/2013 17:28:08PM - MSP430_CGT_HELP is new 08/07/2013 17:28:08PM - MSP430_CGT_HELP is not selected 08/07/2013 17:28:08PM - binary = msp430helprepo.zip do not install 08/07/2013 17:28:08PM - writing ccs_config file: C6000_CGT_HELP 08/07/2013 17:28:08PM - ccs_config: searching for C6000_CGT_HELP in 08/07/2013 17:28:08PM - C6000_CGT_HELP is new 08/07/2013 17:28:08PM - C6000_CGT_HELP is selected 08/07/2013 17:28:08PM - adding size 3 08/07/2013 17:28:08PM - binary = c6000helprepo.zip initial 08/07/2013 17:28:08PM - adding C6000_CGT_HELP to JRE ECLIPSE ECLIPSECORE P2TOOLS MSVC80 MSVC2008 MSVC2012 INSTALLER DS CGT_DEFAULTLIBS_C6000 IDE_MAIN IDE_WORKFLOW IDE_C6000 DVT_COMMON DVT_TRACE DVT_VIA_CCS DVT_UIA GMF TC_XDCTOOLS TC_C6000_XDCTOOLS TC_BIOS5 TC_BIOS6 TC_C6000_BIOS6 TC_XDAIS UIA CCSINIT SIM_TI EMU_BH EMU_TI EMU_TI_XDS100 EMU_SD KEYSTONE1 KEYSTONE2 DMED 08/07/2013 17:28:08PM - writing ccs_config file: ARM_CGT_HELP 08/07/2013 17:28:08PM - ccs_config: searching for ARM_CGT_HELP in 08/07/2013 17:28:08PM - ARM_CGT_HELP is new 08/07/2013 17:28:08PM - ARM_CGT_HELP is not selected 08/07/2013 17:28:08PM - binary = armhelprepo.zip do not install 08/07/2013 17:28:08PM - writing ccs_config file: C2000_CGT_HELP 08/07/2013 17:28:08PM - ccs_config: searching for C2000_CGT_HELP in 08/07/2013 17:28:08PM - C2000_CGT_HELP is new 08/07/2013 17:28:08PM - C2000_CGT_HELP is not selected 08/07/2013 17:28:08PM - binary = c2000helprepo.zip do not install 08/07/2013 17:28:08PM - writing ccs_config file: C5500_CGT_HELP 08/07/2013 17:28:08PM - ccs_config: searching for C5500_CGT_HELP in 08/07/2013 17:28:08PM - C5500_CGT_HELP is new 08/07/2013 17:28:08PM - C5500_CGT_HELP is not selected 08/07/2013 17:28:08PM - binary = c5500helprepo.zip do not install 08/07/2013 17:28:08PM - writing ccs_config file: DEV_SUPPORT_SHARED 08/07/2013 17:28:08PM - ccs_config: searching for DEV_SUPPORT_SHARED in 08/07/2013 17:28:08PM - DEV_SUPPORT_SHARED is new 08/07/2013 17:28:08PM - DEV_SUPPORT_SHARED is selected 08/07/2013 17:28:08PM - adding size 3 08/07/2013 17:28:08PM - binary = shared_device_support_1.0.6.zip initial 08/07/2013 17:28:08PM - adding DEV_SUPPORT_SHARED to JRE ECLIPSE ECLIPSECORE P2TOOLS MSVC80 MSVC2008 MSVC2012 INSTALLER DS CGT_DEFAULTLIBS_C6000 IDE_MAIN IDE_WORKFLOW IDE_C6000 DVT_COMMON DVT_TRACE DVT_VIA_CCS DVT_UIA GMF TC_XDCTOOLS TC_C6000_XDCTOOLS TC_BIOS5 TC_BIOS6 TC_C6000_BIOS6 TC_XDAIS UIA CCSINIT SIM_TI EMU_BH EMU_TI EMU_TI_XDS100 EMU_SD KEYSTONE1 KEYSTONE2 DMED C6000_CGT_HELP 08/07/2013 17:28:08PM - writing ccs_config file: DEV_SUPPORT_SITARA 08/07/2013 17:28:08PM - ccs_config: searching for DEV_SUPPORT_SITARA in 08/07/2013 17:28:08PM - DEV_SUPPORT_SITARA is new 08/07/2013 17:28:08PM - DEV_SUPPORT_SITARA is not selected 08/07/2013 17:28:08PM - binary = sitara_device_support_1.1.4.zip do not install 08/07/2013 17:28:08PM - writing ccs_config file: DEV_SUPPORT_C55XX 08/07/2013 17:28:08PM - ccs_config: searching for DEV_SUPPORT_C55XX in 08/07/2013 17:28:08PM - DEV_SUPPORT_C55XX is new 08/07/2013 17:28:08PM - DEV_SUPPORT_C55XX is not selected 08/07/2013 17:28:08PM - binary = c55xx_device_support_1.0.9.zip do not install 08/07/2013 17:28:08PM - writing ccs_config file: DEV_SUPPORT_C54XX 08/07/2013 17:28:08PM - ccs_config: searching for DEV_SUPPORT_C54XX in 08/07/2013 17:28:08PM - DEV_SUPPORT_C54XX is new 08/07/2013 17:28:08PM - DEV_SUPPORT_C54XX is not selected 08/07/2013 17:28:08PM - binary = c54xx_device_support_1.0.3.zip do not install 08/07/2013 17:28:08PM - writing ccs_config file: DEV_SUPPORT_C6000 08/07/2013 17:28:08PM - ccs_config: searching for DEV_SUPPORT_C6000 in 08/07/2013 17:28:08PM - DEV_SUPPORT_C6000 is new 08/07/2013 17:28:08PM - DEV_SUPPORT_C6000 is not selected 08/07/2013 17:28:08PM - binary = c6000_device_support_1.0.8.zip do not install 08/07/2013 17:28:08PM - writing ccs_config file: DEV_SUPPORT_C6000MC 08/07/2013 17:28:08PM - ccs_config: searching for DEV_SUPPORT_C6000MC in 08/07/2013 17:28:08PM - DEV_SUPPORT_C6000MC is new 08/07/2013 17:28:08PM - DEV_SUPPORT_C6000MC is selected 08/07/2013 17:28:08PM - adding size 0 08/07/2013 17:28:08PM - binary = c6000multicore_device_support_1.0.4.zip initial 08/07/2013 17:28:08PM - adding DEV_SUPPORT_C6000MC to JRE ECLIPSE ECLIPSECORE P2TOOLS MSVC80 MSVC2008 MSVC2012 INSTALLER DS CGT_DEFAULTLIBS_C6000 IDE_MAIN IDE_WORKFLOW IDE_C6000 DVT_COMMON DVT_TRACE DVT_VIA_CCS DVT_UIA GMF TC_XDCTOOLS TC_C6000_XDCTOOLS TC_BIOS5 TC_BIOS6 TC_C6000_BIOS6 TC_XDAIS UIA CCSINIT SIM_TI EMU_BH EMU_TI EMU_TI_XDS100 EMU_SD KEYSTONE1 KEYSTONE2 DMED C6000_CGT_HELP DEV_SUPPORT_SHARED 08/07/2013 17:28:08PM - writing ccs_config file: DEV_SUPPORT_DAVINCI 08/07/2013 17:28:08PM - ccs_config: searching for DEV_SUPPORT_DAVINCI in 08/07/2013 17:28:08PM - DEV_SUPPORT_DAVINCI is new 08/07/2013 17:28:08PM - DEV_SUPPORT_DAVINCI is not selected 08/07/2013 17:28:08PM - binary = davinci_device_support_1.1.1.zip do not install 08/07/2013 17:28:08PM - writing ccs_config file: DEV_SUPPORT_INTEGRA 08/07/2013 17:28:08PM - ccs_config: searching for DEV_SUPPORT_INTEGRA in 08/07/2013 17:28:08PM - DEV_SUPPORT_INTEGRA is new 08/07/2013 17:28:08PM - DEV_SUPPORT_INTEGRA is not selected 08/07/2013 17:28:08PM - binary = integra_device_support_1.0.7.zip do not install 08/07/2013 17:28:08PM - writing ccs_config file: DEV_SUPPORT_OMAP 08/07/2013 17:28:08PM - ccs_config: searching for DEV_SUPPORT_OMAP in 08/07/2013 17:28:08PM - DEV_SUPPORT_OMAP is new 08/07/2013 17:28:08PM - DEV_SUPPORT_OMAP is not selected 08/07/2013 17:28:08PM - binary = omap_device_support_1.0.6.zip do not install 08/07/2013 17:28:08PM - writing ccs_config file: DEV_SUPPORT_CC2538 08/07/2013 17:28:08PM - ccs_config: searching for DEV_SUPPORT_CC2538 in 08/07/2013 17:28:08PM - DEV_SUPPORT_CC2538 is new 08/07/2013 17:28:08PM - DEV_SUPPORT_CC2538 is not selected 08/07/2013 17:28:08PM - binary = cc2538_device_support_1.1.1.0.zip do not install 08/07/2013 17:28:08PM - writing ccs_config file: XULRUNNER 08/07/2013 17:28:08PM - ccs_config: searching for XULRUNNER in 08/07/2013 17:28:08PM - XULRUNNER is new 08/07/2013 17:28:08PM - XULRUNNER is selected 08/07/2013 17:28:08PM - adding size 15 08/07/2013 17:28:08PM - binary = xulrunner_10.4.0.zip initial 08/07/2013 17:28:08PM - adding XULRUNNER to JRE ECLIPSE ECLIPSECORE P2TOOLS MSVC80 MSVC2008 MSVC2012 INSTALLER DS CGT_DEFAULTLIBS_C6000 IDE_MAIN IDE_WORKFLOW IDE_C6000 DVT_COMMON DVT_TRACE DVT_VIA_CCS DVT_UIA GMF TC_XDCTOOLS TC_C6000_XDCTOOLS TC_BIOS5 TC_BIOS6 TC_C6000_BIOS6 TC_XDAIS UIA CCSINIT SIM_TI EMU_BH EMU_TI EMU_TI_XDS100 EMU_SD KEYSTONE1 KEYSTONE2 DMED C6000_CGT_HELP DEV_SUPPORT_SHARED DEV_SUPPORT_C6000MC 08/07/2013 17:28:08PM - writing ccs_config file: GCC_ARM_COMPILER 08/07/2013 17:28:08PM - ccs_config: searching for GCC_ARM_COMPILER in 08/07/2013 17:28:08PM - GCC_ARM_COMPILER is new 08/07/2013 17:28:08PM - GCC_ARM_COMPILER is not selected 08/07/2013 17:28:08PM - binary = gcc_arm_win32_4.7.2012.12.zip do not install 08/07/2013 17:28:08PM - writing ccs_config file: TIVA_TM4C 08/07/2013 17:28:08PM - ccs_config: searching for TIVA_TM4C in 08/07/2013 17:28:08PM - TIVA_TM4C is new 08/07/2013 17:28:08PM - TIVA_TM4C is not selected 08/07/2013 17:28:08PM - binary = ti_tiva_tm4c_setup-10691.exe do not install 08/07/2013 17:28:08PM - writing ccs_config file: TIVA_TM4E 08/07/2013 17:28:08PM - ccs_config: searching for TIVA_TM4E in 08/07/2013 17:28:08PM - TIVA_TM4E is new 08/07/2013 17:28:08PM - TIVA_TM4E is not selected 08/07/2013 17:28:08PM - binary = ti_tiva_tm4e_setup-10691.exe do not install 08/07/2013 17:28:08PM - components verified: JRE ECLIPSE ECLIPSECORE P2TOOLS MSVC80 MSVC2008 MSVC2012 INSTALLER DS CGT_DEFAULTLIBS_C2800 CGT_DEFAULTLIBS_C5400 CGT_DEFAULTLIBS_C5500 CGT_DEFAULTLIBS_C6000 CGT_DEFAULTLIBS_MSP430 CGT_DEFAULTLIBS_TMS470 IDE_MAIN IDE_WORKFLOW IDE_ARM IDE_MSP430 IDE_C2000 IDE_C5500 IDE_C6000 IDE_C5400 DVT_COMMON DVT_TRACE DVT_VIA_CCS DVT_UIA DVT_ENERGYTRACE GMF TC_XDCTOOLS TC_XDCTOOLS_BIOS5 TC_ARM_XDCTOOLS TC_C2000_XDCTOOLS TC_C6000_XDCTOOLS TC_MSP430_XDCTOOLS TC_BIOS5 TC_BIOS6 TC_ARM_BIOS6 TC_C2000_BIOS6 TC_C6000_BIOS6 TC_MSP430_BIOS6 TC_XDAIS TC_XDAIS_BIOS5 GRACE UIA MSP430ware CCSINIT SIM_TI EMU_BH EMU_TI EMU_STELLARIS EMU_HERCULES EMU_SD EMU_C2000 EMU_C2000_FLASH EMU_MSP430 KEYSTONE1 KEYSTONE2 DMED MSP430_CGT_HELP C6000_CGT_HELP ARM_CGT_HELP C2000_CGT_HELP C5500_CGT_HELP DEV_SUPPORT_SHARED DEV_SUPPORT_SITARA DEV_SUPPORT_C55XX DEV_SUPPORT_C54XX DEV_SUPPORT_C6000 DEV_SUPPORT_C6000MC DEV_SUPPORT_DAVINCI DEV_SUPPORT_INTEGRA DEV_SUPPORT_OMAP DEV_SUPPORT_CC2538 XULRUNNER GCC_ARM_COMPILER TIVA_TM4C TIVA_TM4E 08/07/2013 17:28:08PM - adding feature list: JRE ECLIPSE ECLIPSECORE P2TOOLS MSVC80 MSVC2008 MSVC2012 INSTALLER DS CGT_DEFAULTLIBS_C6000 IDE_MAIN IDE_WORKFLOW IDE_C6000 DVT_COMMON DVT_TRACE DVT_VIA_CCS DVT_UIA GMF TC_XDCTOOLS TC_C6000_XDCTOOLS TC_BIOS5 TC_BIOS6 TC_C6000_BIOS6 TC_XDAIS UIA CCSINIT SIM_TI EMU_BH EMU_TI EMU_TI_XDS100 EMU_SD KEYSTONE1 KEYSTONE2 DMED C6000_CGT_HELP DEV_SUPPORT_SHARED DEV_SUPPORT_C6000MC XULRUNNER 08/07/2013 17:28:08PM - adding Product families: 08/07/2013 17:28:08PM - adding product C6000 Multi Core DSPs 08/07/2013 17:28:08PM - 08/07/2013 17:28:08PM - Checking conditions for 920548CF-519B-4AC3-8734-4B1B10EF9DB9 - - Before Action is Executed 08/07/2013 17:28:08PM - Checking condition 206CCE8C-6C57-40EA-9BA0-1675D26C3A71 - String Equal Condition 08/07/2013 17:28:08PM - Checking to see if <%ReRun%> equals 1 08/07/2013 17:28:08PM - ** Checking to see if 0 equals 1 08/07/2013 17:28:08PM - Condition failed 08/07/2013 17:28:08PM - Checking condition 286E5B0F-3F90-4793-AFB5-1B707A54A004 - String Is Condition 08/07/2013 17:28:08PM - Checking to see if <%ReRun%> is true 08/07/2013 17:28:08PM - ** Checking to see if 0 is true 08/07/2013 17:28:08PM - Condition failed 08/07/2013 17:28:08PM - Skipping action 920548CF-519B-4AC3-8734-4B1B10EF9DB9 - Set UpdateMode (when ReRun) - conditions failed 08/07/2013 17:28:08PM - Executing action D00567AE-1434-413D-BBF9-B3F78DF98BF1 - Copy ccs_config.xml to logs 08/07/2013 17:28:09PM - Executing action F5F4E6DF-AFC2-48DD-A525-BDAB727CEC7A - Execute CCSExternalReferences Action 08/07/2013 17:28:09PM - Executing actions C7F8AE2D-4F72-4319-B4C3-CF1603BB148D - CCSExternalReferences Action 08/07/2013 17:28:09PM - Checking conditions for DD6015AF-17F4-4949-9688-1198E22040F4 - - Before Action is Executed 08/07/2013 17:28:09PM - Checking condition 21BB6A65-EF62-4E0D-907A-BF0C9EA94CFD - String Is Condition 08/07/2013 17:28:09PM - Checking to see if <%ComponentInstaller%> is false 08/07/2013 17:28:09PM - ** Checking to see if false is false 08/07/2013 17:28:09PM - Condition passed 08/07/2013 17:28:09PM - Executing action DD6015AF-17F4-4949-9688-1198E22040F4 - Write CCSExternalReferences 08/07/2013 17:28:09PM - Executing action EFFD310B-8A6E-49ED-9BBF-DB3EB1CED639 - Set msp430ware values 08/07/2013 17:28:09PM - Checking conditions for 83C5A9F1-B42C-43BC-BD3F-6F09F561DA64 - - Before Action is Executed 08/07/2013 17:28:09PM - Checking condition 6FA5C6EA-EF06-4F77-BB01-282BA316028B - String Is Condition 08/07/2013 17:28:09PM - Checking to see if <%runmsp430ware%> is true 08/07/2013 17:28:09PM - ** Checking to see if false is true 08/07/2013 17:28:09PM - Condition failed 08/07/2013 17:28:09PM - Skipping action 83C5A9F1-B42C-43BC-BD3F-6F09F561DA64 - Write CCSExternalReferences (msp430ware) - conditions failed 08/07/2013 17:28:09PM - Checking conditions for 0777D128-A512-4F4A-A669-176168D66D63 - - Before Action is Executed 08/07/2013 17:28:09PM - Checking condition 479F880B-F398-4881-9325-6D9EFCAE6FD1 - Execute Script Condition 08/07/2013 17:28:09PM - Condition passed 08/07/2013 17:28:09PM - Executing action 0777D128-A512-4F4A-A669-176168D66D63 - XCopy CCSExternalReferences 08/07/2013 17:28:09PM - USERPROFILE = C:Usersasus 08/07/2013 17:28:09PM - USERPROFILE = C:Usersasus 08/07/2013 17:28:09PM - userprofile is not a junction 08/07/2013 17:28:09PM - Checking conditions for 1C99078C-C159-4C77-BE06-97B942144836 - - Before Action is Executed 08/07/2013 17:28:09PM - Checking condition 47ECC960-3F3F-4749-9320-1946A3F9CBEB - String Is Condition 08/07/2013 17:28:09PM - Checking to see if <%ComponentInstaller%> is false 08/07/2013 17:28:09PM - ** Checking to see if false is false 08/07/2013 17:28:09PM - Condition passed 08/07/2013 17:28:09PM - Executing action 1C99078C-C159-4C77-BE06-97B942144836 - Write ccs.properties 08/07/2013 17:28:09PM - Checking conditions for E199035E-3D19-49EE-8EA4-03DB8ED790DC - - Before Action is Executed 08/07/2013 17:28:09PM - Checking condition 1812B83A-DC51-4100-A3BC-B96979C230E0 - String Is Condition 08/07/2013 17:28:09PM - Checking to see if <%GuiMode%> is true 08/07/2013 17:28:09PM - ** Checking to see if 1 is true 08/07/2013 17:28:09PM - Condition passed 08/07/2013 17:28:09PM - Executing action E199035E-3D19-49EE-8EA4-03DB8ED790DC - Modify Widget 08/07/2013 17:28:09PM - Executing action 8FBEA532-434F-44FD-A478-7B798F8433E6 - Create eclipse downloads folder 08/07/2013 17:28:09PM - Executing action 81192717-8672-4A65-901A-696A7182AFBF - Install Components 08/07/2013 17:28:09PM - Start installing components: 08/07/2013 17:28:09PM - F:/download/CCS5.4.0.00091_win32 08/07/2013 17:28:09PM - percentage 2 08/07/2013 17:28:09PM - percent now 2 08/07/2013 17:28:09PM - unzip = C:/Users/asus/AppData/Local/Temp/ijtmp_EDACDD11-B33D-4D43-806D-6BD0DBD8D818/unzip.exe 08/07/2013 17:28:09PM - found C:/ti/ccsv5/eclipse/ccs_config.xml 08/07/2013 17:28:09PM - in install components 08/07/2013 17:28:09PM - checking utils.zip 08/07/2013 17:28:09PM - percent now 2 08/07/2013 17:28:09PM - making C:/ti/ccsv5 2 08/07/2013 17:28:09PM - cmd = "C:/Users/asus/AppData/Local/Temp/ijtmp_EDACDD11-B33D-4D43-806D-6BD0DBD8D818/unzip.exe" -q -o -d "C:/ti/ccsv5" "F:/download/CCS5.4.0.00091_win32/baserepo/utils.zip" 08/07/2013 17:28:11PM - successfully unzipped utils.zip 08/07/2013 17:28:11PM - percent now 2 08/07/2013 17:28:11PM - checking doc.zip 08/07/2013 17:28:11PM - percent now 2 08/07/2013 17:28:12PM - making C:/ti/ccsv5 2 08/07/2013 17:28:12PM - cmd = "C:/Users/asus/AppData/Local/Temp/ijtmp_EDACDD11-B33D-4D43-806D-6BD0DBD8D818/unzip.exe" -q -o -d "C:/ti/ccsv5" "F:/download/CCS5.4.0.00091_win32/baserepo/doc.zip" 08/07/2013 17:28:15PM - successfully unzipped doc.zip 08/07/2013 17:28:15PM - percent now 2 08/07/2013 17:28:15PM - checking rxtx_jre.zip 08/07/2013 17:28:15PM - percent now 2 08/07/2013 17:28:15PM - making C:/ti/ccsv5/eclipse 2 08/07/2013 17:28:15PM - cmd = "C:/Users/asus/AppData/Local/Temp/ijtmp_EDACDD11-B33D-4D43-806D-6BD0DBD8D818/unzip.exe" -q -o -d "C:/ti/ccsv5/eclipse" "F:/download/CCS5.4.0.00091_win32/baserepo/rxtx_jre.zip" 08/07/2013 17:28:15PM - successfully unzipped rxtx_jre.zip 08/07/2013 17:28:16PM - percent now 2 08/07/2013 17:28:16PM - checking ccstudiobin.zip 08/07/2013 17:28:16PM - percent now 2 08/07/2013 17:28:16PM - making C:/Users/asus/AppData/Local/Temp/ijtmp_EDACDD11-B33D-4D43-806D-6BD0DBD8D818 2 08/07/2013 17:28:16PM - cmd = "C:/Users/asus/AppData/Local/Temp/ijtmp_EDACDD11-B33D-4D43-806D-6BD0DBD8D818/unzip.exe" -q -o -d "C:/Users/asus/AppData/Local/Temp/ijtmp_EDACDD11-B33D-4D43-806D-6BD0DBD8D818" "F:/download/CCS5.4.0.00091_win32/baserepo/ccstudiobin.zip" 08/07/2013 17:28:17PM - successfully unzipped ccstudiobin.zip 08/07/2013 17:28:17PM - percent now 2 08/07/2013 17:28:17PM - making C:/ti/ccsv5/install_logs 08/07/2013 17:28:17PM - MSVC80 checked out ok! 08/07/2013 17:28:17PM - MSVC2008 checked out ok! 08/07/2013 17:28:17PM - check_for_failures MSVC2012 "Microsoft Visual C++ 2012 Redistributable Package (x86)" do not install 08/07/2013 17:28:17PM - MSVC2012 checked out ok! 08/07/2013 17:28:17PM - installing JRE in C:/ti/ccsv5/eclipse 08/07/2013 17:28:17PM - from F:/download/CCS5.4.0.00091_win32/baserepo 08/07/2013 17:28:17PM - percent now 2 08/07/2013 17:28:17PM - 1 - 31364806 08/07/2013 17:28:17PM - making C:/ti/ccsv5/eclipse 3 08/07/2013 17:28:17PM - cmd = "C:/Users/asus/AppData/Local/Temp/ijtmp_EDACDD11-B33D-4D43-806D-6BD0DBD8D818/unzip.exe" -q -o -d "C:/ti/ccsv5/eclipse" "F:/download/CCS5.4.0.00091_win32/baserepo/jre_1.6.0_13.zip" 08/07/2013 17:28:43PM - successfully unzipped jre_1.6.0_13.zip 08/07/2013 17:28:43PM - percent now 2 08/07/2013 17:28:43PM - JRE checked out ok! 08/07/2013 17:28:43PM - installing UNIFLASH in C:/ti/ccsv5 08/07/2013 17:28:43PM - component UNIFLASH doesn't exist 08/07/2013 17:28:43PM - UNIFLASH checked out ok! 08/07/2013 17:28:43PM - installing ECLIPSECORE in C:/Users/asus/AppData/Local/Temp/ijtmp_EDACDD11-B33D-4D43-806D-6BD0DBD8D818 08/07/2013 17:28:43PM - from F:/download/CCS5.4.0.00091_win32/baserepo 08/07/2013 17:28:43PM - percent now 2 08/07/2013 17:28:44PM - 1 - 52897237 08/07/2013 17:28:44PM - making C:/Users/asus/AppData/Local/Temp/ijtmp_EDACDD11-B33D-4D43-806D-6BD0DBD8D818 3 08/07/2013 17:28:44PM - cmd = "C:/Users/asus/AppData/Local/Temp/ijtmp_EDACDD11-B33D-4D43-806D-6BD0DBD8D818/unzip.exe" -q -o -d "C:/Users/asus/AppData/Local/Temp/ijtmp_EDACDD11-B33D-4D43-806D-6BD0DBD8D818" "F:/download/CCS5.4.0.00091_win32/baserepo/eclipse_core_3.7.2.zip" 08/07/2013 17:28:49PM - successfully unzipped eclipse_core_3.7.2.zip 08/07/2013 17:28:49PM - percent now 2 08/07/2013 17:28:49PM - ECLIPSECORE checked out ok! 08/07/2013 17:28:49PM - installing ECLIPSE in C:/Users/asus/AppData/Local/Temp/ijtmp_EDACDD11-B33D-4D43-806D-6BD0DBD8D818/baserepo 08/07/2013 17:28:49PM - from F:/download/CCS5.4.0.00091_win32/baserepo 08/07/2013 17:28:49PM - percent now 2 08/07/2013 17:28:49PM - 1 - 91990247 08/07/2013 17:28:49PM - making C:/Users/asus/AppData/Local/Temp/ijtmp_EDACDD11-B33D-4D43-806D-6BD0DBD8D818/baserepo 3 08/07/2013 17:28:49PM - cmd = "C:/Users/asus/AppData/Local/Temp/ijtmp_EDACDD11-B33D-4D43-806D-6BD0DBD8D818/unzip.exe" -q -o -d "C:/Users/asus/AppData/Local/Temp/ijtmp_EDACDD11-B33D-4D43-806D-6BD0DBD8D818/baserepo" "F:/download/CCS5.4.0.00091_win32/baserepo/eclipserepo.zip" 08/07/2013 17:29:36PM - successfully unzipped eclipserepo.zip 08/07/2013 17:29:36PM - percent now 2 08/07/2013 17:29:36PM - ECLIPSE checked out ok! 08/07/2013 17:29:36PM - C:/Users/asus/AppData/Local/Temp/ijtmp_EDACDD11-B33D-4D43-806D-6BD0DBD8D818/eclipse 08/07/2013 17:29:36PM - filelist C:/Users/asus/AppData/Local/Temp/ijtmp_EDACDD11-B33D-4D43-806D-6BD0DBD8D818/eclipse/plugins/com.ti.ccstudio.p2app_1.0.0.201202161700.jar 08/07/2013 17:29:36PM - found file C:/Users/asus/AppData/Local/Temp/ijtmp_EDACDD11-B33D-4D43-806D-6BD0DBD8D818/eclipse/plugins/com.ti.ccstudio.p2app_1.0.0.201202161700.jar 08/07/2013 17:29:36PM - using C:/ti/ccsv5/eclipse/jre/bin/java.exe 08/07/2013 17:29:36PM - "C:/ti/ccsv5/eclipse/jre/bin/java.exe" -Xmx512m "-Dosgi.configuration.area=C:/Users/asus/AppData/Local/Temp/ijtmp_EDACDD11-B33D-4D43-806D-6BD0DBD8D818/eclipse/cfg" "-Dosgi.instance.area=C:/Users/asus/AppData/Local/Temp/ijtmp_EDACDD11-B33D-4D43-806D-6BD0DBD8D818/eclipse/ws" -jar "C:/Users/asus/AppData/Local/Temp/ijtmp_EDACDD11-B33D-4D43-806D-6BD0DBD8D818/eclipse/plugins/org.eclipse.equinox.launcher.jar" -application com.ti.ccstudio.p2app -repository "file:/C:/Users/asus/AppData/Local/Temp/ijtmp_EDACDD11-B33D-4D43-806D-6BD0DBD8D818/baserepo/eclipserepo" -installIU org.eclipse.platform.ide,org.eclipse.rse.feature.group,org.eclipse.epp.mpc.feature.group,org.eclipse.equinox.p2.discovery.feature.feature.group,org.eclipse.equinox.p2.user.ui.feature.group,org.eclipse.help.feature.group,org.eclipse.wst.jsdt.feature.feature.group,org.eclipse.cvs.feature.group,org.eclipse.cdt.feature.group,org.eclipse.cdt.debug.ui.memory.feature.group,org.eclipse.cdt.msw.feature.group,org.eclipse.cdt.build.crossgcc.feature.group,org.eclipse.cdt.launch.remote.feature.group,org.eclipse.cdt.autotools.feature.group,org.eclipse.cdt.mylyn.feature.group,org.eclipse.mylyn_feature.feature.group,org.eclipse.mylyn.context_feature.feature.group,org.eclipse.cdt.debug.gdbjtag.feature.group,org.eclipse.mylyn.team_feature.feature.group,org.eclipse.mylyn.ide_feature.feature.group,org.eclipse.mylyn.bugzilla_feature.feature.group,org.eclipse.mylyn.wikitext_feature.feature.group,org.eclipse.egit.feature.group,org.eclipse.egit.import.feature.group,org.eclipse.epp.package.common.feature.feature.group,org.eclipse.tm.terminal.sdk.feature.group -destination "C:/ti/ccsv5/eclipse/" -profile epp.package.cpp -profileProperties org.eclipse.update.install.features=true -bundlepool "C:/ti/ccsv5/eclipse/" -p2.os win32 -p2.ws win32 -p2.arch x86 -roaming 08/07/2013 17:29:36PM - percent now 3 08/07/2013 17:29:36PM - Executing actions 057C7BE9-44B0-45B2-A154-6FEE90439EB4 - InstallApp 08/07/2013 17:29:36PM - Executing action 057C7BE9-44B0-45B2-A154-6FEE90439EB4 - InstallApp 08/07/2013 17:29:36PM - Executing with progressive output 08/07/2013 17:29:36PM - Watching progressive output for special syntax. 08/07/2013 17:29:36PM - Executing Command Line: "C:/ti/ccsv5/eclipse/jre/bin/java.exe" -Xmx512m "-Dosgi.configuration.area=C:/Users/asus/AppData/Local/Temp/ijtmp_EDACDD11-B33D-4D43-806D-6BD0DBD8D818/eclipse/cfg" "-Dosgi.instance.area=C:/Users/asus/AppData/Local/Temp/ijtmp_EDACDD11-B33D-4D43-806D-6BD0DBD8D818/eclipse/ws" -jar "C:/Users/asus/AppData/Local/Temp/ijtmp_EDACDD11-B33D-4D43-806D-6BD0DBD8D818/eclipse/plugins/org.eclipse.equinox.launcher.jar" -application com.ti.ccstudio.p2app -repository "file:/C:/Users/asus/AppData/Local/Temp/ijtmp_EDACDD11-B33D-4D43-806D-6BD0DBD8D818/baserepo/eclipserepo" -installIU org.eclipse.platform.ide,org.eclipse.rse.feature.group,org.eclipse.epp.mpc.feature.group,org.eclipse.equinox.p2.discovery.feature.feature.group,org.eclipse.equinox.p2.user.ui.feature.group,org.eclipse.help.feature.group,org.eclipse.wst.jsdt.feature.feature.group,org.eclipse.cvs.feature.group,org.eclipse.cdt.feature.group,org.eclipse.cdt.debug.ui.memory.feature.group,org.eclipse.cdt.msw.feature.group,org.eclipse.cdt.build.crossgcc.feature.group,org.eclipse.cdt.launch.remote.feature.group,org.eclipse.cdt.autotools.feature.group,org.eclipse.cdt.mylyn.feature.group,org.eclipse.mylyn_feature.feature.group,org.eclipse.mylyn.context_feature.feature.group,org.eclipse.cdt.debug.gdbjtag.feature.group,org.eclipse.mylyn.team_feature.feature.group,org.eclipse.mylyn.ide_feature.feature.group,org.eclipse.mylyn.bugzilla_feature.feature.group,org.eclipse.mylyn.wikitext_feature.feature.group,org.eclipse.egit.feature.group,org.eclipse.egit.import.feature.group,org.eclipse.epp.package.common.feature.feature.group,org.eclipse.tm.terminal.sdk.feature.group -destination "C:/ti/ccsv5/eclipse/" -profile epp.package.cpp -profileProperties org.eclipse.update.install.features=true -bundlepool "C:/ti/ccsv5/eclipse/" -p2.os win32 -p2.ws win32 -p2.arch x86 -roaming 08/07/2013 17:29:37PM - Watching progressive output for matches 08/07/2013 17:33:31PM - ExternalProgramStatus 0 08/07/2013 17:33:31PM - ExternalProgramResult Preparing to commit the provisioning operation. Committing the provisioning operation. Installing org.eclipse.platform.ide 3.8.1.M20120914-1540. Installing org.eclipse.rse.feature.group 3.4.1.201209191030-7L7IFBY83omx__z0RFpKdWB-r5MS. Installing org.eclipse.epp.mpc.feature.group 1.1.1.I20110907-0947. Installing org.eclipse.equinox.p2.discovery.feature.feature.group 1.0.100.v20120524-0542-4-Bh9oB58A5N9L28PCQ. Installing org.eclipse.equinox.p2.user.ui.feature.group 2.2.0.v20120524-0542-62DG9JXTlSiz-UbcP0w0KGl9CKNP. Installing org.eclipse.help.feature.group 1.4.1.v20120726-050831-8R7xFOUFLWUl7MoSKV_OFXl27. Installing org.eclipse.wst.jsdt.feature.feature.group 1.4.1.v201208171701-7H7DFg0FC7sReqSyfqesWi. Installing org.eclipse.cvs.feature.group 1.3.200.v20120525-1249-7B79FJJAkF7BF7VEH5IAJT. Installing org.eclipse.cdt.feature.group 8.1.1.201209170703. Installing org.eclipse.cdt.debug.ui.memory.feature.group 2.2.0.201209170703. Installing org.eclipse.cdt.msw.feature.group 1.0.0.201209170703. Installing org.eclipse.cdt.build.crossgcc.feature.group 1.1.0.201209170703. Installing org.eclipse.cdt.launch.remote.feature.group 6.0.0.201209170703. Installing org.eclipse.cdt.autotools.feature.group 3.0.1.201209170703. Installing org.eclipse.cdt.mylyn.feature.group 5.4.2.v20120916-1200. Installing org.eclipse.mylyn_feature.feature.group 3.8.2.v20120916-1200. Installing org.eclipse.mylyn.context_feature.feature.group 3.8.2.v20120916-1200. Installing org.eclipse.cdt.debug.gdbjtag.feature.group 7.0.0.201209170703. Installing org.eclipse.mylyn.team_feature.feature.group 3.8.2.v20120916-1200. Installing org.eclipse.mylyn.ide_feature.feature.group 3.8.2.v20120916-1200. Installing org.eclipse.mylyn.bugzilla_feature.feature.group 3.8.2.v20120916-1200. Installing org.eclipse.mylyn.wikitext_feature.feature.group 1.7.2.v20120916-1200. Installing org.eclipse.egit.feature.group 2.1.0.201209190230-r. Installing org.eclipse.egit.import.feature.group 2.1.0.201209190230-r. Installing org.eclipse.epp.package.common.feature.feature.group 1.5.1.20121004-1506. Installing org.eclipse.tm.terminal.sdk.feature.group 3.3.1.201209191030-7N7FF8P7iMmAV6aAkqxqHKN8. Downloading com.ibm.icu Downloading com.jcraft.jsch Downloading com.sun.el Downloading com.sun.syndication Downloading javax.activation Downloading javax.el Downloading javax.servlet Downloading javax.servlet.jsp Downloading javax.xml Downloading javax.xml.bind Downloading javax.xml.stream Downloading org.apache.ant Downloading org.apache.commons.codec Downloading org.apache.commons.httpclient Downloading org.apache.commons.lang Downloading org.apache.commons.logging Downloading org.apache.commons.net Downloading org.apache.felix.gogo.command Downloading org.apache.felix.gogo.runtime Downloading org.apache.felix.gogo.shell Downloading org.apache.jasper.glassfish Downloading org.apache.lucene Downloading org.apache.lucene.analysis Downloading org.apache.lucene.core Downloading org.apache.ws.commons.util Downloading org.apache.xmlrpc Downloading org.eclipse.ant.core Downloading org.eclipse.cdt Downloading org.eclipse.cdt.autotools.core Downloading org.eclipse.cdt.autotools.docs Downloading org.eclipse.cdt.autotools Downloading org.eclipse.cdt.autotools.ui Downloading org.eclipse.cdt.build.crossgcc Downloading org.eclipse.cdt.codan.checkers Downloading org.eclipse.cdt.codan.checkers.ui Downloading org.eclipse.cdt.codan.core Downloading org.eclipse.cdt.codan.core.cxx Downloading org.eclipse.cdt.codan.ui Downloading org.eclipse.cdt.codan.ui.cxx Downloading org.eclipse.cdt.core Downloading org.eclipse.cdt.core.win32 Downloading org.eclipse.cdt.core.win32.x86 Downloading org.eclipse.cdt.debug.core Downloading org.eclipse.cdt.debug.gdbjtag Downloading org.eclipse.cdt.debug.gdbjtag.core Downloading org.eclipse.cdt.debug.gdbjtag Downloading org.eclipse.cdt.debug.gdbjtag.ui Downloading org.eclipse.cdt.debug.mi.core Downloading org.eclipse.cdt.debug.mi.ui Downloading org.eclipse.cdt.debug.ui Downloading org.eclipse.cdt.debug.ui.memory Downloading org.eclipse.cdt.debug.ui.memory.memorybrowser Downloading org.eclipse.cdt.debug.ui.memory.search Downloading org.eclipse.cdt.debug.ui.memory.traditional Downloading org.eclipse.cdt.debug.ui.memory.transport Downloading org.eclipse.cdt.doc.user Downloading org.eclipse.cdt.dsf Downloading org.eclipse.cdt.dsf.gdb Downloading org.eclipse.cdt.dsf.gdb.ui Downloading org.eclipse.cdt.dsf.ui Downloading org.eclipse.cdt Downloading org.eclipse.cdt.gdb Downloading org.eclipse.cdt.gdb.ui Downloading org.eclipse.cdt.gnu.build Downloading org.eclipse.cdt.gnu.debug Downloading org.eclipse.cdt.gnu.dsf Downloading org.eclipse.cdt.launch Downloading org.eclipse.cdt.launch.remote Downloading org.eclipse.cdt.launch.remote.source Downloading org.eclipse.cdt.make.core Downloading org.eclipse.cdt.make.ui Downloading org.eclipse.cdt.managedbuilder.core Downloading org.eclipse.cdt.managedbuilder.gnu.ui Downloading org.eclipse.cdt.managedbuilder.ui Downloading org.eclipse.cdt.msw.build Downloading org.eclipse.cdt.msw Downloading org.eclipse.cdt.mylyn Downloading org.eclipse.cdt.mylyn.ui Downloading org.eclipse.cdt.platform Downloading org.eclipse.cdt.ui Downloading org.eclipse.cdt_root Downloading org.eclipse.compare Downloading org.eclipse.compare.core Downloading org.eclipse.compare.win32 Downloading org.eclipse.core.boot Downloading org.eclipse.core.commands Downloading org.eclipse.core.contenttype Downloading org.eclipse.core.databinding Downloading org.eclipse.core.databinding.beans Downloading org.eclipse.core.databinding.observable Downloading org.eclipse.core.databinding.property Downloading org.eclipse.core.expressions Downloading org.eclipse.core.externaltools Downloading org.eclipse.core.filebuffers Downloading org.eclipse.core.filesystem Downloading org.eclipse.core.filesystem.win32.x86 Downloading org.eclipse.core.jobs Downloading org.eclipse.core.net Downloading org.eclipse.core.net.win32.x86 Downloading org.eclipse.core.resources Downloading org.eclipse.core.resources.win32.x86 Downloading org.eclipse.core.runtime Downloading org.eclipse.core.runtime.compatibility Downloading org.eclipse.core.runtime.compatibility.auth Downloading org.eclipse.core.runtime.compatibility.registry Downloading org.eclipse.core.variables Downloading org.eclipse.cvs Downloading org.eclipse.cvs_root Downloading org.eclipse.debug.core Downloading org.eclipse.debug.ui Downloading org.eclipse.dstore.core Downloading org.eclipse.dstore.extra Downloading org.eclipse.ecf Downloading org.eclipse.ecf.filetransfer Downloading org.eclipse.ecf.identity Downloading org.eclipse.ecf.provider.filetransfer Downloading org.eclipse.ecf.provider.filetransfer.httpclient Downloading org.eclipse.ecf.provider.filetransfer.httpclient.ssl Downloading org.eclipse.ecf.provider.filetransfer.ssl Downloading org.eclipse.ecf.ssl Downloading org.eclipse.egit Downloading org.eclipse.egit.core Downloading org.eclipse.egit.doc Downloading org.eclipse.egit Downloading org.eclipse.egit.import Downloading org.eclipse.egit.psf Downloading org.eclipse.egit.ui Downloading org.eclipse.epp.mpc.core Downloading org.eclipse.epp.mpc Downloading org.eclipse.epp.mpc.help.ui Downloading org.eclipse.epp.mpc.ui Downloading org.eclipse.epp.package.common.feature Downloading org.eclipse.equinox.app Downloading org.eclipse.equinox.bidi Downloading org.eclipse.equinox.common Downloading org.eclipse.equinox.concurrent Downloading org.eclipse.equinox.console Downloading org.eclipse.equinox.ds Downloading org.eclipse.equinox.event Downloading org.eclipse.equinox.frameworkadmin Downloading org.eclipse.equinox.frameworkadmin.equinox Downloading org.eclipse.equinox.http.jetty Downloading org.eclipse.equinox.http.registry Downloading org.eclipse.equinox.http.servlet Downloading org.eclipse.equinox.jsp.jasper Downloading org.eclipse.equinox.jsp.jasper.registry Downloading org.eclipse.equinox.launcher Downloading org.eclipse.equinox.launcher.win32.win32.x86 Downloading org.eclipse.equinox.p2.artifact.repository Downloading org.eclipse.equinox.p2.console Downloading org.eclipse.equinox.p2.core Downloading org.eclipse.equinox.p2.core.feature Downloading org.eclipse.equinox.p2.director Downloading org.eclipse.equinox.p2.director.app Downloading org.eclipse.equinox.p2.directorywatcher Downloading org.eclipse.equinox.p2.discovery Downloading org.eclipse.equinox.p2.discovery.compatibility Downloading org.eclipse.equinox.p2.discovery.feature Downloading org.eclipse.equinox.p2.engine Downloading org.eclipse.equinox.p2.extensionlocation Downloading org.eclipse.equinox.p2.extras.feature Downloading org.eclipse.equinox.p2.garbagecollector Downloading org.eclipse.equinox.p2.jarprocessor Downloading org.eclipse.equinox.p2.metadata Downloading org.eclipse.equinox.p2.metadata.repository Downloading org.eclipse.equinox.p2.operations Downloading org.eclipse.equinox.p2.publisher Downloading org.eclipse.equinox.p2.publisher.eclipse Downloading org.eclipse.equinox.p2.ql Downloading org.eclipse.equinox.p2.rcp.feature Downloading org.eclipse.equinox.p2.reconciler.dropins Downloading org.eclipse.equinox.p2.repository Downloading org.eclipse.equinox.p2.repository.tools Downloading org.eclipse.equinox.p2.touchpoint.eclipse Downloading org.eclipse.equinox.p2.touchpoint.natives Downloading org.eclipse.equinox.p2.transport.ecf Downloading org.eclipse.equinox.p2.ui Downloading org.eclipse.equinox.p2.ui.discovery Downloading org.eclipse.equinox.p2.ui.importexport Downloading org.eclipse.equinox.p2.ui.sdk Downloading org.eclipse.equinox.p2.ui.sdk.scheduler Downloading org.eclipse.equinox.p2.updatechecker Downloading org.eclipse.equinox.p2.updatesite Downloading org.eclipse.equinox.p2.user.ui Downloading org.eclipse.equinox.preferences Downloading org.eclipse.equinox.registry Downloading org.eclipse.equinox.security Downloading org.eclipse.equinox.security.ui Downloading org.eclipse.equinox.security.win32.x86 Downloading org.eclipse.equinox.simpleconfigurator Downloading org.eclipse.equinox.simpleconfigurator.manipulator Downloading org.eclipse.equinox.util Downloading org.eclipse.help Downloading org.eclipse.help.appserver Downloading org.eclipse.help.base Downloading org.eclipse.help Downloading org.eclipse.help.ui Downloading org.eclipse.help.webapp Downloading org.eclipse.jdt.core Downloading org.eclipse.jdt.debug Downloading org.eclipse.jdt.launching Downloading org.eclipse.jetty.continuation Downloading org.eclipse.jetty.http Downloading org.eclipse.jetty.io Downloading org.eclipse.jetty.security Downloading org.eclipse.jetty.server Downloading org.eclipse.jetty.servlet Downloading org.eclipse.jetty.util Downloading org.eclipse.jface Downloading org.eclipse.jface.databinding Downloading org.eclipse.jface.text Downloading org.eclipse.jgit Downloading org.eclipse.jsch.core Downloading org.eclipse.jsch.ui Downloading org.eclipse.linuxtools.cdt.autotools.core Downloading org.eclipse.ltk.core.refactoring Downloading org.eclipse.ltk.ui.refactoring Downloading org.eclipse.mylyn.bugzilla.core Downloading org.eclipse.mylyn.bugzilla.ide Downloading org.eclipse.mylyn.bugzilla.ui Downloading org.eclipse.mylyn.bugzilla_feature Downloading org.eclipse.mylyn.commons.core Downloading org.eclipse.mylyn.commons Downloading org.eclipse.mylyn.commons.identity Downloading org.eclipse.mylyn.commons.identity.core Downloading org.eclipse.mylyn.commons.identity Downloading org.eclipse.mylyn.commons.net Downloading org.eclipse.mylyn.commons.notifications Downloading org.eclipse.mylyn.commons.notifications.core Downloading org.eclipse.mylyn.commons.notifications Downloading org.eclipse.mylyn.commons.notifications.feed Downloading org.eclipse.mylyn.commons.notifications.ui Downloading org.eclipse.mylyn.commons.repositories Downloading org.eclipse.mylyn.commons.repositories.core Downloading org.eclipse.mylyn.commons.repositories Downloading org.eclipse.mylyn.commons.repositories.ui Downloading org.eclipse.mylyn.commons.screenshots Downloading org.eclipse.mylyn.commons.team Downloading org.eclipse.mylyn.commons.ui Downloading org.eclipse.mylyn.commons.workbench Downloading org.eclipse.mylyn.commons.xmlrpc Downloading org.eclipse.mylyn.context.core Downloading org.eclipse.mylyn.context.tasks.ui Downloading org.eclipse.mylyn.context.ui Downloading org.eclipse.mylyn.context_feature Downloading org.eclipse.mylyn.discovery.core Downloading org.eclipse.mylyn.discovery Downloading org.eclipse.mylyn.discovery.ui Downloading org.eclipse.mylyn.help.ui Downloading org.eclipse.mylyn.ide.ui Downloading org.eclipse.mylyn.ide_feature Downloading org.eclipse.mylyn.monitor.core Downloading org.eclipse.mylyn.monitor Downloading org.eclipse.mylyn.monitor.ui Downloading org.eclipse.mylyn.resources.ui Downloading org.eclipse.mylyn.tasks.bugs Downloading org.eclipse.mylyn.tasks.core Downloading org.eclipse.mylyn.tasks.ide Downloading org.eclipse.mylyn.tasks.index.core Downloading org.eclipse.mylyn.tasks.index.ui Downloading org.eclipse.mylyn.tasks.search Downloading org.eclipse.mylyn.tasks.ui Downloading org.eclipse.mylyn.team.cvs Downloading org.eclipse.mylyn.team.ui Downloading org.eclipse.mylyn.team_feature Downloading org.eclipse.mylyn.wikitext.confluence.core Downloading org.eclipse.mylyn.wikitext.confluence.ui Downloading org.eclipse.mylyn.wikitext.core Downloading org.eclipse.mylyn.wikitext.help.ui Downloading org.eclipse.mylyn.wikitext.mediawiki.core Downloading org.eclipse.mylyn.wikitext.mediawiki.ui Downloading org.eclipse.mylyn.wikitext.tasks.ui Downloading org.eclipse.mylyn.wikitext.textile.core Downloading org.eclipse.mylyn.wikitext.textile.ui Downloading org.eclipse.mylyn.wikitext.tracwiki.core Downloading org.eclipse.mylyn.wikitext.tracwiki.ui Downloading org.eclipse.mylyn.wikitext.twiki.core Downloading org.eclipse.mylyn.wikitext.twiki.ui Downloading org.eclipse.mylyn.wikitext.ui Downloading org.eclipse.mylyn.wikitext_feature Downloading org.eclipse.mylyn_feature Downloading org.eclipse.osgi Downloading org.eclipse.osgi.services Downloading org.eclipse.osgi.util Downloading org.eclipse.platform Downloading org.eclipse.platform.doc.user Downloading org.eclipse.platform Downloading org.eclipse.platform_root Downloading org.eclipse.rcp Downloading org.eclipse.rcp.configuration_root.win32.win32.x86 Downloading org.eclipse.rcp Downloading org.eclipse.rcp_root Downloading org.eclipse.rse Downloading org.eclipse.rse.connectorservice.dstore Downloading org.eclipse.rse.connectorservice.local Downloading org.eclipse.rse.connectorservice.ssh Downloading org.eclipse.rse.connectorservice.telnet Downloading org.eclipse.rse.core Downloading org.eclipse.rse.doc.user Downloading org.eclipse.rse.dstore Downloading org.eclipse.rse.dstore.security Downloading org.eclipse.rse.efs Downloading org.eclipse.rse.efs.ui Downloading org.eclipse.rse Downloading org.eclipse.rse.files.ui Downloading org.eclipse.rse.ftp Downloading org.eclipse.rse.importexport Downloading org.eclipse.rse.local Downloading org.eclipse.rse.processes.ui Downloading org.eclipse.rse.services Downloading org.eclipse.rse.services.dstore Downloading org.eclipse.rse.services.files.ftp Downloading org.eclipse.rse.services.local Downloading org.eclipse.rse.services.ssh Downloading org.eclipse.rse.services.telnet Downloading org.eclipse.rse.shells.ui Downloading org.eclipse.rse.ssh Downloading org.eclipse.rse.subsystems.files.core Downloading org.eclipse.rse.subsystems.files.dstore Downloading org.eclipse.rse.subsystems.files.ftp Downloading org.eclipse.rse.subsystems.files.local Downloading org.eclipse.rse.subsystems.files.ssh Downloading org.eclipse.rse.subsystems.processes.core Downloading org.eclipse.rse.subsystems.processes.dstore Downloading org.eclipse.rse.subsystems.processes.local Downloading org.eclipse.rse.subsystems.processes.shell.linux Downloading org.eclipse.rse.subsystems.shells.core Downloading org.eclipse.rse.subsystems.shells.dstore Downloading org.eclipse.rse.subsystems.shells.local Downloading org.eclipse.rse.subsystems.shells.ssh Downloading org.eclipse.rse.subsystems.shells.telnet Downloading org.eclipse.rse.subsystems.terminals.core Downloading org.eclipse.rse.subsystems.terminals.ssh Downloading org.eclipse.rse.telnet Downloading org.eclipse.rse.terminals Downloading org.eclipse.rse.terminals.ui Downloading org.eclipse.rse.ui Downloading org.eclipse.search Downloading org.eclipse.swt Downloading org.eclipse.swt.win32.win32.x86 Downloading org.eclipse.team.core Downloading org.eclipse.team.cvs.core Downloading org.eclipse.team.cvs.ssh2 Downloading org.eclipse.team.cvs.ui Downloading org.eclipse.team.ui Downloading org.eclipse.text Downloading org.eclipse.tm.terminal Downloading org.eclipse.tm.terminal.sdk Downloading org.eclipse.tm.terminal.serial Downloading org.eclipse.tm.terminal.serial.source Downloading org.eclipse.tm.terminal.source Downloading org.eclipse.tm.terminal.ssh Downloading org.eclipse.tm.terminal.ssh.source Downloading org.eclipse.tm.terminal.telnet Downloading org.eclipse.tm.terminal.telnet.source Downloading org.eclipse.tm.terminal.view Downloading org.eclipse.tm.terminal.view.source Downloading org.eclipse.ui Downloading org.eclipse.ui.browser Downloading org.eclipse.ui.cheatsheets Downloading org.eclipse.ui.console Downloading org.eclipse.ui.editors Downloading org.eclipse.ui.externaltools Downloading org.eclipse.ui.forms Downloading org.eclipse.ui.ide Downloading org.eclipse.ui.ide.application Downloading org.eclipse.ui.intro Downloading org.eclipse.ui.intro.universal Downloading org.eclipse.ui.navigator Downloading org.eclipse.ui.navigator.resources Downloading org.eclipse.ui.net Downloading org.eclipse.ui.presentations.r21 Downloading org.eclipse.ui.views Downloading org.eclipse.ui.views.log Downloading org.eclipse.ui.views.properties.tabbed Downloading org.eclipse.ui.win32 Downloading org.eclipse.ui.workbench Downloading org.eclipse.ui.workbench.compatibility Downloading org.eclipse.ui.workbench.texteditor Downloading org.eclipse.update.configurator Downloading org.eclipse.update.core Downloading org.eclipse.update.core.win32 Downloading org.eclipse.update.scheduler Downloading org.eclipse.update.ui Downloading org.eclipse.wst.jsdt.core Downloading org.eclipse.wst.jsdt.debug.core Downloading org.eclipse.wst.jsdt.debug.crossfire Downloading org.eclipse.wst.jsdt.debug.rhino Downloading org.eclipse.wst.jsdt.debug.rhino.debugger Downloading org.eclipse.wst.jsdt.debug.rhino.ui Downloading org.eclipse.wst.jsdt.debug.transport Downloading org.eclipse.wst.jsdt.debug.ui Downloading org.eclipse.wst.jsdt.doc Downloading org.eclipse.wst.jsdt.feature Downloading org.eclipse.wst.jsdt.manipulation Downloading org.eclipse.wst.jsdt.support.firefox Downloading org.eclipse.wst.jsdt.support.ie Downloading org.eclipse.wst.jsdt.ui Downloading org.jdom Downloading org.jsoup Downloading org.mozilla.javascript Downloading org.sat4j.core Downloading org.sat4j.pb Installing a.jre.javase Installing com.ibm.icu Installing com.jcraft.jsch Installing com.sun.el Installing com.sun.syndication Installing config.a.jre.javase Installing javax.activation Installing javax.el Installing javax.servlet Installing javax.servlet.jsp Installing javax.xml Installing javax.xml.bind Installing javax.xml.stream Installing org.apache.ant Installing org.apache.commons.codec Installing org.apache.commons.httpclient Installing org.apache.commons.lang Installing org.apache.commons.logging Installing org.apache.commons.net Installing org.apache.felix.gogo.command Installing org.apache.felix.gogo.runtime Installing org.apache.felix.gogo.shell Installing org.apache.jasper.glassfish Installing org.apache.lucene Installing org.apache.lucene.analysis Installing org.apache.lucene.core Installing org.apache.ws.commons.util Installing org.apache.xmlrpc Installing org.eclipse.ant.core Installing org.eclipse.cdt Installing org.eclipse.cdt.autotools.core Installing org.eclipse.cdt.autotools.docs Installing org.eclipse.cdt.autotools.feature.group Installing org.eclipse.cdt.autotools.feature.jar Installing org.eclipse.cdt.autotools.ui Installing org.eclipse.cdt.build.crossgcc Installing org.eclipse.cdt.build.crossgcc.feature.group Installing org.eclipse.cdt.build.crossgcc.feature.jar Installing org.eclipse.cdt.codan.checkers Installing org.eclipse.cdt.codan.checkers.ui Installing org.eclipse.cdt.codan.core Installing org.eclipse.cdt.codan.core.cxx Installing org.eclipse.cdt.codan.ui Installing org.eclipse.cdt.codan.ui.cxx Installing org.eclipse.cdt.core Installing org.eclipse.cdt.core.win32 Installing org.eclipse.cdt.core.win32.x86 Installing org.eclipse.cdt.debug.core Installing org.eclipse.cdt.debug.gdbjtag Installing org.eclipse.cdt.debug.gdbjtag.core Installing org.eclipse.cdt.debug.gdbjtag.feature.group Installing org.eclipse.cdt.debug.gdbjtag.feature.jar Installing org.eclipse.cdt.debug.gdbjtag.ui Installing org.eclipse.cdt.debug.mi.core Installing org.eclipse.cdt.debug.mi.ui Installing org.eclipse.cdt.debug.ui Installing org.eclipse.cdt.debug.ui.memory.feature.group Installing org.eclipse.cdt.debug.ui.memory.feature.jar Installing org.eclipse.cdt.debug.ui.memory.memorybrowser Installing org.eclipse.cdt.debug.ui.memory.search Installing org.eclipse.cdt.debug.ui.memory.traditional Installing org.eclipse.cdt.debug.ui.memory.transport Installing org.eclipse.cdt.doc.user Installing org.eclipse.cdt.dsf Installing org.eclipse.cdt.dsf.gdb Installing org.eclipse.cdt.dsf.gdb.ui Installing org.eclipse.cdt.dsf.ui Installing org.eclipse.cdt.feature.group Installing org.eclipse.cdt.feature.jar Installing org.eclipse.cdt.gdb Installing org.eclipse.cdt.gdb.feature.group Installing org.eclipse.cdt.gdb.feature.jar Installing org.eclipse.cdt.gdb.ui Installing org.eclipse.cdt.gnu.build.feature.group Installing org.eclipse.cdt.gnu.build.feature.jar Installing org.eclipse.cdt.gnu.debug.feature.group Installing org.eclipse.cdt.gnu.debug.feature.jar Installing org.eclipse.cdt.gnu.dsf.feature.group Installing org.eclipse.cdt.gnu.dsf.feature.jar Installing org.eclipse.cdt.launch Installing org.eclipse.cdt.launch.remote Installing org.eclipse.cdt.launch.remote.feature.group Installing org.eclipse.cdt.launch.remote.feature.jar Installing org.eclipse.cdt.launch.remote.source Installing org.eclipse.cdt.make.core Installing org.eclipse.cdt.make.ui Installing org.eclipse.cdt.managedbuilder.core Installing org.eclipse.cdt.managedbuilder.gnu.ui Installing org.eclipse.cdt.managedbuilder.ui Installing org.eclipse.cdt.msw.build Installing org.eclipse.cdt.msw.feature.group Installing org.eclipse.cdt.msw.feature.jar Installing org.eclipse.cdt.mylyn.feature.group Installing org.eclipse.cdt.mylyn.feature.jar Installing org.eclipse.cdt.mylyn.ui Installing org.eclipse.cdt.platform.feature.group Installing org.eclipse.cdt.platform.feature.jar Installing org.eclipse.cdt.ui Installing org.eclipse.cdt_root Installing org.eclipse.compare Installing org.eclipse.compare.core Installing org.eclipse.compare.win32 Installing org.eclipse.core.boot Installing org.eclipse.core.commands Installing org.eclipse.core.contenttype Installing org.eclipse.core.databinding Installing org.eclipse.core.databinding.beans Installing org.eclipse.core.databinding.observable Installing org.eclipse.core.databinding.property Installing org.eclipse.core.expressions Installing org.eclipse.core.externaltools Installing org.eclipse.core.filebuffers Installing org.eclipse.core.filesystem Installing org.eclipse.core.filesystem.win32.x86 Installing org.eclipse.core.jobs Installing org.eclipse.core.net Installing org.eclipse.core.net.win32.x86 Installing org.eclipse.core.resources Installing org.eclipse.core.resources.win32.x86 Installing org.eclipse.core.runtime Installing org.eclipse.core.runtime.compatibility Installing org.eclipse.core.runtime.compatibility.auth Installing org.eclipse.core.runtime.compatibility.registry Installing org.eclipse.core.variables Installing org.eclipse.cvs Installing org.eclipse.cvs.feature.group Installing org.eclipse.cvs.feature.jar Installing org.eclipse.cvs_root Installing org.eclipse.debug.core Installing org.eclipse.debug.ui Installing org.eclipse.dstore.core Installing org.eclipse.dstore.extra Installing org.eclipse.ecf Installing org.eclipse.ecf.filetransfer Installing org.eclipse.ecf.identity Installing org.eclipse.ecf.provider.filetransfer Installing org.eclipse.ecf.provider.filetransfer.httpclient Installing org.eclipse.ecf.provider.filetransfer.httpclient.ssl Installing org.eclipse.ecf.provider.filetransfer.ssl Installing org.eclipse.ecf.ssl Installing org.eclipse.egit Installing org.eclipse.egit.core Installing org.eclipse.egit.doc Installing org.eclipse.egit.feature.group Installing org.eclipse.egit.feature.jar Installing org.eclipse.egit.import Installing org.eclipse.egit.import.feature.group Installing org.eclipse.egit.import.feature.jar Installing org.eclipse.egit.psf.feature.group Installing org.eclipse.egit.psf.feature.jar Installing org.eclipse.egit.ui Installing org.eclipse.epp.mpc.core Installing org.eclipse.epp.mpc.feature.group Installing org.eclipse.epp.mpc.feature.jar Installing org.eclipse.epp.mpc.help.ui Installing org.eclipse.epp.mpc.ui Installing org.eclipse.epp.package.common.feature.feature.group Installing org.eclipse.epp.package.common.feature.feature.jar Installing org.eclipse.equinox.app Installing org.eclipse.equinox.bidi Installing org.eclipse.equinox.common Installing org.eclipse.equinox.concurrent Installing org.eclipse.equinox.console Installing org.eclipse.equinox.ds Installing org.eclipse.equinox.event Installing org.eclipse.equinox.frameworkadmin Installing org.eclipse.equinox.frameworkadmin.equinox Installing org.eclipse.equinox.http.jetty Installing org.eclipse.equinox.http.registry Installing org.eclipse.equinox.http.servlet Installing org.eclipse.equinox.jsp.jasper Installing org.eclipse.equinox.jsp.jasper.registry Installing org.eclipse.equinox.launcher Installing org.eclipse.equinox.launcher.win32.win32.x86 Installing org.eclipse.equinox.p2.artifact.repository Installing org.eclipse.equinox.p2.console Installing org.eclipse.equinox.p2.core Installing org.eclipse.equinox.p2.core.feature.feature.group Installing org.eclipse.equinox.p2.core.feature.feature.jar Installing org.eclipse.equinox.p2.director Installing org.eclipse.equinox.p2.director.app Installing org.eclipse.equinox.p2.directorywatcher Installing org.eclipse.equinox.p2.discovery Installing org.eclipse.equinox.p2.discovery.compatibility Installing org.eclipse.equinox.p2.discovery.feature.feature.group Installing org.eclipse.equinox.p2.discovery.feature.feature.jar Installing org.eclipse.equinox.p2.engine Installing org.eclipse.equinox.p2.extensionlocation Installing org.eclipse.equinox.p2.extras.feature.feature.group Installing org.eclipse.equinox.p2.extras.feature.feature.jar Installing org.eclipse.equinox.p2.garbagecollector Installing org.eclipse.equinox.p2.jarprocessor Installing org.eclipse.equinox.p2.metadata Installing org.eclipse.equinox.p2.metadata.repository Installing org.eclipse.equinox.p2.operations Installing org.eclipse.equinox.p2.publisher Installing org.eclipse.equinox.p2.publisher.eclipse Installing org.eclipse.equinox.p2.ql Installing org.eclipse.equinox.p2.rcp.feature.feature.group Installing org.eclipse.equinox.p2.rcp.feature.feature.jar Installing org.eclipse.equinox.p2.reconciler.dropins Installing org.eclipse.equinox.p2.repository Installing org.eclipse.equinox.p2.repository.tools Installing org.eclipse.equinox.p2.touchpoint.eclipse Installing org.eclipse.equinox.p2.touchpoint.natives Installing org.eclipse.equinox.p2.transport.ecf Installing org.eclipse.equinox.p2.ui Installing org.eclipse.equinox.p2.ui.discovery Installing org.eclipse.equinox.p2.ui.importexport Installing org.eclipse.equinox.p2.ui.sdk Installing org.eclipse.equinox.p2.ui.sdk.scheduler Installing org.eclipse.equinox.p2.updatechecker Installing org.eclipse.equinox.p2.updatesite Installing org.eclipse.equinox.p2.user.ui.feature.group Installing org.eclipse.equinox.p2.user.ui.feature.jar Installing org.eclipse.equinox.preferences Installing org.eclipse.equinox.registry Installing org.eclipse.equinox.security Installing org.eclipse.equinox.security.ui Installing org.eclipse.equinox.security.win32.x86 Installing org.eclipse.equinox.simpleconfigurator Installing org.eclipse.equinox.simpleconfigurator.manipulator Installing org.eclipse.equinox.util Installing org.eclipse.help Installing org.eclipse.help.appserver Installing org.eclipse.help.base Installing org.eclipse.help.feature.group Installing org.eclipse.help.feature.jar Installing org.eclipse.help.ui Installing org.eclipse.help.webapp Installing org.eclipse.jdt.core Installing org.eclipse.jdt.debug Installing org.eclipse.jdt.launching Installing org.eclipse.jetty.continuation Installing org.eclipse.jetty.http Installing org.eclipse.jetty.io Installing org.eclipse.jetty.security Installing org.eclipse.jetty.server Installing org.eclipse.jetty.servlet Installing org.eclipse.jetty.util Installing org.eclipse.jface Installing org.eclipse.jface.databinding Installing org.eclipse.jface.text Installing org.eclipse.jgit Installing org.eclipse.jgit.feature.group Installing org.eclipse.jgit.feature.jar Installing org.eclipse.jsch.core Installing org.eclipse.jsch.ui Installing org.eclipse.linuxtools.cdt.autotools.core Installing org.eclipse.ltk.core.refactoring Installing org.eclipse.ltk.ui.refactoring Installing org.eclipse.mylyn.bugzilla.core Installing org.eclipse.mylyn.bugzilla.ide Installing org.eclipse.mylyn.bugzilla.ui Installing org.eclipse.mylyn.bugzilla_feature.feature.group Installing org.eclipse.mylyn.bugzilla_feature.feature.jar Installing org.eclipse.mylyn.commons.core Installing org.eclipse.mylyn.commons.feature.group Installing org.eclipse.mylyn.commons.feature.jar Installing org.eclipse.mylyn.commons.identity Installing org.eclipse.mylyn.commons.identity.core Installing org.eclipse.mylyn.commons.identity.feature.group Installing org.eclipse.mylyn.commons.identity.feature.jar Installing org.eclipse.mylyn.commons.net Installing org.eclipse.mylyn.commons.notifications Installing org.eclipse.mylyn.commons.notifications.core Installing org.eclipse.mylyn.commons.notifications.feature.group Installing org.eclipse.mylyn.commons.notifications.feature.jar Installing org.eclipse.mylyn.commons.notifications.feed Installing org.eclipse.mylyn.commons.notifications.ui Installing org.eclipse.mylyn.commons.repositories Installing org.eclipse.mylyn.commons.repositories.core Installing org.eclipse.mylyn.commons.repositories.feature.group Installing org.eclipse.mylyn.commons.repositories.feature.jar Installing org.eclipse.mylyn.commons.repositories.ui Installing org.eclipse.mylyn.commons.screenshots Installing org.eclipse.mylyn.commons.team Installing org.eclipse.mylyn.commons.ui Installing org.eclipse.mylyn.commons.workbench Installing org.eclipse.mylyn.commons.xmlrpc Installing org.eclipse.mylyn.context.core Installing org.eclipse.mylyn.context.tasks.ui Installing org.eclipse.mylyn.context.ui Installing org.eclipse.mylyn.context_feature.feature.group Installing org.eclipse.mylyn.context_feature.feature.jar Installing org.eclipse.mylyn.discovery.core Installing org.eclipse.mylyn.discovery.feature.group Installing org.eclipse.mylyn.discovery.feature.jar Installing org.eclipse.mylyn.discovery.ui Installing org.eclipse.mylyn.help.ui Installing org.eclipse.mylyn.ide.ui Installing org.eclipse.mylyn.ide_feature.feature.group Installing org.eclipse.mylyn.ide_feature.feature.jar Installing org.eclipse.mylyn.monitor.core Installing org.eclipse.mylyn.monitor.feature.group Installing org.eclipse.mylyn.monitor.feature.jar Installing org.eclipse.mylyn.monitor.ui Installing org.eclipse.mylyn.resources.ui Installing org.eclipse.mylyn.tasks.bugs Installing org.eclipse.mylyn.tasks.core Installing org.eclipse.mylyn.tasks.ide.feature.group Installing org.eclipse.mylyn.tasks.ide.feature.jar Installing org.eclipse.mylyn.tasks.index.core Installing org.eclipse.mylyn.tasks.index.ui Installing org.eclipse.mylyn.tasks.search Installing org.eclipse.mylyn.tasks.ui Installing org.eclipse.mylyn.team.cvs Installing org.eclipse.mylyn.team.ui Installing org.eclipse.mylyn.team_feature.feature.group Installing org.eclipse.mylyn.team_feature.feature.jar Installing org.eclipse.mylyn.wikitext.confluence.core Installing org.eclipse.mylyn.wikitext.confluence.ui Installing org.eclipse.mylyn.wikitext.core Installing org.eclipse.mylyn.wikitext.help.ui Installing org.eclipse.mylyn.wikitext.mediawiki.core Installing org.eclipse.mylyn.wikitext.mediawiki.ui Installing org.eclipse.mylyn.wikitext.tasks.ui Installing org.eclipse.mylyn.wikitext.textile.core Installing org.eclipse.mylyn.wikitext.textile.ui Installing org.eclipse.mylyn.wikitext.tracwiki.core Installing org.eclipse.mylyn.wikitext.tracwiki.ui Installing org.eclipse.mylyn.wikitext.twiki.core Installing org.eclipse.mylyn.wikitext.twiki.ui Installing org.eclipse.mylyn.wikitext.ui Installing org.eclipse.mylyn.wikitext_feature.feature.group Installing org.eclipse.mylyn.wikitext_feature.feature.jar Installing org.eclipse.mylyn_feature.feature.group Installing org.eclipse.mylyn_feature.feature.jar Installing org.eclipse.osgi Installing org.eclipse.osgi.services Installing org.eclipse.osgi.util Installing org.eclipse.platform Installing org.eclipse.platform.doc.user Installing org.eclipse.platform.feature.group Installing org.eclipse.platform.feature.jar Installing org.eclipse.platform.ide Installing org.eclipse.platform_root Installing org.eclipse.rcp Installing org.eclipse.rcp.configuration.feature.group Installing org.eclipse.rcp.configuration_root.win32.win32.x86 Installing org.eclipse.rcp.feature.group Installing org.eclipse.rcp.feature.jar Installing org.eclipse.rcp_root Installing org.eclipse.rse Installing org.eclipse.rse.connectorservice.dstore Installing org.eclipse.rse.connectorservice.local Installing org.eclipse.rse.connectorservice.ssh Installing org.eclipse.rse.connectorservice.telnet Installing org.eclipse.rse.core Installing org.eclipse.rse.core.feature.group Installing org.eclipse.rse.core.feature.jar Installing org.eclipse.rse.doc.user Installing org.eclipse.rse.dstore.feature.group Installing org.eclipse.rse.dstore.feature.jar Installing org.eclipse.rse.dstore.security Installing org.eclipse.rse.efs Installing org.eclipse.rse.efs.ui Installing org.eclipse.rse.feature.group Installing org.eclipse.rse.feature.jar Installing org.eclipse.rse.files.ui Installing org.eclipse.rse.ftp.feature.group Installing org.eclipse.rse.ftp.feature.jar Installing org.eclipse.rse.importexport Installing org.eclipse.rse.local.feature.group Installing org.eclipse.rse.local.feature.jar Installing org.eclipse.rse.processes.ui Installing org.eclipse.rse.services Installing org.eclipse.rse.services.dstore Installing org.eclipse.rse.services.files.ftp Installing org.eclipse.rse.services.local Installing org.eclipse.rse.services.ssh Installing org.eclipse.rse.services.telnet Installing org.eclipse.rse.shells.ui Installing org.eclipse.rse.ssh.feature.group Installing org.eclipse.rse.ssh.feature.jar Installing org.eclipse.rse.subsystems.files.core Installing org.eclipse.rse.subsystems.files.dstore Installing org.eclipse.rse.subsystems.files.ftp Installing org.eclipse.rse.subsystems.files.local Installing org.eclipse.rse.subsystems.files.ssh Installing org.eclipse.rse.subsystems.processes.core Installing org.eclipse.rse.subsystems.processes.dstore Installing org.eclipse.rse.subsystems.processes.local Installing org.eclipse.rse.subsystems.processes.shell.linux Installing org.eclipse.rse.subsystems.shells.core Installing org.eclipse.rse.subsystems.shells.dstore Installing org.eclipse.rse.subsystems.shells.local Installing org.eclipse.rse.subsystems.shells.ssh Installing org.eclipse.rse.subsystems.shells.telnet Installing org.eclipse.rse.subsystems.terminals.core Installing org.eclipse.rse.subsystems.terminals.ssh Installing org.eclipse.rse.telnet.feature.group Installing org.eclipse.rse.telnet.feature.jar Installing org.eclipse.rse.terminals.feature.group Installing org.eclipse.rse.terminals.feature.jar Installing org.eclipse.rse.terminals.ui Installing org.eclipse.rse.ui Installing org.eclipse.search Installing org.eclipse.swt Installing org.eclipse.swt.win32.win32.x86 Installing org.eclipse.team.core Installing org.eclipse.team.cvs.core Installing org.eclipse.team.cvs.ssh2 Installing org.eclipse.team.cvs.ui Installing org.eclipse.team.ui Installing org.eclipse.text Installing org.eclipse.tm.terminal Installing org.eclipse.tm.terminal.feature.group Installing org.eclipse.tm.terminal.feature.jar Installing org.eclipse.tm.terminal.sdk.feature.group Installing org.eclipse.tm.terminal.sdk.feature.jar Installing org.eclipse.tm.terminal.serial Installing org.eclipse.tm.terminal.serial.feature.group Installing org.eclipse.tm.terminal.serial.feature.jar Installing org.eclipse.tm.terminal.serial.source Installing org.eclipse.tm.terminal.source Installing org.eclipse.tm.terminal.ssh Installing org.eclipse.tm.terminal.ssh.feature.group Installing org.eclipse.tm.terminal.ssh.feature.jar Installing org.eclipse.tm.terminal.ssh.source Installing org.eclipse.tm.terminal.telnet Installing org.eclipse.tm.terminal.telnet.feature.group Installing org.eclipse.tm.terminal.telnet.feature.jar Installing org.eclipse.tm.terminal.telnet.source Installing org.eclipse.tm.terminal.view Installing org.eclipse.tm.terminal.view.feature.group Installing org.eclipse.tm.terminal.view.feature.jar Installing org.eclipse.tm.terminal.view.source Installing org.eclipse.ui Installing org.eclipse.ui.browser Installing org.eclipse.ui.cheatsheets Installing org.eclipse.ui.console Installing org.eclipse.ui.editors Installing org.eclipse.ui.externaltools Installing org.eclipse.ui.forms Installing org.eclipse.ui.ide Installing org.eclipse.ui.ide.application Installing org.eclipse.ui.intro Installing org.eclipse.ui.intro.universal Installing org.eclipse.ui.navigator Installing org.eclipse.ui.navigator.resources Installing org.eclipse.ui.net Installing org.eclipse.ui.presentations.r21 Installing org.eclipse.ui.views Installing org.eclipse.ui.views.log Installing org.eclipse.ui.views.properties.tabbed Installing org.eclipse.ui.win32 Installing org.eclipse.ui.workbench Installing org.eclipse.ui.workbench.compatibility Installing org.eclipse.ui.workbench.texteditor Installing org.eclipse.update.configurator Installing org.eclipse.update.core Installing org.eclipse.update.core.win32 Installing org.eclipse.update.scheduler Installing org.eclipse.update.ui Installing org.eclipse.wst.jsdt.core Installing org.eclipse.wst.jsdt.debug.core Installing org.eclipse.wst.jsdt.debug.crossfire Installing org.eclipse.wst.jsdt.debug.rhino Installing org.eclipse.wst.jsdt.debug.rhino.debugger Installing org.eclipse.wst.jsdt.debug.rhino.ui Installing org.eclipse.wst.jsdt.debug.transport Installing org.eclipse.wst.jsdt.debug.ui Installing org.eclipse.wst.jsdt.doc Installing org.eclipse.wst.jsdt.feature.feature.group Installing org.eclipse.wst.jsdt.feature.feature.jar Installing org.eclipse.wst.jsdt.manipulation Installing org.eclipse.wst.jsdt.support.firefox Installing org.eclipse.wst.jsdt.support.ie Installing org.eclipse.wst.jsdt.ui Installing org.jdom Installing org.jsoup Installing org.mozilla.javascript Installing org.sat4j.core Installing org.sat4j.pb Installing tooling.org.eclipse.update.feature.default Installing tooling.osgi.bundle.default Installing tooling.source.default Installing toolingorg.eclipse.configuration Installing toolingorg.eclipse.equinox.launcher Installing toolingorg.eclipse.equinox.launcher.win32.win32.x86 Installing toolingorg.eclipse.platform.ide.config.win32.win32.x86 Installing toolingorg.eclipse.platform.ide.configuration Installing toolingorg.eclipse.platform.ide.ini.win32.win32.x86 Installing toolingwin32.win32.x86org.eclipse.core.runtime Installing toolingwin32.win32.x86org.eclipse.equinox.common Installing toolingwin32.win32.x86org.eclipse.equinox.ds Installing toolingwin32.win32.x86org.eclipse.equinox.event Installing toolingwin32.win32.x86org.eclipse.equinox.p2.reconciler.dropins Installing toolingwin32.win32.x86org.eclipse.equinox.simpleconfigurator Installing toolingwin32.win32.x86org.eclipse.update.configurator Configuring a.jre.javase Configuring com.ibm.icu Configuring com.jcraft.jsch Configuring com.sun.el Configuring com.sun.syndication Configuring config.a.jre.javase Configuring javax.activation Configuring javax.el Configuring javax.servlet Configuring javax.servlet.jsp Configuring javax.xml Configuring javax.xml.bind Configuring javax.xml.stream Configuring org.apache.ant Configuring org.apache.commons.codec Configuring org.apache.commons.httpclient Configuring org.apache.commons.lang Configuring org.apache.commons.logging Configuring org.apache.commons.net Configuring org.apache.felix.gogo.command Configuring org.apache.felix.gogo.runtime Configuring org.apache.felix.gogo.shell Configuring org.apache.jasper.glassfish Configuring org.apache.lucene Configuring org.apache.lucene.analysis Configuring org.apache.lucene.core Configuring org.apache.ws.commons.util Configuring org.apache.xmlrpc Configuring org.eclipse.ant.core Configuring org.eclipse.cdt Configuring org.eclipse.cdt.autotools.core Configuring org.eclipse.cdt.autotools.docs Configuring org.eclipse.cdt.autotools.feature.group Configuring org.eclipse.cdt.autotools.feature.jar Configuring org.eclipse.cdt.autotools.ui Configuring org.eclipse.cdt.build.crossgcc Configuring org.eclipse.cdt.build.crossgcc.feature.group Configuring org.eclipse.cdt.build.crossgcc.feature.jar Configuring org.eclipse.cdt.codan.checkers Configuring org.eclipse.cdt.codan.checkers.ui Configuring org.eclipse.cdt.codan.core Configuring org.eclipse.cdt.codan.core.cxx Configuring org.eclipse.cdt.codan.ui Configuring org.eclipse.cdt.codan.ui.cxx Configuring org.eclipse.cdt.core Configuring org.eclipse.cdt.core.win32 Configuring org.eclipse.cdt.core.win32.x86 Configuring org.eclipse.cdt.debug.core Configuring org.eclipse.cdt.debug.gdbjtag Configuring org.eclipse.cdt.debug.gdbjtag.core Configuring org.eclipse.cdt.debug.gdbjtag.feature.group Configuring org.eclipse.cdt.debug.gdbjtag.feature.jar Configuring org.eclipse.cdt.debug.gdbjtag.ui Configuring org.eclipse.cdt.debug.mi.core Configuring org.eclipse.cdt.debug.mi.ui Configuring org.eclipse.cdt.debug.ui Configuring org.eclipse.cdt.debug.ui.memory.feature.group Configuring org.eclipse.cdt.debug.ui.memory.feature.jar Configuring org.eclipse.cdt.debug.ui.memory.memorybrowser Configuring org.eclipse.cdt.debug.ui.memory.search Configuring org.eclipse.cdt.debug.ui.memory.traditional Configuring org.eclipse.cdt.debug.ui.memory.transport Configuring org.eclipse.cdt.doc.user Configuring org.eclipse.cdt.dsf Configuring org.eclipse.cdt.dsf.gdb Configuring org.eclipse.cdt.dsf.gdb.ui Configuring org.eclipse.cdt.dsf.ui Configuring org.eclipse.cdt.feature.group Configuring org.eclipse.cdt.feature.jar Configuring org.eclipse.cdt.gdb Configuring org.eclipse.cdt.gdb.feature.group Configuring org.eclipse.cdt.gdb.feature.jar Configuring org.eclipse.cdt.gdb.ui Configuring org.eclipse.cdt.gnu.build.feature.group Configuring org.eclipse.cdt.gnu.build.feature.jar Configuring org.eclipse.cdt.gnu.debug.feature.group Configuring org.eclipse.cdt.gnu.debug.feature.jar Configuring org.eclipse.cdt.gnu.dsf.feature.group Configuring org.eclipse.cdt.gnu.dsf.feature.jar Configuring org.eclipse.cdt.launch Configuring org.eclipse.cdt.launch.remote Configuring org.eclipse.cdt.launch.remote.feature.group Configuring org.eclipse.cdt.launch.remote.feature.jar Configuring org.eclipse.cdt.launch.remote.source Configuring org.eclipse.cdt.make.core Configuring org.eclipse.cdt.make.ui Configuring org.eclipse.cdt.managedbuilder.core Configuring org.eclipse.cdt.managedbuilder.gnu.ui Configuring org.eclipse.cdt.managedbuilder.ui Configuring org.eclipse.cdt.msw.build Configuring org.eclipse.cdt.msw.feature.group Configuring org.eclipse.cdt.msw.feature.jar Configuring org.eclipse.cdt.mylyn.feature.group Configuring org.eclipse.cdt.mylyn.feature.jar Configuring org.eclipse.cdt.mylyn.ui Configuring org.eclipse.cdt.platform.feature.group Configuring org.eclipse.cdt.platform.feature.jar Configuring org.eclipse.cdt.ui Configuring org.eclipse.cdt_root Configuring org.eclipse.compare Configuring org.eclipse.compare.core Configuring org.eclipse.compare.win32 Configuring org.eclipse.core.boot Configuring org.eclipse.core.commands Configuring org.eclipse.core.contenttype Configuring org.eclipse.core.databinding Configuring org.eclipse.core.databinding.beans Configuring org.eclipse.core.databinding.observable Configuring org.eclipse.core.databinding.property Configuring org.eclipse.core.expressions Configuring org.eclipse.core.externaltools Configuring org.eclipse.core.filebuffers Configuring org.eclipse.core.filesystem Configuring org.eclipse.core.filesystem.win32.x86 Configuring org.eclipse.core.jobs Configuring org.eclipse.core.net Configuring org.eclipse.core.net.win32.x86 Configuring org.eclipse.core.resources Configuring org.eclipse.core.resources.win32.x86 Configuring org.eclipse.core.runtime Configuring org.eclipse.core.runtime.compatibility Configuring org.eclipse.core.runtime.compatibility.auth Configuring org.eclipse.core.runtime.compatibility.registry Configuring org.eclipse.core.variables Configuring org.eclipse.cvs Configuring org.eclipse.cvs.feature.group Configuring org.eclipse.cvs.feature.jar Configuring org.eclipse.cvs_root Configuring org.eclipse.debug.core Configuring org.eclipse.debug.ui Configuring org.eclipse.dstore.core Configuring org.eclipse.dstore.extra Configuring org.eclipse.ecf Configuring org.eclipse.ecf.filetransfer Configuring org.eclipse.ecf.identity Configuring org.eclipse.ecf.provider.filetransfer Configuring org.eclipse.ecf.provider.filetransfer.httpclient Configuring org.eclipse.ecf.provider.filetransfer.httpclient.ssl Configuring org.eclipse.ecf.provider.filetransfer.ssl Configuring org.eclipse.ecf.ssl Configuring org.eclipse.egit Configuring org.eclipse.egit.core Configuring org.eclipse.egit.doc Configuring org.eclipse.egit.feature.group Configuring org.eclipse.egit.feature.jar Configuring org.eclipse.egit.import Configuring org.eclipse.egit.import.feature.group Configuring org.eclipse.egit.import.feature.jar Configuring org.eclipse.egit.psf.feature.group Configuring org.eclipse.egit.psf.feature.jar Configuring org.eclipse.egit.ui Configuring org.eclipse.epp.mpc.core Configuring org.eclipse.epp.mpc.feature.group Configuring org.eclipse.epp.mpc.feature.jar Configuring org.eclipse.epp.mpc.help.ui Configuring org.eclipse.epp.mpc.ui Configuring org.eclipse.epp.package.common.feature.feature.group Configuring org.eclipse.epp.package.common.feature.feature.jar Configuring org.eclipse.equinox.app Configuring org.eclipse.equinox.bidi Configuring org.eclipse.equinox.common Configuring org.eclipse.equinox.concurrent Configuring org.eclipse.equinox.console Configuring org.eclipse.equinox.ds Configuring org.eclipse.equinox.event Configuring org.eclipse.equinox.frameworkadmin Configuring org.eclipse.equinox.frameworkadmin.equinox Configuring org.eclipse.equinox.http.jetty Configuring org.eclipse.equinox.http.registry Configuring org.eclipse.equinox.http.servlet Configuring org.eclipse.equinox.jsp.jasper Configuring org.eclipse.equinox.jsp.jasper.registry Configuring org.eclipse.equinox.launcher Configuring org.eclipse.equinox.launcher.win32.win32.x86 Configuring org.eclipse.equinox.p2.artifact.repository Configuring org.eclipse.equinox.p2.console Configuring org.eclipse.equinox.p2.core Configuring org.eclipse.equinox.p2.core.feature.feature.group Configuring org.eclipse.equinox.p2.core.feature.feature.jar Configuring org.eclipse.equinox.p2.director Configuring org.eclipse.equinox.p2.director.app Configuring org.eclipse.equinox.p2.directorywatcher Configuring org.eclipse.equinox.p2.discovery Configuring org.eclipse.equinox.p2.discovery.compatibility Configuring org.eclipse.equinox.p2.discovery.feature.feature.group Configuring org.eclipse.equinox.p2.discovery.feature.feature.jar Configuring org.eclipse.equinox.p2.engine Configuring org.eclipse.equinox.p2.extensionlocation Configuring org.eclipse.equinox.p2.extras.feature.feature.group Configuring org.eclipse.equinox.p2.extras.feature.feature.jar Configuring org.eclipse.equinox.p2.garbagecollector Configuring org.eclipse.equinox.p2.jarprocessor Configuring org.eclipse.equinox.p2.metadata Configuring org.eclipse.equinox.p2.metadata.repository Configuring org.eclipse.equinox.p2.operations Configuring org.eclipse.equinox.p2.publisher Configuring org.eclipse.equinox.p2.publisher.eclipse Configuring org.eclipse.equinox.p2.ql Configuring org.eclipse.equinox.p2.rcp.feature.feature.group Configuring org.eclipse.equinox.p2.rcp.feature.feature.jar Configuring org.eclipse.equinox.p2.reconciler.dropins Configuring org.eclipse.equinox.p2.repository Configuring org.eclipse.equinox.p2.repository.tools Configuring org.eclipse.equinox.p2.touchpoint.eclipse Configuring org.eclipse.equinox.p2.touchpoint.natives Configuring org.eclipse.equinox.p2.transport.ecf Configuring org.eclipse.equinox.p2.ui Configuring org.eclipse.equinox.p2.ui.discovery Configuring org.eclipse.equinox.p2.ui.importexport Configuring org.eclipse.equinox.p2.ui.sdk Configuring org.eclipse.equinox.p2.ui.sdk.scheduler Configuring org.eclipse.equinox.p2.updatechecker Configuring org.eclipse.equinox.p2.updatesite Configuring org.eclipse.equinox.p2.user.ui.feature.group Configuring org.eclipse.equinox.p2.user.ui.feature.jar Configuring org.eclipse.equinox.preferences Configuring org.eclipse.equinox.registry Configuring org.eclipse.equinox.security Configuring org.eclipse.equinox.security.ui Configuring org.eclipse.equinox.security.win32.x86 Configuring org.eclipse.equinox.simpleconfigurator Configuring org.eclipse.equinox.simpleconfigurator.manipulator Configuring org.eclipse.equinox.util Configuring org.eclipse.help Configuring org.eclipse.help.appserver Configuring org.eclipse.help.base Configuring org.eclipse.help.feature.group Configuring org.eclipse.help.feature.jar Configuring org.eclipse.help.ui Configuring org.eclipse.help.webapp Configuring org.eclipse.jdt.core Configuring org.eclipse.jdt.debug Configuring org.eclipse.jdt.launching Configuring org.eclipse.jetty.continuation Configuring org.eclipse.jetty.http Configuring org.eclipse.jetty.io Configuring org.eclipse.jetty.security Configuring org.eclipse.jetty.server Configuring org.eclipse.jetty.servlet Configuring org.eclipse.jetty.util Configuring org.eclipse.jface Configuring org.eclipse.jface.databinding Configuring org.eclipse.jface.text Configuring org.eclipse.jgit Configuring org.eclipse.jgit.feature.group Configuring org.eclipse.jgit.feature.jar Configuring org.eclipse.jsch.core Configuring org.eclipse.jsch.ui Configuring org.eclipse.linuxtools.cdt.autotools.core Configuring org.eclipse.ltk.core.refactoring Configuring org.eclipse.ltk.ui.refactoring Configuring org.eclipse.mylyn.bugzilla.core Configuring org.eclipse.mylyn.bugzilla.ide Configuring org.eclipse.mylyn.bugzilla.ui Configuring org.eclipse.mylyn.bugzilla_feature.feature.group Configuring org.eclipse.mylyn.bugzilla_feature.feature.jar Configuring org.eclipse.mylyn.commons.core Configuring org.eclipse.mylyn.commons.feature.group Configuring org.eclipse.mylyn.commons.feature.jar Configuring org.eclipse.mylyn.commons.identity Configuring org.eclipse.mylyn.commons.identity.core Configuring org.eclipse.mylyn.commons.identity.feature.group Configuring org.eclipse.mylyn.commons.identity.feature.jar Configuring org.eclipse.mylyn.commons.net Configuring org.eclipse.mylyn.commons.notifications Configuring org.eclipse.mylyn.commons.notifications.core Configuring org.eclipse.mylyn.commons.notifications.feature.group Configuring org.eclipse.mylyn.commons.notifications.feature.jar Configuring org.eclipse.mylyn.commons.notifications.feed Configuring org.eclipse.mylyn.commons.notifications.ui Configuring org.eclipse.mylyn.commons.repositories Configuring org.eclipse.mylyn.commons.repositories.core Configuring org.eclipse.mylyn.commons.repositories.feature.group Configuring org.eclipse.mylyn.commons.repositories.feature.jar Configuring org.eclipse.mylyn.commons.repositories.ui Configuring org.eclipse.mylyn.commons.screenshots Configuring org.eclipse.mylyn.commons.team Configuring org.eclipse.mylyn.commons.ui Configuring org.eclipse.mylyn.commons.workbench Configuring org.eclipse.mylyn.commons.xmlrpc Configuring org.eclipse.mylyn.context.core Configuring org.eclipse.mylyn.context.tasks.ui Configuring org.eclipse.mylyn.context.ui Configuring org.eclipse.mylyn.context_feature.feature.group Configuring org.eclipse.mylyn.context_feature.feature.jar Configuring org.eclipse.mylyn.discovery.core Configuring org.eclipse.mylyn.discovery.feature.group Configuring org.eclipse.mylyn.discovery.feature.jar Configuring org.eclipse.mylyn.discovery.ui Configuring org.eclipse.mylyn.help.ui Configuring org.eclipse.mylyn.ide.ui Configuring org.eclipse.mylyn.ide_feature.feature.group Configuring org.eclipse.mylyn.ide_feature.feature.jar Configuring org.eclipse.mylyn.monitor.core Configuring org.eclipse.mylyn.monitor.feature.group Configuring org.eclipse.mylyn.monitor.feature.jar Configuring org.eclipse.mylyn.monitor.ui Configuring org.eclipse.mylyn.resources.ui Configuring org.eclipse.mylyn.tasks.bugs Configuring org.eclipse.mylyn.tasks.core Configuring org.eclipse.mylyn.tasks.ide.feature.group Configuring org.eclipse.mylyn.tasks.ide.feature.jar Configuring org.eclipse.mylyn.tasks.index.core Configuring org.eclipse.mylyn.tasks.index.ui Configuring org.eclipse.mylyn.tasks.search Configuring org.eclipse.mylyn.tasks.ui Configuring org.eclipse.mylyn.team.cvs Configuring org.eclipse.mylyn.team.ui Configuring org.eclipse.mylyn.team_feature.feature.group Configuring org.eclipse.mylyn.team_feature.feature.jar Configuring org.eclipse.mylyn.wikitext.confluence.core Configuring org.eclipse.mylyn.wikitext.confluence.ui Configuring org.eclipse.mylyn.wikitext.core Configuring org.eclipse.mylyn.wikitext.help.ui Configuring org.eclipse.mylyn.wikitext.mediawiki.core Configuring org.eclipse.mylyn.wikitext.mediawiki.ui Configuring org.eclipse.mylyn.wikitext.tasks.ui Configuring org.eclipse.mylyn.wikitext.textile.core Configuring org.eclipse.mylyn.wikitext.textile.ui Configuring org.eclipse.mylyn.wikitext.tracwiki.core Configuring org.eclipse.mylyn.wikitext.tracwiki.ui Configuring org.eclipse.mylyn.wikitext.twiki.core Configuring org.eclipse.mylyn.wikitext.twiki.ui Configuring org.eclipse.mylyn.wikitext.ui Configuring org.eclipse.mylyn.wikitext_feature.feature.group Configuring org.eclipse.mylyn.wikitext_feature.feature.jar Configuring org.eclipse.mylyn_feature.feature.group Configuring org.eclipse.mylyn_feature.feature.jar Configuring org.eclipse.osgi Configuring org.eclipse.osgi.services Configuring org.eclipse.osgi.util Configuring org.eclipse.platform Configuring org.eclipse.platform.doc.user Configuring org.eclipse.platform.feature.group Configuring org.eclipse.platform.feature.jar Configuring org.eclipse.platform.ide Configuring org.eclipse.platform_root Configuring org.eclipse.rcp Configuring org.eclipse.rcp.configuration.feature.group Configuring org.eclipse.rcp.configuration_root.win32.win32.x86 Configuring org.eclipse.rcp.feature.group Configuring org.eclipse.rcp.feature.jar Configuring org.eclipse.rcp_root Configuring org.eclipse.rse Configuring org.eclipse.rse.connectorservice.dstore Configuring org.eclipse.rse.connectorservice.local Configuring org.eclipse.rse.connectorservice.ssh Configuring org.eclipse.rse.connectorservice.telnet Configuring org.eclipse.rse.core Configuring org.eclipse.rse.core.feature.group Configuring org.eclipse.rse.core.feature.jar Configuring org.eclipse.rse.doc.user Configuring org.eclipse.rse.dstore.feature.group Configuring org.eclipse.rse.dstore.feature.jar Configuring org.eclipse.rse.dstore.security Configuring org.eclipse.rse.efs Configuring org.eclipse.rse.efs.ui Configuring org.eclipse.rse.feature.group Configuring org.eclipse.rse.feature.jar Configuring org.eclipse.rse.files.ui Configuring org.eclipse.rse.ftp.feature.group Configuring org.eclipse.rse.ftp.feature.jar Configuring org.eclipse.rse.importexport Configuring org.eclipse.rse.local.feature.group Configuring org.eclipse.rse.local.feature.jar Configuring org.eclipse.rse.processes.ui Configuring org.eclipse.rse.services Configuring org.eclipse.rse.services.dstore Configuring org.eclipse.rse.services.files.ftp Configuring org.eclipse.rse.services.local Configuring org.eclipse.rse.services.ssh Configuring org.eclipse.rse.services.telnet Configuring org.eclipse.rse.shells.ui Configuring org.eclipse.rse.ssh.feature.group Configuring org.eclipse.rse.ssh.feature.jar Configuring org.eclipse.rse.subsystems.files.core Configuring org.eclipse.rse.subsystems.files.dstore Configuring org.eclipse.rse.subsystems.files.ftp Configuring org.eclipse.rse.subsystems.files.local Configuring org.eclipse.rse.subsystems.files.ssh Configuring org.eclipse.rse.subsystems.processes.core Configuring org.eclipse.rse.subsystems.processes.dstore Configuring org.eclipse.rse.subsystems.processes.local Configuring org.eclipse.rse.subsystems.processes.shell.linux Configuring org.eclipse.rse.subsystems.shells.core Configuring org.eclipse.rse.subsystems.shells.dstore Configuring org.eclipse.rse.subsystems.shells.local Configuring org.eclipse.rse.subsystems.shells.ssh Configuring org.eclipse.rse.subsystems.shells.telnet Configuring org.eclipse.rse.subsystems.terminals.core Configuring org.eclipse.rse.subsystems.terminals.ssh Configuring org.eclipse.rse.telnet.feature.group Configuring org.eclipse.rse.telnet.feature.jar Configuring org.eclipse.rse.terminals.feature.group Configuring org.eclipse.rse.terminals.feature.jar Configuring org.eclipse.rse.terminals.ui Configuring org.eclipse.rse.ui Configuring org.eclipse.search Configuring org.eclipse.swt Configuring org.eclipse.swt.win32.win32.x86 Configuring org.eclipse.team.core Configuring org.eclipse.team.cvs.core Configuring org.eclipse.team.cvs.ssh2 Configuring org.eclipse.team.cvs.ui Configuring org.eclipse.team.ui Configuring org.eclipse.text Configuring org.eclipse.tm.terminal Configuring org.eclipse.tm.terminal.feature.group Configuring org.eclipse.tm.terminal.feature.jar Configuring org.eclipse.tm.terminal.sdk.feature.group Configuring org.eclipse.tm.terminal.sdk.feature.jar Configuring org.eclipse.tm.terminal.serial Configuring org.eclipse.tm.terminal.serial.feature.group Configuring org.eclipse.tm.terminal.serial.feature.jar Configuring org.eclipse.tm.terminal.serial.source Configuring org.eclipse.tm.terminal.source Configuring org.eclipse.tm.terminal.ssh Configuring org.eclipse.tm.terminal.ssh.feature.group Configuring org.eclipse.tm.terminal.ssh.feature.jar Configuring org.eclipse.tm.terminal.ssh.source Configuring org.eclipse.tm.terminal.telnet Configuring org.eclipse.tm.terminal.telnet.feature.group Configuring org.eclipse.tm.terminal.telnet.feature.jar Configuring org.eclipse.tm.terminal.telnet.source Configuring org.eclipse.tm.terminal.view Configuring org.eclipse.tm.terminal.view.feature.group Configuring org.eclipse.tm.terminal.view.feature.jar Configuring org.eclipse.tm.terminal.view.source Configuring org.eclipse.ui Configuring org.eclipse.ui.browser Configuring org.eclipse.ui.cheatsheets Configuring org.eclipse.ui.console Configuring org.eclipse.ui.editors Configuring org.eclipse.ui.externaltools Configuring org.eclipse.ui.forms Configuring org.eclipse.ui.ide Configuring org.eclipse.ui.ide.application Configuring org.eclipse.ui.intro Configuring org.eclipse.ui.intro.universal Configuring org.eclipse.ui.navigator Configuring org.eclipse.ui.navigator.resources Configuring org.eclipse.ui.net Configuring org.eclipse.ui.presentations.r21 Configuring org.eclipse.ui.views Configuring org.eclipse.ui.views.log Configuring org.eclipse.ui.views.properties.tabbed Configuring org.eclipse.ui.win32 Configuring org.eclipse.ui.workbench Configuring org.eclipse.ui.workbench.compatibility Configuring org.eclipse.ui.workbench.texteditor Configuring org.eclipse.update.configurator Configuring org.eclipse.update.core Configuring org.eclipse.update.core.win32 Configuring org.eclipse.update.scheduler Configuring org.eclipse.update.ui Configuring org.eclipse.wst.jsdt.core Configuring org.eclipse.wst.jsdt.debug.core Configuring org.eclipse.wst.jsdt.debug.crossfire Configuring org.eclipse.wst.jsdt.debug.rhino Configuring org.eclipse.wst.jsdt.debug.rhino.debugger Configuring org.eclipse.wst.jsdt.debug.rhino.ui Configuring org.eclipse.wst.jsdt.debug.transport Configuring org.eclipse.wst.jsdt.debug.ui Configuring org.eclipse.wst.jsdt.doc Configuring org.eclipse.wst.jsdt.feature.feature.group Configuring org.eclipse.wst.jsdt.feature.feature.jar Configuring org.eclipse.wst.jsdt.manipulation Configuring org.eclipse.wst.jsdt.support.firefox Configuring org.eclipse.wst.jsdt.support.ie Configuring org.eclipse.wst.jsdt.ui Configuring org.jdom Configuring org.jsoup Configuring org.mozilla.javascript Configuring org.sat4j.core Configuring org.sat4j.pb Configuring tooling.org.eclipse.update.feature.default Configuring tooling.osgi.bundle.default Configuring tooling.source.default Configuring toolingorg.eclipse.configuration Configuring toolingorg.eclipse.equinox.launcher Configuring toolingorg.eclipse.equinox.launcher.win32.win32.x86 Configuring toolingorg.eclipse.platform.ide.config.win32.win32.x86 Configuring toolingorg.eclipse.platform.ide.configuration Configuring toolingorg.eclipse.platform.ide.ini.win32.win32.x86 Configuring toolingwin32.win32.x86org.eclipse.core.runtime Configuring toolingwin32.win32.x86org.eclipse.equinox.common Configuring toolingwin32.win32.x86org.eclipse.equinox.ds Configuring toolingwin32.win32.x86org.eclipse.equinox.event Configuring toolingwin32.win32.x86org.eclipse.equinox.p2.reconciler.dropins Configuring toolingwin32.win32.x86org.eclipse.equinox.simpleconfigurator Configuring toolingwin32.win32.x86org.eclipse.update.configurator Preparing to commit the provisioning operation. Committing the provisioning operation. Preparing to commit the provisioning operation. Committing the provisioning operation. Operation completed in 227611 ms. 08/07/2013 17:33:31PM - percent now 3 08/07/2013 17:33:31PM - eclipse installed successfully, looking for binary 08/07/2013 17:33:31PM - copied C:/Users/asus/AppData/Local/Temp/ijtmp_EDACDD11-B33D-4D43-806D-6BD0DBD8D818/ccstudio.exe to C:/ti/ccsv5/eclipse 08/07/2013 17:33:31PM - copied C:/Users/asus/AppData/Local/Temp/ijtmp_EDACDD11-B33D-4D43-806D-6BD0DBD8D818/ccstudio.ini to C:/ti/ccsv5/eclipse 08/07/2013 17:33:31PM - could not find C:/Users/asus/AppData/Local/Temp/ijtmp_EDACDD11-B33D-4D43-806D-6BD0DBD8D818/config.ini 08/07/2013 17:33:31PM - copying C:/Users/asus/AppData/Local/Temp/ijtmp_EDACDD11-B33D-4D43-806D-6BD0DBD8D818/eclipse/plugins/com.ti.ccstudio.p2app_1.0.0.201202161700.jar worked 08/07/2013 17:33:31PM - app = com.ti.ccstudio.p2app | com.ti.ccstudio.p2app 08/07/2013 17:33:31PM - installing P2TOOLS in C:/Users/asus/AppData/Local/Temp/ijtmp_EDACDD11-B33D-4D43-806D-6BD0DBD8D818/baserepo 08/07/2013 17:33:31PM - from F:/download/CCS5.4.0.00091_win32/baserepo 08/07/2013 17:33:31PM - percent now 3 08/07/2013 17:33:31PM - 1 - 20756 08/07/2013 17:33:31PM - making C:/Users/asus/AppData/Local/Temp/ijtmp_EDACDD11-B33D-4D43-806D-6BD0DBD8D818/baserepo 3 08/07/2013 17:33:31PM - cmd = "C:/Users/asus/AppData/Local/Temp/ijtmp_EDACDD11-B33D-4D43-806D-6BD0DBD8D818/unzip.exe" -q -o -d "C:/Users/asus/AppData/Local/Temp/ijtmp_EDACDD11-B33D-4D43-806D-6BD0DBD8D818/baserepo" "F:/download/CCS5.4.0.00091_win32/baserepo/lwrepo.zip" 08/07/2013 17:33:31PM - successfully unzipped lwrepo.zip 08/07/2013 17:33:31PM - percent now 3 08/07/2013 17:33:31PM - P2TOOLS checked out ok! 08/07/2013 17:33:31PM - cmdline = "C:/ti/ccsv5/eclipse/eclipsec.exe" -application com.ti.ccstudio.p2app -listInstalledRoots -nosplash 08/07/2013 17:33:47PM - setting featuregroups(org.eclipse.cdt.autotools.feature.group) to 1 and versions(org.eclipse.cdt.autotools.feature.group) to 3.0.1.201209170703 08/07/2013 17:33:47PM - setting featuregroups(org.eclipse.cdt.build.crossgcc.feature.group) to 1 and versions(org.eclipse.cdt.build.crossgcc.feature.group) to 1.1.0.201209170703 08/07/2013 17:33:47PM - setting featuregroups(org.eclipse.cdt.debug.gdbjtag.feature.group) to 1 and versions(org.eclipse.cdt.debug.gdbjtag.feature.group) to 7.0.0.201209170703 08/07/2013 17:33:47PM - setting featuregroups(org.eclipse.cdt.debug.ui.memory.feature.group) to 1 and versions(org.eclipse.cdt.debug.ui.memory.feature.group) to 2.2.0.201209170703 08/07/2013 17:33:47PM - setting featuregroups(org.eclipse.cdt.feature.group) to 1 and versions(org.eclipse.cdt.feature.group) to 8.1.1.201209170703 08/07/2013 17:33:47PM - setting featuregroups(org.eclipse.cdt.launch.remote.feature.group) to 1 and versions(org.eclipse.cdt.launch.remote.feature.group) to 6.0.0.201209170703 08/07/2013 17:33:47PM - setting featuregroups(org.eclipse.cdt.msw.feature.group) to 1 and versions(org.eclipse.cdt.msw.feature.group) to 1.0.0.201209170703 08/07/2013 17:33:47PM - "C:/ti/ccsv5/eclipse/eclipsec.exe" -application com.ti.ccstudio.p2app -repository "file:/C:/Users/asus/AppData/Local/Temp/ijtmp_EDACDD11-B33D-4D43-806D-6BD0DBD8D818/baserepo/lwrepo" -installIU com.ti.ccstudio.p2tool.feature.group -nosplash 08/07/2013 17:33:47PM - percent now 4 08/07/2013 17:33:47PM - Executing actions 057C7BE9-44B0-45B2-A154-6FEE90439EB4 - InstallApp 08/07/2013 17:33:47PM - Executing action 057C7BE9-44B0-45B2-A154-6FEE90439EB4 - InstallApp 08/07/2013 17:33:47PM - Executing with progressive output 08/07/2013 17:33:47PM - Watching progressive output for special syntax. 08/07/2013 17:33:47PM - Executing Command Line: "C:/ti/ccsv5/eclipse/eclipsec.exe" -application com.ti.ccstudio.p2app -repository "file:/C:/Users/asus/AppData/Local/Temp/ijtmp_EDACDD11-B33D-4D43-806D-6BD0DBD8D818/baserepo/lwrepo" -installIU com.ti.ccstudio.p2tool.feature.group -nosplash 08/07/2013 17:33:47PM - Watching progressive output for matches 08/07/2013 17:33:57PM - ExternalProgramStatus 0 08/07/2013 17:33:57PM - ExternalProgramResult Installing com.ti.ccstudio.p2tool.feature.group 5.4.0.201303071252. Downloading com.ti.ccstudio.p2.actions Downloading com.ti.ccstudio.p2tool Downloading com.ti.ccstudio.startupInstaller Installing com.ti.ccstudio.p2.actions Installing com.ti.ccstudio.p2tool.feature.group Installing com.ti.ccstudio.p2tool.feature.jar Installing com.ti.ccstudio.startupInstaller Configuring com.ti.ccstudio.p2.actions Configuring com.ti.ccstudio.p2tool.feature.group Configuring com.ti.ccstudio.p2tool.feature.jar Configuring com.ti.ccstudio.startupInstaller Preparing to commit the provisioning operation. Committing the provisioning operation. Operation completed in 6944 ms. 08/07/2013 17:33:57PM - percent now 4 08/07/2013 17:33:57PM - ECLIPSE url = F:/download/CCS5.4.0.00091_win32/featurerepo 08/07/2013 17:33:57PM - "C:/ti/ccsv5/eclipse/eclipsec.exe" -application com.ti.ccstudio.p2app -repository "file:/F:/download/CCS5.4.0.00091_win32/featurerepo" -installIU com.ti.ccstudio.installer.win32.feature.group -nosplash 08/07/2013 17:33:57PM - percent now 4 08/07/2013 17:33:57PM - Executing actions 057C7BE9-44B0-45B2-A154-6FEE90439EB4 - InstallApp 08/07/2013 17:33:57PM - Executing action 057C7BE9-44B0-45B2-A154-6FEE90439EB4 - InstallApp 08/07/2013 17:33:57PM - Executing with progressive output 08/07/2013 17:33:57PM - Watching progressive output for special syntax. 08/07/2013 17:33:57PM - Executing Command Line: "C:/ti/ccsv5/eclipse/eclipsec.exe" -application com.ti.ccstudio.p2app -repository "file:/F:/download/CCS5.4.0.00091_win32/featurerepo" -installIU com.ti.ccstudio.installer.win32.feature.group -nosplash 08/07/2013 17:33:57PM - Watching progressive output for matches 08/07/2013 17:34:10PM - ExternalProgramStatus 0 08/07/2013 17:34:10PM - ExternalProgramResult Installing com.ti.ccstudio.installer.win32.feature.group 5.4.0.00091. Downloading com.ti.ccstudio.installer.win32 Downloading com.ti.ccstudio.installer.win32_root Installing com.ti.ccstudio.installer.win32.feature.group Installing com.ti.ccstudio.installer.win32.feature.jar Installing com.ti.ccstudio.installer.win32_root Configuring com.ti.ccstudio.installer.win32.feature.group Configuring com.ti.ccstudio.installer.win32.feature.jar Configuring com.ti.ccstudio.installer.win32_root Preparing to commit the provisioning operation. Committing the provisioning operation. Operation completed in 4586 ms. 08/07/2013 17:34:10PM - percent now 4 08/07/2013 17:34:10PM - INSTALLER checked out ok! 08/07/2013 17:34:10PM - processing JRE 08/07/2013 17:34:10PM - processing JRE 08/07/2013 17:34:10PM - tmpsize = 29 08/07/2013 17:34:10PM - processing ECLIPSE 08/07/2013 17:34:10PM - processing ECLIPSE 08/07/2013 17:34:10PM - tmpsize = 87 08/07/2013 17:34:10PM - processing ECLIPSECORE 08/07/2013 17:34:10PM - processing ECLIPSECORE 08/07/2013 17:34:10PM - tmpsize = 50 08/07/2013 17:34:10PM - processing P2TOOLS 08/07/2013 17:34:10PM - processing P2TOOLS 08/07/2013 17:34:10PM - tmpsize = 0 08/07/2013 17:34:10PM - processing MSVC80 08/07/2013 17:34:10PM - processing MSVC80 08/07/2013 17:34:10PM - tmpsize = 2 08/07/2013 17:34:10PM - processing MSVC2008 08/07/2013 17:34:10PM - processing MSVC2008 08/07/2013 17:34:10PM - tmpsize = 4 08/07/2013 17:34:10PM - processing MSVC2012 08/07/2013 17:34:10PM - processing MSVC2012 08/07/2013 17:34:10PM - tmpsize = 6 08/07/2013 17:34:10PM - processing INSTALLER 08/07/2013 17:34:10PM - processing INSTALLER 08/07/2013 17:34:10PM - tmpsize = 0 08/07/2013 17:34:10PM - DS doesn't need to be processed now, skipping 08/07/2013 17:34:10PM - CGT_DEFAULTLIBS_C2800 doesn't need to be processed now, skipping 08/07/2013 17:34:10PM - CGT_DEFAULTLIBS_C5400 doesn't need to be processed now, skipping 08/07/2013 17:34:10PM - CGT_DEFAULTLIBS_C5500 doesn't need to be processed now, skipping 08/07/2013 17:34:10PM - CGT_DEFAULTLIBS_C6000 doesn't need to be processed now, skipping 08/07/2013 17:34:10PM - CGT_DEFAULTLIBS_MSP430 doesn't need to be processed now, skipping 08/07/2013 17:34:10PM - CGT_DEFAULTLIBS_TMS470 doesn't need to be processed now, skipping 08/07/2013 17:34:10PM - IDE_MAIN doesn't need to be processed now, skipping 08/07/2013 17:34:10PM - IDE_WORKFLOW doesn't need to be processed now, skipping 08/07/2013 17:34:10PM - IDE_ARM doesn't need to be processed now, skipping 08/07/2013 17:34:10PM - IDE_MSP430 doesn't need to be processed now, skipping 08/07/2013 17:34:10PM - IDE_C2000 doesn't need to be processed now, skipping 08/07/2013 17:34:10PM - IDE_C5500 doesn't need to be processed now, skipping 08/07/2013 17:34:10PM - IDE_C6000 doesn't need to be processed now, skipping 08/07/2013 17:34:10PM - IDE_C5400 doesn't need to be processed now, skipping 08/07/2013 17:34:10PM - DVT_COMMON doesn't need to be processed now, skipping 08/07/2013 17:34:10PM - DVT_TRACE doesn't need to be processed now, skipping 08/07/2013 17:34:10PM - DVT_VIA_CCS doesn't need to be processed now, skipping 08/07/2013 17:34:10PM - DVT_UIA doesn't need to be processed now, skipping 08/07/2013 17:34:10PM - DVT_ENERGYTRACE doesn't need to be processed now, skipping 08/07/2013 17:34:10PM - GMF doesn't need to be processed now, skipping 08/07/2013 17:34:10PM - TC_XDCTOOLS doesn't need to be processed now, skipping 08/07/2013 17:34:10PM - TC_ARM_XDCTOOLS doesn't need to be processed now, skipping 08/07/2013 17:34:10PM - TC_C2000_XDCTOOLS doesn't need to be processed now, skipping 08/07/2013 17:34:10PM - TC_C6000_XDCTOOLS doesn't need to be processed now, skipping 08/07/2013 17:34:10PM - TC_MSP430_XDCTOOLS doesn't need to be processed now, skipping 08/07/2013 17:34:10PM - TC_BIOS5 doesn't need to be processed now, skipping 08/07/2013 17:34:10PM - TC_BIOS6 doesn't need to be processed now, skipping 08/07/2013 17:34:10PM - TC_ARM_BIOS6 doesn't need to be processed now, skipping 08/07/2013 17:34:10PM - TC_C2000_BIOS6 doesn't need to be processed now, skipping 08/07/2013 17:34:10PM - TC_C6000_BIOS6 doesn't need to be processed now, skipping 08/07/2013 17:34:10PM - TC_MSP430_BIOS6 doesn't need to be processed now, skipping 08/07/2013 17:34:10PM - TC_XDAIS doesn't need to be processed now, skipping 08/07/2013 17:34:10PM - GRACE doesn't need to be processed now, skipping 08/07/2013 17:34:10PM - UIA doesn't need to be processed now, skipping 08/07/2013 17:34:10PM - MSP430ware doesn't need to be processed now, skipping 08/07/2013 17:34:10PM - CCSINIT doesn't need to be processed now, skipping 08/07/2013 17:34:10PM - SIM_TI doesn't need to be processed now, skipping 08/07/2013 17:34:10PM - EMU_BH doesn't need to be processed now, skipping 08/07/2013 17:34:10PM - EMU_TI doesn't need to be processed now, skipping 08/07/2013 17:34:10PM - EMU_STELLARIS doesn't need to be processed now, skipping 08/07/2013 17:34:10PM - EMU_HERCULES doesn't need to be processed now, skipping 08/07/2013 17:34:10PM - EMU_SD doesn't need to be processed now, skipping 08/07/2013 17:34:10PM - EMU_C2000 doesn't need to be processed now, skipping 08/07/2013 17:34:10PM - EMU_C2000_FLASH doesn't need to be processed now, skipping 08/07/2013 17:34:10PM - EMU_MSP430 doesn't need to be processed now, skipping 08/07/2013 17:34:10PM - KEYSTONE1 doesn't need to be processed now, skipping 08/07/2013 17:34:10PM - KEYSTONE2 doesn't need to be processed now, skipping 08/07/2013 17:34:10PM - DMED doesn't need to be processed now, skipping 08/07/2013 17:34:10PM - MSP430_CGT_HELP doesn't need to be processed now, skipping 08/07/2013 17:34:10PM - C6000_CGT_HELP doesn't need to be processed now, skipping 08/07/2013 17:34:10PM - ARM_CGT_HELP doesn't need to be processed now, skipping 08/07/2013 17:34:10PM - C2000_CGT_HELP doesn't need to be processed now, skipping 08/07/2013 17:34:10PM - C5500_CGT_HELP doesn't need to be processed now, skipping 08/07/2013 17:34:10PM - DEV_SUPPORT_SHARED doesn't need to be processed now, skipping 08/07/2013 17:34:10PM - DEV_SUPPORT_SITARA doesn't need to be processed now, skipping 08/07/2013 17:34:10PM - DEV_SUPPORT_C55XX doesn't need to be processed now, skipping 08/07/2013 17:34:10PM - DEV_SUPPORT_C54XX doesn't need to be processed now, skipping 08/07/2013 17:34:10PM - DEV_SUPPORT_C6000 doesn't need to be processed now, skipping 08/07/2013 17:34:10PM - DEV_SUPPORT_C6000MC doesn't need to be processed now, skipping 08/07/2013 17:34:10PM - DEV_SUPPORT_DAVINCI doesn't need to be processed now, skipping 08/07/2013 17:34:10PM - DEV_SUPPORT_INTEGRA doesn't need to be processed now, skipping 08/07/2013 17:34:10PM - DEV_SUPPORT_OMAP doesn't need to be processed now, skipping 08/07/2013 17:34:10PM - DEV_SUPPORT_CC2538 doesn't need to be processed now, skipping 08/07/2013 17:34:10PM - XULRUNNER doesn't need to be processed now, skipping 08/07/2013 17:34:10PM - GCC_ARM_COMPILER doesn't need to be processed now, skipping 08/07/2013 17:34:10PM - TIVA_TM4C doesn't need to be processed now, skipping 08/07/2013 17:34:10PM - TIVA_TM4E doesn't need to be processed now, skipping 08/07/2013 17:34:14PM - here1 08/07/2013 17:34:14PM - setting featuregroups(com.ti.ccstudio.installer.win32.feature.group) to 1 08/07/2013 17:34:14PM - setting featuregroups(com.ti.ccstudio.p2tool.feature.group) to 1 08/07/2013 17:34:14PM - setting featuregroups(org.eclipse.cdt.autotools.feature.group) to 1 08/07/2013 17:34:14PM - setting featuregroups(org.eclipse.cdt.build.crossgcc.feature.group) to 1 08/07/2013 17:34:14PM - setting featuregroups(org.eclipse.cdt.debug.gdbjtag.feature.group) to 1 08/07/2013 17:34:14PM - setting featuregroups(org.eclipse.cdt.debug.ui.memory.feature.group) to 1 08/07/2013 17:34:14PM - setting featuregroups(org.eclipse.cdt.feature.group) to 1 08/07/2013 17:34:14PM - setting featuregroups(org.eclipse.cdt.launch.remote.feature.group) to 1 08/07/2013 17:34:14PM - setting featuregroups(org.eclipse.cdt.msw.feature.group) to 1 08/07/2013 17:34:14PM - length of features = 76; 1; 0 08/07/2013 17:34:14PM - JRE has been processed already 08/07/2013 17:34:14PM - length of features = 76; 2; 0 08/07/2013 17:34:14PM - ECLIPSE has been processed already 08/07/2013 17:34:14PM - length of features = 76; 3; 0 08/07/2013 17:34:14PM - ECLIPSECORE has been processed already 08/07/2013 17:34:14PM - length of features = 76; 4; 0 08/07/2013 17:34:14PM - P2TOOLS has been processed already 08/07/2013 17:34:14PM - length of features = 76; 5; 0 08/07/2013 17:34:14PM - MSVC80 has been processed already 08/07/2013 17:34:14PM - length of features = 76; 6; 0 08/07/2013 17:34:14PM - MSVC2008 has been processed already 08/07/2013 17:34:14PM - length of features = 76; 7; 0 08/07/2013 17:34:14PM - MSVC2012 has been processed already 08/07/2013 17:34:14PM - length of features = 76; 8; 0 08/07/2013 17:34:14PM - INSTALLER has been processed already 08/07/2013 17:34:14PM - length of features = 76; 9; 0 08/07/2013 17:34:14PM - processing DS 08/07/2013 17:34:14PM - processing DS 08/07/2013 17:34:14PM - tmpsize = 15 08/07/2013 17:34:14PM - state = initial 08/07/2013 17:34:14PM - binary = ti_dspack_ibsetup_5.4.0.279.exe 08/07/2013 17:34:14PM - gettcdir value now 08/07/2013 17:34:14PM - location = F:/download/CCS5.4.0.00091_win32/featurerepo 08/07/2013 17:34:14PM - percent now 4 08/07/2013 17:34:14PM - counting = 6; 9 76 08/07/2013 17:34:14PM - fullrepolist file:/F:/download/CCS5.4.0.00091_win32/featurerepo 08/07/2013 17:34:14PM - fullfeaturelist com.ti.ccstudio.debugserver.win32.feature.group 08/07/2013 17:34:14PM - "C:/ti/ccsv5/eclipse/eclipsec.exe" -application com.ti.ccstudio.p2app -repository "file:/F:/download/CCS5.4.0.00091_win32/featurerepo" -installIU com.ti.ccstudio.debugserver.win32.feature.group -nosplash 08/07/2013 17:34:14PM - percent now 4 08/07/2013 17:34:14PM - Executing actions 057C7BE9-44B0-45B2-A154-6FEE90439EB4 - InstallApp 08/07/2013 17:34:14PM - Executing action 057C7BE9-44B0-45B2-A154-6FEE90439EB4 - InstallApp 08/07/2013 17:34:14PM - Executing with progressive output 08/07/2013 17:34:14PM - Watching progressive output for special syntax. 08/07/2013 17:34:14PM - Executing Command Line: "C:/ti/ccsv5/eclipse/eclipsec.exe" -application com.ti.ccstudio.p2app -repository "file:/F:/download/CCS5.4.0.00091_win32/featurerepo" -installIU com.ti.ccstudio.debugserver.win32.feature.group -nosplash 08/07/2013 17:34:14PM - Watching progressive output for matches 08/07/2013 17:34:25PM - ExternalProgramStatus 0 08/07/2013 17:34:25PM - ExternalProgramResult Installing com.ti.ccstudio.debugserver.win32.feature.group 5.4.0.279. Downloading com.ti.ccstudio.debugserver.win32 Downloading com.ti.ccstudio.debugserver.win32_root Installing com.ti.ccstudio.debugserver.win32.feature.group Installing com.ti.ccstudio.debugserver.win32.feature.jar Installing com.ti.ccstudio.debugserver.win32_root Configuring com.ti.ccstudio.debugserver.win32.feature.group Configuring com.ti.ccstudio.debugserver.win32.feature.jar Configuring com.ti.ccstudio.debugserver.win32_root Preparing to commit the provisioning operation. Committing the provisioning operation. Operation completed in 7940 ms. 08/07/2013 17:34:25PM - percent now 4 08/07/2013 17:34:25PM - Processing DS to install 08/07/2013 17:34:25PM - processing DS 08/07/2013 17:34:25PM - tmpsize = 15 08/07/2013 17:34:25PM - state = initial 08/07/2013 17:34:25PM - binary = ti_dspack_ibsetup_5.4.0.279.exe 08/07/2013 17:34:25PM - location = F:/download/CCS5.4.0.00091_win32/featurerepo 08/07/2013 17:34:25PM - percent now 4 08/07/2013 17:34:25PM - values 15 1087 35 08/07/2013 17:34:25PM - increase by 0.482980680773 08/07/2013 17:34:25PM - percent now 4 08/07/2013 17:34:25PM - ext = .exe 08/07/2013 17:34:25PM - .exe: ti_dspack_ibsetup_5.4.0.279.exe --mode unattended --prefix "C:/ti/ccsv5" --eclipseprefix "C:/ti/ccsv5/eclipse" 08/07/2013 17:34:25PM - percent now 4 08/07/2013 17:34:25PM - Executing actions 057C7BE9-44B0-45B2-A154-6FEE90439EB4 - InstallApp 08/07/2013 17:34:25PM - Executing action 057C7BE9-44B0-45B2-A154-6FEE90439EB4 - InstallApp 08/07/2013 17:34:25PM - Executing with progressive output 08/07/2013 17:34:25PM - Watching progressive output for special syntax. 08/07/2013 17:34:25PM - Executing Command Line: "C:/ti/ccsv5/eclipse/downloads/ti_dspack_ibsetup_5.4.0.279.exe" --mode unattended --prefix "C:/ti/ccsv5" --eclipseprefix "C:/ti/ccsv5/eclipse" 08/07/2013 17:34:33PM - Watching progressive output for matches 08/07/2013 17:35:22PM - ExternalProgramResult: child killed: segmentation violation 08/07/2013 17:35:22PM - ExternalProgramStatus: 1 08/07/2013 17:35:22PM - Externalprogramresult: child killed: segmentation violation 08/07/2013 17:35:22PM - state = feature registered 08/07/2013 17:36:04PM - ERROR: Installer failed to install com.ti.ccstudio.debugserver.win32 correctly. The 2 most common reasons for failure are: 1. Anti-virus on your computer could have impeded the executable. 2. Download is corrupted. Please look at the log C:/Program Files (x86)/InstallJammer Registry/ccsv5/60556FE5-C1A1-4061-8DF8-FFB8393BAE2D/ccs_setup_5.4.0.00091_install.log for more information. 08/07/2013 17:36:04PM - Executing actions 664C34E4-4BFA-4F65-AC9F-7188ACA77179 - Cancel Actions 08/07/2013 17:36:04PM - Executing action 9793E317-8E78-4406-ABB0-EAE0C46EAC2E - Execute Copy Logs 08/07/2013 17:36:04PM - Executing actions 04EA6DAB-7AB3-4443-B9AD-CCDC93D5B688 - Copy Logs 08/07/2013 17:36:04PM - Executing action ADC91BE8-E948-40FE-B480-C4F873B2CB4C - Set timestamp 08/07/2013 17:36:04PM - Executing action A8CB9258-3B9C-4107-BE75-74F365A471F5 - Copy ccs_config.xml 08/07/2013 17:36:04PM - Executing action 59FE3F47-7DF2-46AC-B483-1EFDE3F29C30 - Copy manifest.xml 08/07/2013 17:36:04PM - Executing action 9D634302-B8CC-4D76-86D8-43500DD214FC - Copy installini.xml 08/07/2013 17:36:04PM - Executing action E931535B-9F6A-42DE-9A19-60B03E530732 - Copy Install Log 08/07/2013 17:36:04PM - Executing action 04549FCF-3B2D-4B94-9CA3-4CE05EA81B68 - Add To Uninstall 08/07/2013 17:36:04PM - Executing action BA457EA0-22FC-4C31-8DA1-83B0E688AD85 - Add To Uninstall 08/07/2013 17:36:04PM - Executing action 5D93D4EF-6CE0-4D91-ADE0-6234C3418D15 - Add To Uninstall 08/07/2013 17:36:04PM - Executing action 940F2F31-E53A-4405-9AA6-39BB95DB6CB2 - Add To Uninstall 08/07/2013 17:36:04PM - Checking conditions for 8DC9C68D-0C93-432C-9F50-9ECCB01EE7D2 - Rename Config File - Before Action is Executed 08/07/2013 17:36:04PM - Checking condition 13D96D8B-3F10-4DE3-AE45-2260F3EEF34D - File Exists Condition 08/07/2013 17:36:04PM - Checking to see if <%EclipseDir%>/ccs_config.xml.bk exists 08/07/2013 17:36:04PM - ** Checking to see if C:ti/ccsv5/eclipse/ccs_config.xml.bk exists 08/07/2013 17:36:04PM - Condition failed 08/07/2013 17:36:04PM - Skipping action 8DC9C68D-0C93-432C-9F50-9ECCB01EE7D2 - Rename Config File - conditions failed 08/07/2013 17:36:04PM - Checking conditions for 399F1ECF-EE97-4986-B49B-AFBAAA32EEB7 - Rename Update Installer - Before Action is Executed 08/07/2013 17:36:04PM - Checking condition 6C4DE03E-6713-48F2-82B8-822120A43BE6 - String Is Condition 08/07/2013 17:36:04PM - Checking to see if <%UpdateMode%> is true 08/07/2013 17:36:04PM - ** Checking to see if 0 is true 08/07/2013 17:36:04PM - Condition failed 08/07/2013 17:36:04PM - Skipping action 399F1ECF-EE97-4986-B49B-AFBAAA32EEB7 - Rename Update Installer - conditions failed 08/07/2013 17:36:04PM - Checking conditions for BFD51AB7-3ADC-495B-8102-3465FBB334B3 - Message Box - Before Action is Executed 08/07/2013 17:36:04PM - Checking condition D4BB77EC-B3CA-4A9A-8817-3D84D19B7811 - String Is Condition 08/07/2013 17:36:04PM - Checking to see if <%GuiMode%> is true 08/07/2013 17:36:04PM - ** Checking to see if 1 is true 08/07/2013 17:36:04PM - Condition passed 08/07/2013 17:36:04PM - Checking condition EBE9B8A8-38F1-4848-BCAD-5D7C7C548025 - String Is Condition 08/07/2013 17:36:04PM - Checking to see if <%UpdateMode%> is true 08/07/2013 17:36:04PM - ** Checking to see if 0 is true 08/07/2013 17:36:04PM - Condition failed 08/07/2013 17:36:04PM - Skipping action BFD51AB7-3ADC-495B-8102-3465FBB334B3 - Message Box - conditions failed 08/07/2013 17:36:04PM - Checking conditions for 05EE68FE-6C93-4340-82C2-21CF20CE1591 - Create Update.txt - Before Action is Executed 08/07/2013 17:36:04PM - Checking condition C8AE338B-8D17-4EDB-99A9-313C01CA352A - String Is Condition 08/07/2013 17:36:04PM - Checking to see if <%updates_found%> is true 08/07/2013 17:36:04PM - ** Checking to see if false is true 08/07/2013 17:36:04PM - Condition failed 08/07/2013 17:36:04PM - Skipping action 05EE68FE-6C93-4340-82C2-21CF20CE1591 - Create Update.txt - conditions failed 08/07/2013 17:36:04PM - Checking conditions for 1160585F-F26F-4111-911E-B0D10C849C31 - Remove .ij_running.txt - Before Action is Executed 08/07/2013 17:36:04PM - Checking condition 588D69A8-22C4-4BE8-A09F-5123D47D7FEF - File Exists Condition 08/07/2013 17:36:04PM - Checking to see if <%EclipseDir%>/downloads/.ijrunning.txt exists 08/07/2013 17:36:04PM - ** Checking to see if C:ti/ccsv5/eclipse/downloads/.ijrunning.txt exists 08/07/2013 17:36:04PM - Condition failed 08/07/2013 17:36:04PM - Skipping action 1160585F-F26F-4111-911E-B0D10C849C31 - Remove .ij_running.txt - conditions failed |
6个回答
fanbo,你的帖子好长啊!
大神!! 我电脑上面安装ccs 5.4 很急着用 遇到跟您一样的问题 请问 您是怎么解决的 |
我是系统问题,64位的不行,换了32位 |
827 浏览 1 评论
1071 浏览 0 评论
620 浏览 1 评论
467 浏览 1 评论
662 浏览 2 评论
264浏览 29评论
1227浏览 23评论
358浏览 20评论
337浏览 14评论
203浏览 13评论
GMT+8, 2025-3-6 13:46 , Processed in 1.974007 second(s), Total 54, Slave 49 queries .
