扫一扫,分享给好友
"../src/TcpMain.cpp", line 280: error #169: argument of type "void (*)()" is incompatible with parameter of type "void (*)() C"
"../src/TcpMain.cpp", line 280: error #169: argument of type "void (*)()" is incompatible with parameter of type "void (*)() C" "../src/TcpMain.cpp", line 280: error #169: argument of type "void (*)(IPN, uint, uint)" is incompatible with parameter of type "void (*)(IPN, uint, uint) C" "../src/TcpMain.cpp", line 436: error #169: argument of type "int (*)(SOCKET, UINT32)" is incompatible with parameter of type "int (*)(SOCKET, UINT32) C" the code on line 436 static void NetworkOpen() [ // Create our local servers hTCP = DaemonNew( SOCK_STREAMNC, 0, 7, dtask_tcp_deal, OS_TASKPRINORM, OS_TASKSTKNORM, 0, 3 ); ] the code on line 280: do [ rc = NC_NetStart( hCfg, NetworkOpen, NetworkClose, NetworkIPAddr ); ] while( rc > 0 ); How to solve the problem? |
可以在NDK API guide中找到这些函数的定义,确认调用函数的入参个数是否与定义是一致的,也可以参考mcsdk的例程mcsdk_2_01_02_06examplesndk
zbb9612 发表于 2018-6-21 18:02 Andy 你好: 多谢你的回复。这个问题我已经解决了。链接如下: http://e2e.ti.com/support/dsp/c6000_multi-core_dsps/f/639/p/337913/1179488.aspx#1179488 |
574 浏览 1 评论
412 浏览 1 评论
609 浏览 2 评论
877 浏览 3 评论
697 浏览 1 评论
166浏览 29评论
1111浏览 23评论
307浏览 20评论
267浏览 14评论
118浏览 13评论
GMT+8, 2025-1-26 14:36 , Processed in 0.727200 second(s), Total 46, Slave 41 queries .
