您好,AM335X u***0设置host模式,软件部分是不是只是在这个地方修改就行了,我的内核版本3.2 static struct omap_mu***_board_data mu***_board_data = [ .interface_type = MUSB_INTERFACE_ULPI, /* * mode[0:3] = USB0PORT's mode * mode[4:7] = USB1PORT's mode * AM335X beta EVM has USB0 in OTG mode and USB1 in host mode. */ .mode = (MUSB_HOST << 4) | MUSB_HOST, .power = 500, .instances = 1, ]; |
6个回答
是的,同时也请检查硬件连接部分。
请问一下3.2的内核中能否集成USB网络驱动 CDC MBIM接口功能 |
您好,请问下我的USB1也是用HOST模式,内核启动打印有关USB的信息如下 u***core: registered new interface driver u***fs u***core: registered new interface driver hub u***core: registered new device driver u*** mu***-ti81xx mu***-ti81xx: mu***0, board_mode=0x11, plat_mode=0x1 mu***-ti81xx mu***-ti81xx: mu***1, board_mode=0x11, plat_mode=0x1 mu***-hdrc: version 6.0, ?dma?, otg (peripheral+host) mu***-hdrc mu***-hdrc.0: dma type: pio mu***-hdrc: ConfigData=0xde (UTMI-8, dyn FIFOs, bulk combine, bulk split, HB-ISO Rx, HB-ISO Tx, SoftConn) mu***-hdrc: MHDRC RTL version 2.0 mu***-hdrc: setup fifo_mode 4 mu***-hdrc: 28/31 max ep, 16384/16384 memory mu***-hdrc mu***-hdrc.0: MUSB HDRC host driver drivers/u***/core/inode.c: creating file 'devices' drivers/u***/core/inode.c: creating file '001' mu***-hdrc mu***-hdrc.0: new USB bus registered, assigned bus number 1 u*** u***1: default language 0x0409 u*** u***1: udev 1, busnum 1, minor = 0 u*** u***1: New USB device found, idVendor=1d6b, idProduct=0002 u*** u***1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 u*** u***1: Product: MUSB HDRC host driver u*** u***1: Manufacturer: Linux 3.2.0-EmbedSky mu***-hcd u*** u***1: SerialNumber: mu***-hdrc.0 u*** u***1: u***_probe_device u*** u***1: configuration #1 chosen from 1 choice u*** u***1: adding 1-0:1.0 (config #1, interface 0) hub 1-0:1.0: u***_probe_interface hub 1-0:1.0: u***_probe_interface - got id drivers/u***/core/inode.c: creating file '001' mu***-hdrc mu***-hdrc.0: USB Host mode controller at e081c000 using PIO, IRQ 18 mu***-hdrc mu***-hdrc.1: dma type: pio mu***-hdrc: ConfigData=0xde (UTMI-8, dyn FIFOs, bulk combine, bulk split, HB-ISO Rx, HB-ISO Tx, SoftConn) mu***-hdrc: MHDRC RTL version 2.0 mu***-hdrc: setup fifo_mode 4 mu***-hdrc: 28/31 max ep, 16384/16384 memory mu***-hdrc mu***-hdrc.1: MUSB HDRC host driver drivers/u***/core/inode.c: creating file '002' mu***-hdrc mu***-hdrc.1: new USB bus registered, assigned bus number 2 u*** u***2: default language 0x0409 u*** u***2: udev 1, busnum 2, minor = 128 u*** u***2: New USB device found, idVendor=1d6b, idProduct=0002 u*** u***2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 u*** u***2: Product: MUSB HDRC host driver u*** u***2: Manufacturer: Linux 3.2.0-EmbedSky mu***-hcd u*** u***2: SerialNumber: mu***-hdrc.1 u*** u***2: u***_probe_device u*** u***2: configuration #1 chosen from 1 choice u*** u***2: adding 2-0:1.0 (config #1, interface 0) hub 2-0:1.0: u***_probe_interface hub 2-0:1.0: u***_probe_interface - got id drivers/u***/core/inode.c: creating file '001' mu***-hdrc mu***-hdrc.1: USB Host mode controller at e081e800 using PIO, IRQ 19 u***core: registered new interface driver zd1201 u***core: registered new interface driver cdc_ether u***core: registered new interface driver cdc_eem u***core: registered new interface driver dm9601 u***core: registered new interface driver cdc_subset u***core: registered new interface driver cdc_ncm u***core: registered new interface driver cdc_acm u***core: registered new interface driver u***-storage u***core: registered new interface driver u***serial u***core: registered new interface driver u***serial_generic u***serial: USB Serial Driver core u***core: registered new interface driver option u***core: registered new interface driver pl2303 u***core: registered new interface driver u***hid u***hid: USB HID core driver lsu*** Bus 001 Device 001: ID 1d6b:0002 Bus 002 Device 001: ID 1d6b:0002 插U盘启动内核,打印信息中没有识别U盘 我的vbus上拉到5v,id脚接地,请问还有别的问题导致U盘上电不识别吗 |
dingL 发表于 2018-6-21 06:49 先贴下u***部分的原理图把 如果我的回答解决了您的问题,请确认答案,谢谢!:) |
USB0做HOST有问题么? USB做主,硬件要按照下面的参考: http://processors.wiki.ti.com/index.php/AM335x_Schematic_Checklist#USB |
344868615qq 发表于 2018-6-21 07:23 我查查硬件吧,USB1host模式识别U盘了,USB0再看看 |
574 浏览 1 评论
412 浏览 1 评论
609 浏览 2 评论
877 浏览 3 评论
697 浏览 1 评论
166浏览 29评论
1111浏览 23评论
307浏览 20评论
267浏览 14评论
118浏览 13评论
GMT+8, 2025-1-26 14:51 , Processed in 0.805853 second(s), Total 54, Slave 49 queries .
