扫一扫,分享给好友
你好,我想咨询下关于bootcomplete PIN什么情况下才会被拉高,当所有core都从reset中被释放出来后,其中只有两个core的bootcomplete register的bit被置1,其他的bootcomplete register的bit都是0,这种情况bootcomplete PIN会被拉高吗?谢谢。 |
这种情况不会被拉高。
只有当所有core都从reset中被释放出来后,每个core的bootcomplete register的bit都被置位后,bootcomplete pin才会被拉高,bootcomplete register bit置位是在RBL中完成的。请参考bootloader文档。 The RBL uses the BOOTCOMPLETE register, which controls the BOOTCOMPLETE pin status, to indicate the completion of the RBL boot process. The BOOTCOMPLETE pin goes high when the boot complete bits in the BOOTCOMPLETE register for all the cores are set. The RBL sets the bits for each CorePac once it completes the boot process in the CorePac and just before it exits the process. Because of legacy implementation, the BOOTCOMPLETE bit in the register corresponding to the CorePac0 is set by the hardware. http://www.ti.com/lit/ug/sprugy5c/sprugy5c.pdf |
TI的DSP0049在PHS载入值跨过CMPA事件会产生丢波现象
587 浏览 0 评论
958 浏览 1 评论
1222 浏览 0 评论
679 浏览 1 评论
548 浏览 1 评论
437浏览 29评论
1400浏览 23评论
505浏览 20评论
427浏览 14评论
280浏览 13评论
GMT+8, 2025-4-21 14:46 , Processed in 1.042419 second(s), Total 78, Slave 62 queries .
