扫一扫,分享给好友
Hi Zhangjie,
抱歉,您这个问题涵盖面比较广啊... 针对TMS570系列产品,我们有一个非常好的文档: Safety Manual for Hercules™ TMS570LS20x/10x ARM® Safety Critical Microcontrollers www.ti.com/.../spnu507.pdf 建议您阅读这份文档。 这份文档中给出了一些常见的使用方法,如: CPU 自检: The LBIST tests must be triggered by software. User may elect to run all tests, or only a subset of the tests based on the execution time, which can be allocated to the LBIST diagnostic. This time sliced test feature enables the LBIST to be used effectively as a runtime diagnostic with execution of test time slices per safety critical loop as well as a comprehensive test for CPU fault during MCU initialization. Memory PBIST自检: The PBIST tests must be triggered by the software. User can elect to run all algorithms, or only a subset of the algorithms based on the execution time that can be allocated to the PBIST diagnostic. Similarly, the user can elect to run the PBIST on one SRAM or on groups of SRAMs based on the execution time, which can be allocated to the PBIST diagnostic. The PBIST tests are destructive to memory contents, and as such are typically run only at MCU initialization. However, the user has the freedom to initiate the tests at any time when the CPU is operable. |
341 浏览 1 评论
539 浏览 2 评论
781 浏览 3 评论
655 浏览 1 评论
1138 浏览 1 评论
69浏览 29评论
198浏览 23评论
256浏览 20评论
205浏览 14评论
65浏览 13评论
GMT+8, 2024-12-24 22:14 , Processed in 0.901719 second(s), Total 76, Slave 60 queries .
