扫一扫,分享给好友
// Assumes ePWM1 clock is already enabled in InitSysCtrl(); EPwm1Regs.ETSEL.bit.SOCAEN = 1; // Enable SOC on A group EPwm1Regs.ETSEL.bit.SOCASEL = 4; // Select SOC from from CPMA on upcount EPwm1Regs.ETPS.bit.SOCAPRD = 1; // Generate pulse on 1st event EPwm1Regs.CMPA.half.CMPA = 0x0080; // Set compare A value EPwm1Regs.TBPRD = 0xFFFF; // Set period for ePWM1 EPwm1Regs.TBCTL.bit.CTRMODE = 0; // count up and start 以上代码为ADC采样例程,请问多长时间产生一次中断, EPwm1Regs.CMPA.half.CMPA = 0x0080;,是不是第一产生中断的时间为 8*16/60M。之后是不是每次为65536/60M。请问这样理解对不对? |
TI的DSP0049在PHS载入值跨过CMPA事件会产生丢波现象
474 浏览 0 评论
926 浏览 1 评论
1197 浏览 0 评论
653 浏览 1 评论
519 浏览 1 评论
405浏览 29评论
1364浏览 23评论
489浏览 20评论
401浏览 14评论
258浏览 13评论
GMT+8, 2025-4-3 12:48 , Processed in 0.886325 second(s), Total 45, Slave 40 queries .
