扫一扫,分享给好友
UART有8个串口,UART0调试正常(有范例)但配置在UART1/2/3/4/5/6/7都不能正常通讯,不知道是怎么回事。 |
11个回答
不能通讯,你是采用中断还是轮询? 出现的什么错误? 板子是否支持? GPIO口有否复用? |
//***************************************************************************** #include "inc/hw_ints.h" #include "inc/hw_memmap.h" #include "inc/hw_types.h" #include "driverlib/debug.h" #include "driverlib/fpu.h" #include "driverlib/gpio.h" #include "driverlib/interrupt.h" #include "driverlib/sysctl.h" #include "driverlib/uart.h" #include "driverlib/rom.h" #include "grlib/grlib.h" #include "drivers/cfal96x64x16.h" //***************************************************************************** // //! addtogroup example_list //! UART Echo (uart_echo)//! //! This example application utilizes the UART to echo text. The first UART //! (connected to the USB debug virtual serial port on the evaluation board) //! will be configured in 115,200 baud, 8-n-1 mode. All characters received on //! the UART are transmitted back to the UART. // //***************************************************************************** //***************************************************************************** // // The error routine that is called if the driver library encounters an error. // //***************************************************************************** #ifdef DEBUG void __error__(char *pcFilename, unsigned long ulLine) [ ] #endif //***************************************************************************** // // The UART interrupt handler. // //***************************************************************************** void UARTIntHandler(void) [ unsigned long ulStatus; // // Get the interrrupt status. // ulStatus = ROM_UARTIntStatus(UART3_BASE, true); // // Clear the asserted interrupts. // ROM_UARTIntClear(UART3_BASE, ulStatus); // // Loop while there are characters in the receive FIFO. // while(ROM_UARTCharsAvail(UART3_BASE)) [ // // Read the next character from the UART and write it back to the UART. // ROM_UARTCharPutNonBlocking(UART3_BASE, ROM_UARTCharGetNonBlocking(UART3_BASE)); ] ] //***************************************************************************** // // Send a string to the UART. // //***************************************************************************** void UARTSend(const unsigned char *pucBuffer, unsigned long ulCount) [ // // Loop while there are more characters to send. // while(ulCount--) [ // // Write the next character to the UART. // ROM_UARTCharPutNonBlocking(UART3_BASE, *pucBuffer++); ] ] //***************************************************************************** // // This example demonstrates how to send a string of data to the UART. // //***************************************************************************** int main(void) [ tRectangle sRect; tContext sContext; // // The FPU should be enabled because some compilers will use floating- // point registers, even for non-floating-point code. If the FPU is not // enabled this will cause a fault. This also ensures that floating- // point operations could be added to this application and would work // correctly and use the hardware floating-point unit. Finally, lazy // stacking is enabled for interrupt handlers. This allows floating- // point instructions to be used within interrupt handlers, but at the // expense of extra stack usage. // FPUEnable(); FPULazyStackingEnable(); // // Set the clocking to run directly from the crystal. // ROM_SysCtlClockSet(SYSCTL_SYSDIV_1 | SYSCTL_USE_OSC | SYSCTL_OSC_MAIN | SYSCTL_XTAL_16MHZ); // // Initialize the display driver. // CFAL96x64x16Init(); // // Initialize the graphics context. // GrContextInit(&sContext, &g_sCFAL96x64x16); // // Fill the top part of the screen with blue to create the banner. // sRect.sXMin = 0; sRect.sYMin = 0; sRect.sXMax = GrContextDpyWidthGet(&sContext) - 1; sRect.sYMax = 9; GrContextForegroundSet(&sContext, ClrDarkBlue); GrRectFill(&sContext, &sRect); // // Change foreground for white text. // GrContextForegroundSet(&sContext, ClrWhite); // // Put the application name in the middle of the banner. // GrContextFontSet(&sContext, g_pFontFixed6x8); GrStringDrawCentered(&sContext, "OURS-uart3-echo", -1, GrContextDpyWidthGet(&sContext) / 2, 4, 0); // // Initialize the display and write some instructions. // GrStringDrawCentered(&sContext, "Connect a", -1, GrContextDpyWidthGet(&sContext) / 2, 20, false); GrStringDrawCentered(&sContext, "terminal", -1, GrContextDpyWidthGet(&sContext) / 2, 30, false); GrStringDrawCentered(&sContext, "to UART3.", -1, GrContextDpyWidthGet(&sContext) / 2, 40, false); GrStringDrawCentered(&sContext, "115200,N,8,1", -1, GrContextDpyWidthGet(&sContext) / 2, 50, false); // // Enable the peripherals used by this example. // ROM_SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOC); ROM_SysCtlPeripheralEnable(SYSCTL_PERIPH_UART3); // // Enable processor interrupts. // ROM_IntMasterEnable(); // // Set GPIO G4 and G5 as UART pins. // ROM_GPIOPinTypeUART(GPIO_PORTC_BASE, GPIO_PIN_6 | GPIO_PIN_7); // // Configure the UART for 115,200, 8-N-1 operation. // ROM_UARTConfigSetExpClk(UART3_BASE, ROM_SysCtlClockGet(), 115200, (UART_CONFIG_WLEN_8 | UART_CONFIG_STOP_ONE | UART_CONFIG_PAR_NONE)); // // Enable the UART interrupt. // ROM_IntEnable(INT_UART3); ROM_UARTIntEnable(UART3_BASE, UART_INT_RX | UART_INT_RT); // // Prompt for text to be entered. // UARTSend((unsigned char *)"Please Enter: ", 16); // // Loop forever echoing data through the UART. // while(1) [ ] ] |
wacylee 发表于 2018-6-7 02:09 能进得了中断吗? 建议你看看寄存器对比下器件手册,看看UART3是否在正常工作 |
因为UART0的引脚是默认 UART0模式,但是其他的UART单元所使用的引脚需要通过硬件配置下才能使用。可以添加以下两行代码试下: GPIOPinConfigure(GPIO_PC4_U1RX); GPIOPinConfigure(GPIO_PC5_U1TX); |
PC6和PC7管脚是复用的,所以你需要配置GPIO pin脚的功能 GPIOPinConfigure(GPIO_PC6_U3RX); GPIOPinConfigure(GPIO_PC7_U3TX); |
好的,我试试去,谢谢! |
ROM_SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOC); GPIOPinConfigure(GPIO_PC6_U3RX); GPIOPinConfigure(GPIO_PC7_U3TX); ROM_SysCtlPeripheralEnable(SYSCTL_PERIPH_UART3); 按照您的方法配置了,现在是目标板能发送信号,但接收不了(即:在目标板上复位时,在PC机的串口调试工具里能显示:"please enter:",但PC机端的串口调试工具里点击发送却没有任何反应) |
懒默浅默 发表于 2018-6-7 03:22 OK,太好了,非常感谢您的支持! |
我配置了pin脚还是无法通信,板子reset调试工具什么都无法显示,相同代码配置uart0可以显示。我的代码如下: int main(void) [ char cThisChar; //SysCtlClockSet(SYSCTL_SYSDIV_4|SYSCTL_USE_PLL|SYSCTL_XTAL_16MHZ|SYSCTL_OSC_MAIN); SysCtlClockSet(SYSCTL_SYSDIV_1|SYSCTL_USE_OSC|SYSCTL_OSC_MAIN|SYSCTL_XTAL_16MHZ); SysCtlPeripheralEnable(SYSCTL_PERIPH_UART1); SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOB); GPIOPinConfigure(GPIO_PB0_U1RX); GPIOPinConfigure(GPIO_PB1_U1TX); GPIOPinTypeUART(GPIO_PORTB_BASE,GPIO_PIN_0|GPIO_PIN_1); UARTConfigSetExpClk(UART1_BASE,SysCtlClockGet(),115200,(UART_CONFIG_WLEN_8|UART_CONFIG_STOP_ONE|UART_CONFIG_PAR_NONE)); UARTCharPut(UART1_BASE,'!'); do [ cThisChar=UARTCharGet(UART1_BASE); UARTCharPut(UART1_BASE,cThisChar); ]while ((cThisChar!='n')&&(cThisChar!='r')); return(0); ] |
351 浏览 1 评论
546 浏览 2 评论
790 浏览 3 评论
660 浏览 1 评论
1140 浏览 1 评论
87浏览 29评论
321浏览 23评论
262浏览 20评论
210浏览 14评论
69浏览 13评论
GMT+8, 2024-12-29 01:34 , Processed in 1.069928 second(s), Total 67, Slave 61 queries .
