电子发烧友论坛|
示例中,分别有PRCM_HIB_GPIO2/4/13/17/11/24/26,是不是分别代表gpio2/4/13/17/11/24/26?我这边要通过gpio3/gpio9/gpio22高电平的时候唤醒板子,退出HIB,应该怎么设置这几个值?  |
我这边是通过PRCM_HIB_GPIO4唤醒的,gpio4分别连着gpio3/gpio9和gpio22,怎么在唤醒的时候获取到具体是哪个gpio口唤醒的?
musicalboy 发表于 2018-6-7 02:46 参考如下代码 //**************************************************************************** // //! Enter the HIBernate mode configuring the wakeup timer //! //! param none //! //! This function //! 1. Sets up the wakeup RTC timer //! 2. Enables the RTC //! 3. Enters into HIBernate //! //! return None. // //**************************************************************************** void EnterHIBernate() [ #define SLOW_CLK_FREQ (32*1024) // // Configure the HIB module RTC wake time // MAP_PRCMHibernateIntervalSet(5 * SLOW_CLK_FREQ); // // Enable the HIB RTC // // MAP_PRCMHibernateWakeupSourceEnable(PRCM_HIB_SLOW_CLK_CTR); //------------------------------------------------------------Hib模式下增加GPIO唤醒--------------------------------------------------------------- // PRCMHibernateWakeupSourceEnable入口参数 // PRCM_HIB_SLOW_CLK_CTR -PRCM_HIB_GPIO2 -PRCM_HIB_GPIO4 -PRCM_HIB_GPIO13 -PRCM_HIB_GPIO17 -PRCM_HIB_GPIO11 -PRCM_HIB_GPIO24 -PRCM_HIB_GPIO26 PRCMHibernateWakeupSourceEnable(PRCM_HIB_GPIO13); PRCMHibernateWakeUpGPIOSelect(PRCM_HIB_GPIO13,PRCM_HIB_FALL_EDGE); //按键按下去产生上升沿,松开后产生下降沿!注意入口参数的顺序!!! //------------------------------------------------------------------------------------------------------------------------------------------------ // DBG_PRINT("HIB: Entering HIBernate...nr"); UART_PRINT("Entering HIBnr"); MAP_UtilsDelay(80000); // // powering down SPI Flash to save power // Utils_SpiFlashDeepPowerDown(); // // Enter HIBernate mode // MAP_PRCMHibernateEnter(); ] // set_rtc_as_wk_src(WK_LPDS, LPDS_DUR_SEC, false); //测试LPDS功耗,不使用定时器唤醒,仅使用GPIO唤醒! // set_gpio_as_wk_src(WK_LPDS, GPIO_SRC_WKUP, PRCM_LPDS_FALL_EDGE); //------------------------------------------------------------------注意!!--------------------------------------------------------------------------------------------- // set_gpio_as_wk_src(WK_HIB, GPIO_SRC_WKUP, PRCM_LPDS_FALL_EDGE); //必须设置进入Hib模式下的中断唤醒源,否则无法进入Hib模式 //注意在sl_Stop(10)之前不要启动该语句,否则NWP在sl_Stop(10)之后就自动进入了Hib模式但是唤醒源并没设置OK,直接屏蔽该语句,用EnterHIBernate();即可 // 对应低功耗模式: // e_pm_S0, // CPU & HW modules are functioning at optimal & intended freq Active模式 // e_pm_S1, // CPU is halted, high freq PLL CLK is available to HW modules Sleep模式 // e_pm_S2, // CPUSS is clk gated, Mid freq CLK is availalbe to HW modules DPS模式 // e_pm_S3, // SoC almost pwr off, slow CLK is present & OCRAM is retained LPDS模式 // e_pm_S4 // SOC almost pwr off, slow CLK is present & few regs retained hib模式  |
350 浏览 1 评论
544 浏览 2 评论
789 浏览 3 评论
660 浏览 1 评论
1140 浏览 1 评论
81浏览 29评论
282浏览 23评论
261浏览 20评论
210浏览 14评论
68浏览 13评论
GMT+8, 2024-12-27 17:34 , Processed in 0.898719 second(s), Total 78, Slave 62 queries .
