这是28335的一个ADC的下载例程,但是,我看这个程序时,不知道哪一个是启动ADC的触发源,请帮忙指点一下,谢谢您! FILE: Example_2833xAdcSeqModeTest.c // // tiTLE: DSP2833x ADC Seq Mode Test. // // ASSUMPTIONS: // // This program requires the DSP2833x header files. // // Make sure the CPU clock speed is properly defined in // DSP2833x_Examples.h before compiling this example. // // Connect the signal to be converted to channel A0. // // As supplied, this project is configured for "boot to SARAM" // operation. The 2833x Boot Mode table is shown below. // For information on configuring the boot mode of an eZdsp, // please refer to the documentation included with the eZdsp, // // $Boot_Table: // // GPIO87 GPIO86 GPIO85 GPIO84 // XA15 XA14 XA13 XA12 // PU PU PU PU // ========================================== // 1 1 1 1 Jump to Flash // 1 1 1 0 SCI-A boot // 1 1 0 1 SPI-A boot // 1 1 0 0 I2C-A boot // 1 0 1 1 eCAN-A boot // 1 0 1 0 McBSP-A boot // 1 0 0 1 Jump to XINTF x16 // 1 0 0 0 Jump to XINTF x32 // 0 1 1 1 Jump to OTP // 0 1 1 0 Parallel GPIO I/O boot // 0 1 0 1 Parallel XINTF boot // 0 1 0 0 Jump to SARAM <- "boot to SARAM" // 0 0 1 1 Branch to check boot mode // 0 0 1 0 Boot to flash, bypass ADC cal // 0 0 0 1 Boot to SARAM, bypass ADC cal // 0 0 0 0 Boot to SCI-A, bypass ADC cal // Boot_Table_End$ // // DESCRIPTION: // // Channel A0 is converted forever and logged in a buffer (SampleTable) // // Open a memory window to SampleTable to observe the buffer // RUN for a while and stop and see the table contents. // // Watch Variables: // SampleTable - Log of converted values. // //########################################################################### // // Original source by: S.S. // // $TI Release: DSP2833x/DSP2823x C/C++ Header Files V1.31 $ // $Release Date: August 4, 2009 $ //########################################################################### #include "DSP28x_Project.h" // Device Headerfile and Examples Include File // ADC start parameters #if (CPU_FRQ_150MHZ) // Default - 150 MHz SYSCLKOUT #define ADC_MODCLK 0x3 // HSPCLK = SYSCLKOUT/2*ADC_MODCLK2 = 150/(2*3) = 25.0 MHz #endif #if (CPU_FRQ_100MHZ) #define ADC_MODCLK 0x2 // HSPCLK = SYSCLKOUT/2*ADC_MODCLK2 = 100/(2*2) = 25.0 MHz #endif #define ADC_CKPS 0x1 // ADC module clock = HSPCLK/2*ADC_CKPS = 25.0MHz/(1*2) = 12.5MHz #define ADC_SHCLK 0xf // S/H width in ADC module periods = 16 ADC clocks #define AVG 1000 // Average sample limit #define ZOFFSET 0x00 // Average Zero offset #define BUF_SIZE 2048 // Sample buffer size // Global variable for this example Uint16 SampleTable[BUF_SIZE]; main() [ Uint16 i; // Step 1. Initialize System Control: // PLL, WatchDog, enable Peripheral Clocks // This example function is found in the DSP2833x_SysCtrl.c file. InitSysCtrl(); // Specific clock setting for this example: EALLOW; SysCtrlRegs.HISPCP.all = ADC_MODCLK; // HSPCLK = SYSCLKOUT/ADC_MODCLK EDIS; // Step 2. Initialize GPIO: // This example function is found in the DSP2833x_Gpio.c file and // illustrates how to set the GPIO to it's default state. // InitGpio(); // Skipped for this example // Step 3. Clear all interrupts and initialize PIE vector table: // Disable CPU interrupts DINT; // Initialize the PIE control registers to their default state. // The default state is all PIE interrupts disabled and flags // are cleared. // This function is found in the DSP2833x_PieCtrl.c file. InitPieCtrl(); // Disable CPU interrupts and clear all CPU interrupt flags: IER = 0x0000; IFR = 0x0000; // Initialize the PIE vector table with pointers to the shell Interrupt // Service Routines (ISR). // This will populate the entire table, even if the interrupt // is not used in this example. This is useful for debug purposes. // The shell ISR routines are found in DSP2833x_DefaultIsr.c. // This function is found in DSP2833x_PieVect.c. InitPieVectTable(); // Step 4. Initialize all the Device Peripherals: // This function is found in DSP2833x_InitPeripherals.c // InitPeripherals(); // Not required for this example InitAdc(); // For this example, init the ADC // Specific ADC setup for this example: AdcRegs.ADCTRL1.bit.ACQ_PS = ADC_SHCLK; AdcRegs.ADCTRL3.bit.ADCCLKPS = ADC_CKPS; AdcRegs.ADCTRL1.bit.SEQ_CASC = 1; // 1 Cascaded mode AdcRegs.ADCCHSELSEQ1.bit.CONV00 = 0x0; AdcRegs.ADCTRL1.bit.CONT_RUN = 1; // Setup continuous run // Step 5. User specific code, enable interrupts: // Clear SampleTable for (i=0; i SampleTable = 0; ] // Start SEQ1 AdcRegs.ADCTRL2.all = 0x2000; // Take ADC data and log the in SampleTable array for(;;) [ for (i=0; i while (AdcRegs.ADCST.bit.INT_SEQ1== 0) [] // Wait for interrupt AdcRegs.ADCST.bit.INT_SEQ1_CLR = 1; SampleTable =((AdcRegs.ADCRESULT0>>4) ); ] ] ] //=========================================================================== // No more. //=========================================================================== 这是28335的一个ADC的下载例程,但是,我看这个程序时,不知道哪一个是启动ADC的触发源,请帮忙指点一下,谢谢您! |
AdcRegs.ADCTRL2.all = 0x2000; bit13 是SOC_SEQ1,将它置1可以触发。
592 浏览 1 评论
438 浏览 1 评论
628 浏览 2 评论
921 浏览 3 评论
711 浏览 1 评论
207浏览 29评论
1166浏览 23评论
332浏览 20评论
293浏览 14评论
149浏览 13评论
GMT+8, 2025-2-9 02:46 , Processed in 0.830910 second(s), Total 78, Slave 62 queries .
