TMS320F28069外部20M时钟 内部倍频到80M 外设时钟开启如下 SysCtrlRegs.PCLKCR1.bit.EPWM1ENCLK = 0;//1; // ePWM1 SysCtrlRegs.PCLKCR1.bit.EPWM2ENCLK = 0;//1; // ePWM2 SysCtrlRegs.PCLKCR1.bit.EPWM3ENCLK = 0;//1; // ePWM3 SysCtrlRegs.PCLKCR1.bit.EPWM4ENCLK = 0;//1; // ePWM4 SysCtrlRegs.PCLKCR1.bit.EPWM5ENCLK = 0;//1; // ePWM5 SysCtrlRegs.PCLKCR1.bit.EPWM6ENCLK = 0;//1; // ePWM6 SysCtrlRegs.PCLKCR1.bit.EPWM7ENCLK = 0;//1; // ePWM7 SysCtrlRegs.PCLKCR1.bit.EPWM8ENCLK = 0;//0;//1; // ePWM8 SysCtrlRegs.PCLKCR0.bit.HRPWMENCLK = 0;//1; // HRPWM SysCtrlRegs.PCLKCR0.bit.TBCLKSYNC = 0;//1; // Enable TBCLK within the ePWM SysCtrlRegs.PCLKCR1.bit.EQEP1ENCLK = 0;//1; // eQEP1 SysCtrlRegs.PCLKCR1.bit.EQEP2ENCLK = 0;//1; // eQEP2 SysCtrlRegs.PCLKCR1.bit.ECAP1ENCLK = 0;//1; // eCAP1 SysCtrlRegs.PCLKCR1.bit.ECAP2ENCLK = 1; // eCAP2 SysCtrlRegs.PCLKCR1.bit.ECAP3ENCLK = 0;//1; // eCAP3 SysCtrlRegs.PCLKCR2.bit.HRCAP1ENCLK = 0;//1; // HRCAP1 SysCtrlRegs.PCLKCR2.bit.HRCAP2ENCLK = 0;//1; // HRCAP2 SysCtrlRegs.PCLKCR2.bit.HRCAP3ENCLK = 0;//1; // HRCAP3 SysCtrlRegs.PCLKCR2.bit.HRCAP4ENCLK = 0;//1; // HRCAP4 SysCtrlRegs.PCLKCR0.bit.ADCENCLK = 1; // ADC SysCtrlRegs.PCLKCR3.bit.COMP1ENCLK = 0;//1; // COMP1 SysCtrlRegs.PCLKCR3.bit.COMP2ENCLK = 0;//1; // COMP2 SysCtrlRegs.PCLKCR3.bit.COMP3ENCLK = 0;//1; // COMP3 SysCtrlRegs.PCLKCR3.bit.CPUtiMER0ENCLK = 1; // CPU Timer 0 SysCtrlRegs.PCLKCR3.bit.CPUTIMER1ENCLK = 1; // CPU Timer 1 SysCtrlRegs.PCLKCR3.bit.CPUTIMER2ENCLK = 1; // CPU Timer 2 SysCtrlRegs.PCLKCR3.bit.DMAENCLK = 1; // DMA SysCtrlRegs.PCLKCR3.bit.CLA1ENCLK = 1; // CLA1 SysCtrlRegs.PCLKCR3.bit.USB0ENCLK = 0;//1; // USB0 SysCtrlRegs.PCLKCR0.bit.I2CAENCLK = 0;//1; // I2C-A SysCtrlRegs.PCLKCR0.bit.SPIAENCLK = 0;//1; // SPI-A SysCtrlRegs.PCLKCR0.bit.SPIBENCLK = 0;//1; // SPI-B SysCtrlRegs.PCLKCR0.bit.SCIAENCLK = 0;//1; // SCI-A SysCtrlRegs.PCLKCR0.bit.SCIBENCLK = 0;//1; // SCI-B SysCtrlRegs.PCLKCR0.bit.MCBSPAENCLK = 0;//1; // McBSP-A SysCtrlRegs.PCLKCR0.bit.ECANAENCLK=0;//1; // eCAN-A SysCtrlRegs.PCLKCR0.bit.TBCLKSYNC = 0;//1; // Enable TBCLK within the ePWM 其中使用了T0 T1 T2 ECAP2 ADC其他外设时钟都关掉了 但是实际测试下来 CPU功耗为 110毫安左右 我把工作的频率降下来 可是功耗还是不变!! 难道TMS320F28069功耗这么大吗? 有没有办法降低功耗呢? |
6个回答
这个问题可以参考下面的帖子:
www.deyisupport.com/.../7347.aspx 降低功耗主要是下面几个方法,楼主谈到的关闭外设只是其中之一,具体每个外设的耗电可以参考datasheet的Reducing Current Consumption章节 1、将MUX默认设置为GPIO而不是外设,同时将默认的上拉使能disable掉。 2、PCLKCR中关闭不要的外设 3、XCLKOUT也需要关闭,因为它大概会带来15mA的电流 4、楼主可以在上电后把程序copy到RAM,都在RAM中运行然后关闭FLASH,这样可以节约十几mA的电流 降低频率,不用片上的VREG,用外部的。会起到降低功耗的作用,效果不会很明显。 |
Emily1225 发表于 2018-6-6 04:58 你好! 感谢你的帮忙! 我现在把 1、将MUX默认设置为GPIO而不是外设,同时将默认的上拉使能disable掉。 外设只开了 ECAP2 T0 T1 T2 ADC 功耗还是有103mA 请问如何把程序 copy到RAM,都在RAM中运行然后关闭FLASH,有相关例程吗? 能告诉吗? 还有XCLKOUT在哪儿关闭 找不到相应的寄存器 呵呵 |
燕子湖畔 发表于 2018-6-6 05:12 如果将主频降低,功耗没有任何变化,问题应该在硬件上,需要检查一下供电电源问题以及是否有3.3V/5V转换问题。PCB Layout可能也会有影响,但不容易测试,可以尝试飞线来确定。 If a post answers your question, please mark it with the "verify answer" button. |
szbliy 发表于 2018-6-6 05:30 外部晶振是20M 内部倍频到80M 外设开了 ECAP2 T1 T2 T0 ADC 是否28069功耗就是100mA , 数据手册上没看明白数据手册上的I-DDIO (max=140mA )和I-DDA (16毫安 )是什么意思 怎么会有两个电流? 而且还挺大的?你有具体的使用经验数据吗? |
燕子湖畔 发表于 2018-6-6 05:48 应该到不了,我倒没有经验数据,但这两个电流是不同的,一个是GPIO的最大电流,一个是模拟引脚即ADC通道和电源等的最大电流。 If a post answers your question, please mark it with the "verify answer" button. |
功耗的降低也要从电路上进行分析的。可以看看你的电路么
582 浏览 1 评论
419 浏览 1 评论
613 浏览 2 评论
901 浏览 3 评论
705 浏览 1 评论
182浏览 29评论
1144浏览 23评论
316浏览 20评论
277浏览 14评论
129浏览 13评论
GMT+8, 2025-2-1 13:49 , Processed in 1.276838 second(s), Total 54, Slave 49 queries .
