可以读取下面三个内部信号。
可以参考SDK中的adcbufcontinuous和adcsinglechannel例程,按你的需求调整一下ADC channel就可以了。 * # Supported Internal Signals # * Below is a table of internal signals that can be measured using the ADC. * Since we are not connecting to a DIO, there is no DIO to internal signal mapping. The DIO field in the channel lookup table should be marked PIN_UNASSIGNED. * This table can be used to create virtual channel entries in the ADCBufCC26XX_adcChannelLut table in the board file. * * | DIO | Internal Signal CompBInput | * |--------------------|-------------------------------| * | PIN_UNASSIGNED | ADC_COMPB_IN_DCOUPL | * | PIN_UNASSIGNED | ADC_COMPB_IN_VSS | * | PIN_UNASSIGNED | ADC_COMPB_IN_VDDS | |
一种用ADC,精度高点,参考ADC single channel例程
http://dev.ti.com/tirex/#/?link=Software%2FSimpleLink%20CC13x0%20SDK%2FExamples%2FDevelopment%20Tools%2FCC1310%20LaunchPad%2FTI%20Drivers%2Fadcsinglechannel%2FTI-RTOS%2FCCS%20Compiler%2Fadcsinglechannel 另外一种方法用Battery monitor,精度低,只有6位ADC |
615 浏览 1 评论
515 浏览 0 评论
普中科技F28335开发板每次上电复位后数码管都会显示,如何熄灭它?
391 浏览 1 评论
951 浏览 0 评论
TMS320F28377D:新做了以377d为芯片的板子,上电后芯片复位引脚出现方波请问如何解决?
2117 浏览 0 评论
32浏览 3评论
CC3100BOOST使用CC3200lunchXL进行烧录
895浏览 2评论
138浏览 2评论
176浏览 2评论
152浏览 2评论
GMT+8, 2024-9-22 09:49 , Processed in 0.569669 second(s), Total 46, Slave 41 queries .
