频偏会影响调频波的带宽,根据公式Rx BW > 2 * Deviation + 4 * Freq. Error,另外对灵敏度也有影响
Freq. Error这个参数是什么意思,怎么知道 |
Measure the actual frequency on a spectrum analyzer and the delta from the expected frequency gives the frequency error. Eg: if the measured frequency is 2437.3225 Mhz then the frequency error = 2437.3225 – 2437.3125 = 0.01Mhz (10 Khz). For accurate measurement set a low span in the spectrum analyzer , like 100Khz and RBW of 100Hz. To convert this to ppm -> (Freq error/expected frequency) * 10^6 -> (0.01/2437.3125) * 10^6 = 4.1 ppm. |
您好,想向您请教一个频偏的问题:频谱仪测试CC2640的0信道单载波,频率偏低50KHz,然后如下程序,在发射一个单载波的情况下,无论我这么调整信道和SET_CCFG_MODE_CONF_XOSC_CAPARRAY_DELTA的值,信道可以在0-39切换,但是每次都偏低50KHz,即不能通过调整内部晶振来调整频偏,请问可能的原因和解决方法是? C:tisimplelinkble_sdk_2_02_01_18examplescc2650emsimple_peripheral static void SimpleBLEPeripheral_init(void) [ ··· HCI_EXT_SetTxPowerCmd(HCI_EXT_TX_POWER_5_DBM); //TX功率5dBm HCI_EXT_ModemTestTxCmd(LL_EXT_TX_UNMODULATED_CARRIER,11); // TX,非调制,0信道 ··· C:titirtos_cc13xx_cc26xx_2_20_01_08productscc26xxware_2_24_02_17393startup_files #ifndef SET_CCFG_MODE_CONF_XOSC_CAP_MOD #define SET_CCFG_MODE_CONF_XOSC_CAP_MOD 0x0 // Apply cap-array delta // #define SET_CCFG_MODE_CONF_XOSC_CAP_MOD 0x1 // Don't apply cap-array delta #endif #ifndef SET_CCFG_MODE_CONF_XOSC_CAPARRAY_DELTA #define SET_CCFG_MODE_CONF_XOSC_CAPARRAY_DELTA 0x06 // Signed 8-bit value, directly modifying trimmed XOSC cap-array value #endif |
zsqzsqzs 发表于 2018-6-6 06:00 BR.AZ |
832 浏览 1 评论
1071 浏览 0 评论
620 浏览 1 评论
469 浏览 1 评论
663 浏览 2 评论
265浏览 29评论
1228浏览 23评论
360浏览 20评论
337浏览 14评论
204浏览 13评论
GMT+8, 2025-3-6 23:39 , Processed in 0.929239 second(s), Total 84, Slave 68 queries .
