操作系统: Win7 32位 IDE: CCS V5.5 平台: 英蓓特 BeagleBone Black (B4) 利用CCS的ti Resource Explorer ,选择BeagleBone Black 下Generic Examples中的Hello World. [tr]
Error connecting to the target: (Error -1266 @ 0x0) Device is held in reset. Take the device out of reset, and retry the operation. (Emulation package 5.1.232.0) 在配置文件中测试连接: [Start] Execute the command: %ccs_base%/common/uscif/dbgjtag -f %boarddatafile% -rv -o -F inform,logfile=yes -S pathlength -S integrity [Result] -----[Print the board config pathname(s)]------------------------------------ C:UsersZHOUMA~1AppDataLocal.TI4084209646 0 BrdDattestBoard.dat -----[Print the reset-command software log-file]----------------------------- This utility has selected a 100- or 510-class product. This utility will load the adapter 'jioserdesu***.dll'. The library build date was 'Aug 20 2013'. The library build time was '22:56:19'. The library package version is '5.1.232.0'. The library component version is '35.34.40.0'. The controller does not use a programmable FPGA. The controller has a version number of '4' (0x00000004). The controller has an insertion length of '0' (0x00000000). This utility will attempt to reset the controller. This utility has successfully reset the controller. -----[Print the reset-command hardware log-file]----------------------------- The scan-path will be reset by toggling the JTAG TRST signal. The controller is the FTDI FT2232 with USB interface. The link from controller to target is direct (without cable). The software is configured for FTDI FT2232 features. The controller cannot monitor the value on the EMU[0] pin. The controller cannot monitor the value on the EMU[1] pin. The controller cannot control the timing on output pins. The controller cannot control the timing on input pins. The scan-path link-delay has been set to exactly '0' (0x0000). -----[The log-file for the JTAG TCLK output generated from the PLL]---------- There is no hardware for programming the JTAG TCLK frequency. -----[Measure the source and frequency of the final JTAG TCLKR input]-------- There is no hardware for measuring the JTAG TCLK frequency. -----[Perform the standard path-length test on the JTAG IR and DR]----------- This path-length test uses blocks of 512 32-bit words. The test for the JTAG IR instruction path-length succeeded. The JTAG IR instruction path-length is 6 bits. The test for the JTAG DR bypass path-length succeeded. The JTAG DR bypass path-length is 1 bits. -----[Perform the Integrity scan-test on the JTAG IR]------------------------ This test will use blocks of 512 32-bit words. This test will be applied just once. Do a test using 0xFFFFFFFF. Scan tests: 1, skipped: 0, failed: 0 Do a test using 0x00000000. Scan tests: 2, skipped: 0, failed: 0 Do a test using 0xFE03E0E2. Scan tests: 3, skipped: 0, failed: 0 Do a test using 0x01FC1F1D. Scan tests: 4, skipped: 0, failed: 0 Do a test using 0x5533CCAA. Scan tests: 5, skipped: 0, failed: 0 Do a test using 0xAACC3355. Scan tests: 6, skipped: 0, failed: 0 All of the values were scanned correctly. The JTAG IR Integrity scan-test has succeeded. -----[Perform the Integrity scan-test on the JTAG DR]------------------------ This test will use blocks of 512 32-bit words. This test will be applied just once. Do a test using 0xFFFFFFFF. Scan tests: 1, skipped: 0, failed: 0 Do a test using 0x00000000. Scan tests: 2, skipped: 0, failed: 0 Do a test using 0xFE03E0E2. Scan tests: 3, skipped: 0, failed: 0 Do a test using 0x01FC1F1D. Scan tests: 4, skipped: 0, failed: 0 Do a test using 0x5533CCAA. Scan tests: 5, skipped: 0, failed: 0 Do a test using 0xAACC3355. Scan tests: 6, skipped: 0, failed: 0 All of the values were scanned correctly. The JTAG DR Integrity scan-test has succeeded. [End] 请问是什么原因导致无法调试的呢? |
5个回答
CortxA8: Output: **** AM335x BeagleBlack Initialization is in progress ..........
CortxA8: Output: **** AM335x ALL PLL Config for OPP == OPP100 is in progress ......... CortxA8: GEL: Error while executing OnTargetConnect(): Target failed to read 0x44E10040 at (*((unsigned int *) (0x44E10000+0x40))>>22) [beagleboneblack.gel:362] at GetInputClockFrequency() [beagleboneblack.gel:433] at ARM_OPP100_Config() [beagleboneblack.gel:353] at AM335x_BeagleBlack_Initialization() [beagleboneblack.gel:339] at OnTargetConnect() . CortxA8: Trouble Writing Memory Block at 0x800145b0 on Page 0 of Length 0x5c0: (Error -2130 @ 0x800145B0) Unable to access device memory. Verify that the memory address is in valid memory. If error persists, confirm configuration, power-cycle board, and/or try more reliable JTAG settings (e.g. lower TCLK). (Emulation package 5.1.232.0) CortxA8: GEL: File: D:BB Blackhello_BeagleBone_Black_CortexADebughello_BeagleBone_Black_CortexA.out: Load failed. 尝试更换不同的gel,最后总是Load Failed. 什么原因呢? 还是有什么地方操作不正确? 我是用了StarterWare,也不行。 参考过:http://processors.wiki.ti.com/index.php/AM335X_StarterWare_Environment_Setup#Debugging_on_BeagleBone_board_using_CCSv5 |
从调试信息可以看到Jtag已经正常连上了,但是芯片在不断重启,是不是Linux系统已经都跑起来导致的。
应该是Linux系统跑起来了,但是我怎么可以不让linux跑起来呢? 想跑一些裸机程序,熟悉了解一下开发调试环境…… 对AM335X实在很小白~ |
se6238751 发表于 2018-6-4 05:04 如果不想linux启动,可以在BBBlinux启动后,进入boot分区,将MLO删除,再重启就OK了 |
谢谢你,应该是Linux启动造成的。我没有删除MLO,直接通过板子上的按键让它跳过从eMMC引导,然后就可以利用CCS来调试了,谢谢! |
579 浏览 1 评论
416 浏览 1 评论
611 浏览 2 评论
892 浏览 3 评论
702 浏览 1 评论
175浏览 29评论
1138浏览 23评论
315浏览 20评论
274浏览 14评论
121浏览 13评论
GMT+8, 2025-1-30 14:02 , Processed in 0.742298 second(s), Total 53, Slave 48 queries .
