不建议输入输出同时使用,请看TRM上的说明。
Caution must be used when implementing the nRESETIN_OUT as an bi-directional reset signal. Because of the short maximum time allowed using RSTTIME1, it does not supply an adequate debounce time for an external push button circuit. The processor could potentially start running while external components are still in reset. It is recommended that this signal be used as input only (do not connect to other devices as a reset) to implement a push button reset circuit to the AM335x, or an output only to be able to reset other devices after an AM335x reset completes. http://www.ti.com/lit/ug/spruh73p/spruh73p.pdf |
你好, 我疑惑的是,作为 输出或者输入 的话应该如何配置呢? 另外,作为输入时,直接输入低电平复位即可。 那作为输出时,应该如何配置呢,是不是只要配置 RSTTIME1 定时器就可以了? 谢谢! |
351 浏览 1 评论
546 浏览 2 评论
790 浏览 3 评论
660 浏览 1 评论
1140 浏览 1 评论
87浏览 29评论
320浏览 23评论
262浏览 20评论
210浏览 14评论
69浏览 13评论
GMT+8, 2024-12-29 01:06 , Processed in 0.812114 second(s), Total 49, Slave 42 queries .
