扫一扫,分享给好友
[linux-devkit]:~/c> make
/root/CodeSourcery/Sourcery_G++_Lite//bin/ARM-none-linux-gnueabi-gcc -I/usr/local/dvsdk/xdctools_3_16_03_36/packages -I/usr/local/dvsdk/dmai_2_20_00_14/packages -I/usr/local/dvsdk/codec-engine_2_26_01_09/packages -I/usr/local/dvsdk/framework-components_2_25_03_07/packages -I/usr/local/dvsdk/xdais_6_26_00_02/packages -I/usr/local/dvsdk/codecs-dm365_4_00_00_00/packages -DDmai_Device_dm368 -I/usr/local/dvsdk/psp/linux-2.6.32.17-psp03.01.01.38/in -g -Wall -Werror -o hello a.c In file included from /usr/local/dvsdk/codec-engine_2_26_01_09/packages/ti/sdo/ce/Engine.h:57, from /usr/local/dvsdk/codec-engine_2_26_01_09/packages/ti/sdo/ce/CERuntime.h:57, from a.c:11: /usr/local/dvsdk/codec-engine_2_26_01_09/packages/ti/sdo/ce/Server.h:101: error: expected specifier-qualifier-list before 'Int' /usr/local/dvsdk/codec-engine_2_26_01_09/packages/ti/sdo/ce/Server.h:114: error: expected specifier-qualifier-list before 'Char' /usr/local/dvsdk/codec-engine_2_26_01_09/packages/ti/sdo/ce/Server.h:145: error: expected declaration specifiers or '...' before 'Int' /usr/local/dvsdk/codec-engine_2_26_01_09/packages/ti/sdo/ce/Server.h:167: error: expected declaration specifiers or '...' before 'Int' /usr/local/dvsdk/codec-engine_2_26_01_09/packages/ti/sdo/ce/Server.h:196: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'Server_fwriteTrace' /usr/local/dvsdk/codec-engine_2_26_01_09/packages/ti/sdo/ce/Server.h:224: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'Server_getAlgInfo' /usr/local/dvsdk/codec-engine_2_26_01_09/packages/ti/sdo/ce/Server.h:251: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'Server_getCpuLoad' /usr/local/dvsdk/codec-engine_2_26_01_09/packages/ti/sdo/ce/Server.h:275: error: expected declaration specifiers or '...' before 'Int' /usr/local/dvsdk/codec-engine_2_26_01_09/packages/ti/sdo/ce/Server.h:296: error: expected declaration specifiers or '...' before 'Int' /usr/local/dvsdk/codec-engine_2_26_01_09/packages/ti/sdo/ce/Server.h:318: error: expected declaration specifiers or '...' before 'Int' /usr/local/dvsdk/codec-engine_2_26_01_09/packages/ti/sdo/ce/Server.h:324: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'Server_init' /usr/local/dvsdk/codec-engine_2_26_01_09/packages/ti/sdo/ce/Server.h:380: error: expected declaration specifiers or '...' before 'String' /usr/local/dvsdk/codec-engine_2_26_01_09/packages/ti/sdo/ce/Server.h:381: error: expected declaration specifiers or '...' before 'Uint32' /usr/local/dvsdk/codec-engine_2_26_01_09/packages/ti/sdo/ce/Server.h:381: error: expected declaration specifiers or '...' before 'Uint32' /usr/local/dvsdk/codec-engine_2_26_01_09/packages/ti/sdo/ce/Server.h:417: error: expected declaration specifiers or '...' before 'String' /usr/local/dvsdk/codec-engine_2_26_01_09/packages/ti/sdo/ce/Server.h:443: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'Server_setTrace' In file included from /usr/local/dvsdk/codec-engine_2_26_01_09/packages/ti/sdo/ce/Engine.h:58, from /usr/local/dvsdk/codec-engine_2_26_01_09/packages/ti/sdo/ce/CERuntime.h:57, from a.c:11: /usr/local/dvsdk/codec-engine_2_26_01_09/packages/ti/sdo/ce/ipc/Comm.h:50: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'Comm_MSGSIZE' /usr/local/dvsdk/codec-engine_2_26_01_09/packages/ti/sdo/ce/ipc/Comm.h:55: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'Comm_Queue' /usr/local/dvsdk/codec-engine_2_26_01_09/packages/ti/sdo/ce/ipc/Comm.h:73: error: expected declaration specifiers or '...' before '*' token /usr/local/dvsdk/codec-engine_2_26_01_09/packages/ti/sdo/ce/ipc/Comm.h:73: error: expected ')' before 'callHandle' /usr/local/dvsdk/codec-engine_2_26_01_09/packages/ti/sdo/ce/ipc/Comm.h:80: error: expected specifier-qualifier-list before 'Ptr' /usr/local/dvsdk/codec-engine_2_26_01_09/packages/ti/sdo/ce/ipc/Comm.h:93: error: expected specifier-qualifier-list before 'UInt32' /usr/local/dvsdk/codec-engine_2_26_01_09/packages/ti/sdo/ce/ipc/Comm.h:124: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'Comm_locate' /usr/local/dvsdk/codec-engine_2_26_01_09/packages/ti/sdo/ce/ipc/Comm.h:130: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'Comm_alloc' /usr/local/dvsdk/codec-engine_2_26_01_09/packages/ti/sdo/ce/ipc/Comm.h:136: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'Comm_free' /usr/local/dvsdk/codec-engine_2_26_01_09/packages/ti/sdo/ce/ipc/Comm.h:142: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'Comm_put' /usr/local/dvsdk/codec-engine_2_26_01_09/packages/ti/sdo/ce/ipc/Comm.h:148: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'Comm_get' /usr/local/dvsdk/codec-engine_2_26_01_09/packages/ti/sdo/ce/ipc/Comm.h:154: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'Comm_getMsgSize' /usr/local/dvsdk/codec-engine_2_26_01_09/packages/ti/sdo/ce/ipc/Comm.h:160: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'Comm_getSrcQueue' /usr/local/dvsdk/codec-engine_2_26_01_09/packages/ti/sdo/ce/ipc/Comm.h:166: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'Comm_setSrcQueue' /usr/local/dvsdk/codec-engine_2_26_01_09/packages/ti/sdo/ce/ipc/Comm.h:172: error: expected ')' before 'queueName' /usr/local/dvsdk/codec-engine_2_26_01_09/packages/ti/sdo/ce/ipc/Comm.h:179: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'Comm_delete' /usr/local/dvsdk/codec-engine_2_26_01_09/packages/ti/sdo/ce/ipc/Comm.h:184: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'Comm_init' /usr/local/dvsdk/codec-engine_2_26_01_09/packages/ti/sdo/ce/ipc/Comm.h:189: error: expected '=', ',', ';', 'asm' or '__attribute__' |
3个回答
/root/CodeSourcery/Sourcery_G++_Lite//bin/arm-none-linux-gnueabi-gcc -I/usr/local/dvsdk/xdctools_3_16_03_36/packages -I/usr/local/dvsdk/dmai_2_20_00_14/packages -I/usr/local/dvsdk/codec-engine_2_26_01_09/packages -I/usr/local/dvsdk/framework-components_2_25_03_07/packages -I/usr/local/dvsdk/xdais_6_26_00_02/packages -I/usr/local/dvsdk/codecs-dm365_4_00_00_00/packages -DDmai_Device_dm368 -I/usr/local/dvsdk/psp/linux-2.6.32.17-psp03.01.01.38/include -I/usr/local/dvsdk/psp/linux-2.6.32.17-psp03.01.01.38/arch/arm/include -I/usr/local/dvsdk/psp/linux-2.6.32.17-psp03.01.01.38/arch/arm/mach-davinci/include -include /usr/local/dvsdk/psp/linux-2.6.32.17-psp03.01.01.38/include/linux/autoconf.h -I/usr/local/dvsdk/linuxutils_2_25_05_11/packages -I -DDmai_BuildOs_linux -Dxdc_target_types__=gnu/targets/std.h -I/usr/local/dvsdk/linux-devkit/arm-none-linux-gnueabi/usr/include -Dxdc_target_name__=arm/GCArmv5T -g -Wall -Werror -o hello a.c
In file included from /usr/local/dvsdk/codec-engine_2_26_01_09/packages/ti/sdo/ce/Engine.h:57, from /usr/local/dvsdk/codec-engine_2_26_01_09/packages/ti/sdo/ce/CERuntime.h:57, from a.c:11: /usr/local/dvsdk/codec-engine_2_26_01_09/packages/ti/sdo/ce/Server.h:101: error |
jessica_ma 发表于 2018-5-31 00:24 sr/local/dvsdk/codec-engine_2_26_01_09/packages/ti/sdo/ce/Server.h:101: error: expected specifier-qualifier-list before 'Int' /usr/local/dvsdk/codec-engine_2_26_01_09/packages/ti/sdo/ce/Server.h:114: error: expected specifier-qualifier-list before 'Char' |
jessica_ma 发表于 2018-5-31 00:34 修改路径 OK |
543 浏览 1 评论
391 浏览 1 评论
589 浏览 2 评论
840 浏览 3 评论
690 浏览 1 评论
148浏览 29评论
780浏览 23评论
295浏览 20评论
252浏览 14评论
102浏览 13评论
GMT+8, 2025-1-14 05:14 , Processed in 1.062487 second(s), Total 79, Slave 63 queries .
