扫一扫,分享给好友
使用天漠科技的开源项目产品K7作为开发板(应该是基于beagleboard),omap3530,256M DDR SDRAM,256M nand flash。开发板自带了uboot,linux内核2.6.29和android 2.1系统,运行没有问题。现在希望移植android4.0到开发板上,从google上下载了android4.0.3的源码和3.0.8版本的内核(omap)。使用omap2plus_defconfig配置,选择支持beagleboard,编译内核;使用full-eng编译android4.0.3。
开始是使用开发板自带的2.6.29内核和4.0系统,发现android初始化进程init启动的各种服务都会退出,就怀疑是否是内核版本过低。 换成3.0.8内核和4.0系统,发现还是同样的问题,而且内核挂载android系统时还会出现uncorrectable error的错误(但此错误可以过去)。 最终决定先使用3.0.8内核和android2.1系统进行调试,发现都无法启动到android系统的init进程,log如下,请大牛帮帮忙,万分感谢! Texas Instruments X-Loader 1.41 (Apr 17 2011 - 23:04:37) Starting on with MMC Reading boot sector 170240 Bytes Read from MMC Starting OS Bootloader from MMC... U-Boot 1.3.3-svn505 (Dec 15 2011 - 18:40:59) OMAP3530-GP rev 2, CPU-OPP2 L3-165MHz OMAP3 MID7030 Board + LPDDR/NAND DRAM: 256 MB NAND: 256 MiB Display-bmp: 800 x 480 with 256 colors In: serial Out: serial Err: serial Serial #03aa0004000000000401403b0901a01e rtc : ctrl = 0x00 ; data = 0x00 0x00 0x00 0x01 0x01 0x00 0x00 rtc : ctrl = 0x00 ; data = 0x00 0x00 0x00 0x01 0x01 0x00 0x00 Hit space key to stop autoboot: 3 ... 2 ... 1 ... 0 NAND read: device 0 offset 0x280000, size 0x350000 3473408 bytes read: OK ## Booting kernel from Legacy Image at 80300000 ... Image Name: Linux-3.0.8 Image Type: ARM Linux Kernel Image (uncompressed) Data Size: 3233440 Bytes = 3.1 MB Load Address: 80008000 Entry Point: 80008000 Verifying Checksum ... OK Loading Kernel Image ... OK OK Starting kernel ... Uncompressing Linux... done, booting the kernel. <5>Linux version 3.0.8 (lusan@ubuntu) (gcc version 4.4.3 (GCC) ) #6 Tue May 15 19:11:22 CST 2012 CPU: ARMv7 Processor [411fc083] revision 3 (ARMv7), cr=10c53c7f CPU: VIPT nonaliasing data cache, VIPT nonaliasing instruction cache Machine: OMAP3 Beagle Board <4>Ignoring unrecognised tag 0x54410008 Memory policy: ECC disabled, Data cache writeback <6>OMAP3430/3530 ES3.1 (l2cache iva sgx neon isp ) <6>SRAM: Mapped pa 0x40200000 to va 0xfe400000 size: 0x10000 <7>On node 0 totalpages: 65536 <7>free_area_init_node: node 0, pgdat c0640f54, node_mem_map c0c9b000 <7> Normal zone: 576 pages used for memmap <7> Normal zone: 0 pages reserved <7> Normal zone: 64960 pages, LIFO batch:15 <6>Clocking rate (Crystal/Core/MPU): 26.0/332/600 MHz <6>Reprogramming SDRC clock to 332000000 Hz <7>pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768 <7>pcpu-alloc: [0] 0 Built 1 zonelists in Zone order, mobility grouping on. Total pages: 64960 <5>Kernel command line: console=ttyO2,115200n8 ubi.mtd=4 root=ubi0:rootfs rootfstype=ubifs init=/init androidboot.console=ttyO2 <6>PID hash table entries: 1024 (order: 0, 4096 bytes) <6>Dentry cache hash table entries: 32768 (order: 5, 131072 bytes) <6>Inode-cache hash table entries: 16384 (order: 4, 65536 bytes) <6>Memory: 256MB = 256MB total <5>Memory: 246684k/246684k available, 15460k reserved, 0K highmem <5>Virtual kernel memory layout: vector : 0xffff0000 - 0xffff1000 ( 4 kB) fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB) DMA : 0xff000000 - 0xffe00000 ( 14 MB) vmalloc : 0xd0800000 - 0xf8000000 ( 632 MB) lowmem : 0xc0000000 - 0xd0000000 ( 256 MB) modules : 0xbf000000 - 0xc0000000 ( 16 MB) .init : 0xc0008000 - 0xc0048000 ( 256 kB) .text : 0xc0048000 - 0xc05ea384 (5769 kB) .data : 0xc05ec000 - 0xc064a538 ( 378 kB) .bss : 0xc064a55c - 0xc0c9ae30 (6467 kB) <6>NR_IRQS:410 <6>IRQ: Found an INTC at 0xfa200000 (revision 4.0) with 96 interrupts <6>Total of 96 interrupts on 1 active controller <4>omap_hwmod: gpt12_fck: missing clockdomain for gpt12_fck. <6>OMAP clockevent source: GPTIMER12 at 32768 Hz <6>sched_clock: 32 bits at 32kHz, resolution 30517ns, wraps every 131071999ms <6>Console: colour dummy device 80x30 Lock dependency validator: Copyright (c) 2006 Red Hat, Inc., Ingo Molnar ... MAX_LOCKDEP_SUBCLASSES: 8 ... MAX_LOCK_DEPTH: 48 ... MAX_LOCKDEP_KEYS: 8191 ... CLASSHASH_SIZE: 4096 ... MAX_LOCKDEP_ENTRIES: 16384 ... MAX_LOCKDEP_CHAINS: 32768 ... CHAINHASH_SIZE: 16384 memory used by lock dependency info: 3695 kB per task-struct memory footprint: 1152 bytes <6>Calibrating delay loop... <6>pid_max: default: 32768 minimum: 301 <6>Security Framework initialized <6>Mount-cache hash table entries: 512 <6>CPU: Testing write buffer coherency: ok <6>devtmpfs: initialized <4>omap_hwmod: _populate_mpu_rt_base found no _mpu_rt_va for l4_core <4>omap_hwmod: _populate_mpu_rt_base found no _mpu_rt_va for l4_per <4>omap_hwmod: _populate_mpu_rt_base found no _mpu_rt_va for l4_wkup <4>omap_hwmod: _populate_mpu_rt_base found no _mpu_rt_va for u***hs_ohci <4>omap_hwmod: _populate_mpu_rt_base found no _mpu_rt_va for u***hs_ehci <4>omap_hwmod: i2c1: softreset failed (waited 10000 usec) <4>omap_hwmod: i2c2: softreset failed (waited 10000 usec) <4>omap_hwmod: i2c3: softreset failed (waited 10000 usec) <4>omap_hwmod: am35x_otg_hs: cannot be enabled (3) <6>print_constraints: dummy: <6>NET: Registered protocol family 16 <6>GPMC revision 5.0 <6>OMAP GPIO hardware version 2.5 <6>omap_mux_init: Add partition: #1: core, flags: 0 <6>OMAP3 Beagle Rev: Ax/Bx <6>Found NAND on CS0 <6>Registering NAND on CS0 <7>gpio_request: gpio--22 (DVI reset) status -22 <3>Unable to get DVI reset GPIO <4>------------[ cut here ]------------ <4>WARNING: at arch/arm/mach-omap2/opp.c:86 omap_init_opp_table+0x110/0x214() omap_init_opp_table: round_rate for clock dpll3_ck failed [ [ [ [ [ [ [ [ <4>---[ end trace 1b75b31a2719ed1c ]--- <6>hw-breakpoint: debug architecture 0x4 unsupported. <3>omap_init_gpu: Could not look up gpu <6>OMAP DMA hardware revision 4.0 <6>bio: create slab <5>SCSI subsystem initialized <6>u***core: registered new interface driver u***fs <6>u***core: registered new interface driver hub <6>u***core: registered new device driver u*** <6>omap_i2c omap_i2c.1: bus 1 rev3.12 at 2600 kHz <6>twl4030: PIH (irq 7) chaining IRQs 368..375 <6>twl4030: power (irq 373) chaining IRQs 376..383 <6>twl4030: gpio (irq 368) chaining IRQs 384..401 <6>print_constraints: VMMC1: 1850 <--> 3150 mV at 3000 mV normal standby <6>print_constraints: VDAC: 1800 mV normal standby <6>print_constraints: VDVI: 1800 mV normal standby <6>print_constraints: VSIM: 1800 <--> 3000 mV at 1800 mV normal standby <6>omap_i2c omap_i2c.3: bus 3 rev3.12 at 100 kHz <6>Switching to clocksource 32k_counter <6>Switched to NOHz mode on CPU #0 <6>NET: Registered protocol family 2 <6>IP route cache hash table entries: 2048 (order: 1, 8192 bytes) <6>TCP established hash table entries: 8192 (order: 4, 65536 bytes) <6>TCP bind hash table entries: 8192 (order: 6, 294912 bytes) <6>TCP: Hash tables configured (established 8192 bind 8192) <6>TCP reno registered <6>UDP hash table entries: 128 (order: 1, 10240 bytes) <6>UDP-Lite hash table entries: 128 (order: 1, 10240 bytes) <6>NET: Registered protocol family 1 <6>RPC: Registered named UNIX socket transport module. <6>RPC: Registered udp transport module. <6>RPC: Registered tcp transport module. <6>RPC: Registered tcp NFSv4.1 backchannel transport module. <4>NetWinder Floating Point Emulator V0.97 (double precision) <3>omap_iommu_init: could not look up isp <5>VFS: Disk quotas dquot_6.5.2 Dquot-cache hash table entries: 1024 (order 0, 4096 bytes) <6>JFFS2 version 2.2. (NAND) (SUMMARY) 漏 2001-2006 Red Hat, Inc. <6>msgmni has been set to 481 <6>io scheduler noop registered <6>io scheduler deadline registered <6>io scheduler cfq registered (default) <6>start plist test <6>end plist test <6>Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled <6>omap_uart.0: ttyO0 at MMIO 0x4806a000 (irq = 72) is a OMAP UART0 <6>omap_uart.1: ttyO1 at MMIO 0x4806c000 (irq = 73) is a OMAP UART1 <6>omap_uart.2: ttyO2 at MMIO 0x49020000 (irq = 74) is a OMAP UART2 [ 0.000000] Linux version 3.0.8 (lusan@ubuntu) (gcc version 4.4.3 (GCC) ) #6 Tue May 15 19:11:22 CST 2012 [ 0.000000] CPU: ARMv7 Processor [411fc083] revision 3 (ARMv7), cr=10c53c7f [ 0.000000] CPU: VIPT nonaliasing data cache, VIPT nonaliasing instruction cache [ 0.000000] Machine: OMAP3 Beagle Board [ 0.000000] Ignoring unrecognised tag 0x54410008 [ 0.000000] Memory policy: ECC disabled, Data cache writeback [ 0.000000] OMAP3430/3530 ES3.1 (l2cache iva sgx neon isp ) [ 0.000000] SRAM: Mapped pa 0x40200000 to va 0xfe400000 size: 0x10000 [ 0.000000] Clocking rate (Crystal/Core/MPU): 26.0/332/600 MHz [ 0.000000] Reprogramming SDRC clock to 332000000 Hz [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 64960 [ 0.000000] Kernel command line: console=ttyO2,115200n8 ubi.mtd=4 root=ubi0:rootfs rootfstype=ubifs init=/init androidboot.console=ttyO2 [ 0.000000] PID hash table entries: 1024 (order: 0, 4096 bytes) [ 0.000000] Dentry cache hash table entries: 32768 (order: 5, 131072 bytes) [ 0.000000] Inode-cache hash table entries: 16384 (order: 4, 65536 bytes) [ 0.000000] Memory: 256MB = 256MB total [ 0.000000] Memory: 246684k/246684k available, 15460k reserved, 0K highmem [ 0.000000] Virtual kernel memory layout: [ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB) [ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB) [ 0.000000] DMA : 0xff000000 - 0xffe00000 ( 14 MB) [ 0.000000] vmalloc : 0xd0800000 - 0xf8000000 ( 632 MB) [ 0.000000] lowmem : 0xc0000000 - 0xd0000000 ( 256 MB) [ 0.000000] modules : 0xbf000000 - 0xc0000000 ( 16 MB) [ 0.000000] .init : 0xc0008000 - 0xc0048000 ( 256 kB) [ 0.000000] .text : 0xc0048000 - 0xc05ea384 (5769 kB) [ 0.000000] .data : 0xc05ec000 - 0xc064a538 ( 378 kB) [ 0.000000] .bss : 0xc064a55c - 0xc0c9ae30 (6467 kB) [ 0.000000] NR_IRQS:410 [ 0.000000] IRQ: Found an INTC at 0xfa200000 (revision 4.0) with 96 interrupts [ 0.000000] Total of 96 interrupts on 1 active controller [ 0.000000] omap_hwmod: gpt12_fck: missing clockdomain for gpt12_fck. [ 0.000000] OMAP clockevent source: GPTIMER12 at 32768 Hz [ 0.000000] sched_clock: 32 bits at 32kHz, resolution 30517ns, wraps every 131071999ms [ 0.000000] Console: colour dummy device 80x30 [ 0.000000] Lock dependency validator: Copyright (c) 2006 Red Hat, Inc., Ingo Molnar [ 0.000000] ... MAX_LOCKDEP_SUBCLASSES: 8 [ 0.000000] ... MAX_LOCK_DEPTH: 48 [ 0.000000] ... MAX_LOCKDEP_KEYS: 8191 [ 0.000000] ... CLASSHASH_SIZE: 4096 [ 0.000000] ... MAX_LOCKDEP_ENTRIES: 16384 [ 0.000000] ... MAX_LOCKDEP_CHAINS: 32768 [ 0.000000] ... CHAINHASH_SIZE: 16384 [ 0.000000] memory used by lock dependency info: 3695 kB [ 0.000000] per task-struct memory footprint: 1152 bytes [ 0.051788] Calibrating delay loop... 585.04 BogoMIPS (lpj=2285568) [ 0.091644] pid_max: default: 32768 minimum: 301 [ 0.099060] Security Framework initialized [ 0.104492] Mount-cache hash table entries: 512 [ 0.120910] CPU: Testing write buffer coherency: ok [ 0.140350] devtmpfs: initialized [ 0.195007] omap_hwmod: _populate_mpu_rt_base found no _mpu_rt_va for l4_core [ 0.201232] omap_hwmod: _populate_mpu_rt_base found no _mpu_rt_va for l4_per [ 0.207550] omap_hwmod: _populate_mpu_rt_base found no _mpu_rt_va for l4_wkup [ 0.214294] omap_hwmod: _populate_mpu_rt_base found no _mpu_rt_va for u***hs_ohci [ 0.220825] omap_hwmod: _populate_mpu_rt_base found no _mpu_rt_va for u***hs_ehci [ 0.242370] omap_hwmod: i2c1: softreset failed (waited 10000 usec) [ 0.261596] omap_hwmod: i2c2: softreset failed (waited 10000 usec) [ 0.280822] omap_hwmod: i2c3: softreset failed (waited 10000 usec) [ 0.286529] omap_hwmod: am35x_otg_hs: cannot be enabled (3) [ 0.323699] print_constraints: dummy: [ 0.341491] NET: Registered protocol family 16 [ 0.350341] GPMC revision 5.0 [ 0.396972] OMAP GPIO hardware version 2.5 [ 0.460510] omap_mux_init: Add partition: #1: core, flags: 0 [ 0.508270] OMAP3 Beagle Rev: Ax/Bx [ 0.559631] Found NAND on CS0 [ 0.562164] Registering NAND on CS0 [ 0.573455] Unable to get DVI reset GPIO [ 0.578918] ------------[ cut here ]------------ [ 0.586090] WARNING: at arch/arm/mach-omap2/opp.c:86 omap_init_opp_table+0x110/0x214() [ 0.591400] omap_init_opp_table: round_rate for clock dpll3_ck failed [ 0.593322] Modules linked in: [ 0.601928] [ [ 0.610473] [ [ 0.619110] [ [ 0.627899] [ [ 0.636352] [ [ 0.644561] [ [ 0.652282] [ [ 0.660034] [ [ 0.663940] ---[ end trace 1b75b31a2719ed1c ]--- [ 0.670654] hw-breakpoint: debug architecture 0x4 unsupported. [ 0.713714] omap_init_gpu: Could not look up gpu [ 0.794525] OMAP DMA hardware revision 4.0 [ 1.211425] bio: create slab [ 1.264495] SCSI subsystem initialized [ 1.306976] u***core: registered new interface driver u***fs [ 1.317504] u***core: registered new interface driver hub [ 1.324737] u***core: registered new device driver u*** [ 1.347625] omap_i2c omap_i2c.1: bus 1 rev3.12 at 2600 kHz [ 1.380737] twl4030: PIH (irq 7) chaining IRQs 368..375 [ 1.385681] twl4030: power (irq 373) chaining IRQs 376..383 [ 1.396118] twl4030: gpio (irq 368) chaining IRQs 384..401 [ 1.437683] print_constraints: VMMC1: 1850 <--> 3150 mV at 3000 mV normal standby [ 1.451904] print_constraints: VDAC: 1800 mV normal standby [ 1.466827] print_constraints: VDVI: 1800 mV normal standby [ 1.483703] print_constraints: VSIM: 1800 <--> 3000 mV at 1800 mV normal standby [ 1.500335] omap_i2c omap_i2c.3: bus 3 rev3.12 at 100 kHz [ 1.543029] Switching to clocksource 32k_counter [ 1.552612] Switched to NOHz mode on CPU #0 [ 2.152496] NET: Registered protocol family 2 [ 2.160827] IP route cache hash table entries: 2048 (order: 1, 8192 bytes) [ 2.177032] TCP established hash table entries: 8192 (order: 4, 65536 bytes) [ 2.183929] TCP bind hash table entries: 8192 (order: 6, 294912 bytes) [ 2.193756] TCP: Hash tables configured (established 8192 bind 8192) [ 2.196136] TCP reno registered [ 2.201202] UDP hash table entries: 128 (order: 1, 10240 bytes) [ 2.207733] UDP-Lite hash table entries: 128 (order: 1, 10240 bytes) [ 2.215454] NET: Registered protocol family 1 [ 2.230224] RPC: Registered named UNIX socket transport module. [ 2.234008] RPC: Registered udp transport module. [ 2.237945] RPC: Registered tcp transport module. [ 2.243499] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 2.253936] NetWinder Floating Point Emulator V0.97 (double precision) [ 2.270874] omap_iommu_init: could not look up isp [ 2.471343] VFS: Disk quotas dquot_6.5.2 [ 2.477142] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes) [ 2.504730] JFFS2 version 2.2. (NAND) (SUMMARY) 漏 2001-2006 Red Hat, Inc. [ 2.512329] msgmni has been set to 481 [ 2.529388] io scheduler noop registered [ 2.532928] io scheduler deadline registered [ 2.537445] io scheduler cfq registered (default) [ 2.539520] start plist test [ 2.546600] end plist test [ 2.574310] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled [ 2.610443] omap_uart.0: ttyO0 at MMIO 0x4806a000 (irq = 72) is a OMAP UART0 [ 2.624237] omap_uart.1: ttyO1 at MMIO 0x4806c000 (irq = 73) is a OMAP UART1 [ 2.637390] omap_uart.2: ttyO2 at MMIO 0x49020000 (irq = 74) is a OMAP UART2 <6>console [ttyO2] enabled [ 3.413177] console [ttyO2] enabled <6>brd: module loaded [ 3.599731] brd: module loaded <6>loop: module loaded [ 3.692962] loop: module loaded <3>mtdoops: mtd device (mtddev=name/number) must be supplied [ 3.724792] mtdoops: mtd device (mtddev=name/number) must be supplied <6>omap2-nand driver initializing [ 3.735015] omap2-nand driver initializing <6>ONFI flash detected [ 3.742797] ONFI flash detected <6>NAND device: Manufacturer ID: 0x2c, Chip ID: 0xba (Micron NAND 256MiB 1,8V 16-bit) [ 3.754302] NAND device: Manufacturer ID: 0x2c, Chip ID: 0xba (Micron NAND 256MiB 1,8V 16-bit) <5>Creating 5 MTD partitions on "omap2-nand.0": [ 3.768310] Creating 5 MTD partitions on "omap2-nand.0": <5>0x000000000000-0x000000080000 : "X-Loader" [ 3.778503] 0x000000000000-0x000000080000 : "X-Loader" <5>0x000000080000-0x000000260000 : "U-Boot" [ 3.817993] 0x000000080000-0x000000260000 : "U-Boot" <5>0x000000260000-0x000000280000 : "U-Boot Env" [ 3.853515] 0x000000260000-0x000000280000 : "U-Boot Env" <5>0x000000280000-0x000000680000 : "Kernel" [ 3.887847] 0x000000280000-0x000000680000 : "Kernel" <5>0x000000680000-0x000010000000 : "File System" [ 3.924011] 0x000000680000-0x000010000000 : "File System" <6>OneNAND driver initializing [ 4.073394] OneNAND driver initializing <5>UBI: attaching mtd4 to ubi0 [ 4.091857] UBI: attaching mtd4 to ubi0 <5>UBI: physical eraseblock size: 131072 bytes (128 KiB) [ 4.101501] UBI: physical eraseblock size: 131072 bytes (128 KiB) <5>UBI: logical eraseblock size: 129024 bytes [ 4.112701] UBI: logical eraseblock size: 129024 bytes <5>UBI: smallest flash I/O unit: 2048 [ 4.122283] UBI: smallest flash I/O unit: 2048 <5>UBI: sub-page size: 512 [ 4.131042] UBI: sub-page size: 512 <5>UBI: VID header offset: 512 (aligned 512) [ 4.140930] UBI: VID header offset: 512 (aligned 512) <5>UBI: data offset: 2048 [ 4.150970] UBI: data offset: 2048 <3>uncorrectable error : [ 4.217437] uncorrectable error : <3>uncorrectable error : [ 4.233062] uncorrectable error : <3>uncorrectable error : [ 4.279937] uncorrectable error : <3>uncorrectable error : [ 4.373687] uncorrectable error : <3>uncorrectable error : [ 4.506469] uncorrectable error : <3>uncorrectable error : [ 4.654937] uncorrectable error : <3>uncorrectable error : [ 4.748687] uncorrectable error : <5>UBI: max. sequence number: 5 [ 4.810424] UBI: max. sequence number: 5 <4>UBI warning: print_rsvd_warning: cannot reserve enough PEBs for bad PEB handling, reserved 16, need 19 [ 4.911956] UBI warning: print_rsvd_warning: cannot reserve enough PEBs for bad PEB handling, reserved 16, need 19 <5>UBI: attached mtd4 to ubi0 [ 5.016387] UBI: attached mtd4 to ubi0 <5>UBI: MTD device name: "File System" [ 5.025085] UBI: MTD device name: "File System" <5>UBI: MTD device size: 249 MiB [ 5.035034] UBI: MTD device size: 249 MiB <5>UBI: number of good PEBs: 1993 [ 5.044158] UBI: number of good PEBs: 1993 <5>UBI: number of bad PEBs: 3 [ 5.052703] UBI: number of bad PEBs: 3 <5>UBI: number of corrupted PEBs: 0 [ 5.061004] UBI: number of corrupted PEBs: 0 <5>UBI: max. allowed volumes: 128 [ 5.069488] UBI: max. allowed volumes: 128 <5>UBI: wear-leveling threshold: 4096 [ 5.078216] UBI: wear-leveling threshold: 4096 <5>UBI: number of internal volumes: 1 [ 5.086791] UBI: number of internal volumes: 1 <5>UBI: number of user volumes: 1 [ 5.095062] UBI: number of user volumes: 1 <5>UBI: available PEBs: 0 [ 5.103363] UBI: available PEBs: 0 <5>UBI: total number of reserved PEBs: 1993 [ 5.112182] UBI: total number of reserved PEBs: 1993 <5>UBI: number of PEBs reserved for bad PEB handling: 16 [ 5.122711] UBI: number of PEBs reserved for bad PEB handling: 16 <5>UBI: max/mean erase counter: 2/0 [ 5.132598] UBI: max/mean erase counter: 2/0 <5>UBI: image sequence number: 0 [ 5.140350] UBI: image sequence number: 0 <5>UBI: background thread "ubi_bgt0d" started, PID 491 [ 5.152099] UBI: background thread "ubi_bgt0d" started, PID 491 <6>u***core: registered new interface driver asix [ 5.200439] u***core: registered new interface driver asix <6>u***core: registered new interface driver cdc_ether [ 5.214019] u***core: registered new interface driver cdc_ether <6>u***core: registered new interface driver net1080 [ 5.227447] u***core: registered new interface driver net1080 <6>u***core: registered new interface driver cdc_subset [ 5.240997] u***core: registered new interface driver cdc_subset <6>u***core: registered new interface driver zaurus [ 5.254638] u***core: registered new interface driver zaurus <6>cdc_ncm: 04-Aug-2011 [ 5.262969] cdc_ncm: 04-Aug-2011 <6>u***core: registered new interface driver cdc_ncm [ 5.275268] u***core: registered new interface driver cdc_ncm <6>u***core: registered new interface driver cdc_wdm [ 5.301818] u***core: registered new interface driver cdc_wdm <6>Initializing USB Mass Storage driver... [ 5.311920] Initializing USB Mass Storage driver... <6>u***core: registered new interface driver u***-storage [ 5.327545] u***core: registered new interface driver u***-storage <6>USB Mass Storage support registered. [ 5.337768] USB Mass Storage support registered. <6>u***core: registered new interface driver libusual [ 5.352600] u***core: registered new interface driver libusual <6>u***core: registered new interface driver u***test [ 5.368957] u***core: registered new interface driver u***test <6>mousedev: PS/2 mouse device common for all mice [ 5.401885] mousedev: PS/2 mouse device common for all mice <6>input: gpio-keys as /devices/platform/gpio-keys/input/input0 [ 5.431488] input: gpio-keys as /devices/platform/gpio-keys/input/input0 <6>input: twl4030_pwrbutton as /devices/platform/omap/omap_i2c.1/i2c-1/1-0049/twl4030_pwrbutton/input/input1 [ 5.494293] input: twl4030_pwrbutton as /devices/platform/omap/omap_i2c.1/i2c-1/1-0049/twl4030_pwrbutton/input/input1 <6>twl_rtc twl_rtc: Enabling TWL-RTC. [ 5.530517] twl_rtc twl_rtc: Enabling TWL-RTC. <6>using rtc device, twl_rtc, for alarms[ 5.558685] using rtc device, twl_rtc, for alarms<6>twl_rtc twl_rtc: rtc core: registered twl_rtc as rtc0 [ 5.569671] twl_rtc twl_rtc: rtc core: registered twl_rtc as rtc0 <4>twl_rtc twl_rtc: Cannot enable wakeup for IRQ 379 [ 5.582977] twl_rtc twl_rtc: Cannot enable wakeup for IRQ 379 <6>i2c /dev entries driver [ 5.595794] i2c /dev entries driver <6>Driver for 1-wire Dallas network protocol. [ 5.627655] Driver for 1-wire Dallas network protocol. <6>OMAP Watchdog Timer Rev 0x31: initial timeout 60 sec [ 5.660827] OMAP Watchdog Timer Rev 0x31: initial timeout 60 sec <3>twl4030_wdt twl4030_wdt: Failed to register misc device [ 5.676208] twl4030_wdt twl4030_wdt: Failed to register misc device <4>twl4030_wdt: probe of twl4030_wdt failed with error -16 [ 5.688690] twl4030_wdt: probe of twl4030_wdt failed with error -16 <6>cpuidle: using governor ladder [ 5.701232] cpuidle: using governor ladder <6>cpuidle: using governor menu [ 5.708740] cpuidle: using governor menu <6>u***core: registered new interface driver u***hid [ 5.772491] u***core: registered new interface driver u***hid <6>u***hid: USB HID core driver [ 5.781433] u***hid: USB HID core driver <6>logger: created 256K log 'log_main' [ 5.807159] logger: created 256K log 'log_main' <6>logger: created 256K log 'log_events' [ 5.822113] logger: created 256K log 'log_events' <6>logger: created 256K log 'log_radio' [ 5.837646] logger: created 256K log 'log_radio' <6>logger: created 256K log 'log_system' [ 5.853210] logger: created 256K log 'log_system' <6>oprofile: hardware counters not available [ 5.866119] oprofile: hardware counters not available <6>oprofile: using timer interrupt. [ 5.874969] oprofile: using timer interrupt. <6>TCP cubic registered [ 5.885406] TCP cubic registered <6>Initializing XFRM netlink socket [ 5.892303] Initializing XFRM netlink socket <6>NET: Registered protocol family 17 [ 5.901641] NET: Registered protocol family 17 <6>NET: Registered protocol family 15 [ 5.910888] NET: Registered protocol family 15 <5>Registering the dns_resolver key type [ 5.922210] Registering the dns_resolver key type <6>VFP support v0.3: [ 5.930389] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 1 implementor 41 architecture 3 part 30 variant c rev 1 <6>ThumbEE CPU extension supported. [ 5.946868] ThumbEE CPU extension supported. <4>sr_init: No PMIC hook to init smartreflex [ 6.149108] sr_init: No PMIC hook to init smartreflex <6>smartreflex smartreflex.0: omap_sr_probe: SmartReflex driver initialized [ 6.162322] smartreflex smartreflex.0: omap_sr_probe: SmartReflex driver initialized <6>smartreflex smartreflex.1: omap_sr_probe: SmartReflex driver initialized [ 6.181640] smartreflex smartreflex.1: omap_sr_probe: SmartReflex driver initialized <6>SmartReflex Class3 initialized [ 6.199096] SmartReflex Class3 initialized <6>clock: disabling unused clocks to save power [ 6.420898] clock: disabling unused clocks to save power <6>kmemleak: Kernel memory leak detector initialized [ 6.447540] kmemleak: Kernel memory leak detector initialized <6>kmemleak: Automatic memory scanning thread started [ 6.461486] kmemleak: Automatic memory scanning thread started <4>regulator_init_complete: VDVI: incomplete constraints, leaving on [ 6.474609] regulator_init_complete: VDVI: incomplete constraints, leaving on <4>regulator_init_complete: VDAC: incomplete constraints, leaving on [ 6.488800] regulator_init_complete: VDAC: incomplete constraints, leaving on <6>twl_rtc twl_rtc: setting system clock to 2000-01-01 00:00:00 UTC (946684800) [ 6.505401] twl_rtc twl_rtc: setting system clock to 2000-01-01 00:00:00 UTC (946684800) <6>INFO lusan: kernel_init(): invoke prepare_namespace() [ 6.523620] INFO lusan: kernel_init(): invoke prepare_namespace() INFO lusan: prepare_namespace(): saved_root_name[] is:[ 6.535156] INFO lusan: prepare_namespace(): saved_root_name[] is: ubi0:rootfs ubi0:rootfs <6>INFO lusan: prepare_namespace() invokes mount_block_root() [ 6.549957] INFO lusan: prepare_namespace() invokes mount_block_root() <6>INFO lusan: mount_block_root(): fs_names: ubifs [ 6.561645] INFO lusan: mount_block_root(): fs_names: ubifs <5>UBIFS: recovery needed [ 6.618621] UBIFS: recovery needed <5>UBIFS: recovery completed [ 6.674530] UBIFS: recovery completed <5>UBIFS: mounted UBI device 0, volume 0, name "rootfs" [ 6.683746] UBIFS: mounted UBI device 0, volume 0, name "rootfs" <5>UBIFS: file system size: 253145088 bytes (247212 KiB, 241 MiB, 1962 LEBs) [ 6.697357] UBIFS: file system size: 253145088 bytes (247212 KiB, 241 MiB, 1962 LEBs) <5>UBIFS: journal size: 9033728 bytes (8822 KiB, 8 MiB, 71 LEBs) [ 6.712371] UBIFS: journal size: 9033728 bytes (8822 KiB, 8 MiB, 71 LEBs) <5>UBIFS: media format: w4/r0 (latest is w4/r0) [ 6.725128] UBIFS: media format: w4/r0 (latest is w4/r0) <5>UBIFS: default compressor: lzo [ 6.734527] UBIFS: default compressor: lzo <5>UBIFS: reserved for root: 0 bytes (0 KiB) [ 6.743194] UBIFS: reserved for root: 0 bytes (0 KiB) <6>VFS: Mounted root (ubifs filesystem) on device 0:13. [ 6.759033] VFS: Mounted root (ubifs filesystem) on device 0:13. <6>INFO lusan: do_mount_root() return 0 [ 6.769195] INFO lusan: do_mount_root() return 0 <6>devtmpfs: mounted [ 6.781494] devtmpfs: mounted <6>Freeing init memory: 256K [ 6.788452] Freeing init memory: 256K <6>mmc0: new SD card at address 1234 [ 6.829986] mmc0: new SD card at address 1234 <6>mmcblk0: mmc0:1234 SA02G 1.83 GiB (ro) [ 6.868682] mmcblk0: mmc0:1234 SA02G 1.83 GiB (ro) <6> mmcblk0: p1 [ 6.903625] mmcblk0: p1 <0>Kernel panic - not syncing: Attempted to kill init! [ 8.922729] Kernel panic - not syncing: Attempted to kill init! [ [ 8.936401] [ [ [ 8.951782] [ [ [ 8.967132] [ [ [ 8.984374] [ [ [ 9.002593] [ [ [ 9.019989] [ [ [ 9.036895] [ |
5个回答
建议你参考AM37x的beagleboard-xm的android release, 做porting,kernel选择2.6.37,x-loader,u-boot也做相应的更新。
如果我的回答解决了您的问题,请确认答案,谢谢!:) |
jvwueurw 发表于 2018-5-31 03:52 那Kernel能起来,是否就可以说x-loader和uboot没有问题吧? |
从log看你现在是ubifs的问题 |
尝试使用Yao说的2.6.37内核,发现booting the kernel后就停了,而且也希望内核能升级到3.0,,因此还是使用3.0.8内核+android2.1文件系统调试。 从log看好像是ubifs的问题,可是在使用开发板自带的2.6.29内核时启动android2.1文件系统是没有问题的啊。。。 |
highmagtech 发表于 2018-5-31 04:27 你好我也碰到类似问题 我的qq***加我qq讨论下吗 |
594 浏览 1 评论
447 浏览 1 评论
633 浏览 2 评论
932 浏览 3 评论
714 浏览 1 评论
213浏览 29评论
1174浏览 23评论
336浏览 20评论
299浏览 14评论
155浏览 13评论
GMT+8, 2025-2-12 01:22 , Processed in 0.893576 second(s), Total 51, Slave 46 queries .
