扫一扫,分享给好友
你好!
在搭建IPNC_DM368_IMX104_v2.60.05是出现以下问题: 1、在安装交叉编译工具时:tar x*** mvltools5_0_0801921_update.tar.gz出现如下打印语句: tar: montavista/common/var/cache: Cannot mkdir: No such file or directory tar: montavista/common/var/cache/apt: Cannot mkdir: No such file or directory tar: montavista/common/var/cache/apt/archives: Cannot mkdir: No such file or directory tar: montavista/common/var/cache/apt/archives/partial: Cannot mkdir: No such file or directory tar: montavista/common/var/lib: Cannot mkdir: No such file or directory tar: montavista/common/var/lib/apt: Cannot mkdir: No such file or directory tar: montavista/common/var/lib/apt/lists: Cannot mkdir: No such file or directory tar: montavista/common/var/lib/apt/lists/partial: Cannot mkdir: No such file or directory tar: Exiting with failure status due to previous errors 就停止执行了。还有好多类似的提示“Cannot mkdir: No such file or directory、No such file or directory“打印语句 2在解压IPNC_DM368_IMX104_v2.60.05.tgz是也出现了以下打印语句: tar: ti-davinci/mm/shmem.c: Cannot open: No such file or directory tar: ti-davinci/mm/mremap.c: Cannot open: No such file or directory tar: ti-davinci/mm/rmap.c: Cannot open: No such file or directory tar: ti-davinci/mm/mprotect.c: Cannot open: No such file or directory tar: ti-davinci/mm/filemap_xip.c: Cannot open: No such file or directory tar: ti-davinci/mm/internal.h: Cannot open: No such file or directory tar: ti-davinci/mm/thrash.c: Cannot open: No such file or directory tar: ti-davinci/mm/page_alloc.c: Cannot open: No such file or directory tar: ti-davinci/mm/sparse.c: Cannot open: No such file or directory tar: Exiting with failure status due to previous errors 同样的原因,我只是粘贴了部分,其他语句也是类似这些。 请问这是什么原因啊! |
可能是这两个原因:
1. tar包有问题,不完整 2. 权限导致,如果用的ubuntu,可以试下sudo: # sudo tar zxvf mvltools5_0_0801921_update.tar.gz |
感谢这位大哥!困扰我两天的问题终于解决了!正如大哥所说的是第二个原因。现在环境都已搭建好!目前编译一点问题都没有!再次感激! |
591 浏览 2 评论
581 浏览 1 评论
1034 浏览 1 评论
692 浏览 0 评论
普中科技F28335开发板每次上电复位后数码管都会显示,如何熄灭它?
505 浏览 1 评论
140浏览 20评论
108浏览 14评论
在使用3254进行录音的时候出现一个奇怪的现象,右声道有吱吱声,请教一下,是否是什么寄存器设置存在问题?
115浏览 13评论
TLV320芯片内部自带数字滤波功能,请问linein进来的模拟信号是否是先经过ADC的超采样?
112浏览 12评论
TPA6304-Q1: TPA6304 两片公用一组I2C的话,其中一片配置不成功怎么办
146浏览 10评论
GMT+8, 2024-11-13 12:42 , Processed in 0.424685 second(s), Total 48, Slave 42 queries .
