扫一扫,分享给好友
A8送入yuv420sp的1080P的数据到VideoM3 进行jpeg编码后,然后在传到A8,发现图像有问题,图像是绿的,将jpeg从工具在转换到yuv420sp,用yuv工具看,发现Y分量是正确的,UV分量有问题;哪位高手帮忙看下;
link的流程如下: A8--->IpcFramesOutLink-->videoM3(jpeg编码)->A8 建IpcFramesOutLink的代码如下,link建好后,调用IpcFramesOutLink_putFullVideoFrames 将yuv420sp的数据送入到IpcFramesOutLink: A8SysLinkInfo.numCh = 1; A8SysLinkInfo.chInfo[0].bufType = SYSTEM_BUF_TYPE_VIDFRAME;//0; A8SysLinkInfo.chInfo[0].codingformat = 0; A8SysLinkInfo.chInfo[0].dataFormat = SYSTEM_DF_YUV420SP_UV; A8SysLinkInfo.chInfo[0].memType = SYSTEM_MT_NONtiLEDMEM;//0; A8SysLinkInfo.chInfo[0].startX = 0; A8SysLinkInfo.chInfo[0].startY = 0; A8SysLinkInfo.chInfo[0].width = g_ImageWidth; //1920 A8SysLinkInfo.chInfo[0].height = g_ImageHeight; //1080 A8SysLinkInfo.chInfo[0].scanFormat = SYSTEM_SF_PROGRESSIVE;//1; A8SysLinkInfo.chInfo[0].pitch[0] = g_ImageWidth; A8SysLinkInfo.chInfo[0].pitch[1] = g_ImageWidth; A8SysLinkInfo.chInfo[0].pitch[2] = 0; //link1 create_host_frameout_link(ipcFramesOutHostId, ipcFramesInVideoId, A8SysLinkInfo); create_host_frameout_link函数如下: void create_host_frameout_link(UInt32 ipcFramesOutHostId, UInt32 nextLinkId,System_LinkQueInfo queInfo) [ IpcFramesOutLinkHLOS_CreateParams ipcFramesOutHostPrm; MULTICH_INIT_STRUCT(IpcFramesOutLinkHLOS_CreateParams ,ipcFramesOutHostPrm); ipcFramesOutHostPrm.baseCreateParams.noNotifyMode = FALSE; ipcFramesOutHostPrm.baseCreateParams.notifyNextLink = TRUE; ipcFramesOutHostPrm.baseCreateParams.notifyPrevLink = FALSE; ipcFramesOutHostPrm.baseCreateParams.inQueParams.prevLinkId = SYSTEM_LINK_ID_INVALID; ipcFramesOutHostPrm.baseCreateParams.inQueParams.prevLinkQueId = 0; ipcFramesOutHostPrm.baseCreateParams.outQueParams[0].nextLink = nextLinkId; ipcFramesOutHostPrm.baseCreateParams.numOutQue=1; ipcFramesOutHostPrm.baseCreateParams.notifyProcessLink=FALSE; ipcFramesOutHostPrm.cbFxn = rdk_frames_out_cbfxn; ipcFramesOutHostPrm.cbCtx = NULL; gVdisModuleContext.ipcFramesOutHostId = ipcFramesOutHostId; ipcFramesOutHostPrm.inQueInfo = queInfo ; System_linkCreate(ipcFramesOutHostId, &ipcFramesOutHostPrm, sizeof(ipcFramesOutHostPrm)); ] |
4个回答
是不是哪个参数没有没有设置对呢,还是数据哪个没有对齐吗;
videoM3打印的日志: ENCODE: Create CH0 of 1920*1080 ,pitch=(1920,1920) [PROGRESSIVE] [NON-TILED] |
送终鸡酒 发表于 2018-5-31 00:51 图像偏绿,UV的值应该是全0,有没有检查过在送进编码器之前的UV值,是否正确? |
UV的值不是0,我用yuv工具送入videoM3前的yuv420sp的数据是正确的; |
问题解决了,是送到videoM3时,没有对第2个通道的addr,phyAddr地址进行赋值; |
600 浏览 1 评论
447 浏览 1 评论
634 浏览 2 评论
938 浏览 3 评论
716 浏览 1 评论
213浏览 29评论
1177浏览 23评论
336浏览 20评论
301浏览 14评论
156浏览 13评论
GMT+8, 2025-2-12 21:32 , Processed in 0.861489 second(s), Total 49, Slave 44 queries .
