扫一扫,分享给好友
我的板子可以通过SD启动,启动正常 ,但是通过SD卡烧入NAND 来启动,即使用下面命令后: 1. Flashing 1st stage to NAND from 2nd stage in SD boot mmc rescan 0 mw.b 0x81000000 0xFF 0x20000 fatload mmc 0 0x81000000 u-boot.min.nand nand erase 0x0 0x20000 nand write.i 0x81000000 0x0 0x20000 2 Flashing 2nd stage to NAND from 2nd stage in SD boot mmc rescan 0 mw.b 0x81000000 0xFF 0x60000 fatload mmc 0 0x81000000 u-boot.bin nand erase 0x20000 0x60000 nand write.i 0x81000000 0x20000 0x60000 通过NAND FLASH 启不来了,一直停在 Starting application at 0x81000000 ... 打印信息如下: U-Boot 2010.06 (Oct 18 2015 - 23:17:15) TI8148-GP rev 3.0 ARM clk: 600MHz DDR clk: 400MHz DRAM: 2 GiB NAND: HW ECC BCH8 Selected 256 MiB Using default environment The 2nd stage U-Boot will now be auto-loaded Please do not interrupt the countdown till TI8148_EVM prompt if 2nd stage is already flashed Hit any key to stop autoboot: 0 NAND read: device 0 offset 0x100000, size 0x40000 262144 bytes read: OK ## Starting application at 0x81000000 ... 到底是啥原因,我们选的模式是10011 |
509 浏览 0 评论
普中科技F28335开发板每次上电复位后数码管都会显示,如何熄灭它?
380 浏览 1 评论
939 浏览 0 评论
TMS320F28377D:新做了以377d为芯片的板子,上电后芯片复位引脚出现方波请问如何解决?
2111 浏览 0 评论
TPS55340通电后输入端保险丝烧断,芯片输入和GND之间短路
3857 浏览 4 评论
23浏览 3评论
CC3100BOOST使用CC3200lunchXL进行烧录
887浏览 2评论
135浏览 2评论
170浏览 2评论
148浏览 2评论
GMT+8, 2024-9-20 13:26 , Processed in 0.622766 second(s), Total 45, Slave 40 queries .
