扫一扫,分享给好友
mmcblk0: error -110 sending status comand
mmcblk0: error -110 sending read/write command, response 0x0, card status 0x0 mmcblk0: error -110 transferring data, sector 64, nr 1, card status 0x0 mmcblk0: error -110 requesting status func is mmc_sd_num_wr_blocks, file is drivers/mmc/card/block.c[187] <<<----- end_request: I/O error, dev mmcblk0, sector 64 Buffer I/O error on device mmcblk0p1, logical block 1 lost page write due to I/O error on mmcblk0p1 板子上SD卡只能插入一次,拔出SD卡后 df 查看不发生变化,但是文件不能访问,再次插入SD卡会报错 root@ti81xx:~# df -h Filesystem Size Used Available Use% Mounted on ubi0:rootfs 430.0M 55.7M 374.2M 13% / devtmpfs 225.2M 172.0K 225.0M 0% /dev none 225.3M 0 225.3M 0% /dev/shm tmpfs 16.0M 60.0K 15.9M 0% /var/volatile tmpfs 16.0M 0 16.0M 0% /media/ram /dev/sda 916.9G 67.0G 803.3G 8% /zigsun /dev/mmcblk0p2 7.3G 3.7G 3.3G 53% /media/mmcblk0p2 /dev/mmcblk0p1 69.5M 45.3M 24.2M 65% /media/mmcblk0p1 |
4个回答
手动 umount 拔出后,/dev/mmcblk0p1 /dev/mmcblk0p2 下还是有设备,重新插入还是会报错 |
Luo Yu, IPNC RDK的kernel软件有添加GPIO来判断sd卡的插拔,DM8127/DM385的SD接口和DM8168是类似的。 请参考: http://arago-project.org/git/projects/?p=linux-ipnc-rdk-dm81xx.git;a=commit;h=f14b714cfb14f2cb2d347f18b58eeacb5e38aae2 IPNC : MMC/SD support modifications for DM8127 and DM385 Hardware 1. Uses GPIO to implement the card detect function. 2. Export the GPIO2_16, so we can read the write protection status in our application. |
物是人非aaa 发表于 2018-5-28 09:49 插拔有事件报上来,omap_hsmmc_card_detect 检测sd状态 是正常的,而且不论插拔多少次,都能上报正确状态 检查过 硬件的io 插拔电平变化也是正常的 现在是 拔出SD卡后,/dev 下设备没有消失;第二次插入SD卡后,文件系统就会报错。(手动umount 再mount 现象也是一样的) |
272 浏览 1 评论
1012 浏览 0 评论
612 浏览 1 评论
458 浏览 1 评论
650 浏览 2 评论
244浏览 29评论
1211浏览 23评论
349浏览 20评论
324浏览 14评论
180浏览 13评论
GMT+8, 2025-2-24 13:31 , Processed in 0.935965 second(s), Total 84, Slave 68 queries .
