dm6446_h264enc_02_02_00_02_production目下将工程导入CCS3.3,编译出现以下问题,怎么解决? [Linking...] "D:CCStudio_v3.3C6000cgtoolsbincl6x" -@"Debug.lkf" >> warning: creating output section $build.attributes without SECTIONS specification >> error: relocation overflow occurred at address 0x00006a6c in section '.text:_H264VENC_TI_alloc' of input file 'h264venc_ti_plink.o64P (D:/CCStudio_v3.3/dvsdk_1_01_00_15/c64x_h264enc_production/dm6446_h264enc_02_02_00_02_production/packages/ti/sdo/codecs/h264enc/app/Client/Build/../../../Lib/h264venc_ti.l64P)'. The 29-bit PC-relative displacement 524064758 at this location is too large to fit into the 21-bit PC-Relative field; the destination address is too far away from the instruction. >> error: relocation overflow occurred at address 0x00006138 in section '.text:_H264VENC_TI_free' of input file 'h264venc_ti_plink.o64P (D:/CCStudio_v3.3/dvsdk_1_01_00_15/c64x_h264enc_production/dm6446_h264enc_02_02_00_02_production/packages/ti/sdo/codecs/h264enc/app/Client/Build/../../../Lib/h264venc_ti.l64P)'. The 29-bit PC-relative displacement 524067062 at this location is too large to fit into the 21-bit PC-Relative field; the destination address is too far away from the instruction. >> Compilation failure Build Complete, 3 Errors, 1 Warnings, 0 Remarks. 谢谢! |
根据相关FAQ,编译器版本要求6.1,切换之后问题就解决了
580 浏览 1 评论
418 浏览 1 评论
611 浏览 2 评论
894 浏览 3 评论
704 浏览 1 评论
178浏览 29评论
1142浏览 23评论
315浏览 20评论
276浏览 14评论
125浏览 13评论
GMT+8, 2025-1-31 15:58 , Processed in 0.783200 second(s), Total 45, Slave 40 queries .
