扫一扫,分享给好友
在《TI81XX PSP VPSS Video Driver User Guide》中有介绍:
Application need assign the memroy size when loading ti81xxfb.ko if accessing /dev/fb1 and /dev/fb2 nodes $ insmod ti81xxfb.ko vram=0:XXM,1:YYM,2:ZZM FBDEV Driver FBDEV driver supports set of command line argument for size of vram and debug option. These argument are only specified at the time of inserting the driver since FBDev driver only supports dynamic build. Below is the list of arguments which Fbdev driver supports - Fbdev Driver Command Line ArgumentsArgumentDescriptionvramVRAM allocated memory for a framebuffer, user can individually configure VRAM buffers for each plane/device nodedebugEnable Fbdev driver debug messagingFollowing example shows how to specify size of framebuffer: $ insmod ti81xxfb.ko vram=0:16M,1:16M,2:6M Following example shows how to enable debug of Fbdev: $ insmod ti81xxfb.ko debug=1文档链接: http://processors.wiki.ti.com/index.php/TI81XX_PSP_VPSS_Video_Driver_User_Guide |
574 浏览 1 评论
408 浏览 1 评论
609 浏览 2 评论
866 浏览 3 评论
695 浏览 1 评论
161浏览 29评论
1076浏览 23评论
306浏览 20评论
267浏览 14评论
118浏览 13评论
GMT+8, 2025-1-25 03:37 , Processed in 0.648115 second(s), Total 43, Slave 38 queries .
