扫一扫,分享给好友
Hi Zhangjie,
请参考TRM的2.6.1 Doze Mode. 设置Doze模式分为4步: 1. Software writes to the flash control registers to put all flash pumps to sleep. 2. Software writes to the clock source disable register (CSDIS) to disable the clock sources that are not needed. 3. Software writes to the clock domain disable register (CDDIS) to disable the GCLK (CPU clock), HCLK (system clock), VCLKP (peripheral VBUS clock), VCLK2 (peripheral VBUS clock2), VCLKA1 (asynchronous peripheral VBUS clock1), and VCLKA2 (asynchronous peripheral VBUS clock2). 4. Software “idles” the ARM core, then stops the core clock. |
唤醒方式有如下几种: Sleep mode supports the following wakeup (return to normal operation) methods: • Any asynchronous wakeup interrupt – RTI interrupt – An external GIO Interrupt – CAN message – SCI or LIN message • Power-on reset or system reset |
testd27 发表于 2018-5-25 02:50 具体的设置可否提供,谢谢 |
163 浏览 0 评论
380 浏览 1 评论
574 浏览 2 评论
823 浏览 3 评论
685 浏览 1 评论
120浏览 29评论
608浏览 23评论
286浏览 20评论
237浏览 14评论
94浏览 13评论
GMT+8, 2025-1-8 05:10 , Processed in 0.705155 second(s), Total 50, Slave 45 queries .
