扫一扫,分享给好友
由于要移植某个东西,需要用到DLIB库,但是发现移植到Z-STACK上之后编译不了,Z-STACK我移植OK的。 错误提示是: Error[e117]: Incompatible runtime models. Module APS specifies that '__SystemLibrary' must be 'CLib', but module AF has the value 'DLib' 单独编译Z-STACK也不能使用DLib库,寻求帮助!!! |
" - Z-Stack has been built and tested with IAR's CLIB library, which provides a light-weight C library which does not support Embedded C++. Use of DLIB is not recommended since Z-Stack is not tested with that library."
小Qhhui 发表于 2018-5-22 03:51 谢谢回答!!! |
493 浏览 1 评论
513 浏览 0 评论
普中科技F28335开发板每次上电复位后数码管都会显示,如何熄灭它?
388 浏览 1 评论
944 浏览 0 评论
TMS320F28377D:新做了以377d为芯片的板子,上电后芯片复位引脚出现方波请问如何解决?
2115 浏览 0 评论
32浏览 3评论
CC3100BOOST使用CC3200lunchXL进行烧录
894浏览 2评论
138浏览 2评论
175浏览 2评论
152浏览 2评论
GMT+8, 2024-9-21 23:32 , Processed in 1.085193 second(s), Total 48, Slave 43 queries .
