扫一扫,分享给好友
威廉希尔官方网站
支持您好:
我使用的硬件平台是AM335X starter kit ,SDK版本使用的是04版本(ti-processor-sdk-linux-am335x-evm-04.00.00.04-Linux-x86-Install.bin)官网上最新的SDK,现在编译了uboot和kernel,现在想通过nfs挂载文件系统,现在遇到的问题是: [ 6.172931] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready [ 6.202864] IP-Config: Complete: [ 6.206146] device=eth0, hwaddr=c4:ed:ba:8b:76:95, ipaddr=192.168.1.199, mask=255.255.255.0, gw=192.168.1.1 [ 6.216755] host=192.168.1.199, domain=, nis-domain=(none) [ 6.222727] bootserver=192.168.155.0, rootserver=192.168.1.155, rootpath= [ 6.230809] lis3_reg: disabling [ 6.234206] vwl1271: disabling [ 6.237682] ALSA device list: [ 6.240683] No soundcards found. [ 8.330196] VFS: Mounted root (nfs filesystem) on device 0:15. [ 8.337056] devtmpfs: mounted [ 8.341127] Freeing unused kernel memory: 304K (c08b2000 - c08fe000) [ 8.347644] This architecture does not have kernel memory protection. [ 8.640540] systemd[1]: System time before build time, advancing clock. [ 8.691890] systemd[1]: Failed to mount tmpfs at /sys/fs/cgroup: No such file or directory [ 8.703599] systemd[1]: Failed to mount cgroup at /sys/fs/cgroup/systemd: No such file or directory [!!!!!!] Failed to mount API filesystems, freezing. [ 8.753079] systemd[1]: Freezing execution. [ 30.083735] cpsw 4a100000.ethernet eth0: Link is Down [ 153.953531] random: crng init done 挂载被中断了,卡在这里,请问一下这个问题是文件系统没有做好还是?我使用的文件系统是安装SDK的时候的targetNFS文件夹中的。求解答,谢谢! |
已解决!
TI的DSP0049在PHS载入值跨过CMPA事件会产生丢波现象
579 浏览 0 评论
954 浏览 1 评论
1218 浏览 0 评论
678 浏览 1 评论
543 浏览 1 评论
433浏览 29评论
1395浏览 23评论
504浏览 20评论
425浏览 14评论
279浏览 13评论
GMT+8, 2025-4-18 16:23 , Processed in 0.955081 second(s), Total 76, Slave 60 queries .
