扫一扫,分享给好友
默认的systick是10us,在.cfg文件中设置的。
/* ================ Clock configuration ================ */ var Clock = xdc.useModule('ti.sy***ios.knl.Clock'); /* * When using Power and calibrateRCOSC is set to true, this should be set to 10. * The timer used by the Clock module supports TickMode_DYNAMIC. This enables us * to set the tick period to 10 us without generating the overhead of additional * interrupts. * * Note: The calibrateRCOSC parameter is set within the Power configuration * structure in the "Board.c" file. */ Clock.tickPeriod = 10; |
509 浏览 0 评论
普中科技F28335开发板每次上电复位后数码管都会显示,如何熄灭它?
380 浏览 1 评论
939 浏览 0 评论
TMS320F28377D:新做了以377d为芯片的板子,上电后芯片复位引脚出现方波请问如何解决?
2111 浏览 0 评论
TPS55340通电后输入端保险丝烧断,芯片输入和GND之间短路
3857 浏览 4 评论
23浏览 3评论
CC3100BOOST使用CC3200lunchXL进行烧录
888浏览 2评论
135浏览 2评论
170浏览 2评论
148浏览 2评论
GMT+8, 2024-9-20 14:54 , Processed in 0.624998 second(s), Total 43, Slave 38 queries .
