开发板(development board) 开发板由以下器件组装而成: Development board consist of following components:
开发板配件有: development board accessories include:
在启动开发板之前我们需要认识一些接口,并将这些接口正确连接到计算机。这里我先认识MY-IMX6-MB314的接口。 MY-IMX6-MB314正面图(MY-IMX6-MB314 front view)MY-IMX6-MB314背面图(MY-IMX6-MB314 rear view)MY-IMX6-MB314接口(MY-IMX6-MB314 interface)We need to know about some interfaces before boot development board,and correctly connects with computers through these interfaces,here let's start with MY-IMX6-MB314 interfaces.
1)跳到“开发板与计算机的连接”那一节中“关闭电源开关”,“连接电源线”操作。 1)Skip to segment “power supply switch off”,“power supply connection cable”in chapter of "connection between development and computer" for operation. 2)跳到“开发板的启动”那一节中的“为开发板上电”,从那开始继续操作。 2)Skip to segment "power up for development board" in chapter "development board boot",continue the operations with this step. 注意:快速启动方式下,开发板与计算机没有连接,但是在液晶屏上是可以看到系统启动过程的。 开发板与计算机的连接(connection between development board and computer)Note:in mode of fast boot,there is not connection between development board and computer, but system booting status can be viewed on the screen. 由于在很多情况下我们需要连接开发板与计算机,下面内容将描述开发板与计算机的连接方式。 关闭电源开关(power supply switch off)Since we need to connect development board with computer in many cases, please refer the instructions about the job as below. 在连接开发板与计算机之前,我们需要检查开发板电源开关状态,并确保电源开关是断开状态。 We need to check switching status of development board power supply before the connection between development board and computer, to ensure power supply switch in off status. 使开发板电源开关处于断开的方式是:将开发板电源开关J3(开发板正面图的图示28)按到断开状态(—:闭合,O:断开)。 串口线的连接(connection of serial line)线缆连接(cable connection)Ways to make power supply switch in off status:press development board power supply switch J3(icon 28 on front view of development board) to be "off" status(—:closed,O:off) 将串口线一端连接到开发板的P3(开发板正面图的图示12),一端连接到计算机。 Connect one end of serial line to development board P3(icon 12 on front view of development board),another connect to computer. 如果计算机没有串口,则需要自行准备USB转串口线并连接。 If there is no serial port in the computer, you need to prepare USB by yourself to serial line and connect. 如果没有连接串口线,将不能通过串口方式与开发板交互。但是不影响开发板的启动及烧录系统。 串口终端工具配置(serial port terminal tool configuration)If there is no connection of serial line with computer, interaction can't be done with development board via serial port, but no affection on development board booting and burning system. 通过Windows的设备管理器找到计算机上我们使用端口号。 Use Windows's device manager to find the port number we use on the computer. 配置串口终端工具的各参数。 Parameter of configure for serial port terminal tool. SecureCRT & USB串口3 示例配置如下: 网线的连接(Connection of network cable)SecureCRT & USB serial port3 configuration example as below: 将网线一端插入开发板的U12(开发板正面图的图示18),网线另一端插入计算机的网口。 USB下载线的连接(connection of USB download line)Connect one end of network cable with development board U12(icon 18 on front view),another end inserted into lan port of computer. 将USB线一端连接到开发板的J5(开发板正面图的图示22),另外一端插入计算机的USB接口。 连接电源线(connection of power supply cable)Connect one end of USB line with development board J5(icon 22 on front view),another end inserted into USB port of computer. 将电源线一端连接到开发板的J4(开发板正面图的图示29),一端连接电源插座。 开发板的启动(booting of development board)Connect one end of power supply cable with development J4(icon 29 on front view),another end connected with power supply socket. 在“开发板与计算机的连接”中按照顺序进行操作后,我们的开发板与计算机的连接已经完成了。要使开发板启动,我们需要为开发板上电。 为开发板上电(power on development board)After all the operations in "connection between development board and computer"were completed in order,the connection of development board with computer is ready. To boot the board, we need to power on the development board. 将开发板电源开关J3(开发板正面图的图示28)按到闭合状态(—:闭合,O:断开)。 观察启动状况(observe booting condition)U-boot启动动态(U-boot dynamics)Press development board power supply switch J3(icon 28 on front view)to closed status(—:closed,O:off) 会看到液晶屏被点亮,并显示 Freescale 与 明远智睿 的LOGO。 串口终端动态(serial port terminal dynamics)You will see the LCD screen lit up and display Freescale and MYZR’s LOGO. 会看到计算机的串口终端有开发板启动过程中输出的启动过程信息。 内核启动动态(kernel booting dynamics)You can see the information about booting process outputed during the course of development board booting through serial port terminal. 内核启动到一定阶段后,在液晶屏上会看到小企鹅。 系统动态(system dynamics)After the kernel boots at a certain stage, you can see the penguins on the LCD screen. < br > 1)Linux系统(Linux system) 系统启动完成后,在液晶屏上会保持小企鹅的显示。 After the system booting is completed, the little penguin will be still displayed on the LCD screen. 串口输出信息会提示用户按下“Enter” ,这时候按下计算机上的“Enter”即可进入系统。示例如下: The serial port output message prompts the user to press " Enter " , and then press " Enter " on the computer to enter the system . For example: 2)Linux QT系统(Linux QT system) 系统启动完成后,开发板会运行一个QT的示例程序,在液晶屏上可以看到QT示例程序的运行。 After the system booting is completed, the development board will run a QT sample program, and you can see the QT sample program running on the LCD screen. < br > 3)Ubuntu系统(Ubuntu system) 系统启动完成后,在液晶屏上可以看到Ubuntu系统界面。 After the system booting is completed, you can see the interface on the LCD screen. |
迅为RK3568开发板篇OpenHarmony配置HDF驱动控制LED-配置创建私有配置文件
777 浏览 0 评论
飞凌嵌入式ElfBoard ELF 1板卡-初识设备树之Makefile修改
885 浏览 0 评论
飞凌嵌入式-ELFBOARD-ELF 2硬件知识分享之Debug
968 浏览 1 评论
飞凌嵌入式ElfBoard ELF 1板卡-烧录流程介绍之单独更新内核
2528 浏览 1 评论
飞凌嵌入式ElfBoard ELF 1板卡-TF卡烧录流程之烧写过程
1072 浏览 0 评论
GMT+8, 2025-1-12 14:08 , Processed in 0.585172 second(s), Total 65, Slave 48 queries .
