小信号二极管网络限制放大器电路
One response to this dilemma is to limit the signal with a nonlinear transfer function (Figure 1), implemented by adding a few components to a standard application circuit. When a positive or negative peak of the audio input exceeds the turn-on voltage for one of the back-to-back diodes (D1), the diode conducts and attenuates any further increase in the signal amplitude. Resistors R1 and R2 add a series impedance that prevents excessive loading of the audio source. Figure 1. A small-signal diode network limits an amplifier's output voltage. |
GMT+8, 2025-3-5 10:01 , Processed in 1.546869 second(s), Total 41, Slave 31 queries .
