void DisplayFirstA(void)
{ if(U***InOff) { switch(MESCA_ge) { case 0: WriteByteHT1621(0,15,4); break; case 1: WriteByteHT1621(0,6,4); break; case 2: WriteByteHT1621(0,13,4); break; case 3: WriteByteHT1621(0,15,4); break; case 4: WriteByteHT1621(0,6,4); break; case 5: WriteByteHT1621(0,11,4); break; case 6: WriteByteHT1621(0,11,4); break; case 7: WriteByteHT1621(0,14,4); break; case 8: WriteByteHT1621(0,15,4); break; case 9: WriteByteHT1621(0,15,4); break; default :break; } } if(U***InOn) { switch(U***timeMin_ge) { case 0: WriteByteHT1621(0,15,4); break; case 1: WriteByteHT1621(0,6,4); break; case 2: WriteByteHT1621(0,13,4); break; case 3: WriteByteHT1621(0,15,4); break; case 4: WriteByteHT1621(0,6,4); break; case 5: WriteByteHT1621(0,11,4); break; case 6: WriteByteHT1621(0,11,4); break; case 7: WriteByteHT1621(0,14,4); break; case 8: WriteByteHT1621(0,15,4); break; case 9: WriteByteHT1621(0,15,4); break; default :break; } } } void DisplayFirstB(void) { if(U***InOff) { switch(MESCA_ge) { case 0: SendDataHT1621(10,4); break; case 1: SendDataHT1621(0,4); break; case 2: SendDataHT1621(6,4); break; case 3: SendDataHT1621(4,4); break; case 4: SendDataHT1621(12,4); break; case 5: SendDataHT1621(12,4); break; case 6: SendDataHT1621(14,4); break; case 7: SendDataHT1621(0,4); break; case 8: SendDataHT1621(14,4); break; case 9: SendDataHT1621(12,4); break; default :break; } } if(U***InOn) { switch(U***TimeMin_ge) { case 0: SendDataHT1621(10,4); break; case 1: SendDataHT1621(0,4); break; case 2: SendDataHT1621(6,4); break; case 3: SendDataHT1621(4,4); break; case 4: SendDataHT1621(12,4); break; case 5: SendDataHT1621(12,4); break; case 6: SendDataHT1621(14,4); break; case 7: SendDataHT1621(0,4); break; case 8: SendDataHT1621(14,4); break; case 9: SendDataHT1621(12,4); break; default :break; } } } if(QHValue==1) { switch(GLValue) { case 0: LCDDispValue=4; break; case 1: LCDDispValue=5; break; case 2: LCDDispValue=6; break; case 3: LCDDispValue=7; break; default :break; } } if(QHValue==2) { switch(GLValue) { case 0: LCDDispValue=8; break; case 1: LCDDispValue=9; break; case 2: LCDDispValue=10; break; case 3: LCDDispValue=11; break; default :break; } void LCDDisplayEight(void) { // DisplayFirstA(); WriteByteHT1621(0,15,4); LcdCSOff; SendByteHT1621(0xa0,3);//送写命令模式 SendByteHT1621(4,6);//1<<2 // DisplayFirstB(); SendDataHT1621(10,4); SendDataHT1621(DisplayCode[0]+0x10,8); SendDataHT1621(DisplayCode[0],8); BattDisplay(); if(PauseValue) SendDataHT1621(1,4); else SendDataHT1621(0,4); SendDataHT1621(3,4); SendDataHT1621(0,4); SendDataHT1621(0,4); SendDataHT1621(1,4); LcdCSOn; }
7个回答
大神可以回复下液晶怎么驱动的吗
w
w
1407 浏览 0 评论
国产NSI1300D05-DSWVR放大芯片放大增益8.2或41的问题
1472 浏览 0 评论
STM32串口接受中断使用C++STL中的queue导致所有中断失效
8932 浏览 1 评论
3740 浏览 0 评论
STM32配合可编程加密芯片SMEC88ST的防抄板加密方案设计
1644 浏览 0 评论
GMT+8, 2025-3-10 01:01 , Processed in 0.594444 second(s), Total 57, Slave 48 queries .
