扫一扫,分享给好友
P0SKIP = 0x02; // Skip P0.1 which is used for IDA0 P0MDIN &= ~0x02; // Configure P0.1 as an analog pin XBR0 = 0x00; XBR1 = 0x40; // Enable cros***ar and weak pullups REF0CN = 0x03; // Enable internal VREF generator IDA0CN = 0xF0; // Enable IDAC0 for 0.5 mA full-scale output; updated on IDA0H Changed; while(1) { IAD0L = 0x00; IDA0H = Setvalue; //Setvalue 由外部设置 } =================================================================== 上面是程序的一部分,大部分配置参考的官方例程,但是P0.1口电压只能是0V或者3.3V,不是想要的变化值,求路过大神解惑 |
8个回答
P0SKIP = 0x02; // Skip P0.1 which is used for IDA0 P0MDIN &= ~0x02; // Configure P0.1 as an analog pin XBR0 = 0x00; XBR1 = 0x40; // Enable cros***ar and weak pullups REF0CN = 0x03; // Enable internal VREF generator IDA0CN = 0xF0; // Enable IDAC0 for 0.5 mA full-scale output; updated on IDA0H Changed; while(1) { IAD0L = 0x00; IDA0H = Setvalue; //Setvalue 由外部设置 } =================================================================== 同样的程序,F410就可以!求回复 ![]() |
老哥!遇到和你一样的,握爪……正在解决!
老哥!我解决了啦!加电阻!
零知开源——ESP8266结合ICM20948实现高精度姿态解算
1419 浏览 0 评论
嵌入式学习-飞凌嵌入式ElfBoard ELF 1板卡-开发板适配之USB转网络
284 浏览 0 评论
379 浏览 1 评论
758 浏览 2 评论
ESP32开发中,使用ADF环境,系统报错I2C Bus WriteReg Error和I2C Bus ReadReg Error
630 浏览 1 评论
12481 浏览 31 评论
GMT+8, 2025-3-10 18:55 , Processed in 1.073050 second(s), Total 87, Slave 70 queries .
