扫一扫,分享给好友
拉格朗日算法: function s=lag(x,y,t) syms p; n=length(x); s=0; for (k=1:n) la=y(k); for(j=1:k-1) la=la*(p-x(j))/(x(k)-x(j)); end; for(j=k+1:n) la=la*(p-x(j))/(x(k)-x(j)); end; s=s+la; simplify(s); end if(nargin==2) s=subs(s,'p','x'); s=collect(s); s=vpa(s,6); else m=length(t); for i=1:m temp(i)=subs(s,'p','t(i)'); end s=temp; end 主程序: x=[pi/4,pi/6,pi/3,pi/2]; y=[cos(pi/4),cos(pi/6),cos(pi/3),cos(pi/2)]; t=[-40*pi/180,47*pi/180,53*pi/180,79*pi/180,174*pi/180]; disp('角度') du=[-40 47 53 79 174] disp('插值结果') yt=lag(x,y,t) disp('cos函数值') yreal=[cos(-40*pi/180) cos(47*pi/180) cos(53*pi/180) cos(79*pi/180) cos(174*pi/180)]' disp('插值与函数值误差') dy=yt-yreal yt=lag(x,y); ezplot(yt,[-pi/4,pi]) hold on ezplot('cos(t)',[-pi/4,pi]); grid hold off 警告内容: Support of strings that are not valid variable names or define a number will be removed in a future release. To create symbolic expressions, first create symbolic variables and then use operations on them. > In sym>convertExpression (line 1536) In sym>convertChar (line 1441) In sym>tomupad (line 1198) In sym (line 177) In sym/subs>inputchk (line 229) In sym/subs>mupadsubs (line 134) In sym/subs (line 125) In lag (line 23) In lag_main (line 7)
使用simulink进行三相短路故障分析时,各参数应该如何设置
1405 浏览 1 评论
想请教一下图中是simulink的什么模块,需要这种三段斜率函数模块但没找到在哪
1505 浏览 1 评论
2425 浏览 1 评论
200圆!求助大佬给一份VSG并网和离网模式的simulink仿真
2690 浏览 0 评论
MATLAB(3)--矩阵的引用(sub2ind、ind2sub、reshape函数使用)
3518 浏览 0 评论
GMT+8, 2024-12-23 19:33 , Processed in 0.499801 second(s), Total 39, Slave 32 queries .
