C# 串口中断中接收缓冲区会在下次进入时突然变成几百个数据(断点调试看到的),按理说请求一次数据只会接收到19个字节的,请求数据放在一个100ms的定时器里进行
上位机程序: public void port_DataRecived(object sender, SerialDataReceivedEventArgs e) { byte[] r = new byte[serialPort1.BytesToRead]; if (r.Length != 0){ serialPort1.Read(r, 0, r.Length); PortReceivedList.AddRange(r); } while (true){ if (PortReceivedList.Count>19){ if (PortReceivedList[0] == 0x66 && PortReceivedList[1] == 0x66 && PortReceivedList[2] == 0x66){ int CalculateCRC = 0; int CRC = ((int)PortReceivedList[17] << 8) | PortReceivedList[18]; for (int i = 3; i<17; i++) { CalculateCRC += PortReceivedList[i]; } if (CRC == CalculateCRC){ int ID = PortReceivedList[3]; O_DY[ID] = (ushort)(((ushort)(PortReceivedList[5] & 0x0f) << 8) | PortReceivedList[6]); O_DL[ID] = (ushort)(((ushort)(PortReceivedList[7] & 0x0f) << 8) | PortReceivedList[8]); DCDY[ID] = (ushort)(((ushort)(PortReceivedList[9] & 0x0f) << 8) | PortReceivedList[10]); DCDL[ID] = (ushort)(((ushort)(PortReceivedList[11] & 0x0f) << 8) | PortReceivedList[12]); SDDY[ID] = (ushort)(((ushort)(PortReceivedList[13] & 0x0f) << 8) | PortReceivedList[14]); SDDL[ID] = (ushort)(((ushort)(PortReceivedList[15] & 0x0f) << 8) | PortReceivedList[16]); SD[ID] = ((PortReceivedList[4] & 0x01) == 0) ? false : true; YJ[ID] = ((PortReceivedList[4] & 0x02) == 0) ? false : true; GZ[ID] = ((PortReceivedList[4] & 0x04) == 0) ? false : true; myPan(); PortReceivedList.RemoveRange(0, 19); InteractiveSuccessful[nowMachine] = true; }else{ //SendCmd(LastCmd[nowMachine], nowMachine); InteractiveSuccessful[nowMachine] = false; } }else{ PortReceivedList.RemoveRange(0,1); } }else{ break; } } } 下位机程序: void USART1_IRQHandler(void) { if (USART_GetFlagStatus(USART1, USART_FLAG_ORE) != RESET){ USART_ReceiveData(USART1); } if (USART_GetITStatus(USART1, USART_IT_RXNE) != RESET){ static u8 DataCount = 0; r[DataCount] = USART_ReceiveData(USART1); if(r[0] != 0x99){ DataCount = 0; }else{ if( DataCount==1 && r[1]!=0x99 ){ DataCount = 0; } } if(++DataCount>=5){ DataCount = 0; if(r[0]==0x99 && r[1]==0x99){ u8 CalculateCRC = (r[2]+r[3])/2.0+0.5; u8 Cmd = r[3]; if(CalculateCRC == r[4]){ if(r[2]==ID){ u16 Crc = 0,i; if(Cmd&0x02){ ForceStop = 1; }else{ ForceStop = 0; } if(Cmd&0x04){ ForceStart = 1; }else{ ForceStart = 0; } txBuffer[4]++; txBuffer[5] = O_DY>>8; txBuffer[6] = O_DY&0xff; txBuffer[7] = O_DL>>8; txBuffer[8] = O_DL&0xff; txBuffer[9] = DCDY>>8; txBuffer[10] = DCDY&0xff; txBuffer[11] = DCDL>>8; txBuffer[12] = DCDL&0xff; txBuffer[13] = SDDY>>8; txBuffer[14] = SDDY&0xff; txBuffer[15] = SDDL>>8; txBuffer[16] = SDDL&0xff; for(i=3;i<17;i++){ Crc += txBuffer[i]; } txBuffer[17] = Crc>>8; txBuffer[18] = Crc&0xff; SendDatas(); } } } } } USART_ClearITPendingBit(USART1, USART_IT_RXNE); } 上位机发送格式:0x99 0x99 ID Cmd CRC(=(byte)(ID+Cmd)/2.0+0.5) 下位机发送格式:0x66 0x66 0x66 ID State(状态标志) Datas(数据12个) CRCh CRCl |
3个回答
SendDatas();
不知道你这个函数里是怎么实现的,使用查询标志位,是不是判读有问题。如果使用中断发送,但是在你的void USART1_IRQHandler(void)里 我没有看到关于发送的标志位判断。
最佳答案
愚塘霸主 发表于 2017-10-14 11:31 谢谢你的热心解答,之前很久没人回答就没上这个论坛,今天上来才发现。这个问题解决了。是起始位没有判断正确的原因,因为这是多级通讯,一个单片机发送的数据,不光上位机可以接收到另一个单片机也能接收到,起始位没有判断对所以导致单片机一直在发送数据,另一个单片机误判后也一直发送数据,就存在了许多冲突了! 不过真的谢谢了! |
愚塘霸主 发表于 2017-10-14 11:31 void USART1_IRQHandler(void) { if (USART_GetFlagStatus(USART1, USART_FLAG_ORE) != RESET){ USART_ReceiveData(USART1); } if (USART_GetITStatus(USART1, USART_IT_RXNE) != RESET){ static u8 DataCount = 0; r[DataCount] = USART_ReceiveData(USART1); if(r[0] != 0x99){ DataCount = 0; goto a; }else{ if( DataCount==1 && r[1]!=0x99 ){ DataCount = 0; goto a; } } if(++DataCount>=5){ DataCount = 0; if(r[0]==0x99 && r[1]==0x99){ u8 CalculateCRC = (r[2]+r[3])/2.0+0.5; u8 Cmd = r[3]; if(CalculateCRC == r[4]){ if(r[2]==ID){ u16 Crc = 0,i; if(Cmd&0x02){ ForceStop = 1; }else{ ForceStop = 0; } if(Cmd&0x04){ ForceStart = 1; }else{ ForceStart = 0; } O_DY++,O_DL++, DCDY++,DCDL ++, SDDY++,SDDL++; txBuffer[4]++; txBuffer[5] = O_DY>>8; txBuffer[6] = O_DY&0xff; txBuffer[7] = O_DL>>8; txBuffer[8] = O_DL&0xff; txBuffer[9] = DCDY>>8; txBuffer[10] = DCDY&0xff; txBuffer[11] = DCDL>>8; txBuffer[12] = DCDL&0xff; txBuffer[13] = SDDY>>8; txBuffer[14] = SDDY&0xff; txBuffer[15] = SDDL>>8; txBuffer[16] = SDDL&0xff; for(i=3;i<17;i++){ Crc += txBuffer; } txBuffer[17] = Crc>>8; txBuffer[18] = Crc&0xff; SendDatas(); } } } } a: txBuffer[0] = 0x66; } USART_ClearITPendingBit(USART1, USART_IT_RXNE); } 这是我重新写的,这起始位置判断对了就没问题了 |
503 浏览 0 评论
求助一下关于51系列单片机的Timer0的计时问题,TH0、TL0+1的时间是怎么算的?
1756 浏览 1 评论
【RA-Eco-RA4E2-64PIN-V1.0开发板试用】开箱+Keil环境搭建+点灯+点亮OLED
1183 浏览 0 评论
【敏矽微ME32G070开发板免费体验】使用coremark测试敏矽微ME32G070 跑分
1053 浏览 0 评论
【敏矽微ME32G070开发板免费体验】开箱+点灯+点亮OLED
1287 浏览 2 评论
12020 浏览 31 评论
GMT+8, 2024-12-23 16:58 , Processed in 0.434688 second(s), Total 41, Slave 35 queries .
