下面一段程序的功能是检测同步机转子位置,不知思路是什么?
void SynInitPosDetSetPwm(Uint Section) { EALLOW; switch(Section) { case 0: // A+, B- EPwm1Regs.AQCSFRC.all = 0x08; EPwm2Regs.AQCSFRC.all = 0x02; EPwm3Regs.AQCSFRC.all = 0x0A; //1010? break; case 1: // A-, B+ EPwm1Regs.AQCSFRC.all = 0x02; EPwm2Regs.AQCSFRC.all = 0x08; EPwm3Regs.AQCSFRC.all = 0x0A; break; case 2: // B+, C- EPwm1Regs.AQCSFRC.all = 0x0A; EPwm2Regs.AQCSFRC.all = 0x08; EPwm3Regs.AQCSFRC.all = 0x02; break; case 3: // B-, C+ EPwm1Regs.AQCSFRC.all = 0x0A; EPwm2Regs.AQCSFRC.all = 0x02; EPwm3Regs.AQCSFRC.all = 0x08; break; case 4: // A-, C+ EPwm1Regs.AQCSFRC.all = 0x02; EPwm2Regs.AQCSFRC.all = 0x0A; EPwm3Regs.AQCSFRC.all = 0x08; break; case 5: // A+, C- EPwm1Regs.AQCSFRC.all = 0x08; EPwm2Regs.AQCSFRC.all = 0x0A; EPwm3Regs.AQCSFRC.all = 0x02; break; case 6: //恢复PWM模块的寄存器设置 EPwm1Regs.DBCTL.all = 0x0007; //OUT_MODE=11 POLSEL=01 EPwm1Regs.AQCTLA.all = 0x0090; //CAD=10 下降计数若比较相等,则Set: force EPWMxA output high;CAU=01 上升计数若比较相等,Clear: force EPWMxA output low EPwm1Regs.AQCTLB.all = 0x00; EPwm1Regs.AQCSFRC.all = 0x00; EPwm2Regs.DBCTL.all = 0x0007; EPwm2Regs.AQCTLA.all = 0x0090; EPwm2Regs.AQCTLB.all = 0x00; EPwm2Regs.AQCSFRC.all = 0x00; EPwm3Regs.DBCTL.all = 0x0007; EPwm3Regs.AQCTLA.all = 0x0090; EPwm3Regs.AQCTLB.all = 0x00; EPwm3Regs.AQCSFRC.all = 0x00; break; default: //同步机初始位置角检测初始化寄存器 EPwm1Regs.AQCSFRC.all = 0x0A; //CSFB=2--EPWM1B=1 CSFA=2--EPWM1A=1 EPwm1Regs.DBCTL.all = 0; EPwm1Regs.AQCTLA.all = 0x000C; //PRD---Toggle EPWM1A EPwm1Regs.AQCTLB.all = 0x000C; //PRD---Toggle EPWM1B EPwm2Regs.AQCSFRC.all = 0x0A; EPwm2Regs.DBCTL.all = 0; EPwm2Regs.AQCTLA.all = 0x000C; EPwm2Regs.AQCTLB.all = 0x000C; EPwm3Regs.AQCSFRC.all = 0x0A; EPwm3Regs.DBCTL.all = 0; EPwm3Regs.AQCTLA.all = 0x000C; EPwm3Regs.AQCTLB.all = 0x000C; break; } EDIS; } |
还没有解决的话,可以加我微信:xmclby ***
GMT+8, 2025-4-4 11:12 , Processed in 0.415717 second(s), Total 44, Slave 38 queries .
