最近同事问我要树莓派3B的结构尺寸图,然后发现论坛里很多人也在找相关的资料索性,就分享给大家raspberry git地址,里面资料很全
文档资料https://github.com/raspberrypi/documentation 里面包含原理图,机械结构图,外设使用说明等 结构尺寸图:https://github.com/raspberrypi/documentation/blob/master/hardware/raspberrypi/mechanical/Raspberry-Pi-3B-V1.2-Mechanical.pdf 原理图(被阉割了):https://github.com/raspberrypi/documentation/blob/master/hardware/raspberrypi/schematics/Raspberry-Pi-3B-V1.2-Schematics.pdf |
aaaaaaaaaaaaaaaaaaaaaaaa
我找1天没找到BCM2837datasheet.............开源开源,有国产芯片替代么.....等你一万年.......... |
马付林 发表于 2017-9-21 18:03 This is the Broadcom chip used in the Raspberry Pi 3, and in later models of the Raspberry Pi 2. The underlying architecture of the BCM2837 is identical to the BCM2836. The only significant difference is the replacement of the ARMv7 quad core cluster with a quad-core ARM Cortex A53 (ARMv8) cluster. Also see the Raspberry Pi 2's chip BCM2836 and the Raspberry Pi 1's chip BCM2835 摘自GitHub readme,意思是,BCM2837是在BCM2836的基础上修改的,手册参考BCM2836或者2835 |
马付林 发表于 2017-9-21 18:03 BCM2836的链接 请参考 https://github.com/raspberrypi/documentation/blob/master/hardware/raspberrypi/bcm2836/QA7_rev3.4.pdf |
6302 浏览 0 评论
14333 浏览 9 评论
7917 浏览 0 评论
基于Amazon Echo 和 Raspberry Pi 的自动窗帘控制
7258 浏览 1 评论
【下载】《Linux+树莓派玩转智能家居》——亲手进行树莓派应用制作
162399 浏览 374 评论
GMT+8, 2025-4-6 08:30 , Processed in 0.588649 second(s), Total 74, Slave 57 queries .
