1、在资料上看到MSP430的I2C的中断向量的对应:
USCIAB0TX_VECTOR为数据向量(包括发送和接收) USCIAB0RX_VECTOR为状态向量(包括4个状态变化) 请问 (包括发送和接收)(包括4个状态变化)分别指什么?? 下面这是个主机程序 #include unsigned char TXData; unsigned char TXByteCtr; int main(void) { WDTCTL = WDTPW + WDTHOLD; // Stop WDT P1SEL |= BIT6 + BIT7; // Assign I2C pins to USCI_B0 P1SEL2|= BIT6 + BIT7; // Assign I2C pins to USCI_B0 UCB0CTL1 |= UCSWRST; // Enable SW reset UCB0CTL0 = UCMST + UCMODE_3 + UCSYNC; // I2C Master, synchronous mode UCB0CTL1 = UCSSEL_2 + UCSWRST; // Use SMCLK, keep SW reset UCB0BR0 = 12; // fSCL = SMCLK/12 = ~100kHz UCB0BR1 = 0; UCB0I2CSA = 0x48; // Slave Address is 048h UCB0CTL1 &= ~UCSWRST; // Clear SW reset, resume operation IE2 |= UCB0TXIE; // 使能发送中断 TXData = 0x00; // Holds TX data while (1) { TXByteCtr = 1; // Load TX byte counter while (UCB0CTL1 & UCTXSTP); // Ensure stop condition got sent UCB0CTL1 |= UCTR + UCTXSTT; // I2C TX, start condition __bis_SR_register(CPUOFF + GIE); // Enter LPM0 w/ interrupts // Remain in LPM0 until all data // is TX'd TXData++; // Increment data byte } } #pragma vector = USCIAB0TX_VECTOR __interrupt void USCIAB0TX_ISR(void) { if (TXByteCtr) // Check TX byte counter { UCB0TXBUF = TXData; // Load TX buffer TXByteCtr--; // Decrement TX byte counter } else { UCB0CTL1 |= UCTXSTP; // I2C stop condition IFG2 &= ~UCB0TXIFG; // Clear USCI_B0 TX int flag __bic_SR_register_on_exit(CPUOFF); // Exit LPM0 } } 主机发送数据,使能发送中断,使用vector = USCIAB0TX_VECTOR 下面是从机程序 #include volatile unsigned char RXData; int main(void) { WDTCTL = WDTPW + WDTHOLD; // Stop WDT P1SEL |= BIT6 + BIT7; // Assign I2C pins to USCI_B0 P1SEL2|= BIT6 + BIT7; // Assign I2C pins to USCI_B0 UCB0CTL1 |= UCSWRST; // Enable SW reset UCB0CTL0 = UCMODE_3 + UCSYNC; // I2C Slave, synchronous mode UCB0I2COA = 0x48; // Own Address is 048h UCB0CTL1 &= ~UCSWRST; // Clear SW reset, resume operation IE2 |= UCB0RXIE; // 从机使能接收中断 while (1) { __bis_SR_register(CPUOFF + GIE); // Enter LPM0 w/ interrupts __no_operation(); // Set breakpoint >>here<< and read } // RXData } // USCI_B0 Data ISR【 #pragma vector = USCIAB0TX_VECTOR __interrupt void USCIAB0TX_ISR(void) { RXData = UCB0RXBUF; // Get RX data __bic_SR_register_on_exit(CPUOFF); // Exit LPM0 } 从机接收数据,使能接收中断,为什么不使用 #pragma vector = USCIAB0RX_VECTOR而使用#pragma vector = USCIAB0TX_VECTOR??? |
1 个讨论
你正在撰写讨论
《DNK210使用指南 -CanMV版 V1.0》第八章 CanMV IDE初体验
1754 浏览 0 评论
过采样提高12位ADC精度在STM32主控上的实现(附电路及代码)
1189 浏览 1 评论
飞凌嵌入式-ELFBOARD 解决PCB布线时无法捕捉到焊盘中心的问题
1147 浏览 0 评论
Openharmony软件评估指南-米尔瑞芯微RK3568开发板
2072 浏览 0 评论
STM32CUBEMX(7)--移植雅特力AT32F403AVGT(兼容STM32F103VGT6),DAC输出电压
1422 浏览 0 评论
11203 浏览 31 评论
GMT+8, 2024-9-22 07:15 , Processed in 0.402879 second(s), Total 35, Slave 29 queries .
