试着使用ShairPort来做Airplay服务器,测试时使用一个USB声卡来播放声音,完全正常。但是换到板载的Line out接口时候却遇到了问题,死活没有声音播出来,aplay和speaker-test也都不行。 Ubuntu Core 16.04 Alsa 1.0.25 aplay -l似乎显示一切正常 **** List of PLAYBACK Hardware Devices **** card 0: Pcm5102a [Pcm5102a], device 0: Playback pcm5102a-hifi-0 [] Subdevices: 1/1 Subdevice #0: subdevice #0 card 1: sndhdmi [sndhdmi], device 0: SUNXI-HDMIAUDIO sndhdmi-0 [] Subdevices: 1/1 Subdevice #0: subdevice #0 使用amixer命令时,什么都没有返回,而HDMI接口的信息却能正常显示。 root@FriendlyARM:/# amixer root@FriendlyARM:/# amixer -c 0 alsamixer如下 ![]() 另外是aplay -L的信息 root@FriendlyARM:/# aplay -L null Discard all samples (playback) or generate zero samples (capture) sysdefault:CARD=Pcm5102a Pcm5102a, Default Audio Device dmix:CARD=Pcm5102a,DEV=0 Pcm5102a, Direct sample mixing device dsnoop:CARD=Pcm5102a,DEV=0 Pcm5102a, Direct sample snooping device hw:CARD=Pcm5102a,DEV=0 Pcm5102a, Direct hardware device without any conversions plughw:CARD=Pcm5102a,DEV=0 Pcm5102a, Hardware device with all software conversions sysdefault:CARD=sndhdmi sndhdmi, Default Audio Device dmix:CARD=sndhdmi,DEV=0 sndhdmi, Direct sample mixing device dsnoop:CARD=sndhdmi,DEV=0 sndhdmi, Direct sample snooping device hw:CARD=sndhdmi,DEV=0 sndhdmi, Direct hardware device without any conversions plughw:CARD=sndhdmi,DEV=0 sndhdmi, Hardware device with all software conversions 附上接线图,大概是正确的吧… ![]() |
3个回答
大神,我也遇到同样的问题,能分享一下你的固件下载连接吗?
374个成员聚集在这个小组
加入小组NanoPi m3适合刷什么系统,刚接触玩,我刷了一个比较卡
5554 浏览 1 评论
7274 浏览 1 评论
4851 浏览 1 评论
【NanoPC-T4试用体验】4、手把手教你从单片机移植驱动到ARM Linux上
7912 浏览 1 评论
【NanoPC-T4试用体验】NanoPC-T4控制步进电机
24693 浏览 1 评论
5554浏览 1评论
501浏览 0评论
GMT+8, 2025-2-13 06:27 , Processed in 0.612208 second(s), Total 80, Slave 62 queries .
