这个软件好像支持自建元件库吧
最佳答案
谢谢,我正在学习自己建立元件库,但是卡在了模型数据,有点看不懂ti提供的稳压芯片的模型数据了,您有没有好的学习资料可以推荐吗? |
################## 模型数据报告 ################## ============= SPICE 模型 ================= *** *$ * QX2302 Model ***************************************************************************** * (C) Copyright 2013 Texas Instruments Incorporated. All rights reserved. ***************************************************************************** ** This model is designed as an aid for customers of Texas Instruments. ** TI and its licensors and suppliers make no warrenties, either expressed ** or implied, with respect to this model, including the warranties of ** merchantability or fitness for a particular purpose. The model is ** provided solely on an "as is" basis. The entire risk as to its quality ** and performance is with the customer ***************************************************************************** * ** Released by: WEBENCH(R) Design Center, Texas Instruments Inc. * Part: TPS76150 * Date: 01/18/2013 * Model Type: TRANSIENT * Simulator: PSPICE * Simulator Version: 16.2 * EVM Order Number: TPS76xxxEVM-125 * EVM Users Guide: SLVU019 - August 1999 * Datasheet: SLVS178B - DECEMBER 1998 - REVISED MAY 2001 * * Model Version: Final 1.00 * ***************************************************************************** * * Updates: * * Final 1.00 * Release to Web. * ***************************************************************************** * source LDO_Create.php - TPS76150 .SUBCKT TPS76150/TI IN GND EN OUT X1 OUT GND IN IN EN FBK_INT LDO_BASIC + PARAMS: + rinp = 1.000e+7 + rout = 3.500e-1 + psrr = 7.079e-4 + pole = 1.000e+3 + zero = 1.000e+5 + venb = 2.000e+0 + ehys = 1.000e-1 + uvlo = 5.380e+0 + uhys = 1.000e-1 + vref = 1.200e+0 + drop = 1.700e-1 + ilim = 1.250e-1 + ttrn = 1.000e-5 R1 OUT FBK_INT 3.800MEG R2 FBK_INT GND 1.200MEG *$ .SUBCKT ldo_basic out vgnd vin bias enb fbk + PARAMS: + rinp = 1e07 + rout = 0.1 + psrr = 5e-4 + pole = 100 + zero = 10e3 + venb = 1.0 + ehys = 0.1 + uvlo = 2.0 + uhys = 0.1 + vref = 1.20 + drop = 0.25 + ilim = 0.10 + ttrn = 1e-4 R00 vin vxx { rinp } C00 vin vxx { 1/(6.28*rinp*pole) } EX1 vx1 0 VALUE {IF(V(enb, vgnd) + V(egd)*ehys > venb, 1, 0)} RX1 vx1 egd 10 CX1 egd 0 1n EX2 vx2 0 VALUE {IF(V(bias, vgnd) + V(vgd)*uhys > uvlo, 1, 0)} RX2 vx2 vgd 10 CX2 vgd 0 1n E01 v01 vgnd VALUE { + IF(V(egd)>0.51&V(vgd)>0.51, { vref }, 0) } R01 v01 ref {3.333e5*SQRT(ttrn)} C01 ref vgnd {1e-6*SQRT(ttrn)} E02 v02 0 VALUE { + V(ref)*(ABS(V(out)) + 1E-6)/(ABS(V(fbk)) + 1E-6) } R02 v02 des 10 C02 des 0 1n E03 drv 0 VALUE { + MIN(V(des), MAX(V(vin)-drop, 0))} R03 drv vxx { psrr*rinp } C03 drv vxx { 1/(6.28*psrr*rinp*zero) } E04 vyy 0 VALUE { + MIN(V(vxx), V(vzz) + ilim*rout) } R04 vyy vzz { rout } F04 vin vyy V04 1 V04 vzz out 0V .ENDS ldo_basic .ENDS TPS76150/TI ============= 模型模板 ================= x%p %tIN %tGND %tEN %tOUT %m |
这个我不懂 ***I的论坛看看吧 |
2546 浏览 1 评论
电源板:求助小熊A50M2加湿器电源主板有二个稳压二极管坏了
1405 浏览 1 评论
1874 浏览 1 评论
3438 浏览 1 评论
6543 浏览 5 评论
GMT+8, 2025-2-2 16:48 , Processed in 0.556417 second(s), Total 81, Slave 64 queries .
