扫一扫,分享给好友
WARNING): Your design does not contain a Ground (0) net. You may not be able to run analog simulation on this design.?To run analog simulation,?your design must have?at least one?Ground (0) net.?Use at least one PSpice Ground (0) symbol in the design.?Ignore this warning, if this?is a?digital design.
搞不懂啊,画了一个boost电路,但不能仿真,时间不能设置,运行图标也是灰色的... 求助大神 |
没有接地吧,放上ground 0 试试
没有接地
1499 浏览 2 评论
LDO线性稳压器产生了模拟电源与数字电源,模拟电源去给运放供电,他们的地是不是同一个地?
3264 浏览 2 评论
3193 浏览 2 评论
1324 浏览 0 评论
4216 浏览 1 评论
GMT+8, 2025-2-24 16:48 , Processed in 0.561058 second(s), Total 76, Slave 59 queries .
