4.控制5110显示屏显示6x8字符
先看一下LCD5110针脚含义吧(注意:LCD5110的针脚有些不一样的)
TPYBoard的针脚与5110的针脚对应关系如下:
TPYBoard LCD5110 memo
# any Pin => RST Reset pin (0=reset, 1=normal)
# any Pin => CE Chip Enable (0=listen for input, 1=ignore input)
# any Pin => DC Data/Command (0=commands, 1=data)
# MOSI => DIN data flow (Master out, Slave in)
# SCK => CLK SPI clock
# 3V3 or any Pin => VCC 3.3V logic voltage (0=off, 1=on)
# any Pin => LIGHT Light (0=on, 1=off)
# GND => GND
还是看不明白的话,直接上针脚编号吧
Y10 => RST Reset pin (0=reset, 1=normal)
Y11 => CE Chip Enable (0=listen for input, 1=ignore input)
Y9 => DC Data/Command (0=commands, 1=data)
X8 => DIN data flow (Master out, Slave in)
X6 => CLK SPI clock
VCC
Y12 => LIGHT Light (0=on, 1=off)
GND
5.源代码
- import pyb
- from pyb import Pin
- from pyb import timer
- import upcd8544
- from machine import SPI,Pin
- Trig = Pin('X2',Pin.OUT_PP)
- Echo = Pin('X1',Pin.IN)
- num=0
- flag=0
- run=1
- def start(t):
- global flag
- global num
- if(flag==0):
- num=0
- else:
- num=num+1
- def stop(t):
- global run
- if(run==0):
- run=1
- start1=Timer(1,freq=10000,callback=start)
- stop1=Timer(4,freq=2,callback=stop)
- while True:
- if(run==1):
- SPI = pyb.SPI(1) #DIN=>X8-MOSI/CLK=>X6-SCK
- #DIN =>SPI(1).MOSI 'X8' data flow (Master out, Slave in)
- #CLK =>SPI(1).SCK 'X6' SPI clock
- RST = pyb.Pin('Y10')
- CE = pyb.Pin('Y11')
- DC = pyb.Pin('Y9')
- LIGHT = pyb.Pin('Y12')
- lcd_5110 = upcd8544.PCD8544(SPI, RST, CE, DC, LIGHT)
- Trig.value(1)
- pyb.udelay(100)
- Trig.value(0)
- while(Echo.value()==0):
- Trig.value(1)
- pyb.udelay(100)
- Trig.value(0)
- flag=0
- if(Echo.value()==1):
- flag=1
- while(Echo.value()==1):
- flag=1
- if(num!=0):
- #print('num:',num)
- distance=num/10000*34000/2
- print('Distance')
- print(distance,'cm')
- lcd_5110.lcd_write_string('Distance',0,0)
- lcd_5110.lcd_write_string(str(distance),6,1)
- lcd_5110.lcd_write_string('cm',58,1)
- lcd_5110.lcd_write_string('This is a test of Distance',0,2)
- flag=0
- run=0
复制代码
