扫一扫,分享给好友
试试.C(31): error C141: syntax error near 'unsigned'怎么改?
#include #define uchar unsigned char #define uint unsigned int ***it KEY1=P0^0; ***it KEY2=P0^1; ***it KEY3=P0^2; ***it KEY4=P0^3; ***it F4=P3^5; ***it led1=P3^4; uchar code table[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f}; void delayms(uint); void key_scan_pro(); void display(uchar,uchar,uchar); uchar num,num1,num2,min,fj,shi,ge; void main() { TMOD=0X11; TH0=0x3c; TL0=0xaf; TH1=0x3c; TL1=0xaf; EA=1; ET0=1; ET1=1; TR0=1; TR1=1; F4=0; min=5,shi=0,ge=0; while(1) { display(uchar min,shi,ge); key_scan_pro(); } } void diaplay(uchar min,uchar shi,uchar ge) { P1=table{min}; P1=0xff; P2=0xef; delayms(5); P1=0x40; P1=0xff; P2=0xf7; delayms(5); P1=table{shi}; P1=0xff; P2=0xfb; delayms(5); P1=table{ge}; p1=0xff; p2=0xfd; delayms(5); } void delayms(uint xms) { uint i,j; for(i=xms;i>0;i--) for(j=110;j>0;j--); } void T0_time()interrupt 1 { TH0=0x3c; TL0=0xaf; num1++; if(num==4) { num1=0; led1=~led1; } } void T1_time()interrupt 3 { TH0=0x3c; TL0=0xaf; num++; if(num==20) { num=0; num2++; if(num2==60) min--; num2=0; shi=(60-num2)/10; ge=(60-num2)%10 ; if((0==min)&&(shi==0)&&(ge==0)) TR0=0;TR1=0;F4=1;led1=1; } } void key_scan_pro() { if(KEY4==0) { delayms(10); if(KEY4==0) { TRO=0;TR1=0; } while(KEY4==0); delayms(10); If(KEY1==0) delayms(10); If(KEY1==0) min++; while(KEY1==0); delayms(10); If(KEY2==0) delayms(10); If(KEY2==0) shi++; while(KEY2==0); delayms(10); If(KEY3==0) delayms(10); If(KEY3==0) ge++; while(KEY3==0); delayms(10); } } |
3个回答
你求帮忙做什么啊?这求助有点意思啊!
看不懂
你前面两条预编译指令是不是关键字之间有别的字符
202 浏览 0 评论
556 浏览 2 评论
ESP32开发中,使用ADF环境,系统报错I2C Bus WriteReg Error和I2C Bus ReadReg Error
495 浏览 1 评论
在ZYNQ上跑超炫酷GUI!手把手教你移植LVGL到ZYNQ平台!
709 浏览 0 评论
嵌入式学习-飞凌嵌入式ElfBoard ELF 1板卡-开发板适配之FLEXCAN
888 浏览 0 评论
12463 浏览 31 评论
GMT+8, 2025-3-7 04:31 , Processed in 0.391126 second(s), Total 44, Slave 38 queries .
